查看: 4242|回復: 2
51單片機計算器的制作
  1. #include <reg51.h>
  2. #include <math.h>
  4. #define uint unsigned int
  5. //---------定義引腳--------------------
  6. bit clr=0;
  7. bit ok=0;
  8. bit xiaoshu=0;
  9. bit jiego=0;
  10. bit first_1=1;
  11. bit first_2=1;
  12. sbit dout = P3^2;
  13. sbit load = P2^0;
  14. sbit din = P2^1;
  15. sbit dclk = P2^2;
  16. sbit beer=P0^1;
  17. sbit LCD1602_RS=P2^3;
  18. sbit LCD1602_RW=P2^4;
  19. sbit LCD1602_E=P2^5;
  20. //---------定義變量--------------------
  21. uchar ch451_key=0xff;
  22. uchar yun_sign;
  23. uchar xiabiao=0;
  24. uchar tab[32];
  25. uchar tab1[]={"welcome to use!"};
  26. uchar tab2[]={" make by JunRu!"};
  27. uchar tab3[]={"ERR0R"};
  28. float opr_1=0,opr_temp=0,end=0,a;
  29. //---------聲明函數--------------------
  30. void ch451_init(void); //CH451初始化
  31. void ch451_write(uint command);//寫命令或數據到ch451
  32. uchar ch451_read(void); //讀按鍵值
  33. uchar get_char(void);
  34. void LCD_init(void);//初始化;
  35. void delay(unsigned int k);//延時程序
  36. void LCD_inter_command(unsigned char command);//寫入控制字
  37. void LCD_inter_dat(unsigned char dat);//寫入要顯示的數據
  38. void set_xy(unsigned char x,unsigned char y);//找地址
  39. void write(unsigned char date);//寫入字符
  40. void lcdbusy();//查忙時
  41. void display(void);
  42. void spec(void);
  43. void get_end(void);
  44. void hun_he(uchar n);
  45. //-------- 主函數----------------------
  46. void main()
  47. {
  48. uchar i;
  49. LCD_init();//LCD初始化;
  50. ch451_init();//CH451初始化
  51. EA = 1;//打開中斷
  52. LCD_inter_command(0x01);//清屏
  53. for(i=0;i<=14;i++)
  54. {
  55. LCD_inter_dat(tab1[i]);
  56. beer=0;
  57. delay(4000);//延時
  58. beer=1;
  59. }
  60. LCD_inter_command(0xc0);//從第二行開始顯示
  61. for(i=0;i<=14;i++)
  62. {
  63. LCD_inter_dat(tab2[i]);
  64. beer=0;
  65. delay(4000);//延時
  66. beer=1;
  67. }
  68. delay(0xffff);
  69. delay(0xffff);
  70. LCD_inter_command(0x01);
  71. while(1)
  72. {
  73. if(ok)
  74. {
  75. display();
  76. ok=0;clr=1;
  77. }
  78. }
  79. }
  80. //----------子函數--------------------
  81. void hun_he(uchar n)
  82. {int j;
  83. switch(n)
  84. {
  85. case '+':opr_temp=opr_temp+opr_1;break;
  86. case '-':opr_temp=opr_temp-opr_1;break;
  87. case '*':opr_temp=opr_temp*opr_1;break;
  88. case '/':
  89. {
  90. if(a==0)//減數為零顯錯
  91. { LCD_inter_command(0xc0);
  92. for(j=0;j<=4;j++)
  93. {
  94. LCD_inter_dat(tab3[j]);
  95. beer=0;
  96. delay(4000);//延時
  97. beer=1;
  98. }
  99. }
  100. else
  101. {opr_temp=opr_temp/opr_1;}
  102. break;
  103. }
  104. default:break;}
  105. }
  106. void ch451_init(void)//CH451初始化
  107. {
  108. EX0 = 1;
  109. din = 0;
  110. din = 1;
  111. ch451_write(0x403); //開顯示
  112. ch451_write(0x580); //BCD譯碼方式
  113. }
  114. void ch451_write(uint command)//寫命令或數據到ch451
  115. { uchar i;
  116. EX0 = 0;
  117. load = 0;
  118. for(i=0;i<12;i++)
  119. {
  120. din = command&1;
  121. dclk = 0;
  122. command>>=1;
  123. dclk = 1;
  124. }
  125. load = 1;
  126. EX0 = 1;
  127. }
  128. uchar ch451_read(void)//讀
  129. 按鍵值
  130. { uchar key=0x07;
  131. uchar i;
  132. EX0=0;
  133. load = 0;
  134. for(i=0;i<4;i++) //將0111讀入
  135. {
  136. din = key &1;
  137. dclk = 0;
  138. key>>=1;
  139. dclk =1;
  140. }
  141. load = 1;
  142. key = 0;
  143. for(i=0;i<7;i++) //從CH451讀出按鍵值
  144. {
  145. key<<=1;
  146. key|= dout;
  147. dclk =0;
  148. dclk =1;
  149. }
  150. EX0 =1;
  151. return key;
  152. }
  153. void EX0_ISR(void)interrupt 0 //中斷程序
  154. {
  155. uchar temp;
  156. ch451_key=ch451_read(); //將讀出的按鍵值賦給變量
  157. spec();
  158. if(clr) {LCD_inter_command(0x01);clr=0;}
  159. temp=get_char();
  160. if(temp){tab[xiabiao++]=temp; LCD_inter_dat(temp);}
  161. if(xiabiao>=16)LCD_inter_command(0xc0);//若大于16,則從第2行開始顯示
  162. if(ok) get_end();
  163. beer=0;
  164. delay(3000);
  165. beer=1;
  166. }
  167. uchar get_char(void)
  168. {
  169. uchar dis=0;
  170. uint temp=0,temp1=0;
  171. switch(ch451_key)
  172. {
  173. case 0x40:dis='1';break;
  174. case 0x41:dis='2';break;
  175. case 0x42:dis='3';break;
  176. case 0x48:dis='4';break;
  177. case 0x49:dis='5';break;
  178. case 0x4A:dis='6';break;
  179. case 0x50:dis='7';break;
  180. case 0x51:dis='8';break;
  181. case 0x52:dis='9';break;
  182. case 0x58:dis='0';break;
  183. case 0x43:dis='+';break;
  184. case 0x4B:dis='-';break;
  185. case 0x53:dis='x';break;
  186. case 0x5B:dis='/';break;
  187. case 0x44:dis='!';break;
  188. case 0x5A:dis='=';
  189. ok=1; //遇到“=”,開始運算
  190. break;
  191. case 0x59:dis='.';break; //小數點
  192. case 0x5C: //刪除鍵
  193. LCD_inter_command(0x01);
  194. xiabiao=0;
  195. break;
  196. default: break;
  197. }
  198. return dis;
  199. }
  200. void spec(void) //特殊功能鍵
  201. {
  202. switch(ch451_key)
  203. {
  204. case 0x4C:LCD_inter_command(0x10);{if(xiabiao>0)xiabiao-=1;}break; //左移
  205. case 0x54:LCD_inter_command(0x14);{xiabiao+=1;}break; //右移
  206. default:break;
  207. }
  208. }
  209. void delay(unsigned int k)//延時程序
  210. {
  211. while (k--);
  212. }
  213. void LCD_inter_command(unsigned char command)//寫入控制字
  214. {
  215. delay(5000);
  216. LCD1602_RS=0;
  217. LCD1602_RW=0;
  218. LCD1602_E=1;
  219. P1=command;
  220. LCD1602_E=0;
  221. lcdbusy();
  222. }
  223. void LCD_init(void)//初始化;
  224. {delay(5000);
  225. LCD_inter_command(0x01);//清屏
  226. delay(5000);
  227. LCD_inter_command(0x38);//設置為8位的數據接口,兩行顯示,5、7點字符
  228. delay(5000);
  229. LCD_inter_command(0x0E);//顯示打開,光標開并閃爍
  230. delay(5000);
  231. }
  232. void LCD_inter_dat(unsigned char dat)//寫入要顯示的數據
  233. {
  234. delay(5000);
  235. LCD1602_RS=1;
  236. LCD1602_RW=0;
  237. LCD1602_E=1;
  238. P1=dat;
  239. LCD1602_E=0;
  240. lcdbusy();
  241. }
  242. void lcdbusy()//查忙
  243. {
  244. P1=0xFF;
  245. LCD1602_RS=0;
  246. LCD1602_RW=1;
  247. LCD1602_E=1;
  248. while((P1&0x80)==1);
  249. }
  250. void display(void) //轉化在LCD上顯示計算結果
  251. {
  252. int temp=end; //浮點數
  253. int i;
  254. uint xiao_temp;
  255. uint xx; //浮點數的整數部分
  256. if (end>-32769&&end<32768)
  257. {
  258. xx=fabs(end);
  259. xiao_temp=(fabs(end)-xx)*1000;//取出浮點數的小數部分
  260. LCD_inter_command(0xc0);
  261. if(end<0) LCD_inter_dat('-'
  262. );beer=0;delay(4000); beer=1;//判斷是否為負數,若是則顯示負號
  263. if(xx>9999) LCD_inter_dat((xx/10000)%10+'0'); beer=0;delay(4000);beer=1;
  264. if(xx>999) LCD_inter_dat((xx/1000)%10+'0');beer=0;delay(4000);beer=1; //在LCD上顯示千位的數
  265. if(xx>99)LCD_inter_dat((xx/100)%10+'0'); beer=0;delay(4000);beer=1;//百位
  266. if(xx>9)LCD_inter_dat((xx/10)%10+'0');beer=0;delay(4000); beer=1;//十位
  267. LCD_inter_dat(xx%10+'0');beer=0;delay(4000); beer=1;//個位
  268. if(xiao_temp!=0) //顯示小數部分
  269. {
  270. LCD_inter_dat('.');beer=0;delay(4000);beer=1;
  271. LCD_inter_dat((xiao_temp/100)%10+'0');beer=0;delay(4000);beer=1;
  272. LCD_inter_dat((xiao_temp/10)%10+'0');beer=0;delay(4000);beer=1;
  273. LCD_inter_dat(xiao_temp%10+'0');beer=0;delay(4000);beer=1;
  274. }
  275. }
  276. else {LCD_inter_command(0xc0);//從第二行開始顯示
  277. for(i=0;i<=4;i++)
  278. { LCD_inter_dat(tab3[i]);
  279. beer=0;
  280. delay(4000);//延時
  281. beer=1;
  282. }
  283. }
  284. }
  285. void get_end(void)//計算子程序
  286. { float xiaoshu=1;
  287. uchar fu_flag=0;
  288. uchar xiao_flag=0;
  289. uchar lianji_sign;
  290. uchar i=0;
  291. uchar j;
  292. uchar n;//正負標記符
  293. while(i<=xiabiao)
  294. {
  295. while(tab[i]<=0x39&&tab[i]>=0x30)
  296. {
  297. n=0;
  298. opr_1*=10;
  299. opr_1+=tab[i++]-0x30;
  300. n='+';
  301. }
  302. switch(tab[i])
  303. {
  304. case '.': xiao_flag=1;break;//遇到小數點跳到“if(xiao_flag)”里
  305. case '!': fu_flag=1;break;
  306. case '+': xiaoshu=1;yun_sign='+';if(opr_temp==0){end=opr_temp=opr_1;}else hun_he(lianji_sign);opr_1=0;lianji_sign='+'; break;
  307. case '-': xiaoshu=1;yun_sign='-';if(opr_temp==0){end=opr_temp=opr_1;}else hun_he(lianji_sign);opr_1=0;lianji_sign='-'; break;
  308. case 'x': xiaoshu=1;yun_sign='x';if(opr_temp==0){end=opr_temp=opr_1;}else hun_he(lianji_sign);opr_1=0;lianji_sign='*';break;
  309. case '/': xiaoshu=1;yun_sign='/';if(opr_temp==0){end=opr_temp=opr_1;}else hun_he(lianji_sign);a=opr_1;opr_1=0;lianji_sign='/';break;
  310. case '=':
  311. switch(yun_sign)//進行運算
  312. {
  313. case '+':end=opr_temp+opr_1;break;
  314. case '-':end=opr_temp-opr_1;break;
  315. case 'x':end=opr_temp*opr_1;break;
  316. case '/':{
  317. if(a==0)//減數為零顯錯
  318. { LCD_inter_command(0xc0);
  319. for(j=0;j<=4;j++)
  320. {
  321. LCD_inter_dat(tab3[j]);
  322. beer=0;
  323. delay(4000);//延時
  324. beer=1;
  325. }
  326. }
  327. else
  328. {end=opr_temp/opr_1;}
  329. break;
  330. }
  331. default:break;
  332. }
  333. ok=1;//開始進行顯示,標志位置1
  334. xiabiao=0;//小數的標志位清零
  335. break;
  336. default:break;
  337. }
  338. i++;
  339. if(xiao_flag)//表示小數
  340. {
  341. while(tab[i]<=0x39&&tab[i]>=0x30)
  342. {
  343. xiaoshu*=0.1;
  344. switch(n)
  345. {
  346. case '+': opr_1=opr_1+(tab[i++]-0x30)*xiaoshu;break;
  347. case '-': opr_1=opr_1-(tab[i++]-0x30)*xiaosh
  348. u; break ;
  349. default:break; }
  350. xiao_flag=0;
  351. }
  352. }
  353. if(fu_flag)
  354. {
  355. while(tab[i]<=0x39&&tab[i]>=0x30)
  356. {
  357. n=0;
  358. opr_1=-opr_1*10;
  359. opr_1=-(opr_1+(tab[i++]-0x30));
  360. n='-';
  361. fu_flag=0;
  362. }
  363. }
  364. }
  365. opr_1=0;
  366. opr_temp=0;
  367. xiabiao=0;
  368. xiaoshu=1;
  369. }
ID:82765 發表于 2017-3-17 14:50 | 只看該作者
提示: 作者被禁止或刪除 內容自動屏蔽
ID:130231 發表于 2017-3-17 15:02 | 只看該作者
不錯哦
主站蜘蛛池模板: 在线日韩一区 | 欧美专区在线 | 日韩一区三区 | 黄色片观看 | 欧美日韩亚洲一区二区 | 亚洲av毛片成人精品 | 色精品| 黄视频网站在线观看 | 亚洲欧美日韩另类 | 四虎影院网站 | 免费在线观看黄 | 2014天堂网 | 美日韩一区二区三区 | 伊人成人在线视频 | 日本欧美久久久久免费播放网 | av久久久| 免费黄色片视频 | 欧美国产一区二区 | 日本a在线| 一级做a爰片久久毛片潮喷 视频一二区 | www.国产精品 | 国产精品久久久久久久久借妻 | 免费成人小视频 | 中文字幕理伦片免费看 | 日韩成人高清 | 亚洲精品一二三四 | 精品国产福利 | 国产一级片在线播放 | 三级理论片 | a级片网站| аⅴ资源新版在线天堂 | 麻豆国产91在线播放 | 欧美日韩免费在线 | 蜜桃成人av| 日韩精品在线看 | www亚洲天堂| 午夜精品999 | 精品一区在线播放 | 久精品视频| 波多野结衣一区二区三区在线观看 | 日本一区二区三区在线视频 |
