查看: 15507|回復(fù): 27
單片機(jī)PID算法的恒溫控制系統(tǒng)仿真與程序源碼設(shè)計(jì)(DS18B20傳感器)
ID:85512 發(fā)表于 2018-4-24 10:21 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
樓主做的基于51單片機(jī)主控的PID算法的恒溫控制系統(tǒng),帶加熱指示燈與遞增和遞減按鈕.采用DS18B20做的溫度傳感器
電路原理圖如下:
恒溫控制系統(tǒng)實(shí)物圖:
pcb圖:
恒溫控制系統(tǒng)的單片機(jī)源程序如下:
  1. #include<reg52.h>
  2. #include<intrins.h>
  3. #include<math.h>
  4. #include<string.h>
  5. struct PID {
  6. unsigned int SetPoint; // 設(shè)定目標(biāo) Desired Value
  7. unsigned int Proportion; // 比例常數(shù) Proportional Const
  8. unsigned int Integral; // 積分常數(shù) Integral Const
  9. unsigned int Derivative; // 微分常數(shù) Derivative Const
  10. unsigned int LastError; // Error[-1]
  11. unsigned int PrevError; // Error[-2]
  12. unsigned int SumError; // Sums of Errors
  13. };
  14. struct PID spid; // PID Control Structure
  15. unsigned int rout; // PID Response (Output) 響應(yīng)輸出
  16. unsigned int rin; // PID Feedback (Input)//反饋輸入
  17. unsigned char high_time,low_time,count=0;//占空比調(diào)節(jié)參數(shù)
  18. #define uchar unsigned char
  19. #define uint unsigned int
  20. sbit output=P1^0;
  21. sbit ds=P3^2;
  22. sbit DQ=P3^2;//ds18b20與單片機(jī)連接口
  23. sbit lcden=P2^7;//LCE使能引腳
  24. sbit lcdrs=P2^5;
  25. sbit lcdrw=P2^6;
  26. sbit ledred=P1^6;
  27. sbit ledgreen=P1^7;
  28. sbit key0=P2^0;//按鍵引腳
  29. sbit key1=P2^1;
  30. uchar set[2]={0};
  31. uchar code str1[]="now temp:      C";
  32. uchar code str2[]="set temp:      C";
  33. uchar code table[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};
  34. uchar n,num;
  35. int set_temper=30,temper,temp; //溫度變量定義
  36. unsigned int s;
  37. float         f_temp;//轉(zhuǎn)換后的溫度
  38. uint tvalue;
  39. uchar tflag;//溫度正負(fù)標(biāo)志
  40. void delay(i)//延時(shí)函數(shù)
  41. {
  42.         uint j;
  43.         for(i;i>0;i--)
  44.         for(j=110;j>0;j--);
  45. }
  46. void wr_com(uchar ml)//寫(xiě)命令
  47. {
  48.         lcdrs=0;
  49.         P0=ml;
  50.         delay(5);
  51.         lcden=1;
  52.         delay(5);
  53.         lcden=0;
  54. }
  55. void wr_data(uchar shuju)//寫(xiě)數(shù)據(jù)
  56. {
  57.         lcdrs=1;
  58.         //lcden=1;
  59.         P0=shuju;
  60.         delay(5);
  61.         lcden=1;
  62.         delay(5);
  63.         lcden=0;
  64. }
  65. void init()  //按照時(shí)序操作的初始化
  66. {
  67.         lcdrw=0;
  68.         wr_com(0x38);//顯示模式設(shè)置,設(shè)置為16*2顯示,5*7點(diǎn)陣,八位數(shù)據(jù)口
  69.         wr_com(0x0c);//開(kāi)顯示,但不開(kāi)光標(biāo),光標(biāo)不閃
  70.         wr_com(0x06);//顯示光標(biāo)移動(dòng)設(shè)置
  71.         wr_com(0x01);// 清屏
  72.         wr_com(0x80);        // 數(shù)據(jù)指針初始化
  73.         for(num=0;num<16;num++)
  74.                 {
  75.                         wr_data(str1[num]);//now temp
  76.                 }
  77.         wr_com(0x80+0x40); //地址初始化
  78.         for(num=0;num<16;num++)
  79.                 {
  80.                         wr_data(str2[num]);//set temp
  81.                 }
  82. }
  83. /*************************DS1820程序****************************/
  84. void delay_18B20(unsigned int i)//延時(shí)1微秒
  85. {
  86.    while(i--);
  87. }
  88. void ds1820rst(void)/*ds1820復(fù)位*/
  89. {
  90.         unsigned char x=0;
  91.         DQ = 1;          //DQ復(fù)位
  92.         delay_18B20(4); //延時(shí)
  93.         DQ = 0;          //DQ拉低
  94.    TR0=0;
  95.         delay_18B20(100); //精確延時(shí)大于
  96.    TR0=1;
  97.         DQ = 1;          //拉高
  98.         delay_18B20(40);
  99. }
  100. uchar ds1820rd(void)/*讀數(shù)據(jù)*/
  101. {
  102.         unsigned char i=0;
  103.         unsigned char dat = 0;
  104.    TR0=0;
  105.         for (i=8;i>0;i--)
  106.         {
  107.                 DQ = 0; //給脈沖信號(hào)
  108.                 dat>>=1;
  109.                 DQ = 1; //給脈沖信號(hào)
  110.                 if(DQ)
  111.                 dat|=0x80;
  112.                 delay_18B20(10);
  113.         }
  114.    return(dat);
  115. }
  116. void ds1820wr(uchar wdata)/*寫(xiě)數(shù)據(jù)*/
  117. {
  118.         unsigned char i=0;
  119.    TR0=0;
  120.    for (i=8; i>0; i--)
  121.    {
  122.                 DQ = 0;
  123.                 DQ = wdata&0x01;
  124.                 delay_18B20(10);
  125.                 DQ = 1;
  126.                 wdata>>=1;
  127.    }
  128. }
  129. uint get_temper()//獲取溫度
  130. {
  131.
  132.         uchar a,b;
  133.         ds1820rst();
  134.         ds1820wr(0xcc);//*跳過(guò)讀序列號(hào)*/
  135.         ds1820wr(0x44);//*啟動(dòng)溫度轉(zhuǎn)換*/
  136.         ds1820rst();
  137.         ds1820wr(0xcc);//*跳過(guò)讀序列號(hào)*/
  138.         ds1820wr(0xbe);//*讀取溫度*/
  139.         a=ds1820rd();
  140.         b=ds1820rd();
  141.
  142.         tvalue=b;
  143.         tvalue<<=8;
  144.         tvalue=tvalue|a;
  145.    TR0=1;
  146.    if(tvalue<0x0fff)   tflag=0;
  147.    else {tvalue=~tvalue+1;tflag=1;}
  148.         tvalue=tvalue*(0.625);//溫度值擴(kuò)大10倍,精確到1位小數(shù)
  149.         temp=tvalue;
  150.         return temp;
  151. }
  152. void dis_temp(int t)//顯示溫度
  153. {
  154.         uchar d0,d1,d2,d3;
  155.         //t=26;
  156.         if(tflag==0)
  157.         {
  158.                 d0=t/1000+0x30;
  159.                 d1=t%1000/100+0x30;
  160.                 d2=t%100/10+0x30;
  161.                 d3=t%10+0x30;
  162.                 if(d0==0x30)
  163.                 {
  164.                         wr_com(0x80+9);
  165.                         wr_data(d1);
  166.                         wr_com(0x80+10);
  167.                         wr_data(d2);
  168.                         wr_com(0x80+11);
  169.                         wr_data(0x2e);
  170.                         wr_com(0x80+12);
  171.                         wr_data(d3);
  172.                 }
  173.                 else
  174.                 {
  175.                         wr_com(0x80+9);
  176.                         wr_data(d0);
  177.                         wr_com(0x80+10);
  178.                         wr_data(d1);
  179.                         wr_com(0x80+11);
  180.                         wr_data(d2);
  181.                         wr_com(0x80+12);
  182.                         wr_data(' ');
  183.                 }
  184.
  185.         }
  186.         else
  187.         {
  188.                 wr_com(0x80+9);
  189.                 wr_data('-');
  190.                 wr_com(0x80+10);
  191.                 wr_data(d1);
  192.                 wr_com(0x80+11);
  193.                 wr_data(d2);
  194.                 wr_com(0x80+12);
  195.                 wr_data(' ');
  196.                 //wr_com(0x80+12);
  197.                 //wr_data(d3);
  198.         }
  199.         wr_com(0x80+14);
  200.         wr_data(0xdf);
  201.         temper=t/10;
  202. }
  203. void keyscan()//鍵盤(pán)掃描
  204. {
  205.    if(key0==0)
  206.    {
  207.                 delay(1);
  208.                 if(key0==0)
  209.                 {
  210.                         while(!key0);
  211.                         delay(1);
  212.                         while(!key0);
  213.                         set_temper++;
  214.                 }
  215.                 set[0]=set_temper/10;        //獲得設(shè)置溫度顯示值
  216.                 set[1]=set_temper%10;
  217.                 wr_com(0x80+0x40+9);
  218.                 wr_data(table[set[0]]);
  219.                 delay(1);
  220.                 wr_com(0x80+0x40+10);
  221.                 wr_data(table[set[1]]);
  222.                 delay(1);
  223.                 //wr_com(0x80+0x40+11);
  224.                 //wr_data(0x2e);
  225.                 //wr_com(0x80+0x40+14);
  226.                 //wr_data(0xdf);
  227.                 delay(1);
  228.         }
  229.         if(key1==0)
  230.    {
  231.                 delay(3);//延時(shí)去抖
  232.                 if(key1==0)
  233.                 {
  234.                         while(!key1);
  235.                         delay(3);
  236.                         while(!key1);
  237.                         set_temper--;//溫度減
  238.                         if(set_temper==0)
  239.                         {set_temper=0;}
  240.                 }
  241.
  242.                 set[0]=set_temper/10;        //獲得設(shè)置溫度顯示值
  243.                 set[1]=set_temper%10;
  244.                 wr_com(0x80+0x40+9);        //顯示設(shè)置溫度值
  245.                 wr_data(table[set[0]]);
  246.                 delay(1);
  247.                 wr_com(0x80+0x40+10);
  248.                 wr_data(table[set[1]]);
  249.                 delay(1);
  250.                 //wr_com(0x80+0x40+11);
  251.                 //wr_data(0x2e);
  252.                 wr_com(0x80+0x40+14);
  253.                 wr_data(0xdf);
  254.                 delay(1);
  255.         }
  256. }
  257. void PIDInit (struct PID *pp)
  258. {
  259.         memset ( pp,0,sizeof(struct PID)); //用參數(shù)0初始化pp
  260. }
  261. unsigned int PIDCalc( struct PID *pp, unsigned int NextPoint ) //PID計(jì)算
  262. {
  263.         unsigned int dError,Error;
  264.         Error = pp->SetPoint - NextPoint; // 偏差
  265.         pp->SumError += Error; // 積分
  266.         dError = pp->LastError - pp->PrevError; // 當(dāng)前微分
  267.         pp->PrevError = pp->LastError;
  268.         pp->LastError = Error;
  269.         return (pp->Proportion * Error//比例
  270.         + pp->Integral * pp->SumError  //積分項(xiàng)
  271.         + pp->Derivative * dError); //   微分項(xiàng)
  272. }
  273. /***********************************************************
  274. 溫度比較處理子程序
  275. ***********************************************************/
  276. void compare_temper(void)
  277. {
  278.         unsigned char i;
  279.         if(set_temper>temper)         //設(shè)置溫度大于當(dāng)前溫度
  280.         {
  281.                 ledred=0;
  282.                 ledgreen=1;
  283.                 if(set_temper-temper>1)         //溫度相差1度以上
  284.                 {
  285.                         high_time=100;
  286.                         low_time=0;
  287.                 }
  288.                 else         //設(shè)置溫度不大于當(dāng)前溫度
  289.                 {
  290.                         for(i=0;i<10;i++)
  291.                         {
  292.                                 get_temper();
  293.                                 rin = s; // Read Input
  294.                                 rout = PIDCalc ( &spid,rin ); // Perform PID Interation
  295.                         }
  296.                         if (high_time<=100)         high_time=(unsigned char)(rout/800);
  297.                         else        high_time=100;
  298.                         low_time= (100-high_time);
  299.                 }
  300.         }
  301.         else if(set_temper<=temper)         //設(shè)置溫度不大于當(dāng)前溫度
  302.         {
  303.                 ledred=1;
  304.                 ledgreen=0;
  305.                 if(temper-set_temper>0) //溫度相差0度以上
  306.                 {
  307.                         high_time=0;
  308.                         low_time=100;
  309.                 }
  310.                 else
  311.                 {
  312.                         for(i=0;i<10;i++)
  313.                         {
  314.                                 get_temper();
  315.                                 rin = s; // Read Input
  316.                                 rout = PIDCalc ( &spid,rin ); // Perform PID Interation
  317.                         }
  318.                         if (high_time<100) high_time=(unsigned char)(rout/10000);
  319.                         else         high_time=0;
  320.                         low_time= (100-high_time);
  321.                 }
  322.         }
  323. }
  324. /*****************************************************
  325. T0中斷服務(wù)子程序,用于控制電平的翻轉(zhuǎn) ,40us*100=4ms周期
  326. ******************************************************/
  327. void serve_T0() interrupt 1 using 1
  328. {
  329.         if(++count<=(high_time))         output=0;
  330.         else if(count<=100)
  331.         {
  332.                 output=1;
  333.         }
  334.         else count=0;
  335.         TH0=0x2f;
  336.         TL0=0x40;
  337. }
  338. /***********主函數(shù)**********/
  339. void main(void)
  340. {
  341.         unsigned char i;
  342.         init();//LCD初始化
  343.         TMOD=0x01;
  344.         TH0=0x2f;
  345.         TL0=0x40;
  346.         EA=1;
  347.         ET0=1;
  348.         TR0=1;
  349.         high_time=50;
  350.         low_time=50;
  351.         PIDInit ( &spid ); // Initialize Structure
  352.         spid.Proportion= 10; // Set PID Coefficients
  353.         spid.Integral = 8;
  354.         spid.Derivative =6;
  355.         spid.SetPoint =100; // Set PID Setpoint
  356.         set[0]=set_temper/10;
  357.         set[1]=set_temper%10;
  358.         wr_com(0x80+0x40+9);        //顯示設(shè)置溫度
  359.         wr_data(table[set[0]]);
  360.    delay(1);
  361.         wr_com(0x80+0x40+10);
  362. ……………………
  363. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
1DS18B20 控溫 源程序.rar (95.34 KB, 下載次數(shù): 586)
仿真.rar (24.19 KB, 下載次數(shù): 459)
評(píng)分
參與人數(shù) 3黑幣 +85 收起 理由
liwenyi666 + 30 樓主能加個(gè)QQ私聊一下嗎
dearluca + 5 回帖助人的獎(jiǎng)勵(lì)!
查看全部評(píng)分
收藏收藏24 分享淘帖 頂1 踩
ID:1134216 發(fā)表于 2024-10-21 11:32 | 只看該作者
設(shè)計(jì)的不錯(cuò)啊
ID:336378 發(fā)表于 2022-3-30 15:11 | 只看該作者
                        for(i=0;i<10;i++)
                                s=get_temper();//取得現(xiàn)在的溫度。
ID:739402 發(fā)表于 2020-5-5 11:08 | 只看該作者
樓主能QQ私聊一下嗎?救助,感激不盡
ID:732724 發(fā)表于 2020-5-5 10:56 來(lái)自觸屏版 | 只看該作者
landing 發(fā)表于 2020-5-4 11:14
謝謝,剛好要寫(xiě)一個(gè)恒溫PID控制,可以參考一下。
能否加個(gè)QQ傳我 感激不盡
ID:732724 發(fā)表于 2020-5-5 10:55 來(lái)自觸屏版 | 只看該作者
請(qǐng)問(wèn)你能打開(kāi)嗎?我打不開(kāi),顯示丟失什么文件
ID:739026 發(fā)表于 2020-5-4 11:14 | 只看該作者
ID:491642 發(fā)表于 2019-5-11 15:49 | 只看該作者
謝謝樓主分享
ID:509991 發(fā)表于 2019-4-16 21:17 | 只看該作者
樓主你這個(gè)是通過(guò)什么加熱裝置加熱的呀
ID:507638 發(fā)表于 2019-4-13 19:45 | 只看該作者
樓主,沒(méi)有降溫處理嗎?
ID:507638 發(fā)表于 2019-4-10 20:23 | 只看該作者
有沒(méi)有解析呢??
ID:507638 發(fā)表于 2019-4-9 11:04 | 只看該作者
yzh123 發(fā)表于 2018-4-24 20:41
樓主你好,你的pid參數(shù)是怎么整定的?
要求精度不高的話通常設(shè)置都是一樣的
ID:507638 發(fā)表于 2019-4-9 11:03 | 只看該作者
樓主能私聊下嗎
ID:507638 發(fā)表于 2019-4-9 10:50 | 只看該作者
zxr961129 發(fā)表于 2018-6-7 21:13
感謝樓主,最近在做畢業(yè)設(shè)計(jì),需要模糊pid方面的程序和仿真,很高興樓主能夠分享出來(lái)!
能互相交流下嗎
ID:507638 發(fā)表于 2019-4-9 10:46 | 只看該作者
樓主能加QQ聊嗎
ID:489404 發(fā)表于 2019-3-12 18:22 | 只看該作者
ID:450056 發(fā)表于 2018-12-20 23:49 來(lái)自觸屏版 | 只看該作者
謝謝,樓主給力
ID:245429 發(fā)表于 2018-12-20 20:58 | 只看該作者
學(xué)習(xí)了,下載下來(lái)以后試試
ID:407060 發(fā)表于 2018-10-9 16:05 | 只看該作者
求救樓主 仿真的電路板在哪里,我打不開(kāi)
ID:280466 發(fā)表于 2018-9-1 19:52 | 只看該作者
可以嗎???
ID:340241 發(fā)表于 2018-6-14 02:00 | 只看該作者
樓主流弊
ID:304629 發(fā)表于 2018-6-7 21:13 | 只看該作者
ID:323102 發(fā)表于 2018-6-7 12:49 | 只看該作者
實(shí)際測(cè)量溫度不顯示誰(shuí)幫幫我加qq2304146938
ID:323102 發(fā)表于 2018-6-7 12:48 | 只看該作者
ID:323102 發(fā)表于 2018-6-7 11:17 | 只看該作者
溫度顯示不出來(lái)怎么回事
ID:311660 發(fā)表于 2018-4-25 19:37 | 只看該作者
樓主我想對(duì)你的程序提幾個(gè)問(wèn)題。在你的溫度比較處理子程序里面有一段程序是這樣的if(set_temper>temper)         //設(shè)置溫度大于當(dāng)前溫度
                ledred=0;
                ledgreen=1;
                        high_time=100;
                        low_time=0;
                        for(i=0;i<10;i++)
                                get_temper();
                        else        high_time=100;
  請(qǐng)問(wèn)一下rin=s是不是表示的是PID的回饋輸入,那么既然如此的話rin不應(yīng)該是等于輸出的溫度嗎?為什么是s呢?我看了一下程序除了一開(kāi)始的定義unsigned int s;和剛剛那個(gè)地方s就沒(méi)有別的用處了。
      else         //設(shè)置溫度不大于當(dāng)前溫度     這一條語(yǔ)句的注釋也不是很明白。  這個(gè)else是在if(set_temper-temper>1)         //溫度相差1度以上      這條語(yǔ)句后面,那么我感覺(jué)他的注釋?xiě)?yīng)該是     溫度相差小于一度
      最后的話是這一句  if (high_time<=100)         high_time=(unsigned char)(rout/800);
                        else        high_time=100;
                        low_time= (100-high_time);整個(gè)都不太明白 ,特別是(rout/800)
希望樓主有空的話可以賜教一下,謝謝!
評(píng)分
參與人數(shù) 1黑幣 +80 收起 理由
admin + 80 贊一個(gè)!
查看全部評(píng)分
ID:311660 發(fā)表于 2018-4-25 10:18 | 只看該作者
謝謝樓主,最近剛好在做這方面的東西
ID:314339 發(fā)表于 2018-4-24 20:41 來(lái)自觸屏版 | 只看該作者
主站蜘蛛池模板: 欧美一级淫片免费视频黄 | 伊人av网| 91精品国产成人www | 久久综合热 | 国产精品免费在线播放 | 亚洲精品中文字幕乱码三区91 | 国产一区二区三区免费视频 | 国产一级在线视频 | 欧美成人猛片aaaaaaa | 亚洲综合二区 | 激情五月综合色婷婷一区二区 | 艳妇臀荡乳欲伦交换h漫 | 在线日韩| 欧美性色网 | 五月伊人网| 亚洲一级黄色片 | 国产白丝精品91爽爽久久 | 一区二区三区影视 | 日韩特黄| 四虎成人在线 | 91视频色| 日韩av免费在线观看 | 糖心vlog精品一区二区 | 国产乱码精品一区二区三区忘忧草 | 日韩在线观看一区 | 亚洲乱码一区二区 | 天天干天天操 | 成人激情在线 | 操欧美女人 | 黄色精品视频 | 一本伊人| 成人黄色一级片 | 91久久精品日日躁夜夜躁欧美 | 亚洲视频精品 | 毛片视频免费 | 99爱视频 | 日本免费网站 | 自拍偷在线精品自拍偷无码专区 | 日韩特级片 | 国产精品成人一区 | 国产精品视频免费 |
