查看: 4096|回復: 2
基于51的ds18b20溫度檢測儀,超過預警溫度會進行聲光報警,并驅動電動機散熱
ID:212118 發表于 2017-6-17 20:30 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#define uchar unsigned char
#define uint unsigned int
sbit DS=P2^2;           //define interface
sbit FM=P2^3;
uint temp;             // variable of temperature
uchar flag1;            // sign of the result positive or negative
#define ON 0;
#define OFF 1;
uint ad=280;
sbit DJ=P2^5;
sbit dula=P2^6;
sbit wela=P2^7;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char code table1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,
                        0x87,0xff,0xef};
void delay(uint count)      //delay
  uint i;
  while(count)
    i=200;
    while(i>0)
    i--;
    count--;
void dsreset(void)       //send reset and initialization command
  uint i;
  DS=0;
  i=103;
  while(i>0)i--;
  DS=1;
  i=4;
  while(i>0)i--;
bit tmpreadbit(void)       //read a bit
   uint i;
   bit dat;
   DS=0;i++;          //i++ for delay
   DS=1;i++;i++;
   dat=DS;
   i=8;while(i>0)i--;
   return (dat);
uchar tmpread(void)   //read a byte date
  uchar i,j,dat;
  dat=0;
  for(i=1;i<=8;i++)
    j=tmpreadbit();
    dat=(j<<7)|(dat>>1);   //讀出的數據最低位在最前面,這樣剛好一個字節在DAT里
  return(dat);
void tmpwritebyte(uchar dat)   //write a byte to ds18b20
  uint i;
  uchar j;
  bit testb;
  for(j=1;j<=8;j++)
    testb=dat&0x01;
    dat=dat>>1;
    if(testb)     //write 1
      DS=0;
      i++;i++;
      DS=1;
      i=8;while(i>0)i--;
      DS=0;       //write 0
      i=8;while(i>0)i--;
      DS=1;
      i++;i++;
void tmpchange(void)  //DS18B20 begin change
  dsreset();
  delay(1);
  tmpwritebyte(0xcc);  // address all drivers on bus
  tmpwritebyte(0x44);  //  initiates a single temperature conversion
uint tmp()               //get the temperature
  float tt;
  uchar a,b;
  dsreset();
  delay(1);
  tmpwritebyte(0xcc);
  tmpwritebyte(0xbe);
  a=tmpread();
  b=tmpread();
  temp=b;
  temp<<=8;             //two byte  compose a int variable
  temp=temp|a;
  tt=temp*0.0625;
  temp=tt*10+0.5;
  return temp;
void display(uint temp)                        //顯示程序
   uchar A1,A2,A2t,A3;
   A1=temp/100;
   A2t=temp%100;
   A2=A2t/10;
   A3=A2t%10;
   dula=0;
   P0=table[A1];                //顯示百位
   dula=1;
   dula=0;
   wela=0;
   P0=0xfe;
   wela=1;
   wela=0;
   delay(1);
   dula=0;
   P0=table1[A2];                //顯示十位
   dula=1;
   dula=0;
   wela=0;
   P0=0xfd;
   wela=1;
   wela=0;
   delay(1);
   dula=0;
   P0=table[A3];                //顯示個位
   dula=1;
   dula=0;
   wela=0;
   P0=0xfb;
   wela=1;
   wela=0;
   delay(1);
uchar a;
uint t,i=0x7f;//i用于LED燈顯示
  DJ=1;
        DJ=1;
    tmpchange();
        t=tmp();
        display(tmp());
        P1=0XFF;
        if(t>ad)
    DJ=0;
        FM=0;
        display(tmp());
    i=_crol_(i,1);
        P1=i;
        display(tmp());
        delay(3);
        display(tmp());
else{FM=1;P1=0XFF;DJ=1;}
ID:710428 發表于 2020-3-18 20:28 | 顯示全部樓層
沒有原理圖嗎?
ID:460524 發表于 2020-4-7 10:11 | 顯示全部樓層
請問 有沒有仿真圖 proteus
主站蜘蛛池模板: 国产九九热| 四虎影院在线播放 | 国产三级在线观看 | 精品在线播放 | 蜜桃色一区二区三区 | 一级特黄毛片 | av在线成人 | 亚洲精品二区 | 日本久久视频 | 成人免费毛片观看 | 午夜视频免费观看 | 国产精品久久久久久99 | 中文字幕无人区二 | 国产精品久久久精品 | 亚洲综合网站 | 成人三级视频在线观看 | 免费看一级片 | 国产又粗又长又爽 | 日韩 欧美| 成人aaaa | 色av吧 | www.国产精品.com | 在线播放国产精品 | 日本一级淫片 | 在线日韩一区 | 亚洲视频在线播放 | 国产精品嫩草影院桃色 | 97超碰资源站 | 国产精品网站在线观看 | 亚洲一区日韩 | 精品久久网站 | 国产美女网站 | 福利视频免费观看 | 日韩伦理在线观看 | 四虎影视在线 | 日本男人的天堂 | 人人干人人草 | 亚洲精品无 | 久久久久久久久久久国产 | 日本免费在线观看 | 夜色在线影院 |
