查看: 11057|回復: 11
發一個pwm直流電機調速程序,LCD段碼屏顯示的程序
ID:77707 發表于 2015-4-22 13:34 | 顯示全部樓層 |閱讀模式
寫這個程序是要實現,用按鍵+,-使電機調速,并在LCD段碼屏上
出現累加的兩位數字顯示。
段式LCD驅動和電機調速實驗
外部晶體:12MHz
作者:dpj555
郵箱:
日期:2015.03.26
#include <reg52.h>
#include <stdio.h>
#define uint unsigned int
#define uchar unsigned char
/*管腳定義*/
sbit COM1=P1^7;
sbit COM2=P1^6;
sbit BI_4=P1^5;
sbit RTC_CLK=P1^4;
sbit RTC_IO=P1^3;
sbit RTC_RST=P1^2;   //復用
/*P3口模式寄存器*/
sfr P3M1=0xb1;
sfr P3M0=0xb2;
/* 開機默認顯示*/
unsigned char ClockBuffer[8]={0x34,0x12,0x08,0x20,0x03,0x05,0x09};
0~9的段碼查詢表
位序 D7 D6 D5 D4 D3 D2 D1 D0
段   A  B  C  D  E  F  G  DOT
code unsigned char seg_code[10]={~0x03,~0x9f,~0x25,~0x0d,~0x99,~0x49,~0x41,~0x1f,~0x01,~0x09};
unsigned char ScanCoun=0;                  //動態掃描顯示位數計數器
unsigned char DisplayBuf[2]={1,2 };               //2位數字對應的顯示暫存
/*段碼緩沖區*/
unsigned char SegBuf[2]={0x00,0x00};//COM1、COM2 的段碼
bit bi_4a=0; //COM1對應的4a
bit bi_4b=0; //COM2對應的4b
/*延時*/
void dly(unsigned char x)
   {unsigned char i;
    for (i=0; i<x; i++);
/*ds1302寫1字節*/
void rtc_wt_byte(unsigned char sent_buf)
         {unsigned char i;
          for (i=0; i<8; i++)
              {RTC_CLK=0;
               if (sent_buf&0x01) RTC_IO=1;
               else RTC_IO=0;
               RTC_CLK=1;
               dly(5);
               sent_buf=sent_buf>>1;
              RTC_CLK=0;
              dly(5);
/*ds1302讀1字節*/
unsigned char rtc_rd_byte(void)
          {unsigned char i,read_buf;
           RTC_IO=1;         //RTC_IO置1,保證為輸入狀態
           for (i=0; i<8; i++)
               {read_buf=read_buf>>1;
                       RTC_CLK=0;
                       dly(5);
                if (RTC_IO) read_buf=read_buf|0x80;
                else read_buf=read_buf&0x7f;
                RTC_CLK=1;
                dly(5);
           RTC_CLK=0;
           dly(5);
           return read_buf;
/*ds1302寫入時間*/
void rtc_wr_time(unsigned char *p_wt_time)
           {unsigned char i;
            unsigned char tmp1;
            dly(30);
            RTC_RST=1;
            rtc_wt_byte(0xbe);         //burst寫入時間
            for (i=0; i<8; i++)
                  {tmp1=*p_wt_time++;
                   rtc_wt_byte(tmp1);
            RTC_CLK=0;
            RTC_RST=0;
/*ds1302讀出時間*/
void rtc_rd_time(unsigned char *p_rd_time)
           {unsigned char i;
            unsigned char tmp1;
            dly(30);
            RTC_RST=1;
            rtc_wt_byte(0xbf);        //burst讀取時間
            RTC_IO=1;
            for (i=0; i<8; i++)
                  {tmp1=rtc_rd_byte();
                   *p_rd_time++=tmp1;
            RTC_CLK=0;
            RTC_RST=0;
/*ds1302初始化*/
void ini_rtc()
         {RTC_CLK=0;
          RTC_RST=0;
          dly(30);
          RTC_RST=1;
          rtc_wt_byte(0x8e);        //寫CONTROL寄存器
          rtc_wt_byte(0x00);        //值:去掉寫保護
          RTC_RST=0;                //復位
          RTC_RST=1;                //正常工作
          rtc_wt_byte(0x90);        //寫TRICKLE CHARGER寄存器
          rtc_wt_byte(0xa9);        //值:使能充電,串聯2個二極管,串聯2k歐姆的電阻
          RTC_CLK=0;
          RTC_RST=0;
把2位數字的SEG放到COM1、COM2 對應的段碼
LCD的管腳定義與LED不同,它不是一個COM對應一位數字,而是對應每個數字的一部分SEG
1   2   3   4   5   6   7   8
<  1f  1a  2f  2a      3f  3a  4f  4a   >          --       ---- COM1
<  1g  1b  2g  2b      2g  3b  4g  4b   >          --       ---- COM2
void Seg2Seg()
{unsigned char SegXX;
SegBuf[1]=0;
SegBuf[2]=0x08;
bi_4a=0;
bi_4b=0;
SegXX=seg_code[DisplayBuf[0]];      //第1位數字
if (SegXX&0x80) SegBuf[0]|=0x40;
if (SegXX&0x40) SegBuf[1]|=0x40;
if (SegXX&0x20) SegBuf[2]|=0x40;
if (SegXX&0x10) SegBuf[3]|=0x80;
if (SegXX&0x08) SegBuf[2]|=0x80;
if (SegXX&0x04) SegBuf[0]|=0x80;
if (SegXX&0x02) SegBuf[1]|=0x80;
if (SegXX&0x01) SegBuf[3]|=0x40;
  SegXX=seg_code[DisplayBuf[1]];    //第2位數字
if (SegXX&0x80) SegBuf[0]|=0x10;
if (SegXX&0x40) SegBuf[1]|=0x10;
if (SegXX&0x20) SegBuf[2]|=0x10;
if (SegXX&0x10) SegBuf[3]|=0x20;
if (SegXX&0x08) SegBuf[2]|=0x20;
if (SegXX&0x04) SegBuf[0]|=0x20;
if (SegXX&0x02) SegBuf[1]|=0x20;
if (SegXX&0x01) SegBuf[3]|=0x10;
/*一個BCD碼轉化成兩個十進制數(如:0x79轉化成0x07和0x09)*/
BcdToDec(unsigned char BcdValue,unsigned char *pDecValue)
       {//if (BcdValue>=0x9a||(BcdValue&0x0f)>=0x0a) return 0;
               *pDecValue++=(BcdValue&0xf0)>>2;
        *pDecValue=BcdValue&0x0f;
        //return 1;
//初始化MCS51內部資源
InitInterResource()
       {IE=0;       //關全部中斷
        TCON=0;     //清全部中斷請求
        IP=0;       //清中斷優先級
        TMOD=0x01;  //T0工作方式1(16位定時器)
        TH0=0x00;   //T0定時器輔初值
        TL0=0x00;
        TR0=1;      //允許T0定時
        ET0=1;      //允許T0中斷
        EA=0;       //關全局中斷
        RTC_RST=0;
     InitInterResource();
     ini_rtc();                    //初始化DS1302
     rtc_wr_time(ClockBuffer);     //寫入時間初始值
     EA=1;         //開全局中斷
//定時器0中斷服務程序,5ms定時器,4位數碼管動態顯示驅動
void tmr0_p(void) interrupt 1
     TL0=0x78;     //重新定時5ms
     TH0=0xec;
     Seg2Seg();
     P3M1=0x3c;
     P3M0=0x00;
          switch(ScanCoun)                //動態掃描顯示
          case 1:                       //COM1正向驅動
          P1= SegBuf[1];
          BI_4= bi_4a;
          COM1=0;
          P3M1=0x2c;
          P3M0=0x00;
          break;
          case 2:                       //COM1反向驅動
          P1= ~SegBuf[1];
          BI_4= ~bi_4a;
          COM1=1;
          P3M1=0x2c;
          P3M0=0x00;
          break;
          case 3:                       //COM2正向驅動
          P1= SegBuf[2];
          BI_4= bi_4b;
          COM2=0;
          P3M1=0x34;
          P3M0=0x00;
          break;
          case 4:                       //COM2反向驅動
          P1= ~SegBuf[2];
          BI_4= ~bi_4b;
          COM2=1;
          P3M1=0x34;
          P3M0=0x00;
          break;
     ScanCoun++;       //下一位
     if (ScanCoun>2) ScanCoun=0;
/*使單片機輸出PWM調速*/
為了使大家徹底掌握此方面,下面再給出一個復雜一點的程序,實現的功能為
通過按鍵使之可以在0到20級之間調速的程序。
/* 程序名:PWM直流電機調速 */
/* 晶振:11.00592 MHz CPU型號:STC12C2051 */
/* 直流電機的PWM波控制,可以通過按鍵控制正反轉并在0到20級之間調速 */
uchar time,count=50,flag=1;//低電平的占空比
sbit PWM1=P3^5;//PWM 通道 1,反轉脈沖
sbit PWM2=P3^7;//PWM 通道 2,正轉脈沖
sbit key_add=P1^1;//電機加速
sbit key_dec=P1^2;//電機減速
/************函數聲明**************/
void delayxms(uint z);
void Motor_turn();
void Motor_add();
void Motor_dec();
void timer0_init();
/****************延時處理**********************/
void delayxms(uint z)//延時xms程序
    uint x,y;
        for(y=z;x>0;x--)
        for(y=110;y>0;y--);
/*********主函數********************/
        timer0_init();
                Motor_turn();
                Motor_add();
                Motor_dec();
void Motor_add()//電機加速
        if(key_add==0)
                  delayxms(2);//此處時間不能太長,否者會的中斷產生沖突
                  if(key_add==0)
                    count+=5;
                        if(count>=100)
                                count=0;
                  while(!key_add);
void Motor_dec()//電機加減速
        if(key_dec==0)
                  if(key_dec==0)
                    count-=5;
                        if(count>=100)
                                count=0;
                  while(!key_dec);
/***********定時器0初始化***********/
void timer0_init()
        TMOD=0x01; //定時器0工作于方式1
        TH0=(65536-10)/256;
        TL0=(65536-10)%256;
        TR0=1;
        ET0=1;
        EA=1;
/**************定時0中斷處理******************/
void timer0_int() interrupt 1
        TR0=0;//設置定時器初值期間,關閉定時器
        TH0=(65536-10)/256;
        TL0=(65536-10)%256;
        TR0=1;
        if(flag==1)//電機正轉
                PWM1=0;
                   time++;
                  if(time<count)
                    PWM2=1;
            PWM2=0;
            if(time>=100)
                    time=0;
        else //電機反轉
                PWM2=0;
                  time++;
            if(time<count)
                    PWM1=1;
                    PWM1=0;
            if(time>=100)
                    time=0;
admin + 50 共享資料的積分獎勵!
ID:1099381 發表于 2023-11-12 04:24 | 顯示全部樓層
好資料,整好用的上
ID:1095483 發表于 2023-11-10 18:05 | 顯示全部樓層
感謝版主
ID:71535 發表于 2015-4-24 07:59 | 顯示全部樓層
感謝版主加分鼓勵
ID:76929 發表于 2015-4-24 07:08 | 顯示全部樓層
謝謝分享
ID:77707 發表于 2015-4-23 09:14 | 顯示全部樓層
感謝版主加分鼓勵。
ID:77707 發表于 2015-4-23 09:08 | 顯示全部樓層
本帖最后由 dpj555 于 2015-4-24 08:14 編輯
更改后的圖
ID:77707 發表于 2015-4-23 09:06 | 顯示全部樓層
gaozhaohong 發表于 2015-4-22 14:33
資料不錯 不過簡圖中的R2R3中間的一顆線 和R4R5中間的一顆線都接在P1.6上嗎?
抱歉!錯了應該p1.7上有一個,給com2 位供2.5v電壓。
ID:76408 發表于 2015-4-22 20:42 | 顯示全部樓層
圖在下面沒注意到,對不起
ID:76408 發表于 2015-4-22 20:40 | 顯示全部樓層
最好有圖容易看得懂。
ID:61876 發表于 2015-4-22 14:33 | 顯示全部樓層
ID:77707 發表于 2015-4-22 14:09 | 顯示全部樓層
再附張簡圖
主站蜘蛛池模板: 在线视频日本 | 天天看天天射 | 夜夜操夜夜爽 | 中文字幕在线观看一区二区三区 | 亚洲香蕉在线 | 一级黄色片在线观看 | 免费一区二区 | 国产成人午夜精品 | 国产精品一区二区在线播放 | 一级片免费视频 | 国产日韩欧美日韩大片 | 成人羞羞国产免费 | 欧美在线视频一区二区 | 中文字幕日韩在线观看 | 99精品久久久久久中文字幕 | 日韩在线不卡视频 | 日韩视频在线免费观看 | 精品国产一区二区三区久久久蜜月 | 欧美一级日韩一级 | 日本特黄一级片 | 国产精自产拍久久久久久蜜 | 蜜桃精品视频 | 亚洲精品不卡 | 婷婷五月在线视频 | 日韩成人在线播放 | 国产黄色片网站 | 影音先锋中文字幕在线 | 欧美日韩中文字幕 | 九九热这里有精品 | 亚洲一级免费视频 | 激情视频网 | 中文字幕av久久爽av | 小镇姑娘国语版在线观看免费 | 一区二区三区四区在线播放 | 国产精品成人免费视频 | 国产视频一区二区三区四区 | 欧美精品二区三区四区免费看视频 | 欧美顶级黄色大片免费 | 高清乱码男女免费观看 | 日本青青草 | 久久久黄色|
