查看: 2095|回復: 0
看門狗程序
ID:116518 發表于 2016-4-25 11:14 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <msp430x14x.h>
void Init_Port(void)
    //將P1口所有的管腳在初始化的時候設置為輸入方式
    P1DIR = 0;
    //將P1口所有的管腳設置為一般I/O口
    P1SEL = 0;
    // 將P1.4 P1.5 P1.6 P1.7設置為輸出方向
    P1DIR |= BIT4;
    P1DIR |= BIT5;
        P1DIR |= BIT6;
    P1DIR |= BIT7;
        //先輸出低電平
        P1OUT = 0x00;
        // 將中斷寄存器清零
    P1IE = 0;
    P1IES = 0;
    P1IFG = 0;
    //打開管腳的中斷功能
        //對應的管腳由高到低電平跳變使相應的標志置位
    P1IE |= BIT0;
    P1IES |= BIT0;
    P1IE |= BIT1;
    P1IES |= BIT1;
        P1IE |= BIT2;
    P1IES |= BIT2;
    P1IE |= BIT3;
    P1IES |= BIT3;
        _EINT();//打開中斷
    return;
void Delay(void)
        int i;
        for(i = 100;i--;i > 0) ;//延時一點時間
int KeyProcess(void)
    int nP10,nP11,nP12,nP13;
        int nRes = 0;
        //P1.4輸出低電平
        P1OUT &= ~(BIT4);
        nP10 = P1IN & BIT0;
        if (nP10 == 0) nRes = 13;
        nP11 = P1IN & BIT1;
        if (nP11 == 0) nRes = 14;
        nP12 = P1IN & BIT2;
        if (nP12 == 0) nRes = 15;
        nP13 = P1IN & BIT3;
        if (nP13 == 0) nRes = 16;
        //P1.5輸出低電平
        P1OUT &= ~(BIT4);
        nP10 = P1IN & BIT0;
        if (nP10 == 0) nRes = 9;
        nP11 = P1IN & BIT1;
        if (nP11 == 0) nRes = 10;
        nP12 = P1IN & BIT2;
        if (nP12 == 0) nRes = 11;
        nP13 = P1IN & BIT3;
        if (nP13 == 0) nRes = 12;
        //P1.6輸出低電平
        P1OUT &= ~(BIT4);
        nP10 = P1IN & BIT0;
        if (nP10 == 0) nRes = 5;
        nP11 = P1IN & BIT1;
        if (nP11 == 0) nRes = 6;
        nP12 = P1IN & BIT2;
        if (nP12 == 0) nRes = 7;
        nP13 = P1IN & BIT3;
        if (nP13 == 0) nRes = 8;
        //P1.7輸出低電平
        P1OUT &= ~(BIT4);
        nP10 = P1IN & BIT0;
        if (nP10 == 0) nRes = 1;
        nP11 = P1IN & BIT1;
        if (nP11 == 0) nRes = 2;
        nP12 = P1IN & BIT2;
        if (nP12 == 0) nRes = 3;
        nP13 = P1IN & BIT3;
        if (nP13 == 0) nRes = 4;
        P1OUT = 0x00;//恢復以前值。
        //讀取各個管腳的狀態
        nP10 = P1IN & BIT0;
        nP11 = P1IN & BIT1;
        nP12 = P1IN & BIT2;
        nP13 = P1IN & BIT3;
        for(;;)
                if(nP10 == 1 && nP11 == 1 && nP12 == 1 && nP13 == 1)
                        //等待松開按鍵
                        break;
        return nRes;
// 處理來自端口 1 的中斷
interrupt [PORT1_VECTOR] void PORT_ISR(void)
        Delay();
        KeyProcess();
    if(P1IFG & BIT0)
            P1IFG &= ~(BIT0);// 清除中斷標志位
    if(P1IFG & BIT1)
            P1IFG &= ~(BIT1);// 清除中斷標志位
    if(P1IFG & BIT2)
            P1IFG &= ~(BIT2);// 清除中斷標志位
        if(P1IFG & BIT3)
            P1IFG &= ~(BIT3);// 清除中斷標志位
void Init_CLK(void)
    unsigned int i;
    BCSCTL1 = 0X00;                        //將寄存器的內容清零
                                        //XT2震蕩器開啟
                                        //LFTX1工作在低頻模式
                                        //ACLK的分頻因子為1
    do
        IFG1 &= ~OFIFG;                       // 清除OSCFault標志
        for (i = 0x20; i > 0; i--);
    while ((IFG1 & OFIFG) == OFIFG);      // 如果OSCFault =1
    BCSCTL2 = 0X00;                        //將寄存器的內容清零
    BCSCTL2 += SELM1;                //MCLK的時鐘源為TX2CLK,分頻因子為1
    BCSCTL2 += SELS;                //SMCLK的時鐘源為TX2CLK,分頻因子為1
主站蜘蛛池模板: 福利视频1000 | 国产欧美精品一区 | 日本一区二区三区免费观看 | 4虎最新网址| 91麻豆精品国产 | 香蕉视频一区二区三区 | 国产一级片免费观看 | 久久久久久97 | 久久香蕉精品 | 亚洲天堂男人天堂 | 免费a视频 | 亚洲成人精品一区 | 香蕉久久a毛片 | 国产成人97精品免费看片 | 亚洲精品视频在线播放 | 国产精品一区二区三区四区 | 日日夜夜精品 | 久久精品av| 在线免费观看日韩av | 一区二区三区国产 | 亚洲国产成人在线 | 日本中文字幕网站 | 国产又粗又大又长 | 久在线视频| 成人激情在线 | 免费爱爱网站 | 亚洲一区二区在线 | 中国女人真人一级毛片 | 天天操夜夜摸 | 日韩一级视频 | 黄色片小视频 | 中文在线资源 | 久久久久久爱 | 亚洲毛片av | 日韩精品在线免费观看 | 国产成人高清 | 精品国产乱码一区二区三 | 久久天堂av | 欧美午夜精品一区二区三区 | 亚洲一区免费观看 | 天天插夜夜操 |
