查看: 3005|回復(fù): 0
51計(jì)算器程序
ID:212824 發(fā)表于 2017-6-20 09:13 | 顯示全部樓層 |閱讀模式
#include <reg51.H>
#define uchar unsigned char
#define uint unsigned int
#define duan P2//數(shù)碼管顯示段選定義
#define wei P2//數(shù)碼管顯示位選定義
#define key P1//鍵盤(pán)接口定義
sbit xwei=P3^5;
sbit xduan=P3^4;
unsigned              long
shu,shz,shuz,shuz1,shu1,i,shu2,shz3,shuz3,shz5,shuz5,shz4,shuz4,shz6,shuz6,xshu,shz7,shuz7;//進(jìn)行運(yùn)算的兩個(gè)變量數(shù)
uchar num;////鍵盤(pán)掃描返回值
uchar flag1,fuhao,fhao ,flag2,flagf,flagl,flagLJ1,flagLJ2;//fuhao運(yùn)符
unsigned char code Wela[]={0x20,0x10,0x08,0x04,0x02,0x01};//六位數(shù)碼管的位選
unsigned char code Duan[]={0x3f,0x06,0x5b,// 0 1 2
    0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};// 3 4 5 6 7 8 9 無(wú)顯示共陰極數(shù)碼管
uchar keyscan();//鍵盤(pán)掃描函數(shù)
void weixz();
void duanxz();
void displayshu(unsigned long);
void delay(uint i)//延時(shí)函數(shù)
while(i--);
/***********************************************主函數(shù)************************************************/
     shu=100;
      xshu=0;
      shu1=0;
      shu2=0;
    flag1=0;
    flag2=0;
      flagf=0;
      flagl=0;
     shu=keyscan();
     if((shu<10)&&flag1==0&&flag2==0&&flagf==0&&flagLJ1==0)
        shu1=shu;
        flag1=1;
        displayshu(shu1);
           flagLJ1=1;
           for (i=1;i<200;i++)
            delay(500);
           else if((shu<10)&&flag1==1&&flag2==0&&flagf==0&&flagLJ1==1)
             shu1=shu1*10;
             shu1=shu+shu1;
               flag1=1;
             displayshu(shu1);
              flagLJ1=1;
if(shu==13&&flag1==1&&flagf==0)
           fuhao=shu;
             wei=0xef;
           weixz();
           duan=Duan[0];
                duanxz();
             flagf=1;
         if(shu==12&&flag1==1&&flagf==0)
           fuhao=shu;
             wei=0xdf;
           weixz();
             duan=Duan[0];
           duanxz();
             flagf=1;
if(shu==15&&flag1==1&&flagf==0)
      fuhao=shu;
      wei=0xdf;
      weixz();
      duan=Duan[0];
        duanxz();
        flagf=1;
/////////chu///////////////
if(shu==11&&flag1==1&&flagf==0)
fuhao=shu;
   wei=0xdf;
weixz();
duan=Duan[0];
duanxz();
flagf=1;
if((shu<10)&&flag1==1&&flagf==1&&flagLJ2==0)
     shu2=shu;
     flag2=1;
       flagLJ2=1;
       displayshu(shu2);
  else             if
((shu<10)&&flag1==1&&flag2==1&&flagf==1&&flagLJ2==1)
         shu2=shu2*10;
           shu2=shu+shu2;
           flag2=1;
         displayshu(shu2);
          if(shu==10&&flag1==1&&flag2==1&&flagf==1)
      switch(fuhao)
      case13:shu1=shu2+shu1; break;
      case12:shu1=shu1-shu2; break;
      case15:shu1=shu1*shu2; break;
      case11:shu1=shu1/shu2; break;
        shu2=0;
        flag1=1;
      flag2=0;
      flagf=0;
      flagLJ1=0;
      flagLJ2=0;
        displayshu(shu1);
         if(shu==14)
       shu1=0;
       shu2=0;
       flag1=0;
       flag2=0;
         flagf=0;
       flagLJ1=0;
     flagLJ2=0;
       displayshu(0);
///////////////鍵盤(pán)掃描/////////////////
          uchar keyscan()
           //////1
          key=0xfe;
            if(key!=0xfe)
           delay(500);
            if(key!=0xfe)
            switch(key)
                case 0xee:num=7 break;
                case 0xde:num=8 break;
                case 0xbe:num=9 break;
                case 0x7e:num=13;break; //"/"
                 return num;
           ////// 1
        ////// 2
           key=0xfd;
        if(key!=0xfd)
           delay(500);
           if(key!=0xfd)
            switch(key)
                 case 0xed:num=4 break;
                 case 0xdd:num=5 break;
                 case 0xbd:num=6 break;
                 case 0x7d:num=12;break; //*
               return num
               //////2
            //////3
                  key=0xfb;
             if(key!=0xfb)
              delay(500);
              if(key!=0xfb)
                 switch(key)
                  case 0xeb:num=1 break;
                  case 0xdb:num=2;break;
                  case 0xbb:num=3;break;
                  case 0x7b:num=11;break;
                     return num
              //////3
             //////4
              key=0xf7;
                 if(key!=0xf7)
                 delay(500);
                   if(key!=0xf7)
                     switch(key)
                       case 0xe7:num=0;break;
                       case 0xd7:num=15;break;
                       case 0xb7:num=14;break;
                       case 0x77:num=10;break;
                        return num
                      for(i=1;i<30;i++)
                       delay(1600);
                    void weixz()
                       xwei=1;
                         delay(1);
                         xwei=0;
                    void duanxz()
                      xduan=1;
                        delay(1);
                      xduan=0;
                   void displayshu(shu)
                     { if(shu<10)
                               wei=0xfe;
                             weixz()
                             duan=Duan[shu];
                               duanxz();
                             delay(5000);
                         else if(shu>9&&shu<100)
                                 for (i=1;i<100;i++ )
                                  wei=0xfe;
                                  shuz=shu%10;
                                  weixz();
                                  duan=Duan[shuz];
                                  duanxz();
                                  delay(200);
                                  shz=shu/10;
                                  wei=0xfd;
                                  shuz1=shz%10;
                                  weixz()
                                  duan=Duan[shuz1];
                                  duanxz();
                                  delay(200);
                                  wei=0xff;
                                    weixz();
                         //////////////3wei/////
                          else if(shu>99&&shu<1000)
                                   wei=0xfe;
                                   shuz=shu%10;
                                   weixz();
                                   duan=Duan[shuz];
                                   duanxz();
                                   delay(100);
                                   shz=shu/10;
                                   wei=0xfd;
                                   shuz1=shz%10;
                                   weixz()
                                   duan=Duan[shuz1];
                                   duanxz();
                                   delay(100);
                                   shz3=shu/100;
                                   wei=0xfb;
                                   shuz3=shz3%10;
                                   weixz();
                                 duan=Duan[shuz3];
                                 duanxz();
                                   delay(100);
                                    wei=0xff;
                                   weixz();
                         //////////////4////////////
                         else if(shu>999&&shu<10000)
                                  for(i=1;i<100;i++)
                                 wei=0xfe;
                                 shuz=shu%10;
                                 weixz();
                                 duan=Duan[shuz];
                                   duanxz();
                                 delay(120);
                                   shz=shu/10;
                                   wei=0xfd;
                                   shuz1=shz%10;
                                 weixz()
                                 duan=Duan[shuz1];
                                   duanxz();
                                 delay(120);
                                   shz3=shu/100;
                                   wei=0xfb;
                                 shuz3=shz3%10;
                                 weixz();
                                   duan=Duan[shuz3];
                                   duanxz();
                                 delay(120);
                                 shz4=shu/1000;
                                 wei=0xf7;
                                 shuz4=shz4%10;
                                   weixz();
                                 duan=Duan[shuz4];
                                 duanxz();
                                 delay(120);
                                    wei=0xff;
                                   weixz();
                     ////////////5///////////////////////
                   else if(shu>9999&&shu<100000)
                          for(i=1;i<100;i++)
                                  wei=0xfe;
                                shuz=shu%10;
                                weixz();
                                duan=Duan[shuz];
                                duanxz();
                                delay(180);
                                  shz=shu/10;
                                  wei=0xfd;
                                  shuz1=shz%10;
                                  weixz()
                                duan=Duan[shuz1];
                               duanxz();
                                delay(180);
                                  shz3=shu/100;
                                  wei=0xfb;
                                shuz3=shz3%10;
                                weixz();
                                duan=Duan[shuz3];
                                  duanxz();
                                delay(180);
                                  shz4=shu/1000;
                                  wei=0xf7;
                                shuz4=shz4%10;
                                weixz();
                                  duan=Duan[shuz4];
                                  duanxz();
                                delay(180);
                                  shz5=shu/10000;
                                  wei=0xef;
                                  shuz5=shz5%10;
                                weixz();
                                  duan=Duan[shuz5];
                                  duanxz();
                                delay(180);
                                wei=0xff;
                                 weixz();
                     ////////////6///////////////////////
                     else if(shu>99999&&shu<1000000)
                             for(i=1;i<100;i++)
                               wei=0xfe;
                             shuz=shu%10;
                               weixz();
                             duan=Duan[shuz];
                             duanxz();
                             delay(180);
                             shz=shu/10;
                               wei=0xfd;
                             shuz1=shz%10;
                               weixz();
                               duan=Duan[shuz1];
                               duanxz();
                             delay(180);
                               shz3=shu/100;
                               wei=0xfb;
                             shuz3=shz3%10;
                             weixz();
                               duan=Duan[shuz3];
                             duanxz();
                             delay(180);
                               shz4=shu/1000;
                             wei=0xf7;
                             shuz4=shz4%10;
                             weixz();
                               duan=Duan[shuz4];
                               duanxz();
                             delay(180);
                               shz5=shu/10000;
                             wei=0xef;
                             shuz5=shz5%10;
                               weixz();
                             duan=Duan[shuz5];
                             duanxz();
                             delay(180);
                               shz6=shz5/10;
                             wei=0xdf;
                             shuz6=shz6%10;
                             weixz();
                             duan=Duan[shuz6];
                               duanxz();
                             delay(180);
                               wei=0xff;
                               weixz();
相關(guān)帖子
主站蜘蛛池模板: 亚洲色吧| www.av在线播放 | 色婷婷香蕉在线一区二区 | 在线观看av片 | 欧美激情精品 | 免费的黄色小视频 | 一区二区三区欧美日韩 | 欧美久久久久久久久 | 欧美日韩中文字幕在线 | www.狠狠操.com| 黑人巨大猛烈捣出白浆 | 日韩成人小视频 | 亚洲精品乱码久久久久久 | 欧美日韩免费一区二区三区 | 黄色一区二区三区 | 国产在线不卡 | 91精品国 | 国产精品视频在线观看 | 欧美视频a | 日韩中文av | 欧美三级在线视频 | 亚洲第一黄网 | 可以看av的网站 | 成人深夜福利 | 婷久久 | 久久精品观看 | 欧美一级黄 | 国产午夜精品久久久久久久 | 91在线观看免费视频 | 波多野结衣一区二区三区在线观看 | 美日韩一区| 激情导航| 性少妇mdms丰满hdfilm | 黄色午夜 | 在线亚洲欧美 | 精品免费在线观看 | 欧美日韩亚洲一区二区三区 | 国产一级大片 | 亚洲天堂免费视频 | 亚洲性视频 | 亚洲国产欧美日韩 |
