查看: 4744|回復: 0
倒計時程序 1602液晶從5~0倒計時6秒,到0時計時停止程序停止
ID:76556 發表于 2015-4-10 02:57 | 顯示全部樓層 |閱讀模式
倒計時程序初級——范列
#include<reg51.h>
#define uchar unsigned char
#define uint unsigned int
uchar code xian1[]="you win!";
uchar code xian2[]="I Iove You^-^";
uchar code tishi[]="into the clock";
uchar code ling[]="00";
uchar code shu1[]="1";
uchar code shu2[]="2";
uchar code shu3[]="3";
uchar code shu4[]="4";
uchar code shu5[]="5";
uchar code shu0[]="0";
uchar cc,num1,num2,num3,num4,num5,num6;
sbit rs=P1^0;
sbit rw=P1^1;
sbit e=P1^2;
void timer(uint s)
uint x,c;
for(x=s;x>0;x--)
        for(c=110;c>0;c--);
void zhiling(uchar p)
rs=0;
rw=0;
P2=p;
timer(5);
e=1;
timer(5);
e=0;
void shuju(uchar y)
rs=1;
rw=0;
P2=y;
timer(5);
e=1;
timer(5);
e=0;
void init()
zhiling(0x38);
zhiling(0x0c);
zhiling(0x06);
zhiling(0x01);
void djs()
ET1=1;
TR1=1;
void timerkai()
TMOD=0x11;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
TH1=(65536-50000)/256;
TL1=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
ET1=0;
TR1=0;
num3=0;
num5=6;
num6=0;
init();
zhiling(0x80);
for(cc=0;cc<8;cc++)
        shuju(xian1[cc]);
        timer(5);
zhiling(0x80+0x42);
for(cc=0;cc<13;cc++)
        shuju(xian2[cc]);
        timer(5);
timerkai();
                if(num2==5|num3==1)
                        num3=1;
                        djs();
                                init();
                                zhiling(0x80+0x01);
                                for(cc=0;cc<14;cc++)
                                        shuju(tishi[cc]);
                                        timer(5);
                                zhiling(0x80+0x48);
                                for(cc=0;cc<2;cc++)
                                        shuju(ling[cc]);
                                        timer(5);
                                if(num5==1)
                                        zhiling(0x80+0x49);
                                        for(cc=0;cc<1;cc++)
                                                shuju(shu1[cc]);
                                                timer(5);
                                if(num5==2)
                                        zhiling(0x80+0x49);
                                        for(cc=0;cc<1;cc++)
                                                shuju(shu2[cc]);
                                                timer(5);
                                if(num5==3)
                                        zhiling(0x80+0x49);
                                        for(cc=0;cc<1;cc++)
                                                shuju(shu3[cc]);
                                                timer(5);
                                if(num5==4)
                                        zhiling(0x80+0x49);
                                        for(cc=0;cc<1;cc++)
                                                shuju(shu4[cc]);
                                                timer(5);
                                if(num5==5)
                                        zhiling(0x80+0x49);
                                        for(cc=0;cc<1;cc++)
                                                shuju(shu5[cc]);
                                                timer(5);
                                if(num5==6)
                                        zhiling(0x80+0x49);
                                        for(cc=0;cc<1;cc++)
                                                shuju(shu0[cc]);
                                                timer(5);
                                if(num6==1)
void t0() interrupt 1
num1++;
        if(num1==20)
                num2++;
                num1=0;
                if(num2==6)
                        num2=0;
void t1() interrupt 3
num4++;
if(num4==20)
        num5--;
        num4=0;
        if(num5==0)
                num5=6;
                TR1=0;
                ET1=0;
                num6=1;
設計者:薛羽豪
主站蜘蛛池模板: 国产精品亚洲综合 | 亚洲成人精品 | 国精产品99永久一区一区 | 欧美在线视频一区二区 | 91丨九色丨蝌蚪丨丝袜 | 欧美在线视频观看 | 九九九精品视频 | 91久久精品日日躁夜夜躁欧美 | 每日更新av | 一级肉体裸体bbbb | 四川毛片 | 国产一级在线观看 | 日韩精品免费 | 中文字幕理伦片免费看 | 中文字幕免费视频 | 欧美一区免费 | 日韩精品成人免费观看视频 | 久久精品国产一区 | 免费a网站 | 欧美性生活网站 | 国产精品国产精品国产专区不片 | 国产超碰人人模人人爽人人添 | 亚洲精品资源 | 国产成人高清 | 国产日本在线观看 | 国产成人精品一区二区三区在线 | 免费视频一区二区 | 国产一区二区日韩 | 成人在线a| 黄色一级片免费 | 欧美成人精品欧美一级乱黄 | 国产精品久久久国产盗摄 | 日韩免费一区二区三区 | 青青草91 | 亚洲久热 | 欧美精品自拍 | 色网站在线| www.黄色网 | 午夜视频一区二区三区 | 欧美日韩免费 | 日本黄色中文字幕 |
