查看: 2204|回復(fù): 0
求大神看看程序或者連線有什么問(wèn)題,LCD沒(méi)顯示
ID:129350 發(fā)表于 2017-4-25 20:18 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#define    uchar    unsigned char
#define    uint    unsigned int
sbit LCD_SI=P2^0;                //串行數(shù)據(jù)
sbit LCD_SCL=P2^1;                //同步時(shí)鐘
sbit LCD_A0=P2^2;                //選擇命令還是數(shù)據(jù)
sbit LCD_CS=P2^3;
uchar code EF16x8[][16] =
    {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*   */
    {0x00,0x00,0x00,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x33,0x30,0x00,0x00,0x00},/* ! */
    {0x00,0x10,0x0C,0x06,0x10,0x0C,0x06,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/* */
    {0x40,0xC0,0x78,0x40,0xC0,0x78,0x40,0x00,0x04,0x3F,0x04,0x04,0x3F,0x04,0x04,0x00},/* # */
    {0x00,0x70,0x88,0xFC,0x08,0x30,0x00,0x00,0x00,0x18,0x20,0xFF,0x21,0x1E,0x00,0x00},/* $ */
    {0xF0,0x08,0xF0,0x00,0xE0,0x18,0x00,0x00,0x00,0x21,0x1C,0x03,0x1E,0x21,0x1E,0x00},/* % */
    {0x00,0xF0,0x08,0x88,0x70,0x00,0x00,0x00,0x1E,0x21,0x23,0x24,0x19,0x27,0x21,0x10},/* & */
    {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0xB0,0x70,0x00,0x00,0x00,0x00,0x00},/* , */
    {0x00,0x00,0x00,0xE0,0x18,0x04,0x02,0x00,0x00,0x00,0x00,0x07,0x18,0x20,0x40,0x00},/* ( */
    {0x00,0x02,0x04,0x18,0xE0,0x00,0x00,0x00,0x00,0x40,0x20,0x18,0x07,0x00,0x00,0x00},/* ) */
    {0x40,0x40,0x80,0xF0,0x80,0x40,0x40,0x00,0x02,0x02,0x01,0x0F,0x01,0x02,0x02,0x00},/* * */
    {0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x1F,0x01,0x01,0x01,0x00},/* + */
    {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01},/* - */
    {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00},/* . */
    {0x00,0x00,0x00,0x00,0x80,0x60,0x18,0x04,0x00,0x60,0x18,0x06,0x01,0x00,0x00,0x00},/* / */
    {0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00},/* 0 */
    {0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00},/* 1 */
    {0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00},/* 2 */
    {0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00},/* 3 */
    {0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00},/* 4 */
    {0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00},/* 5 */
    {0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00},/* 6 */
    {0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00},/* 7 */
    {0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00},/* 8 */
    {0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00},/* 9 */
    {0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00},/* : */
    {0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x60,0x00,0x00,0x00,0x00},/* ; */
    {0x00,0x00,0x80,0x40,0x20,0x10,0x08,0x00,0x00,0x01,0x02,0x04,0x08,0x10,0x20,0x00},/* < */
    {0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00},/* = */
    {0x00,0x08,0x10,0x20,0x40,0x80,0x00,0x00,0x00,0x20,0x10,0x08,0x04,0x02,0x01,0x00},/* > */
    {0x00,0x70,0x48,0x08,0x08,0x08,0xF0,0x00,0x00,0x00,0x00,0x30,0x36,0x01,0x00,0x00},/* ? */
    {0xC0,0x30,0xC8,0x28,0xE8,0x10,0xE0,0x00,0x07,0x18,0x27,0x24,0x23,0x14,0x0B,0x00},/* @ */
    {0x00,0x00,0xC0,0x38,0xE0,0x00,0x00,0x00,0x20,0x3C,0x23,0x02,0x02,0x27,0x38,0x20},/* A */
    {0x08,0xF8,0x88,0x88,0x88,0x70,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x11,0x0E,0x00},/* B */
    {0xC0,0x30,0x08,0x08,0x08,0x08,0x38,0x00,0x07,0x18,0x20,0x20,0x20,0x10,0x08,0x00},/* C */
    {0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00},/* D */
    {0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x20,0x23,0x20,0x18,0x00},/* E */
    {0x08,0xF8,0x88,0x88,0xE8,0x08,0x10,0x00,0x20,0x3F,0x20,0x00,0x03,0x00,0x00,0x00},/* F */
    {0xC0,0x30,0x08,0x08,0x08,0x38,0x00,0x00,0x07,0x18,0x20,0x20,0x22,0x1E,0x02,0x00},/* G */
    {0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x20,0x3F,0x21,0x01,0x01,0x21,0x3F,0x20},/* H */
    {0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00},/* I */
    {0x00,0x00,0x08,0x08,0xF8,0x08,0x08,0x00,0xC0,0x80,0x80,0x80,0x7F,0x00,0x00,0x00},/* J */
    {0x08,0xF8,0x88,0xC0,0x28,0x18,0x08,0x00,0x20,0x3F,0x20,0x01,0x26,0x38,0x20,0x00},/* K */
    {0x08,0xF8,0x08,0x00,0x00,0x00,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x20,0x30,0x00},/* L */
    {0x08,0xF8,0xF8,0x00,0xF8,0xF8,0x08,0x00,0x20,0x3F,0x00,0x3F,0x00,0x3F,0x20,0x00},/* M */
    {0x08,0xF8,0x30,0xC0,0x00,0x08,0xF8,0x08,0x20,0x3F,0x20,0x00,0x07,0x18,0x3F,0x00},/* N */
    {0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x10,0x20,0x20,0x20,0x10,0x0F,0x00},/* O */
    {0x08,0xF8,0x08,0x08,0x08,0x08,0xF0,0x00,0x20,0x3F,0x21,0x01,0x01,0x01,0x00,0x00},/* P */
    {0xE0,0x10,0x08,0x08,0x08,0x10,0xE0,0x00,0x0F,0x18,0x24,0x24,0x38,0x50,0x4F,0x00},/* Q */
    {0x08,0xF8,0x88,0x88,0x88,0x88,0x70,0x00,0x20,0x3F,0x20,0x00,0x03,0x0C,0x30,0x20},/* R */
    {0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00},/* S */
    {0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00},/* T */
    {0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00},/* U */
    {0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00},/* V */
    {0xF8,0x08,0x00,0xF8,0x00,0x08,0xF8,0x00,0x03,0x3C,0x07,0x00,0x07,0x3C,0x03,0x00},/* W */
    {0x08,0x18,0x68,0x80,0x80,0x68,0x18,0x08,0x20,0x30,0x2C,0x03,0x03,0x2C,0x30,0x20},/* X */
    {0x08,0x38,0xC8,0x00,0xC8,0x38,0x08,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00},/* Y */
    {0x10,0x08,0x08,0x08,0xC8,0x38,0x08,0x00,0x20,0x38,0x26,0x21,0x20,0x20,0x18,0x00},/* Z */
    {0x00,0x00,0x00,0xFE,0x02,0x02,0x02,0x00,0x00,0x00,0x00,0x7F,0x40,0x40,0x40,0x00},/* [ */
    {0x00,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,0x00,0x40,0x40,0x40,0x7F,0x00,0x00,0x00},/* ] */
    {0x00,0x00,0x04,0x02,0x02,0x02,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/* ^ */
    {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80},/* _ */
    {0x10,0x16,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/* ' */
    {0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x19,0x24,0x22,0x22,0x22,0x3F,0x20},/* a */
    {0x08,0xF8,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x3F,0x11,0x20,0x20,0x11,0x0E,0x00},/* b */
    {0x00,0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x00,0x0E,0x11,0x20,0x20,0x20,0x11,0x00},/* c */
    {0x00,0x00,0x00,0x80,0x80,0x88,0xF8,0x00,0x00,0x0E,0x11,0x20,0x20,0x10,0x3F,0x20},/* d */
    {0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x22,0x22,0x22,0x22,0x13,0x00},/* e */
    {0x00,0x80,0x80,0xF0,0x88,0x88,0x88,0x18,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00},/* f */
    {0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x6B,0x94,0x94,0x94,0x93,0x60,0x00},/* g */
    {0x08,0xF8,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20},/* h */
    {0x00,0x80,0x98,0x98,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00},/* i */
    {0x00,0x00,0x00,0x80,0x98,0x98,0x00,0x00,0x00,0xC0,0x80,0x80,0x80,0x7F,0x00,0x00},/* j */
    {0x08,0xF8,0x00,0x00,0x80,0x80,0x80,0x00,0x20,0x3F,0x24,0x02,0x2D,0x30,0x20,0x00},/* k */
    {0x00,0x08,0x08,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00},/* l */
    {0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x20,0x3F,0x20,0x00,0x3F,0x20,0x00,0x3F},/* m */
    {0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20},/* n */
    {0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00},/* o */
    {0x80,0x80,0x00,0x80,0x80,0x00,0x00,0x00,0x80,0xFF,0xA1,0x20,0x20,0x11,0x0E,0x00},/* p */
    {0x00,0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x0E,0x11,0x20,0x20,0xA0,0xFF,0x80},/* q */
    {0x80,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x20,0x20,0x3F,0x21,0x20,0x00,0x01,0x00},/* r */
    {0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x33,0x24,0x24,0x24,0x24,0x19,0x00},/* s */
    {0x00,0x80,0x80,0xE0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x1F,0x20,0x20,0x00,0x00},/* t */
    {0x80,0x80,0x00,0x00,0x00,0x80,0x80,0x00,0x00,0x1F,0x20,0x20,0x20,0x10,0x3F,0x20},/* u */
    {0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x00,0x01,0x0E,0x30,0x08,0x06,0x01,0x00},/* v */
    {0x80,0x80,0x00,0x80,0x00,0x80,0x80,0x80,0x0F,0x30,0x0C,0x03,0x0C,0x30,0x0F,0x00},/* w */
    {0x00,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x31,0x2E,0x0E,0x31,0x20,0x00},/* x */
    {0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x80,0x81,0x8E,0x70,0x18,0x06,0x01,0x00},/* y */
    {0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x21,0x30,0x2C,0x22,0x21,0x30,0x00},/* z */
    {0x00,0x00,0x00,0x00,0x80,0x7C,0x02,0x02,0x00,0x00,0x00,0x00,0x00,0x3F,0x40,0x40},/* { */
    {0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00},/* | */
    {0x00,0x02,0x02,0x7C,0x80,0x00,0x00,0x00,0x00,0x40,0x40,0x3F,0x00,0x00,0x00,0x00},/* } */
    {0x00,0x06,0x01,0x01,0x02,0x02,0x04,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00}/* ~ */
uchar code CHINESE_WORD[]={“東北大學(xué)測(cè)控技術(shù)及儀器專(zhuān)業(yè)"};
uchar code CF16x16[][32]={
    {0x00,0x08,0x88,0x48,0x28,0x18,0x0F,0xE8,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,
     0x00,0x20,0x11,0x09,0x05,0x41,0x81,0x7F,0x01,0x01,0x05,0x09,0x11,0x20,0x00,0x00},/*"",0*/
    {0x00,0x20,0x20,0x20,0x20,0xFF,0x00,0x00,0x00,0xFF,0x40,0x20,0x10,0x08,0x00,0x00,
     0x20,0x60,0x20,0x10,0x10,0xFF,0x00,0x00,0x00,0x3F,0x40,0x40,0x40,0x40,0x78,0x00},/*"",1*/
    {0x20,0x20,0x20,0x20,0x20,0x20,0x20,0xFF,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
     0x80,0x80,0x40,0x20,0x10,0x0C,0x03,0x00,0x03,0x0C,0x10,0x20,0x40,0x80,0x80,0x00},/*"",2*/
    {0x40,0x30,0x11,0x96,0x90,0x90,0x91,0x96,0x90,0x90,0x98,0x14,0x13,0x50,0x30,0x00,
     0x04,0x04,0x04,0x04,0x04,0x44,0x84,0x7E,0x06,0x05,0x04,0x04,0x04,0x04,0x04,0x00},/*"學(xué)",3*/
    {0x10,0x60,0x02,0x8C,0x00,0xFE,0x02,0xF2,0x02,0xFE,0x00,0xF8,0x00,0xFF,0x00,0x00,
     0x04,0x04,0x7E,0x01,0x80,0x47,0x30,0x0F,0x10,0x27,0x00,0x47,0x80,0x7F,0x00,0x00},/*"測(cè)",4*/
    {0x10,0x10,0x10,0xFF,0x90,0x20,0x98,0x48,0x28,0x09,0x0E,0x28,0x48,0xA8,0x18,0x00,
     0x02,0x42,0x81,0x7F,0x00,0x40,0x40,0x42,0x42,0x42,0x7E,0x42,0x42,0x42,0x40,0x00},/*"",5*/
    {0x10,0x10,0x10,0xFF,0x10,0x90,0x08,0x88,0x88,0x88,0xFF,0x88,0x88,0x88,0x08,0x00,
     0x04,0x44,0x82,0x7F,0x01,0x80,0x80,0x40,0x43,0x2C,0x10,0x28,0x46,0x81,0x80,0x00},/*"",6*/
    {0x00,0x10,0x10,0x10,0x10,0xD0,0x30,0xFF,0x30,0xD0,0x12,0x1C,0x10,0x10,0x00,0x00,
     0x10,0x08,0x04,0x02,0x01,0x00,0x00,0xFF,0x00,0x00,0x01,0x02,0x04,0x08,0x10,0x00},/*"術(shù)",7*/
    {0x00,0x00,0x02,0x02,0xFE,0x42,0x82,0x02,0x42,0x72,0x4E,0x40,0xC0,0x00,0x00,0x00,
     0x80,0x40,0x30,0x0C,0x83,0x80,0x41,0x46,0x28,0x10,0x28,0x46,0x41,0x80,0x80,0x00},/*"",8*/
    {0x00,0x80,0x60,0xF8,0x07,0x00,0x1C,0xE0,0x01,0x06,0x00,0xE0,0x1E,0x00,0x00,0x00,
     0x01,0x00,0x00,0xFF,0x00,0x80,0x40,0x20,0x13,0x0C,0x13,0x20,0x40,0x80,0x80,0x00},/*"",9*/
    {0x80,0x80,0x9E,0x92,0x92,0x92,0x9E,0xE0,0x80,0x9E,0xB2,0xD2,0x92,0x9E,0x80,0x00,
     0x08,0x08,0xF4,0x94,0x92,0x92,0xF1,0x00,0x01,0xF2,0x92,0x94,0x94,0xF8,0x08,0x00},/*"",10*/
    {0x40,0x40,0x48,0x48,0x48,0xC8,0x78,0x4F,0x48,0x48,0x48,0x48,0x48,0x40,0x40,0x00,
     0x00,0x00,0x00,0x00,0x03,0x12,0x12,0x22,0x22,0x52,0x8A,0x06,0x00,0x00,0x00,0x00},/*"專(zhuān)",11*/
    {0x00,0x10,0x60,0x80,0x00,0xFF,0x00,0x00,0x00,0xFF,0x00,0x00,0xC0,0x30,0x00,0x00,
     0x40,0x40,0x40,0x43,0x40,0x7F,0x40,0x40,0x40,0x7F,0x42,0x41,0x40,0x40,0x40,0x00}/*"業(yè)",12*/
LCD寫(xiě)函數(shù)
void LCD_write(數(shù)據(jù)或者命令,A0選擇)
void LCD_write(uchar data_command,uchar dc)
{//參數(shù)dc=0時(shí)表示發(fā)命令,dc=1時(shí)表示發(fā)送數(shù)據(jù)
  uchar i;
  LCD_A0=dc;
  LCD_CS=0;
  for(i=0;i<8;i++)
   LCD_SCL=0;
   LCD_SI=(data_command&0x80)==0?0:1;
   data_command<<=1;
   LCD_SCL=1;
  LCD_CS=1;
LCD初始化函數(shù)
void LCD_Init(void)
    uchar i;
    for ( i = 100; i>0; i--);
    LCD_write(0xa2,0);        // LCD偏壓設(shè)置:1/9 BIAS
    LCD_write(0xa1,0);        //列地址選擇為從右到左對(duì)應(yīng)0~127;0xa1:列地址從左到右;0xa0:列地址從右到左
    LCD_write(0xc0,0);        // 行地址從上到下為0~63;0xc0:行地址從上到下;0xc8:行地址從下到上
    LCD_write(0x26,0);        // V5電壓內(nèi)部電阻調(diào)整設(shè)置
    LCD_write(0x81,0);        //亮度調(diào)整命令為雙字節(jié)命令
    LCD_write(0x10,0);        //亮度調(diào)節(jié), 0~63(暗到亮)
    LCD_write(0x2f,0);        //上電控制,打開(kāi)調(diào)壓器、穩(wěn)壓器和電壓跟隨
    LCD_write(0xaf,0);        //0xae:set display off。0xaf:set display on
    LCD_write(0x40,0);        //起始行設(shè)置
void clrscr(uchar page_f, uchar pages,uchar column_f,uchar columns )
{        //參數(shù):指向字首地址,起始頁(yè),占多少頁(yè),起始列,占多少列
  uchar i,j,page=0xb0;                //指向首頁(yè)命令
    for(i=page_f;i<page_f+pages;i++)
        LCD_write(page+i,0);
        LCD_write(0x10|((0xf0 & column_f)>>4),0);        //設(shè)定列地址高4位為0
        LCD_write(0x00|(0x0f & column_f),0);            //設(shè)定列地址低4位為0
        for(j=0;j<columns;j++)
            LCD_write(0x00,1);
void Draw_word(uchar *d_where,uchar page_f,
    uchar pages,uchar column_f,uchar columns)
{//參數(shù):字模首地址,起始頁(yè),占多少頁(yè),起始列,占多少列
    for ( i=page_f; i<page_f+pages; i++)
        LCD_write(0x10|((0xf0&column_f)>>4),0);//設(shè)定列地址高4
        LCD_write(0x00|(0x0f&column_f),0);    //設(shè)定列地址低4
            LCD_write(*d_where,1);
            d_where++;
void Draw_word_inv(uchar *d_where,uchar page_f,
            LCD_write(~(*d_where),1);
            d_where++;
void PrintString(uchar *str,uchar line,uchar column)
    uchar i,c,d;
    while (c=*str)                        //取得一個(gè)字符
        if (c<0xA1)                        //是半角字符?
            str++;                        //指向下一個(gè)字符
            if ((c<‘ ’)||(c>~)) continue;                //不在可顯示字符范圍內(nèi),忽略
            Draw_word(EF16x8[c-‘ ’],line,2,column,8);        //顯示ASCII字符,8×16點(diǎn)陣
            column+=8;                        //定位到下一個(gè)顯示位置
            if (column>=128)
                column=0;
                line+=2;
                if (line>=7) line=0;
        else                                //可能是漢字
            d=*str;
            if (d<0xA1) continue;                //不是漢字,忽略
            for (i=0;i<sizeof(CHINESE_WORD);i+=2)
                if ( (c==CHINESE_WORD) && (d==CHINESE_WORD[i+1]) )
                    Draw_word(CF16x16[i/2],line,2,column,16); //顯示ASCII字符,16×16點(diǎn)陣
                    column+=16;                        //定位到下一個(gè)顯示位置
                    if (column>=128)
                        column=0;
                        line+=2;
                    break;
    uchar i,c,d;
            Draw_word_inv (EF16x8[c-‘ ’],line,2,column,8);        //顯示ASCII字符,8×16點(diǎn)陣
            if (column>=128)
                column=0;
                line+=2;
                if (line>=3) line=0;
        else                                //可能是漢字
            d=*str;
                    Draw_word_inv(CF16x16[i/2],line,2,column,16); //顯示ASCII字符,16×16點(diǎn)陣
                    if (column>=128)
                        column=0;
                        line+=2;
                    break;
主站蜘蛛池模板: 极品av在线| 性一交一乱一伧老太 | 毛茸茸性猛交xxxx | 欧美激情一区 | 毛片视频免费 | 久久性视频 | 成人av播放 | 成人av免费看 | www.久草.com | 日韩精品久久久久久久 | 日韩欧美精品 | 欧美日韩免费在线 | 一区免费视频 | 亚洲一区二区在线播放 | 精品国产乱码一区二区三 | 国产精品久久久久久久久久 | 国产探花视频在线观看 | 亚洲欧美综合网 | av噜噜噜| 欧美亚洲在线 | 中文亚洲字幕 | 国产精品羞羞答答 | 51调教丨国产调教视频 | 国产一级免费观看 | 在线观看h视频 | 国产乱人乱偷精品视频 | 黄a视频| 玖草在线 | 欧美理论片在线观看 | 亚洲精品1| 天堂av影视 | 亚洲精品一区中文字幕乱码 | 国产精品欧美一区二区 | 久久99精品久久久久久 | 在线观看国产一区二区 | 91亚洲一区 | 黄视频在线播放 | 国产三级视频在线播放 | 人人草人人 | 欧美日韩国产在线观看 | 婷婷激情综合 |
