查看: 2787|回復(fù): 0
求助,剛才發(fā)的PM2.5檢測(cè)儀發(fā)現(xiàn)硬件沒問題,大家能看看是軟件的問題嗎?
ID:195842 發(fā)表于 2017-5-6 22:00 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
void senddata(uchar dat);
uchar cal [7]= {0};//        cal[0]:起始位 0xAA
//        cal[1] : Vout(H)
//        cal[2] : Vout(L)
//        cal[3] : Vref(H)
//        cal[4] : Vref(L)
//        cal[5] : 校驗(yàn)位
//        cal[6] : 結(jié)束位 OxFF
float Vo;
int i=0;
sbit rs=P1^0;
sbit lcden=P2^5;
sbit rw=P1^1;
sbit voice=P2^3;
sbit light=P2^2;
uchar  buf,sum,count;
uchar num,TV,a,b,c;
void delay(uint z)
  uint x,y;
   for(x=z;x>0;x--)
     for(y=110;y>0;y--);
void write_com(uchar com)
  rs=0;
   rw=0;
      P0=com;
    delay(5);
    lcden=1;
   delay(5);
    lcden=0;
void write_data(uchar date)
    rs=1;
    rw=0;
    P0=date;
    delay(5);
    lcden=1;
    delay(5);
    lcden=0;
void init()
    lcden=0; //使能端為低電平
    write_com(0x38);
    /*顯示模式設(shè)置  00111000  設(shè)置16*2顯示  5*7點(diǎn)陣  8位數(shù)據(jù)接口*/
    write_com(0x0f);
    /*顯示開關(guān)及光標(biāo)設(shè)置   00001DCB
    D=1,開顯示     D=0, 關(guān)顯示
    C=1,顯示光標(biāo)   C=0,不顯示光標(biāo)
    B=1,光標(biāo)閃爍   B=0,光標(biāo)不閃爍*/
   write_com(0x06);//地址指針自動(dòng)+1且光標(biāo)+1,寫字符屏幕不會(huì)移動(dòng)
    write_com(0x01);
write_com(0x80);
write_data ('P');
write_com (0x81);
write_data ('M');
write_com (0x82);
write_data ('2');
write_com (0x83);
write_data ('.');
write_com (0x84);
write_data ('5');
write_com (0x85);
write_data (':');
write_com (0xcb);
write_data ('m');
write_com (0xcc);
write_data ('g');
write_com (0xcd);
write_data ('/');
write_com (0xce);
write_data ('m');
write_com (0xcf);
write_data ('3');
void  warn()
if   (num>=200)
         voice=0;
         light=0;
init();
SCON=0x50;        //設(shè)定串口工作方式
PCON=0x00;        //波特章不倍增
TMOD=0x20;        //定時(shí)器1工作于8位自動(dòng)重載橫式,用于產(chǎn)生波特率
EA=1;
ES = 1;        //允許串口中斷
TL0=0x80;
TH0=0xFB;
TR0=1;
num=TV;
a= TV /100+0x30;
TV %=100;
b= TV /10+0x30;
TV %=10;
c= TV +0x30;
write_com (0x88);
write_data (a);
write_com (0x89);
write_data (b);
write_com (0x8a);
write_data (c);
//warn();
while(1);
void serial()  interrupt 4
ES = 0;        //關(guān)閉串行中斷
RI = 0;        //清除串行接受標(biāo)志位
buf = SBUF;        //從串口緩沖區(qū)取得數(shù)據(jù)
senddata(buf);
ES = 1;        //允許串口中斷
{if(dat==170) //判斷起始位 OxAA, (0xAA==l70〉
i=0;
cal[i]=dat;
i=i+1;
cal[i]=dat;
if(i==6)
sum= cal[1]+cal[2]+cal[3]+cal[4];//sum=Vout(M)+Vout(L)+Vref(M)+Vref(L)
if (sum == cal [5] && cal[6]==255)        //sum與校驗(yàn) 相同 &&最后一位是 OxFF 結(jié)束位
for (i=0; i <=6; i++) //此處for循環(huán)是顯示出所有數(shù)據(jù),即cal [7]中的數(shù)據(jù)
      SBUF=cal[i];
while(!TI);
TI=0;
Vo=(cal[1]*256+cal[2])/2048*5;
TV=3000* Vo;
主站蜘蛛池模板: 欧美专区在线 | 久草视| 亚洲欧美日韩在线 | 成人高清免费 | 一区二区三区国产视频 | 1024日韩 | 国产农村妇女aaaaa视频 | 日韩一区二区在线播放 | av免费看片| 毛片毛片毛片毛片毛片 | 精品视频99| 亚洲激情中文字幕 | 伊人国产女 | 欧美精品一区在线观看 | 一级黄色av| 黄色小视频在线免费观看 | 国产永久视频 | 日韩av在线不卡 | 亚洲视频二区 | 五月天婷婷激情 | 欧美日韩在线免费 | 国产乱码久久久久久 | 亚洲高清在线 | 中文字幕一区二区三区视频 | 久久人人爽人人爽人人片 | 黑人巨大猛烈捣出白浆 | 亚洲一级免费视频 | 亚洲黄色在线视频 | 一级做a视频 | 日韩精品极品视频在线观看免费 | 国产午夜精品久久久久久久 | 韩日中文字幕 | 自拍偷拍福利视频 | 国产女人水真多18毛片18精品 | 中文字幕在线免费 | 玉足女爽爽91 | a天堂在线观看 | 青青久久久| 精品免费国产一区二区三区四区 | 欧美成人高清 | 免费在线成人 |
