查看: 4735|回復(fù): 10
12864顯示問題
ID:85129 發(fā)表于 2015-7-31 21:08 | 顯示全部樓層 |閱讀模式
我的12864顯示的問題,
程序如下:
#include <reg52.h>
#include"intrins.h"
#define LCD12864DataPort P0
#define  uchar unsigned char
#define  uint  unsigned  int
// LCD128*64 I/O
//信號管腳
sbit rs =P2^0;   // //數(shù)據(jù)\//指令//選擇
sbit rw =P2^1;   // //讀\寫選擇
sbit en =P2^2;   // 讀\寫使能
sbit cs1 =P2^4;  // 片選1,低有效(前64列)
sbit cs2 =P2^5;  // 片選2,低有效(后64列)
void    lcdstate()
uchar  lcd=0x00; /*設(shè)置初值為0,全部為低,方便后面的判忙*/
rs=0; /*根據(jù)時序圖拉低,選擇寫指令*/
rw=1; /*根據(jù)時序圖拉低,選擇寫模式*/
do
en=1; /*使能,使液晶輸出信號,檢查是否忙*/
_nop_();_nop_();_nop_();_nop_();/*延時4US*/
lcd=P0; /*把P0口的狀態(tài)值讀回來給lcd*/
en=0; /*使能端跳變*/;
}while(lcd&0x80); /*結(jié)果的高位保留,如果高位DB7為一,則表示忙*/
void delay(uchar  ms)
{ uchar   i;
   uchar   j;
  for(i=0;i<100;i++)
   for(j=0;j<ms;j++);
void   write_command(uchar   command)
lcdstate();
  rs=0;    //RS=0;為往MCU進(jìn)行指令操作
  rw=0;    //RW=0;為往MCU寫入操作
  en=0;
  en=1;
  P0=command;
  en=0;
void   write_data(uchar   datas)
   lcdstate();
   rs=1;
   rw=0;
   en=0;
   en=1;
   P0=datas;
   en=0;
void   lcdinit()
    delay(100);      //
    cs1=1;
cs2=1;
delay(100);
  lcdstate();     //
write_command(0x3e);   //
write_command(0xb8+0);    //
write_command(0xc0+0);   //
write_command(0x40+0);   //
write_command(0x3f);
void clearScreen(  )
{   uchar i,j;
    lcdstate();
    cs1=1;
cs2=1;
write_command(0x3f);   //設(shè)置顯示開
write_command(0xb8);      //Y 設(shè)置第0頁;
write_command(0x40);    // 設(shè)置第0列
   for(i=0;i<8;i++)
     write_command(0xb8+i);
     for(j=0;j<64;j++)
    //write_command(0x40+j);
       write_data(0x00);
uchar code    xms[16]= {
0xee,0xef,0xee,0xee,0xee,0xff,0xff,0xff,0xff,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,
void hz_display16(unsigned char pag, unsigned char col, unsigned char code *hzk)
uchar j=0;
uchar i=0;
for(j=0;j<1;j++)
  write_command(0xb8+pag+j);
  write_command(0x40+col);
  for(i=0;i<16;i++)
  write_data(hzk[16*j+i]);
lcdinit();
clearScreen(  );
    cs1=1;
    cs2=0;
  delay(2);
// hz_display16(0,0,xms[]);
  hz_display16(0,0,xms);
0xee,0xef,0xee,0xee,0xee,0xff,0xff,0xff,0xff,0x1f,0xff,0xff,0xff,0xff,0xff,0xff,這里的第六個0XFF,在液晶上顯示的是0XEF,第十個0X1F,顯示的是0X0F,百思不得其解,液晶是KS0108芯片。顯示1,3,5,7,9,B,D,F,都有類似問題,求幫助!先謝謝大家了!
ID:85129 發(fā)表于 2015-8-2 09:07 | 顯示全部樓層
沒有人回復(fù),我搞明白了,是因?yàn)樯侠娮铔]有焊好。
ID:86380 發(fā)表于 2015-8-3 15:07 | 顯示全部樓層
qhdfnftyzt 發(fā)表于 2015-8-2 09:07
可憐.............
ID:87562 發(fā)表于 2015-8-3 18:51 | 顯示全部樓層
看是不是 引腳插錯了
ID:85129 發(fā)表于 2015-8-4 12:32 | 顯示全部樓層
qiujie1996 發(fā)表于 2015-8-3 18:51
看是不是 引腳插錯了
上拉電阻沒有焊好,多謝!
ID:87639 發(fā)表于 2015-8-4 20:13 | 顯示全部樓層
虛焊了吧
ID:143203 發(fā)表于 2016-11-17 11:27 | 顯示全部樓層
這個怎么接?
ID:200028 發(fā)表于 2017-5-14 14:14 | 顯示全部樓層
按照你的接法,你的程序顯示不出來啊。
ID:194276 發(fā)表于 2017-5-14 15:58 | 顯示全部樓層
是不是虛焊了
ID:198608 發(fā)表于 2017-5-16 13:49 來自觸屏版 | 顯示全部樓層
同樣,我想請教一下那csq與cs2口是什么
ID:85129 發(fā)表于 2017-8-10 14:15 | 顯示全部樓層
梁光陽 發(fā)表于 2017-5-16 13:49
CS1與CS2是左半邊屏和右半邊屏選擇使能。
主站蜘蛛池模板: 国产精品五区 | 色视频www在线播放国产人成 | 亚洲免费小视频 | 欧美日韩三区 | 国产欧美精品一区二区色综合 | 91中文字幕在线 | 午夜精品久久久久久久 | 午夜精品免费 | 国产成人精品一区二区三区福利 | 日韩精品在线一区二区 | 深夜免费福利 | 亚洲黄色免费 | 国产精品二区一区二区aⅴ污介绍 | 91女人18毛片水多国产 | 8x8ⅹ国产精品一区二区 | 国内精品一区二区 | www.99色| 国产精品美女毛片真酒店 | 亚洲日本精品 | 国产福利在线播放 | 日本成人一区 | 亚洲免费看片 | 中文字幕永久 | 五月天激情婷婷 | 久久亚洲免费视频 | 九色网址| 午夜视频一区二区三区 | 简单av网| 久操精品视频 | 91免费黄 | 最新国产在线视频 | 久草黄色 | 国产精品欧美在线 | 日本久久精品视频 | 欧美成人一区二区三区 | 中文字幕第5页 | 成年人视频在线播放 | 亚洲成人毛片 | 天天操夜夜摸 | 国产精品99久久久久久www | 国产精品欧美在线 |
