查看: 6103|回復: 1
16x16點陣使用兩個74HC595顯示圖片 源程序
最近在研究單片機驅動16x16點陣,分享一個程序~
關于大家想要顯示的圖形,可以自行更改uchar code tab1[] ={..}的內容
單片機源程序:
  1. #include <REG51.H>
  2. //--重定義函數變量--//
  4. #define uint  unsigned int
  5. #define ulong unsigned long
  6. #define  GPIO_KEY P1
  7. //--定義SPI要使用的 IO--//
  8. sbit MOSIO = P3^4;
  9. sbit R_CLK = P3^5;
  10. sbit S_CLK = P3^6;
  11. //---全局變量聲明--//
  12. ulong column;   //點陣列
  13. ulong row;      //點陣行
  14. ulong dt;
  15. void Delay10ms(unsigned int c);
  16. unsigned char Key_Scan();
  17. //--點陣顯示數組--//
  18. unsigned char code tab0[] =
  19. {0x00, 0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08,
  20. 0x00, 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80,
  21. 0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08, 0x00,
  22. 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80, 0x00};
  23. uchar code tab1[] ={255,255,1,128,1,128,1,128,1,128,1,128,1,128,1,128,1,128,1,128,1,128,1,128,1,128,1,128,1,128,255,255};
  24. uchar code tab2[] ={255,255,1,128,253,191,5,160,5,160,5,160,5,160,5,160,5,160,5,160,5,160,5,160,5,160,253,191,1,128,255,255}        ;
  25. uchar code tab3[] = {255,255,1,128,253,191,5,160,245,175,21,168,21,168,21,168,21,168,21,168,21,168,245,175,5,160,253,191,1,128,255,255};
  26. uchar code tab4[] ={255,255,1,128,253,191,5,160,245,175,21,168,213,171,85,170,85,170,213,171,21,168,245,175,5,160,253,191,1,128,255,255};
  27. uchar code tab5[] ={0,0,0,0,0,0,0,0,0,0,0,0,0,0,128,1,128,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
  28. uchar code tab6[] = {0,0,0,0,0,0,0,0,0,0,224,7,32,4,160,5,160,5,32,4,224,7,0,0,0,0,0,0,0,0,0,0};
  29. uchar code tab7[] = {0,0,0,0,0,0,248,31,8,16,232,23,40,20,168,21,168,21,40,20,232,23,8,16,248,31,0,0,0,0,0,0};
  30. uchar code tab8[] = {0,0,254,127,2,64,250,95,10,80,234,87,42,84,170,85,170,85,42,84,234,87,10,80,250,95,2,64,254,127,0,0};
  31. //--全局函數聲明--//
  32. void HC595SendData(  uchar BT3, uchar BT2,uchar BT1,uchar BT0);
  33.
  34. void main(void)
  35. {
  36.         int k, i, ms;
  37.         i = 40;                                        //顯示時間
  38.         while(1)
  39.         {
  40.                 //--顯示10--//
  41.                 for(ms = i; ms > 0; ms--)
  42.                 {
  43.                         for(k = 0; k < 16; k++)
  44.                         {
  45.                         HC595SendData(~tab1[2*k +1],~tab1[2*k],tab0[2*k],tab0[2*k + 1]);
  46.                         }
  47.                 }
  48.                 HC595SendData(0xff,0xff,0,0);
  49.
  50.                 //--顯示09--//
  51.                 for(ms = i; ms > 0; ms--)
  52.                 {
  53.                         for(k = 0; k < 16; k++)
  54.                         {
  55.                                 HC595SendData(~tab2[2*k +1],~tab2[2*k],tab0[2*k],tab0[2*k + 1]);
  56.                         }
  57.                 }
  58.                 HC595SendData(0xff,0xff,0,0);
  59.
  60.                 //--顯示08--//
  61.                 for(ms = i; ms > 0; ms--)
  62.                 {
  63.                         for(k = 0; k < 16; k++)
  64.                         {
  65.                                 HC595SendData(~tab3[2*k +1],~tab3[2*k],tab0[2*k],tab0[2*k + 1]);
  66.                         }
  67.                 }
  68.                 HC595SendData(0xff,0xff,0,0);
  69.
  70.                 //--顯示07--//
  71.                 for(ms = i; ms > 0; ms--)
  72.                 {
  73.                         for(k = 0; k < 16; k++)
  74.                         {
  75.                                 HC595SendData(~tab4[2*k +1],~tab4[2*k],tab0[2*k],tab0[2*k + 1]);
  76.                         }
  77.                 }
  78.                 HC595SendData(0xff,0xff,0,0);
  79.
  80.                 //--顯示06--//
  81.                 for(ms = i; ms > 0; ms--)
  82.                 {
  83.                         for(k = 0; k < 16; k++)
  84.                         {
  85.                                 HC595SendData(~tab5[2*k +1],~tab5[2*k],tab0[2*k],tab0[2*k + 1]);
  86.                         }
  87.                 }
  88.                 HC595SendData(0xff,0xff,0,0);
  89.
  90.             //--顯示05--//
  91.                 for(ms = i; ms > 0; ms--)
  92.                 {
  93.                         for(k = 0; k < 16; k++)        //歡
  94.                         {
  95.                                 HC595SendData(~tab6[2*k +1],~tab6[2*k],tab0[2*k],tab0[2*k + 1]);
  96.                         }
  97.                 }
  98.                 HC595SendData(0xff,0xff,0,0);
  99.
  100.             //--顯示04--//
  101.                 for(ms = i; ms > 0; ms--)
  102.                 {
  103.                         for(k = 0; k < 16; k++)
  104.                         {
  105.                                 HC595SendData(~tab7[2*k +1],~tab7[2*k],tab0[2*k],tab0[2*k + 1]);
  106.                         }
  107.                 }
  108.                 HC595SendData(0xff,0xff,0,0);
  109.
  110.                 //--顯示03--//
  111.                 for(ms = i; ms > 0; ms--)
  112.                 {
  113.                         for(k = 0; k < 16; k++)
  114.                         {
  115.                                 HC595SendData(~tab8[2*k +1],~tab8[2*k],tab0[2*k],tab0[2*k + 1]);
  116.                         }
  117.                 }
  118.                 HC595SendData(0xff,0xff,0,0);
  119.         }
  120. }
  121. void HC595SendData(  uchar BT3, uchar BT2,uchar BT1,uchar BT0)
  122. {
  123.         uchar i;
  124.
  125.         //--發送第一個字節--//
  126.         for(i=0;i<8;i++)
  127.         {
  128.                 MOSIO = BT3 >> 7 ;        //從高位到低位
  129.                 BT3 <<= 1;
  130.                 S_CLK = 0;
  131.                 S_CLK = 1;
  132.         }
  133.         //--發送第一個字節--//
  134.         for(i=0;i<8;i++)
  135.         {
  136.                 MOSIO = BT2 >>7;                //從高位到低位
  137.                 BT2 <<= 1;
  138.                 S_CLK = 0;
  139.                 S_CLK = 1;
  140.         }
  141.         //--發送第一個字節--//
  142.         for(i=0;i<8;i++)
  143.         {
  144.                 MOSIO = BT1 >> 7;                //從高位到低位
  145.                 BT1 <<= 1;
  146.                 S_CLK = 0;
  147.                 S_CLK = 1;
  148.         }
  149.         //--發送第一個字節--//
  150.         for(i=0;i<8;i++)
  151.         {
  152.                 MOSIO = BT0 >> 7;                //從高位到低位
  153.                 BT0 <<= 1;
  154.                 S_CLK = 0;
  155.                 S_CLK = 1;
  156.         }
  157.
  158.         //--輸出--//
  159.         R_CLK = 0; //set dataline low
  160.         R_CLK = 1; //片選
  161.         R_CLK = 0; //set dataline low
  162. }
  163. unsigned char Key_Scan()
  164. {
  165.         unsigned char keyValue = 0 , i; //????
  166.         //--????1--//
  167.         if (GPIO_KEY != 0xFF)                //????K1????
  168.         {
  169.                 Delay10ms(1);        //????
  170.                 if (GPIO_KEY != 0xFF)        //??????????
  171.                 {
  172.                         keyValue = GPIO_KEY;
  173.                         i = 0;
  174.                         while ((i<50) && (GPIO_KEY != 0xFF))         //????????
  175.                         {
  176.                                 Delay10ms(1);
  177.                                 i++;
  178.                         }
  179.                 }
  180.         }
  181. …………限于本文篇幅 余下代碼請從51黑下載附件…………
下載:
dianzhen.zip (1.44 KB, 下載次數: 37)
ID:83626 發表于 2018-12-13 11:07 | 只看該作者
謝謝,正需要。
主站蜘蛛池模板: 日韩国产在线播放 | 欧美综合一区 | 亚洲91av| 成人网av | 91精品久久久久久 | 日韩理论视频 | 亚洲天天看 | 国产在线观看免费 | 欧美一级特黄aa大片 | 一区二区网站 | 黄色在线小视频 | 日韩在线播放视频 | 黑森林av| 国产精品aaa | 五月婷婷色综合 | 成人精品视频在线观看 | 国产麻豆精品视频 | 亚洲在线视频 | 免费av不卡| 日韩一区二区三区免费 | 久久久久久免费毛片精品 | 青青草成人在线 | 国产日韩欧美 | 麻豆一区二区三区四区 | 亚洲精品一区二区在线观看 | 久久久久女人精品毛片九一 | 国产精品不卡 | 欧美不卡视频 | 日本久久视频 | 欧美一区二区精品 | 日韩av免费 | 永久免费看片在线播放 | 在线网站免费观看18 | 久久高清免费视频 | a免费视频 | 国产91免费| 久草福利 | 国产永久精品 | 国产成人免费在线观看 | 久久免费看片 | 日韩一区二区三区在线播放 |
