我就是這樣接的只不過(guò)我接的5k電阻
#include<reg51.h>
#include<string.h>
#include<intrins.h>
#define uchar unsigned char
#define uint unsigned int
#define LCDIO P0
//#define delay4us() _nop_();_nop_();_nop_();_nop_();
uchar buffer[6]={0};
sbit sda=P3^7;
sbit scl=P3^6;
sbit beep=P2^7;
sbit jdq=P2^6;
bit flag=0,aa; //用戶蹲淵義定時(shí)溢出標(biāo)志位
uchar DSY_BUFFER[16]=" ";
uchar DSY_BUFFER1[16]=" ";
uchar Userpassword[6]={0};
sbit rs=P2^0;
sbit rd=P2^1;
sbit lcden=P2^2;
uchar code table2[]="123456";
uchar code table[]="Your Password...";
void delayms(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void write_com(uchar com)
rs=0;
rd=0;
lcden=0;
P0=com;
delayms(5);
lcden=1;
delayms(5);
lcden=0;
void write_date(uchar date)
rs=1;
rd=0;
lcden=0;
P0=date;
delayms(5);
lcden=1;
delayms(5);
lcden=0;
void Display_String(uchar *p,uchar com)
{ uchar i;
write_com(com);
for(i=0;i<16;i++)
write_date(p);
void init_lcd()
lcden=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
Display_String(table,0x80);
Display_String("It is Locked! ",0xc0);
//**************************************//I2C通信協(xié)議
void nop()
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
void start()//開(kāi)始信號(hào)
sda=1;
nop();
scl=1;
nop();
sda=0;
nop();
void stop()//停止
sda=0;
nop();
scl=1;
nop();
sda=1;
nop();
void respons()//應(yīng)答
unsigned char i;
scl=1;
nop();
while((sda==1)&&(i<250))
i++;
scl=0;
nop();
void init()//初始化函數(shù)
sda=1;
scl=1;
void write_byte(unsigned char dat)//寫一字節(jié)
unsigned char i;
scl=0;
for(i=0;i<8;i++)
dat=dat<<1;
sda=CY;
scl=1;
nop();
scl=0;
nop();
unsigned char read_byte()//讀取一字節(jié)
unsigned char i,k;
for(i=0;i<8;i++)
scl=1;
nop();
k=(k<<1)|sda;
scl=0;
nop();
return k;
void write(unsigned char address,unsigned char dat)//向AT24C02地址中寫數(shù)據(jù)
start();
write_byte(0xa0);
respons();
write_byte(address);
respons();
write_byte(dat);
respons();
stop();
unsigned char read(unsigned char address)//從AT24C02地址中讀出數(shù)據(jù)
unsigned char dat;
start();
write_byte(0xa0);
respons();
respons();
start();
write_byte(0xa1);
respons();
dat=read_byte();
stop();
return dat;
void clear_password()
{ uchar i;
for(i=0;i<6;i++)
Userpassword=' ';
for(i=0;i<16;i++)
DSY_BUFFER=' ';
uchar Keys_Scan()
uchar temp,keynum;
P1=0x0F;
delayms(5);
temp=P1^0x0F;
switch(temp)
case 1:keynum=0;break;
case 2:keynum=1;break;
case 4:keynum=2;break;
case 8:keynum=3;break;
break;
P1=0xF0;
delayms(5);
temp=P1>>4^0x0F;
switch(temp)
case 1:keynum+=0;break;
case 2:keynum+=4;break;
case 4:keynum+=8;break;
case 8:keynum+=12;break;
break;
delayms(600);
return keynum;
{ uchar temp,i=0,j=0,k=0,n;
uchar IS_valid_user;
beep=1;
init();
init_lcd();
delayms(5);
write(0x00,table2[0]);
delayms(10);
write(0x01,table2[1]);
delayms(10);
write(0x02,table2[2]);
delayms(10);
write(0x03,table2[3]);
delayms(10);
write(0x04,table2[4]);
delayms(10);
write(0x05,table2[5]);
delayms(10);
buffer[0]=read(0x00);
delayms(10);
buffer[1]=read(0x01);
delayms(10);
buffer[2]=read(0x02);
delayms(10);
buffer[3]=read(0x03);
delayms(10);
buffer[4]=read(0x04);
delayms(10);
buffer[5]=read(0x05);
delayms(10);
P1=0x0f;
if(P1!=0x0f)
temp=Keys_Scan();
switch(temp)
case 0: case 1: case 2: case 3: case 4:
case 5: case 6: case 7: case 8: case 9:
if (i<=5) //密碼限制在6位以內(nèi)
Userpassword=temp;
DSY_BUFFER='*';
Display_String(DSY_BUFFER,0xc0);
i++;
break;
case 10: //按A鍵開(kāi)鎖
for(k=0;k<=5;k++)
{ flag=flag&&(buffer[k]==Userpassword[k]);}
if (flag)
{ flag=0;
i=0;
jdq=0; //點(diǎn)亮LED
clear_password();
Display_String("OPEN OK! ",0xc0);
IS_valid_user = 1;
j=0;
j++;
jdq=1; //關(guān)閉LED
clear_password();
Display_String("ERROR!Have try ",0xc0);
write_com(0xcf);
write_date(0x30+j);
IS_valid_user=0;
i=0;
break;
case 11: //按B鍵上鎖
jdq=1;
clear_password();
Display_String("Lock OK! ",0xc0);
i=0;
IS_valid_user=0;
break;
case 12: //按C鍵設(shè)置新密碼
//如果是合法用戶則提示輸入新密碼
if ( !IS_valid_user)
i=0;
Display_String("No rights ! ",0xc0);
delayms(1000);
Display_String("Your Password...",0x80);
i=0;
Display_String("New Password: ",0x80);
Display_String(" ",0xc0);
break;
case 13: //按D鍵保存新密碼
{ i=0;
delayms(1000);
{i = 0;
init();
delayms(5);
for(k=0;k<6;k++)
Userpassword[k]=Userpassword[k];
write(0x00,Userpassword[0]);
delayms(10);
write(0x01,Userpassword[1]);
delayms(10);
write(0x02,Userpassword[2]);
delayms(10);
write(0x03,Userpassword[3]);
delayms(10);
write(0x04,Userpassword[4]);
delayms(10);
write(0x05,Userpassword[5]);
delayms(10);
delayms(10);
delayms(10);
delayms(10);
delayms(10);
delayms(10);
delayms(10);
clear_password();
Display_String(table,0x00);
Display_String("Password Saved! ",0xc0);
delayms(1000);
Display_String("Do lock agian ? ",0xc0);
break;
case 14: //按E鍵消除所有輸入
i=0;
clear_password();
break;
case 15: //清除一位
if(i!=0)i--;
for(n=0;n<i;n++)
DSY_BUFFER1[n]='*';
Display_String(DSY_BUFFER1,0xc0);
P1=0x0f;
if(j==3)
{ Display_String("THIEF!!!THIEF!!!",0xc0);
j=0;
beep=0;
這是全部程序,改完了以后輸入123456也不對(duì)輸入000000也不對(duì)了 |
