查看: 3554|回復(fù): 2
誰能給幫忙把這個(gè)程序分解下謝謝。數(shù)碼管實(shí)在搞不亮
#include "p18cxxx.h"              //頭文件
#include "delays.h"
#include "SEG.h"
#define uchar unsigned char
#define uint unsigned int
#define  uch unsigned char                     //給unsigned char起別名 uch
# define DQ  LATAbits.LATA0                              //定義18B20數(shù)據(jù)端口
# define DQ_DIR TRISAbits.TRISA0                         //定義18B20D口方向寄存器
# define DQ_HIGH()  DQ =1 ; DQ_DIR =1                  //設(shè)置數(shù)據(jù)口為輸入
# define DQ_LOW()    DQ_DIR = 0 ;DQ = 0        //設(shè)置數(shù)據(jù)口為輸出
unsigned char  TLV=0 ;                        //采集到的溫度高8位
unsigned char  THV=0;                         //采集到的溫度低8位
unsigned char TZ=0;                           //轉(zhuǎn)換后的溫度值整數(shù)部分
unsigned char TX=0;                           //轉(zhuǎn)換后的溫度值小數(shù)部分
unsigned int wd;                              //轉(zhuǎn)換后的溫度值BCD碼形式
unsigned char shi;                             //整數(shù)十位
unsigned char ge;                              //整數(shù)個(gè)位
unsigned char shifen;                          //十分位
unsigned char baifen;                          //百分位
unsigned char qianfen;                         //千分位
unsigned char wanfen;                          //萬分位
#define TMR0HLOAD     0xf6        //4MHZ  2.5mS
#define TMR0LLOAD     0x4D
unsigned char TickClock = 0;      //系統(tǒng)時(shí)基
#define SCLK   LATBbits.LATB0     //74HC164時(shí)鐘
#define SDAT   LATBbits.LATB1     //74HC164數(shù)據(jù)
const unsigned char SegCode[] =   //圖型表
    Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,
    Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,
    BmpCMap,BmpDMap,BmpEMap,BmpFMap
const unsigned char SegCS[6] = {0xFE,0xFD,0xFB,0xF7,0xEF,0xDF};              //顯示片選
unsigned char SegBuf[6] = {BmpPMap,Bmp1Map,BmpCMap,Bmp1Map,Bmp8Map,BmpFMap}; //顯示緩沖
// 數(shù)碼管顯示驅(qū)動(dòng)
void SegDisplay(void)
static unsigned char i = 0;
unsigned char j;
unsigned char tep;
tep = SegCS;         //片選輸出
for(j=0;j<8;j++)        //8位
  if(tep&0x80) SDAT = 1;
  else         SDAT = 0;
  SCLK = 1;
  SCLK = 0;
  tep = tep<< 1;
tep = SegBuf;        //數(shù)據(jù)輸出
  else         SDAT = 0;
  SCLK = 1;
  SCLK = 0;
  tep = tep<< 1;
if(i < 5) i ++;        //掃描6位
else      i = 0;
// ADC采集程序
unsigned int  SampleADValue[8];    // 8次采樣
unsigned int  AvgADValue = 0;      // AD采樣平均值
unsigned char ADConverStep = 0;    // AD采樣頻步
void GET_ADValue(void)
unsigned char i;
unsigned int ConverValue;
do
}while(ADCON0bits.GO_DONE);   //等待轉(zhuǎn)換完成
ConverValue = ADRESH;         //處理10位結(jié)果
ConverValue = (ConverValue << 8) + ADRESL;
SampleADValue[ADConverStep] = ConverValue;
if (ADConverStep == 7)
  ConverValue = 0;
  for (i = 0; i < 8 ; i++)
   ConverValue += SampleADValue;
  AvgADValue = ConverValue >> 3;
  ADConverStep = 0;
  ADConverStep++;
// TMR1定時(shí)器初始化
void TMR1_Init(void)
TMR1H = 0xF0;             //4mS 4MHz
TMR1L = 0x98;
T1CONbits.RD16 = 1;       //16位定時(shí)方式
T1CONbits.TMR1CS = 0;     //內(nèi)部FOSC/4
PIE1bits.TMR1IE = 1;      //T1中斷 ON
// ADC初始化
void ADC_Init(void)               // ADC 初始化
ADCON0 = 0b00000001;          // ADC模塊使能
ADCON1 = 0b00001110;          // AN0 ADC輸入
ADCON2 = 0b10111111;          // 右對(duì)齊  FRC
// 高優(yōu)先級(jí)中斷向量
#pragma code InterruptVectorHigh = 0x08
void InterruptVectorHigh(void)
_asm
goto  Interrupt_High        //跳到中斷程
_endasm
// 高優(yōu)先級(jí)中斷服務(wù)程序
#pragma interrupt Interrupt_High
void Interrupt_High(void)
if(PIR1bits.TMR1IF)          //T1中斷
  PIR1bits.TMR1IF = 0;     //清除標(biāo)志位
  TMR1H = 0xF0;            //4MS
  TMR1L = 0x98;
  SegDisplay();            //掃描顯示
  TickClock = 1;          //置位
if(PIR1bits.RCIF)            // 接收中斷
  PIR1bits.RCIF = 0;
  TXREG = RCREG;           // 將收到的數(shù)據(jù)發(fā)出
  if(RCSTAbits.OERR)       // 接收溢出錯(cuò)誤處理
   RCSTAbits.CREN = 0;
   RCSTAbits.CREN = 1;
// 計(jì)算溫度值
int GET_TempValue(unsigned int ADCValue)
ADCValue = (32*ADCValue)/10;     // y = (3300/1024)* x
if(ADCValue >500)   ADCValue = (ADCValue - 500);   //零上   500mV時(shí) 零度
else                ADCValue = (500 - ADCValue);   //零下
return ADCValue;
void initled()//初始化數(shù)碼管
SegBuf[0] = Bmp0Map;               // "T"
SegBuf[1] = Bmp0Map;                  // "P"
SegBuf[2] = Bmp0Map;    //千位
SegBuf[3] = Bmp0Map;//百位
SegBuf[4] = Bmp0Map;
SegBuf[5] = Bmp0Map;
// 數(shù)碼管分段顯示函數(shù)
void LEDisplay(unsigned int ADValue)
SegBuf[2] = SegCode[ADValue/1000];    //千位
SegBuf[3] = SegCode[ADValue%1000/100];//百位
SegBuf[4] = SegCode[ADValue%100/10]|Smg_dp;  //十位 有小數(shù)點(diǎn)
SegBuf[5] = SegCode[ADValue%10];      //個(gè)位
// 主程序部分
void main(void)
unsigned int SystemTick = 0; // 串口發(fā)數(shù)據(jù)定時(shí)
TRISB = 0b11111100;          //RB0 RB1 輸出
TMR1_Init();                 //定時(shí)器1初始化
ADC_Init();                  //ADC初始化
INTCONbits.PEIE = 1;         //外設(shè)中斷允許
INTCONbits.GIE  = 1;         //總中斷允許
T1CONbits.TMR1ON= 1;         //使能T1
  initled();
  if(TickClock)            //采集AD值
   TickClock = 0;
   ADCON0bits.GO_DONE = 1;
   SystemTick ++;
   GET_ADValue();
  if(SystemTick > 300)     //發(fā)送1次AD采樣值
   SystemTick = 0;
   AvgADValue = GET_TempValue(AvgADValue);  //獲取溫度值
   LEDisplay(AvgADValue);                   //顯示溫度值
我想把數(shù)碼管顯示和定時(shí)器分離,搞74HC146清楚數(shù)碼管到底怎么驅(qū)動(dòng)的。或者哪位大神幫忙注釋下,
相關(guān)帖子
ID:111634 發(fā)表于 2016-7-3 11:15 | 只看該作者
本帖最后由 zl2168 于 2016-7-3 11:21 編輯
是74HC164,不是74HC146。164是串入并出一位寄存器。
先給你個(gè)74HC164串入并出控制16循環(huán)燈案例吧
區(qū)別是:你的案例是8位段碼和6位位碼(共14位),我的案例是16位數(shù)據(jù),實(shí)際上是一樣的。
Proteus仿真一下,確認(rèn)有效。
實(shí)例42 74HC164串行輸出控制8-16循環(huán)燈.rar (53.19 KB, 下載次數(shù): 4)
以上摘自張志良編著《單片機(jī)實(shí)驗(yàn)實(shí)訓(xùn)100例》 ISBN 978-7-5124-1603-1,北航社出版
書中電路和程序設(shè)計(jì)有詳細(xì)說明,程序語句條條有注解。
ID:472325 發(fā)表于 2019-2-7 11:09 | 只看該作者
要先保證一種情況下亮,定時(shí)與溫度只是錯(cuò)開不斷刷新的事
主站蜘蛛池模板: 色播av| 黄色片在线 | 亚洲视频在线看 | 五月天丁香 | 亚洲精品在线免费 | 性色av一区二区 | 怡红院av | 亚洲激情在线视频 | 成人动漫一区二区 | 精品一区二区三区四区五区 | 国产精品久久久久久久久久久久久 | 国产午夜精品一区二区三区视频 | 国产成人免费观看 | 亚洲国产一区二区三区 | 久久午夜剧场 | 免费国产一区 | 亚洲高清免费 | 水蜜桃一区二区 | 久久男人的天堂 | 亚洲精品a| 亚洲综合二区 | 婷婷综合视频 | 激情啪啪网 | 国产日韩在线播放 | www.四虎影视 | 中文字幕日韩欧美 | 精品在线一区二区 | 成人一级视频 | 日韩精品影视 | 伊人av网| 久久一区二区三区四区 | 在线视频黄 | 精品国产福利 | 国产伦精品一区二区三区免费视频 | 色吧综合 | 亚洲九九夜夜 | 九色精品 | 精品视频国产 | 亚洲精品自拍视频 | 秋霞一区| av在线一区二区 |
