查看: 1743|回復: 0
九路搶答實驗課程設計
ID:209316 發表于 2017-6-8 19:29 | 顯示全部樓層 |閱讀模式
#include <reg51.h>
/********定義按鍵引腳********/
sbit key_One = P2^3;
sbit key_Two = P2^2;
sbit key_Three = P2^1;
sbit key_Four = P2^0;
unsigned char code num[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};  //0~9數字的8421編碼
unsigned char code wei[] = {0x7f,0xbf,0xdf,0xef};  //數碼管位選編碼
char number = 0;  //要顯示的數字
unsigned char key_Buff;   //按鍵鍵值緩沖值
/********函數聲明********/
void delay(int z);
void display(int x);
char key_Scan();
        key_Buff = key_Scan();     //將按鍵值存入緩沖區
        switch(key_Buff)   //判斷緩沖區的值
            case 0: break;
            case 1: number++;    //按鍵1按下,number自加一并將按鍵
                    if(number >= 255)
                        number = 255;   //number值大于255不再自加
                    key_Buff = 0;  //按鍵值緩沖區清零,防止下次按鍵未按下還再次進入
                    break;
            case 2: number--;
                    if(number <= 0)
                        number = 0;
                    key_Buff = 0;
                    break;
            case 3: break;
            case 4: break;
        display(number);  //數碼管顯示
/**函數名: delay(z)
/**函數功能: 粗略延時
/**輸入參數: z表示要延時的毫秒數
/**示例: delay(300) //粗略延時300毫秒
void delay(int z)
    int x,y;
    for(x=z; x>0; x--)
        for(y=110; y>0; y--);
/**函數名: display()
/**函數功能: 數碼管顯示函數
/**輸入參數: x:要顯示的數
/**示例: display(1234); //顯示1234
void display(int x)
    unsigned char ge, shi, bai, qian;
    /**提取x的個十百千位
    /**‘/’為取模運算
    /**‘%’為求余運算
    qian = x/1000 %10;
    bai = x/100 %10;
    shi = x/10 %10;
    ge = x/1 %10;
    P0 = ~num[qian];    //顯示千位
    P2 = wei[0];        //第0個數碼管顯示
    delay(2);           //延時2毫秒
    P0 = ~num[bai];     //顯示百位
    P2 = wei[1];
    delay(2);
    P0 = ~num[shi];     //顯示十位
    P2 = wei[2];
    delay(2);
    P0 = ~num[ge];      //顯示個位
    P2 = wei[3];
    delay(2);
    P0 = 0xff;          //數碼管消隱
/**函數名: key_Scan()
/**函數功能: 按鍵掃描函數
/**輸入參數: 無
/**返回參數: 按鍵的鍵值
/**示例: key_Buff = key_Scan();
char key_Scan()
    char key_Value = 0;  //按鍵鍵值,用于返回鍵值使用
    P2 = 0x0f;    //將按鍵引腳電平拉高
    if(key_One == 0)  //檢測按鍵1是否被按下
        delay(10);    //延時消抖
        while(key_One == 0)   //按鍵1確定被按下
            key_Value = 1;    //按鍵鍵值置1
            display(number);  //調用顯示函數,防止按鍵一直被按下時數碼管不顯示
    if(key_Two == 0)   //按鍵2的檢測
        delay(10);
        while(key_Two == 0)
            key_Value = 2;
            display(number);
    if(key_Three == 0)
        delay(10);
        while(key_Three == 0)
            key_Value = 3;
            display(number);
    if(key_Four == 0)
        delay(10);
        while(key_Four == 0)
            key_Value = 4;
            display(number);
    return key_Value;  //返回鍵值
主站蜘蛛池模板: 日本在线网站 | 午夜爱 | 国产乱人伦 | www.婷婷 | 成人午夜又粗又硬又大 | 亚洲欧美日韩综合 | 久久av片 | 激情视频网址 | 中文字幕不卡在线 | 91av免费 | 亚洲欧美视频 | 超碰在线免费 | 青草av在线| www.国产在线 | 精品欧美黑人一区二区三区 | 一区| 亚洲国产片 | 福利视频网址 | 麻豆av在线免费观看 | 日韩av在线免费看 | 在线观看小视频 | 97精品在线 | 久久精品国产亚洲 | 国产suv精品一区 | 在线观看视频一区二区 | 国产h片在线观看 | 国产一区高清 | 色婷婷精品 | 亚洲另类视频 | 日韩国产一区 | 中文字幕少妇 | 不卡视频在线观看 | 999精品在线 | 色窝| 国产成人免费视频 | 久久国产欧美 | 一区二区精品视频 | 久久xxxx| 伦一理一级一a一片 | 日韩专区中文字幕 | 看毛片网站 |
