查看: 2325|回復(fù): 0
msp430 三級(jí)菜單程序
ID:109048 發(fā)表于 2016-3-15 17:16 | 顯示全部樓層 |閱讀模式
uchar welcome_tab1[] = {"系統(tǒng)初始化中"};
uchar welcome_tab2[] = {"請(qǐng)稍等..."};
uchar tab3[] = {"處理中..."};
struct menu{
  unsigned char menucount;   //當(dāng)前層節(jié)點(diǎn)數(shù)
  unsigned char *str; //菜單標(biāo)題
  unsigned char pos;
  unsigned char length;
  void (*subs)();     //節(jié)點(diǎn)函數(shù)
  struct menu *childrenmenu; //子節(jié)點(diǎn)
  struct menu *parentmenu;   //父節(jié)點(diǎn)
struct menu1{
  unsigned char *str1;
  unsigned char pos1;
  unsigned char length1;
//************************************空函數(shù)************************************
//函數(shù)名稱:    nullsubs
//函數(shù)說(shuō)明:    無(wú)
//入口參數(shù):    無(wú)
//出口參數(shù):    無(wú)
void nullsubs(void)
//***********************************待處理函數(shù)*********************************
//函數(shù)名稱:    aa
//函數(shù)說(shuō)明:    實(shí)際中要替換為具體函數(shù)原型,這里只是舉例說(shuō)明
//入口參數(shù):    無(wú)
//出口參數(shù):    無(wú)
void aa(void)
  clrram();
  wch_disp(tab3,0x91,5);
  long_delay(10000);
//******************************菜單顯示內(nèi)容************************************
//說(shuō)明:    結(jié)構(gòu)體中放的是菜單的顯示內(nèi)容等參數(shù),完成菜單功能變換,菜單返回
//          菜單指針函數(shù)、可以指向下一級(jí)菜單,也可以指向某一項(xiàng)選項(xiàng)的功能
//          實(shí)際中可以根據(jù)具體內(nèi)容變換。是程序的關(guān)鍵之一。
struct menu1 menu2[5][4] = {
  {"系┃",0x80,2},
  {"統(tǒng)┃",0x90,2},
  {"設(shè)┃",0x88,2},
  {"置┃",0x98,2}
  {"時(shí)┃",0x80,2},
  {"間┃",0x90,2},
  {"設(shè)┃",0x88,2},
  {"置┃",0x98,2}
  {"日┃",0x80,2},
  {"期┃",0x90,2},
  {"設(shè)┃",0x88,2},
  {"置┃",0x98,2}
  {"背┃",0x80,2},
  {"光┃",0x90,2},
  {"設(shè)┃",0x88,2},
  {"置┃",0x98,2}
  {"其┃",0x80,2},
  {"它┃",0x90,2},
  {"設(shè)┃",0x88,2},
  {"置┃",0x98,2}
struct menu main_menu[5];
struct menu time_menu[4];
struct menu date_menu[5];
struct menu backlight_menu[3];
struct menu other_menu[3];
struct menu main_menu[5] = {
  {5,"1.時(shí)間設(shè)置",0x82,5,nullsubs,time_menu,Null},
  {5,"2.日期設(shè)置",0x92,5,nullsubs,date_menu,Null},
  {5,"3.背光設(shè)置",0x8a,5,nullsubs,backlight_menu,Null},
  {5,"4.其它設(shè)置",0x9a,5,nullsubs,other_menu,Null},
  {5,"5.返回",0x82,3,nullsubs,main_menu,main_menu}
struct menu time_menu[4] = {
  {4,"1.時(shí)區(qū)設(shè)置",0x82,5,aa,Null,main_menu},
  {4,"2.小時(shí)設(shè)置",0x92,5,aa,Null,main_menu},
  {4,"3.分鐘設(shè)置",0x8a,5,aa,Null,main_menu},
  {4,"4.返回",0x9a,3,nullsubs,main_menu,main_menu}
struct menu date_menu[5] = {
  {5,"1.年份設(shè)置",0x82,5,aa,Null,main_menu},
  {5,"2.月份設(shè)置",0x92,5,aa,Null,main_menu},
  {5,"3.日期設(shè)置",0x8a,5,aa,Null,main_menu},
  {5,"4.星期設(shè)置",0x9a,5,aa,Null,main_menu},
struct menu backlight_menu[3] = {
  {3,"1.背光變亮",0x82,5,aa,Null,main_menu},
  {3,"2.背光變暗",0x92,5,aa,Null,main_menu},
  {3,"3.返回",0x8a,3,nullsubs,main_menu,main_menu}
struct menu other_menu[3] = {
  {3,"1.通信設(shè)置",0x82,5,aa,Null,main_menu},
  {3,"2.PC通信",0x92,4,aa,Null,main_menu},
//************************************全局變量**********************************
struct menu (*menupoint) = main_menu;  //結(jié)構(gòu)體指針,指向結(jié)構(gòu)體后由內(nèi)部函數(shù)指針指向功能函數(shù)
unsigned char displaystart = 0; //顯示時(shí)的第一個(gè)菜單項(xiàng)
unsigned char userchoose = 0;   //用戶所選菜單項(xiàng)
unsigned char displaypoint = 0; //顯示指針
unsigned char maxitems;         //同級(jí)最大菜單數(shù)
unsigned char key;
void init_clk(void)
  uchar i;
  BCSCTL1 &= ~XT2OFF;                   // XT2 = HF XTAL
  do
  IFG1 &= ~OFIFG;                       // Clear OSCFault flag
  for (i = 0xFF; i > 0; i--);           // Time for flag to set
  while ((IFG1 & OFIFG) != 0);          // OSCFault flag still set?
  BCSCTL2 |= SELM1;                     // MCLK = XT2 (safe)
//************************************菜單顯示**********************************
//函數(shù)名稱:    void menu_disp(uchar n)
//函數(shù)說(shuō)明:    顯示主菜單
//入口參數(shù):    uint n,要顯示的菜單級(jí)數(shù)號(hào)碼
//出口參數(shù):    無(wú)
void menu_disp(void)
  uchar i;
  clrram();
  maxitems = menupoint[0].menucount;
  if(userchoose < 4 && maxitems < 5)
    for(i = 0 ;i < maxitems;i++)
      wch_disp(menupoint[i].str,menupoint[i].pos,menupoint[i].length);
  else if(userchoose < 4 && maxitems >= 5)
    for(i = 0;i < 4;i++)
  else if(userchoose >= 4)
    clrram();
    clrram();
    for(i = 0; i < maxitems - 4;i ++)
      wch_disp(menupoint[i + 4].str,menupoint[i + 4].pos,menupoint[i + 4].length);
  if(menupoint == main_menu)
    for(i = 0; i < 4;i ++)
      wch_disp(menu2[0][i].str1,menu2[0][i].pos1,menu2[0][i].length1);
  else if(menupoint == time_menu)
      wch_disp(menu2[1][i].str1,menu2[1][i].pos1,menu2[1][i].length1);
  else if(menupoint == date_menu)
      wch_disp(menu2[2][i].str1,menu2[2][i].pos1,menu2[2][i].length1);
  else if(menupoint == backlight_menu)
      wch_disp(menu2[3][i].str1,menu2[3][i].pos1,menu2[3][i].length1);
  else if(menupoint == other_menu)
      wch_disp(menu2[4][i].str1,menu2[4][i].pos1,menu2[4][i].length1);
  con_wch_disp(menupoint[userchoose].pos,menupoint[userchoose].length);
//************************************鍵盤處理**********************************
//函數(shù)名稱:    key_process
//函數(shù)說(shuō)明:    鍵盤處理
//入口參數(shù):    無(wú)
//出口參數(shù):    無(wú)
void key_process(void)
  switch(P1IN & 0x0f)
  case 0x01 :
    key = DOWN;
    break;
  case 0x02 :
    key = UP;
    break;
  case 0x04 :
    key = ENTER;
    break;
  case 0x08 :
    key = ESC;
    break;
  default :
    break;
  while(P1IN & 0x0f);
  P1IFG &= 0x00;
void main(void)
  WDTCTL = WDTPW + WDTHOLD;
  P1IE = 0X0f;
  _EINT();
  init_clk();
  init_lcdport();
  init_lcd();
  img_disp(tab32);
  long_delay(20000);
  clrram();
  wch_disp(welcome_tab1,0x91,6);
  wch_disp(welcome_tab2,0x8a,5);
  long_delay(20000);
  clrram();
  menu_disp();
  while(1);
//***********************************中斷處理函數(shù)*******************************
//函數(shù)名稱:    p1
//函數(shù)說(shuō)明:    完成鍵盤鍵值處理,菜單變換,屏幕刷新等功能,是程序的關(guān)鍵之一
//入口參數(shù):    無(wú)
//出口參數(shù):    無(wú)
#pragma vector = PORT1_VECTOR
__interrupt void p1(void)
  key_process();
  if(key)
    switch(key)
    case DOWN :
      userchoose++;
      if(userchoose == maxitems)
        userchoose = 0;
      break;
    case UP :
      userchoose--;
      if(userchoose == 255)
        userchoose = maxitems - 1;
      break;
    case ENTER :
      if(menupoint[userchoose].subs != nullsubs)
        (*menupoint[userchoose].subs)();
      else if(menupoint[userchoose].childrenmenu != Null)
        menupoint = menupoint[userchoose].childrenmenu;
        userchoose = 0;
        displaystart = 0;
      break;
    case ESC :
      if(menupoint[userchoose].parentmenu != Null)
        menupoint = menupoint[userchoose].parentmenu;
        userchoose = 0;
        displaystart = 0;
      break;
    menu_disp();
評(píng)分
查看全部評(píng)分
主站蜘蛛池模板: 成人深夜福利视频 | 欧美日韩黄色片 | 国产h在线| 欧美资源在线 | 成人在线免费看 | 欧美日韩精品一区二区 | 欧美日韩一区二区在线 | 日韩高清一区 | 欲色av| 免费福利片 | 亚洲国产精 | 青青草成人在线 | 欧美一区二区三区在线观看视频 | 国产欧美日韩综合 | 一级大片免费看 | 日韩亚洲欧美在线 | a在线免费观看 | 亚洲精品久久久久久久久久久 | 香蕉视频网站 | 日韩av手机在线 | 国产h片在线观看 | 高清不卡av| 日韩国产精品视频 | 亚洲精品国产精品国自产观看浪潮 | 日韩女优在线观看 | 嫩草嫩草嫩草嫩草 | 日本黄色三级视频 | 欧美揉bbbbb揉bbbbb | 夜夜操夜夜爽 | 天堂在线中文资源 | 日本大尺度吃奶做爰久久久绯色 | 成人精品一区二区三区 | 亚洲欧美乱综合图片区小说区 | 黄av在线 | 激情六月天 | 欧美一区二区三区在线视频 | 国产精品3 | 国产欧美精品一区二区色综合 | 欧美日韩a| 久久av一区二区 | 国产精品久久久久久久 |
