查看: 2104|回復: 0
單片機交通燈設計源碼
ID:145459 發表于 2016-11-2 11:37 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
實驗名:交通燈設計
實驗內容:利用中斷,定時/計數器,數碼管和led燈進行交通燈的設計
                                       #include <reg52.h>
                                 #define uint unsigned int
                                        #define uchar unsigned char
                                        sbit wei1=P2^4;             //定義位選 0
                                        sbit wei2=P2^5;             //1
                                        sbit wei3=P2^6;             //2
                                        sbit wei4=P2^7;             //3
                                        sbit green_we=P1^2;         //定義交通燈綠東西
                                        sbit green_ns=P1^3; //定義交通燈綠南北
                                        sbit red_we=P1^0;    //定義交通燈紅東西
                                        sbit red_ns=P1^1;      //定義交通燈紅南北
                                        sbit yellow_we=P1^4;        //定義交通燈黃東西
                                        sbit yellow_ns=P1^5;         //定義交通燈黃南北
                                        uchar num,num1,shi_we,shi_ns,ge_we,ge_ns;
                                        uint xianshi_we,xianshi_ns;
                                        uchar code table[]={
                                        0x3f,0x06,0x5b,0x4f,0x66,
                                        0x6d,0x7d,0x07,0x7f,0x6f}; //定義數值0,1,2....9
                                        void delayms(uint xsm) //延時程序
                                        uint i,j;
                                        for(i=xsm;i>0;i--)
                                        for(j=110;j>0;j--);
                                        void display(uchar shi_we,uchar ge_we,ucharshi_ns,uchar ge_ns)          //定義數碼管函數
                                        wei1=1;
                                        wei2=0;
                                        wei3=0;
                                        wei4=0;
                                        P0=table[shi_we];
                                        delayms(5);
                                        wei1=0;
                                        wei2=1;
                                        wei3=0;
                                        wei4=0;
                                        P0=table[ge_we];
                                        delayms(5);
                                        wei1=0;
                                         wei2=0;
                                        wei3=1;
                                        wei4=0;
                                        P0=table[shi_ns];
                                        delayms(5);
                                        wei1=0;
                                        wei2=0;
                                        wei3=0;
                                        wei4=1;
                                        P0=table[ge_ns];
                                        delayms(5);
                                        num=0;
                                        num1=0;
                                        xianshi_we=99;
                                        xianshi_ns=99;
                                        shi_we=9;
                                        ge_we=9;
                                        shi_ns=9;
                                        ge_ns=9;
                                        TMOD=0x51;                                   //設置定時器0和計數器1為工作方式1
                                        TH0=(65536-46080)/256;    //設置初值
                                        TL0=(65536-46080)%256;
                                        TH1=(65536-46080)/256;
                                        TL1=(65536-46080)%256;
                                        EA=1;                                        //開總中斷
                                        ET0=1;                                               //開定時器0中斷
                                        ET1=1;                                               //開定時器1中斷
                                        TR0=1;                                               //啟動定時器0
                                        TR1=1;                                               //啟動定時器1
                                        P1=0xff;         //led燈全滅
                                        P1=0xf6;  //定義東西亮紅燈,南北亮綠燈;
                                               display(shi_we,ge_we,shi_ns,ge_ns);
                                                 if(num1==1140)
                                               P1=0xde;//定義東西亮紅燈,南北亮黃燈;
                                    if(num1==1200)
                                               P1=0xf9;//定義東西亮綠燈,南北亮紅燈;
                                               xianshi_we=60;
                                    xianshi_ns=60;
                                    if(num1==2340)
                                               P1=0xed;//定義東西亮黃燈,南北亮紅燈;
                                    if(num1==2400)
                                               num1=0;
                                               xianshi_we=60;
                                    xianshi_ns=60;
                                               P1=0xf6;//定義東西亮紅燈,南北亮綠燈;
                                        void T0_time()interrupt 1
                                               num++;
                                               if(num%20==0)
                                          num=0;
                                                xianshi_we--;
                                           xianshi_ns--;
                                                shi_we=xianshi_we/10;
                                                ge_we=xianshi_we%10;
                                                shi_ns=xianshi_ns/10;
                                                ge_ns=xianshi_ns%10;
                                        void T1_count() interrupt 3
                                        num1++;
主站蜘蛛池模板: 黄色小视频免费 | 国产福利一区二区三区 | 日韩毛片网 | 麻豆精品一区二区 | 午夜你懂的 | 午夜在线免费观看 | 国产伦精品一区二区三区免费视频 | www.av在线播放 | 高清一区二区三区 | 国产精品一区二 | 国产午夜视频 | 成人av资源 | 在线观看日韩视频 | 午夜影院免费 | www.日本黄色 | 成人免费视频一区二区 | 日日夜夜狠狠 | 一区二区三区四区免费视频 | 伊人国产女| 亚洲女优在线 | 一本久久道 | 欧美一级片免费 | 狠狠干2018 | 最新免费黄色网址 | 狠狠做 | 谁有毛片网址 | 日韩免费网站 | 欧美日韩在线精品 | 亚洲123区 | 国产福利在线观看 | 国产精品久久久久久久久久久久久久 | 久久精品久久久久久久 | 成年人国产 | 男男成人高潮片免费网站 | 欧美高清视频在线观看mv | 日韩精品久久久久久 | 日日日操 | 国产一级黄色 | 国产网站免费 | 日韩特级片 | 91亚洲精品在线 |
