查看: 2653|回復: 0
基于89S52單片機與12864液晶的俄羅斯方塊游戲
ID:111336 發(fā)表于 2016-3-29 19:46 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #ifndef _MAIN_H
  2. #define _MAIN_H
  3. #include <reg52.h>
  4. #define LcdDataPort P2   //數(shù)據(jù)端口
  5. #ifndef UCHAR_DEF
  6. #define UCHAR_DEF
  7. typedef unsigned char uchar;
  8. #endif
  9. sbit Reset = P3^0;   //復位
  10. sbit RS = P3^1;    //指令數(shù)據(jù)選擇
  11. sbit E = P3^2;    //指令數(shù)據(jù)控制
  12. sbit CS1 = P3^4;   //左屏幕選擇,低電平有效
  13. sbit CS2 = P3^5;   //右屏幕選擇
  14. sbit RW = P3^3;    //讀寫控制
  15. sbit busy = P2^7;   //忙標志
  16. void SetOnOff(uchar onoff);  //開關顯示
  17. void SelectScreen(uchar screen);//選擇屏幕
  18. void ClearScreen(uchar screen); //清屏
  19. void Show1616(uchar lin,uchar colum,uchar *address);//顯示一個漢字
  20. void CheckState();   //判斷狀態(tài)
  21. void LcdDelay(unsigned int time); //延時
  22. void WriteData(uchar dat); //寫數(shù)據(jù)
  23. void SendCommand(uchar command); //寫指令
  24. void SetLine(uchar line);  //置行地址
  25. void SetColum(uchar colum);//置列地址
  26. void SetStartLine(uchar startline);//置顯示起始行
  27. void InitLcd();    //初始化
  28. void ResetLcd();   //復位
  29. #endif
  30. /*********************************************************************/
  31. /***********************************lcd.c****************************************/
  32. void CheckState()
  33. {
  34. E = 1;
  35. RS = 0;
  36. RW = 1;
  37. LcdDataPort = 0xff;
  38. while(!busy);
  39. }
  40. void LcdDelay(unsigned int time)
  41. {
  42. while(time --);
  43. }
  44. void WriteData(uchar dat)
  45. {
  46. CheckState();
  47. E = 1;
  48. RS = 1;
  49. RW = 0;
  50. LcdDataPort = dat;
  51. E = 0;
  52. }
  53. void SendCommand(uchar command)
  54. {
  55. CheckState();
  56. E = 1;
  57. RW = 0;
  58. RS = 0;
  59. LcdDataPort = command;
  60. E = 0;
  61. }
  62. void SelectScreen(uchar screen) //0-全屏,1-左屏,2-右屏
  63. {
  64. switch(screen)
  65. {
  66.   case 0 :
  67.    CS1 = 0;
  68.    LcdDelay(2);
  69.    CS2 = 1;
  70.    LcdDelay(2);
  71.    break;
  72.   case 1 :
  73.    CS1 = 1;
  74.    LcdDelay(2);
  75.    CS2 = 0;
  76.    LcdDelay(2);
  77.    break;
  78.   case 2 :
  79.    CS1 = 0;
  80.    LcdDelay(2);
  81.    CS2 = 0;
  82.    LcdDelay(2);
  83.    break;
  84. }
  85. }
  86. void ClearScreen(uchar screen)  // screen 0-全屏,1-左屏,2-右屏
  87. {
  88. uchar i,j;
  89. SelectScreen(screen);
  90. for(i = 0;i < 8;i ++)
  91. {
  92.   SetLine(i);
  93.   SetColum(0);
  94.   for(j = 0;j < 64; j ++)
  95.    WriteData(0);
  96. }
  97. }
  98. void SetLine(uchar line)  //line -> 0 : 7
  99. {
  100. line = line & 0x07;
  101. line = line | 0xb8;   //1011 1xxx
  102. SendCommand(line);
  103. }
  104. void SetColum(uchar colum) //colum -> 0 :63
  105. {
  106. colum = colum & 0x3f;
  107. colum = colum | 0x40;  //01xx xxxx
  108. SendCommand(colum);
  109. }
  110. void SetStartLine(uchar startline) //startline -> 0 : 63
  111. {
  112. startline = startline & 0x3f;
  113. startline = startline | 0xc0; //11xxxxxx
  114. SendCommand(startline);
  115. }
  116. void SetOnOff(uchar onoff) //1-開顯示 0-關
  117. {
  118. if(onoff == 1)
  119.   SendCommand(0x3f);   //0011 111x
  120. else
  121.   SendCommand(0x3e);
  122. }
  123. void ResetLcd()
  124. {
  125. Reset = 0;
  126. LcdDelay(2);
  127. Reset = 1;
  128. LcdDelay(2);
  129. RS0 = 0;
  130. LcdDelay(2);
  131. RS1 = 0;
  132. LcdDelay(2);
  133. SetOnOff(1);
  134. }
  135. void InitLcd()
  136. {
  137. ResetLcd();
  138. SetOnOff(0);
  139. ClearScreen(2);
  140. SetLine(0);
  141. SetColum(0);
  142. SetStartLine(0);
  143. SetOnOff(1);
  144. }
  145. void Show1616(uchar lin,uchar colum,uchar *address)
  146. {
  147. uchar i;
  148. SetLine(lin);
  149. SetColum(colum);
  150. for(i = 0;i < 16;i ++)
  151.   WriteData(*(address ++));
  152. SetLine(lin + 1);
  153. SetColum(colum);
  154. for(i = 0;i < 16;i ++)
  155.   WriteData(*(address ++));
  156. }
  157. /*******************************************************************************/
  158. /********************************main.c***********************************************/
  159. #include <reg52.h>
  160. const uchar code HZ_tab[] = {44
  161. };
  162. void main()
  163. {
  164. uchar i,line,colum ;
  165. uchar *address ;
  166. InitLcd();
  167. while(1)
  168. {
  169.   colum = 16;
  170.   line = 1;
  171.   address = HZ_tab;
  172.   SetOnOff(0);                //關顯示
  173.   for(i = 1;i < 7;i ++)
  174.   {
  175.    if(i < 4)
  176.     SelectScreen(0);
  177.    else
  178.     SelectScreen(1);
  179.    Show1616(line,colum ,address);
  180.    colum += 16;
  181.    if(colum >63)
  182.     colum = 0;
  183.    address += 32;       //向DDRAM中寫入數(shù)據(jù)
  184.   }
  185.   line = 5;
  186.   colum = 0;
  187.   for(i = 0;i <8; i ++)
  188.   {
  189.    if(i < 4)
  190.     SelectScreen(0);
  191.    else
  192.     SelectScreen(1);
  193.    Show1616(line,colum ,address);
  194.    colum += 16;
  195.    if(colum >63)
  196.     colum = 0;
  197.    address += 32;
  198.   }
  199.   SelectScreen(2);
  200.   SetOnOff(1);    // 開顯示
  201.   for(i = 0;i < 50;i ++)  //延時
  202.    LcdDelay(30000);
  203. }
  204. }
  205. /************說明******************************
  206. 此程序包含一個俄羅斯方塊.c 文件和一個12864.h 文件
  207. ********************俄羅斯方塊.c文件**************************/
  208. #include "reg51.h"
  209. #include "12864.h"
  210. #define uchar unsigned char
  211. #define uint unsigned int
  212. static unsigned long Seed = 1;
  213. #define A 48271L
  214. #define M 2147483647L
  215. #define Q (M / A)
  216. #define R (M % A)
  217. sbit K1=P3^4;
  218. sbit K2=P3^5;
  219. sbit K3=P3^6;
  220. sbit K4=P3^7;
  221. unsigned int idata num[19+2]={
  222. 0xfff,//第1行,最下面
  223. 0x801,0x801,0x801,0x801,0x801,0x801,0x801,0x801,0x801,0x801,
  224. 0x801,0x801,0x801,0x801,0x801,0x801,0x801,0x801,0x801,//第2行到第20行共19行
  225. 0xfff//第21行,最上面
  226. };//定義共21行,其中num[0]為下墻壁行,num[20]為上墻壁行,每行12格,最左一格為左墻壁列,最右一格為右墻壁列
  227. unsigned char code Block[28][2]={
  228. /*
  229. *   口     口口口   口口
  230. *   口     口         口      口
  231. *   口口              口  口口口
  232. */
  233. {0x88,0xc0},{0xe8,0x00},{0x62,0x20},{0x02,0xe0},
  234. /*
  235. *   口        口口 口口口
  236. *   口 口     口       口
  237. * 口口 口口口 口
  238. */
  239. {0x22,0x60},{0x08,0xe0},{0xc8,0x80},{0xe2,0x00},
  240. /*
  241. *   口
  242. *   口口         口口
  243. *     口       口口
  244. */
  245. {0x8c,0x40},{0x6c,0x00},{0x8c,0x40},{0x6c,0x00},
  246. /*
  247. *   口        口口
  248. * 口口          口口
  249. * 口
  250. */
  251. {0x4c,0x80},{0xc6,0x00},{0x4c,0x80},{0xc6,0x00},
  252. /*
  253. *          口                口
  254. *   口     口口   口口口   口口
  255. * 口口口   口       口       口
  256. */
  257. {0x04,0xe0},{0x8c,0x80},{0xe4,0x00},{0x26,0x20},
  258. /*口
  259. * 口
  260. * 口       口口口口
  261. * 口
  262. */
  263. {0x44,0x44},{0x0f,0x00},{0x44,0x44},{0x0f,0x00},
  264. /*
  265. * 口口
  266. * 口口
  267. */
  268. {0x06,0x60},{0x06,0x60},{0x06,0x60},{0x06,0x60}
  269. };
  270. #define PASSSCORE 20
  271. struct Jimu
  272. {
  273. unsigned int dat;
  274. char x;
  275. unsigned char y;
  276. unsigned char type;
  277. unsigned char change;
  278. }Sign[3];//積木結(jié)構(gòu)體
  279. unsigned char SysFlag=0;
  280. #define NEWSIGNFLAG 0
  281. #define DEADFLAG 1
  282. #define PAUSEFLAG 2
  283. unsigned char Score=0;
  284. unsigned char Level=1;
  285. unsigned char DelayCnt=5;
  286. /*********************************************************/
  287. #define N 25
  288. /************************************
  289. 偽隨機數(shù)發(fā)生器
  290. *************************************/
  291. double Random(void)
  292. {
  293. long TmpSeed;
  294. TmpSeed=A*(Seed%Q)-R*(Seed/Q);
  295. if(TmpSeed>=0)
  296. Seed=TmpSeed;
  297. else
  298. Seed=TmpSeed+M;
  299. return (double)Seed/M;
  300. }
  301. /**************************************
  302. 為偽隨機數(shù)發(fā)生器播種
  303. ***************************************/
  304. void InitRandom(unsigned long InitVal)
  305. {
  306. Seed=InitVal;
  307. }
  308. //延時子程序
  309. void Delay(unsigned int t)
  310. {
  311. unsigned int i,j;
  312. for(i=0;i<t;i++)
  313. for(j=0;j<10;j++);
  314. }
  315. /*********************************
  316. 初始化MPU
  317. **********************************/
  318. void InitCpu(void)
  319. {
  320. TMOD=0x0;
  321. TH0=0;
  322. TL0=0;
  323. TR0=1;
  324. ET0=1;
  325. EX1=1;
  326. EA=1;
  327.     TCON|=0x04;
  328. }
  329. /****************************
  330. welcome  游戲選擇界面
  331. /**********************/
  332. void welcome()
  333. {
  334. Lcd_WriteStr(0,0,"歡迎來玩");
  335. Lcd_WriteStr(0,1,"俄羅斯方塊");
  336. Lcd_WriteStr(0,2,"設置按K1");
  337. Lcd_WriteStr(0,2,"開玩按K2");
  338. }
  339. /*************俄羅斯方塊部分
  340. /******************************
  341. 畫墻壁,初始化界面
  342. *******************************/
  343. void DrawBoard(void)
  344. {
  345. unsigned char n;
  346. for(n=0;n<12;n++) ////畫上下兩邊的墻壁
  347. {
  348. Lcd_Rectangle(3*n,0,3*n+2,2,1);////在最上面一行畫個2*2的方塊
  349. Lcd_Rectangle(3*n,60,3*n+2,62,1);////在最下面一行畫個2*2的方塊
  350. }
  351. for(n=0;n<20;n++) ////畫左右兩邊的墻壁
  352. {
  353. Lcd_Rectangle(0,3*n,2,3*n+2,1); ////在左面畫2*2的方塊
  354. Lcd_Rectangle(33,3*n,35,3*n+2,1);////在右面畫2*2的方塊
  355. }
  356. Lcd_WriteStr(4,0,"經(jīng)典游戲");
  357. Lcd_WriteStr(3,2,"Score:");
  358. Lcd_WriteStr(3,3,"Level:");
  359. }
  360. /***********************************
  361. 游戲結(jié)束處理
  362. ************************************/
  363. void GameOver(void)
  364. {
  365. if((SysFlag&(1<<DEADFLAG))!=0)
  366. Lcd_WriteStr(3,1,"You Fail");////SysFlag=2
  367. else
  368. Lcd_WriteStr(3,1,"You Pass");////SysFlag=1或=0
  369. }
  370. unsigned int code MaskTab[16]={
  371. 0x0001,0x0002,0x0004,0x0008,0x0010,0x0020,0x0040,0x0080,
  372. 0x0100,0x0200,0x0400,0x0800,0x1000,0x2000,0x4000,0x8000
  373. };
  374. /**********************************
  375. 根據(jù)積木圖標左下坐標X,Y來畫出積木圖標
  376. ***********************************/
  377. void DrawSign(struct Jimu Temp,unsigned char DrawMode)
  378. {
  379. unsigned char m,n;
  380. for(m=0;m<4;m++)
  381. for(n=0;n<4;n++)
  382. {
  383. if((Temp.dat&MaskTab[4*m+n])!=0)
  384. Lcd_Rectangle(Temp.x+n*3,Temp.y-2-3*m,Temp.x+n*3+2,Temp.y-3*m,DrawMode);
  385. }
  386. }
  387. /********************************
  388. 將積木圖標值融入num數(shù)據(jù)中
  389. 也即把積木圖標固定,無法再下降
  390. *********************************/
  391. void FixSign(void)
  392. {
  393. unsigned char m,n;
  394. for(m=0;m<4;m++)//行循環(huán)
  395. for(n=0;n<4;n++)//列循環(huán)
  396. {
  397. if((Sign[0].dat&MaskTab[4*m+n])!=0)
  398. {
  399. num[20-(Sign[0].y-2)/3+m]|=MaskTab[11-Sign[0].x/3-n];
  400. }
  401. }
  402. }
  403. /********************************
  404. 判斷積木圖標中方塊是否與障礙方塊重合
  405. *********************************/
  406. unsigned char CheckIf(void)
  407. {
  408. unsigned char m,n;
  409. for(m=0;m<4;m++)//行循環(huán)
  410. for(n=0;n<4;n++)//列循環(huán)
  411. {
  412. if((Sign[1].dat&MaskTab[4*m+n])!=0)
  413. {
  414. if((num[20-(Sign[1].y-2)/3+m]&MaskTab[11-Sign[1].x/3-n])!=0)
  415. return 0;
  416. }
  417. }
  418. return 1;
  419. }
  420. /********************************
  421. 判斷積木圖標是否可以繼續(xù)下降一格
  422. ********************************/
  423. unsigned char CheckIfDown(void)
  424. {
  425. Sign[1]=Sign[0];//
  426. Sign[1].y+=3;//假設下降一格
  427. return CheckIf();
  428. }
  429. /********************************
  430. 判斷積木圖標是否可以向左移動
  431. *********************************/
  432. unsigned char CheckIfLeft(void)
  433. {
  434. Sign[1]=Sign[0];
  435. Sign[1].x-=3;
  436. return CheckIf();
  437. }
  438. /********************************
  439. 判斷積木圖標是否可以向右移動
  440. *********************************/
  441. unsigned char CheckIfRight(void)
  442. {
  443. Sign[1]=Sign[0];
  444. Sign[1].x+=3;
  445. return CheckIf();
  446. }
  447. /********************************
  448. 判斷是否可以旋轉(zhuǎn)
  449. *********************************/
  450. unsigned char CheckIfRoll(void)
  451. {
  452. unsigned char i;
  453. unsigned int Temp;
  454. Sign[1]=Sign[0];
  455. if(++Sign[1].change>3)
  456. Sign[1].change=0;
  457.    i=Sign[1].type*4+Sign[1].change;
  458. Temp=(unsigned int)Block[i][0]<<8;
  459. Temp=Temp|Block[i][1];
  460. Sign[1].dat=Temp;
  461. return CheckIf();
  462. }
  463. /********************************
  464. 尋找滿格的行并做消除處理
  465. 最多尋找4個滿行并做消除
  466. *********************************/
  467. void DelFull(void)
  468. {
  469. unsigned char m,n;
  470. unsigned char Temp;
  471. unsigned char Flag=0;
  472. Temp=(Sign[0].y-2)/3;
  473. if(Temp>=20)//防止越過了下邊界
  474. Temp=1;
  475. else
  476. Temp=20-Temp;
  477. ////Temp為積木的最下邊界,即最下一行
  478. for(n=Temp+3;n>=Temp;n--)//積木圖標的最頂行開始尋找滿行比較有利于運算
  479. {
  480. if(num[n]==0xfff)
  481. {
  482. Flag=1;
  483. for(m=n+1;m<=19;m++)
  484. {
  485. num[m-1]=num[m];
  486. }
  487. num[m]=0x801;
  488. Score++;//每找到一個滿行,則分數(shù)加1
  489. }
  490. }
  491. if(Flag)//為加速而設置并判斷的標志,有已固定的積木有滿格消行變化則重畫積木界面
  492. {
  493. /*行*/for(m=Temp;m<=19;m++)//為加速,不必要重第一行重畫起,只需要從積木圖標最下行開始往上的重畫
  494. /*列*/for(n=1;n<=10;n++)
  495. {
  496. if((num[m]&MaskTab[n])==0)
  497. {
  498. if(Lcd_ReadPixel(30-(n-1)*3,57-(m-1)*3)!=0)
  499. //為加速而做的讀象素操作
  500. ////如果該像素為1,即為黑點
  501. {
  502. Lcd_Rectangle(30-(n-1)*3,57-(m-1)*3,30-(n-1)*3+2,57-(m-1)*3+2,0);
  503. }////將給像素設置為0,即為空白
  504. }
  505.   else
  506. {
  507. if(Lcd_ReadPixel(30-(n-1)*3,57-(m-1)*3)==0)//為加速而做的讀象素操作
  508. {  ////如果該像素為0
  509. Lcd_Rectangle(30-(n-1)*3,57-(m-1)*3,30-(n-1)*3+2,57-(m-1)*3+2,1);
  510. }  ////將給像素設置為1
  511. }
  512. }
  513. }
  514. }
  515. /*******************************
  516. 隨機產(chǎn)生一個積木圖標放到預產(chǎn)生區(qū)域并顯示出來
  517. ********************************/
  518. void CreatSign(void)
  519. {
  520. unsigned char n;
  521. unsigned int Temp;
  522. DrawSign(Sign[2],0);//先清除
  523. n=Random()*28;
  524. Temp=(unsigned int)Block[n][0]<<8;  ////產(chǎn)生積木圖形的高八位
  525. Temp=Temp|Block[n][1];  ////產(chǎn)生積木圖形的第八位
  526. Sign[2].dat=Temp;
  527. Sign[2].x=45;
  528. Sign[2].y=4*3+2;
  529. Sign[2].type=n/4;////什么意思
  530. Sign[2].change=n%4;
  531. DrawSign(Sign[2],1);//后畫出
  532. }
  533. void PrintScore(void)
  534. {
  535. unsigned char Str[3];
  536. Str[0]=(Score/10)|0x30;
  537. Str[1]=(Score%10)|0x30;
  538. Str[2]=0;
  539. Lcd_WriteStr(6,2,Str);
  540. }
  541. void PrintLevel(void)
  542. {
  543. unsigned char Str[3];
  544. Str[0]=(Level/10)|0x30;
  545. Str[1]=(Level%10)|0x30;
  546. Str[2]=0;
  547. Lcd_WriteStr(6,3,Str);
  548. }
  549. /********************************
  550. 游戲的具體過程,也是俄羅斯方塊算法的關鍵部分
  551. *********************************/
  552. void GamePlay(void)
  553. {
  554. unsigned char m,n;
  555. unsigned int Temp;
  556. SysFlag|=1<<NEWSIGNFLAG;//剛開始初始化為需要產(chǎn)生新的積木圖標  ////SysFlag=1
  557. InitRandom(TL0);  ////用以產(chǎn)生隨即數(shù)
  558. Lcd_WriteStr(3,1,"Playing");
  559. PrintScore();
  560. PrintLevel();
  561. CreatSign();////先清空積木顯示區(qū)域,在隨即產(chǎn)生一個類型的積木
  562. while(1)
  563. {
  564. if((SysFlag&(1<<NEWSIGNFLAG))==1)//判是否需要產(chǎn)生新的積木圖標
  565. {////SysFlag=1時產(chǎn)生新積木
  566. SysFlag&=~(1<<NEWSIGNFLAG);   ////SysFlag=0
  567. Sign[0]=Sign[2];
  568. CreatSign();
  569. Sign[0].x=12;
  570. Sign[0].y=14;
  571. for(m=0;m<4;m++)//行循環(huán)
  572. {
  573. for(n=0;n<4;n++)//列循環(huán)
  574. {
  575. if((Sign[0].dat&MaskTab[15-m*4-n])==0) ////從最高位開始倒序測試
  576. break;////測試Sign[0].dat的每一位,如果為該位為1,則繼續(xù)測試下一位
  577. ////若為0,則直接測試下半字節(jié)
  578. }
  579. if(n==4)  ////如果在半個字節(jié)里面每一位數(shù)據(jù)都是1,則將縱坐標-3,即向上移動一個小方格
  580. Sign[0].y-=3;
  581. }//將積木圖標出現(xiàn)置頂
  582. for(m=0;m<4;m++)//行循環(huán)
  583. for(n=0;n<4;n++)//列循環(huán)
  584. {
  585. if((Sign[0].dat&MaskTab[4*m+n])!=0)////從最低位開始順序測試
  586. {
  587. if((num[20-(Sign[0].y-2)/3+m]&MaskTab[11-Sign[0].x/3-n])!=0)
  588. ////2為上墻壁,(Sign[0].y-2)/3為積木的總高度
  589. ////num[20-(Sign[0].y-2)/3+m] 從下往上變化
  590. ////MaskTab[11-Sign[0].x/3-n]為從4*4積木的最右邊往積木的最左邊變化
  591. SysFlag|=1<<DEADFLAG; ////SysFlag=2;
  592. }
  593. }
  594. if((SysFlag&(1<<DEADFLAG))!=0)
  595. break;//如果產(chǎn)生新的積木圖標中的方塊與已固定好的方塊重合,則死亡。游戲結(jié)束
  596. DrawSign(Sign[0],1);
  597. }
  598. if((CheckIfLeft())&&(K3==0)) //左
  599. {
  600. DrawSign(Sign[0],0);
  601. Sign[0].x-=3;
  602. DrawSign(Sign[0],1);
  603. }
  604. if((CheckIfRight())&&(K4==0))  //右
  605. {
  606. DrawSign(Sign[0],0);
  607. Sign[0].x+=3;
  608. DrawSign(Sign[0],1);
  609. }
  610. if((CheckIfDown())&&(K2==0))//下
  611. {
  612. DrawSign(Sign[0],0);
  613. Sign[0].y+=3;
  614. DrawSign(Sign[0],1);
  615. }
  616. if((CheckIfRoll())&&(K1==0)) //翻轉(zhuǎn)
  617. {
  618. DrawSign(Sign[0],0);
  619. if(++Sign[0].change>3)
  620. Sign[0].change=0;
  621.   m=Sign[0].type*4+Sign[0].change;
  622. ////將Block數(shù)組中的元素分為7類,type為該類型;該類型分為4種,change為種類
  623. ////所以,change加1之后就表示翻轉(zhuǎn)之后的積木形態(tài)
  624. Temp=(unsigned int)Block[m][0]<<8;
  625. Temp=Temp|Block[m][1]; ////讀取翻轉(zhuǎn)之后積木形態(tài)的dat數(shù)據(jù)
  626. Sign[0].dat=Temp;   ////賦dat值給積木結(jié)構(gòu)體的dat
  627. DrawSign(Sign[0],1);  ////畫出翻轉(zhuǎn)后的積木
  628. }
  629. ////2
  630. if((SysFlag&(1<<PAUSEFLAG))!=0)
  631. continue;
  632. Delay(500);
  633. if(++DelayCnt>=2*(11-Level))
  634. {
  635. DelayCnt=0;
  636. if(CheckIfDown())//判斷是否能繼續(xù)下降一格
  637. {
  638. DrawSign(Sign[0],0);
  639. Sign[0].y+=3;
  640. DrawSign(Sign[0],1);
  641. }
  642. else
  643. {
  644. FixSign();  ////將積木移入num數(shù)組中
  645. DelFull(); ////消行處理
  646. PrintScore();
  647. if(Score>=PASSSCORE)
  648. {
  649. SysFlag&=~(1<<DEADFLAG); ////SysFlag=1或=0
  650. break;//跳出玩游戲過程
  651. }
  652. SysFlag|=1<<NEWSIGNFLAG;//新的積木圖標產(chǎn)生標志置1
  653. }
  654. }
  655. }
  656. }
  657. void Main()
  658. {
  659. InitCpu();//初始化CPU
  660. Lcd_Reset(); //初始化LCD屏
  661. Lcd_Clear(0);//清屏
  662. Lcd_Reset(); //初始化LCD屏
  663. Lcd_Clear(0);//清屏
  664. DrawBoard();//畫界面
  665. GamePlay();//玩游戲
  666. GameOver();//游戲結(jié)束
  667. Lcd_Reset(); //初始化LCD屏
  668. Lcd_Clear(0);//清屏
  669. }
主站蜘蛛池模板: a级片免费观看 | 日本在线视频一区 | 一级片免费视频 | 中文字幕av一区二区三区 | 一区二区水蜜桃 | 亚洲小视频在线观看 | 欧美一级黄 | 69视频在线播放 | 9l视频自拍九色9l视频成人 | 午夜在线观看视频 | 美女一级毛片 | 中文在线免费观看 | 中文字幕理伦片免费看 | 少妇视频网站 | 日韩欧美在线观看视频 | 可以免费看黄色的网站 | 婷婷第四色 | 91人人爽 | 久久日韩精品 | 日韩新片王网 | 91亚色视频 | 日日干日日操 | 欧美黄色片在线观看 | 黑森林av | a级片免费 | 性生活毛片| 中文字幕亚洲一区 | 欧美日韩国产一区 | 欧美性受xxxx黑人xyx性爽 | www.久久久久 | 欧美理论在线观看 | 国产精品6 | 精品视频在线免费 | 天天干在线观看 | 久久久天堂国产精品女人 | 怡红院久久 | 超碰在线免费播放 | 曰本毛茸茸性生活 | 综合网在线| 成人欧美激情 | 亚洲人网站|
