查看: 18570|回復: 32
PID算法控制電機轉速源程序+Proteus仿真工程文件+電路圖
一個關于PID算法的控制電機轉動的Proteus仿真及程序,電路圖在仿真工程文件里面打開即可
  1. #include<reg52.h>
  2. #include"lcd1602.h"
  3. sfr T2MOD = 0x0c9;
  5. #define uint unsigned int
  6. sbit Q0 = P2^4;
  7. sbit Q1 = P2^5;
  8. sbit Q2 = P2^6;
  9. sbit Q3 = P2^7;
  10. sbit PWM                 = P1^7;
  11. sbit UP                         = P1^0;
  12. sbit DOWM                 = P1^1;
  13. sbit GORB                = P2^3; //換相
  14. sbit ADDSPEED         = P1^2;
  15. sbit SUBSPEED        = P1^3;
  16. uint tuint = 65535;
  17. uint tpwm = 1;        //pwm周期為10000us tpwm變量表示pwm高電平時間,也相當于占空比 (仿真時,頻率高時,電機反應慢。在實物上要加大頻率)
  18. uchar t1_flag = 0;
  19. uint pulse = 0;
  20. uint t0_flag = 0;
  21. uchar t2_flag = 0;
  22. bit t2_over = 0;
  23. bit Just_Get = 1;
  24. #define         ZZ                 { Q0 = 0;Q1 = 0;Q2 = 1;Q3 = 1;}        //正轉
  25. #define         FZ                 { Q0 = 1;Q1 = 1;Q2 = 0;Q3 = 0;}        //反轉
  26. #define         STOP        { Q0 = 1;Q1 = 0;Q2 = 1;Q3 = 0;}        //停止
  27. //禁止出現 Q0 = 0;Q1 = 1;Q2 = 0;Q3 = 1; 不然會燒掉mos管
  28. //************************ PID *************************************
  29. float now = 0,bef = 0,bbef = 0;         //本次采樣值,上次采樣值,上上次采樣值
  30. float err_now,err_bef,err_bbef;                //當前偏差,上次偏差,上上次偏差
  31. float error_add = 0;                                //所有偏差之和
  32. float set = 25;                                                //設定值
  33. float kp = 25;
  34. float ki = 25;
  35. float kd = 0;
  36. //*****************************************************************
  37. void delayms(uint ms)//延時?個 ms
  38. {
  39.     uchar a,b,c;
  40.         while(ms--)
  41.         {
  42.           for(c=1;c>0;c--)
  43.         for(b=142;b>0;b--)
  44.             for(a=2;a>0;a--);
  45.         }
  46. }
  47. void timer_init()
  48. {
  49.         EA = 1;
  50.         ET0 = 1;
  51.         ET1 = 1;
  52.         ET2 = 1;
  53.
  54.         TMOD = 0x15; //定時器0 計數模式 定時器1模式1
  55.         T2MOD = 0x01;
  56.
  57.         TH0 = TL0 = 255;
  58.         TH2 = 0x3C;
  59.         TL2 = 0xB0;                //50MS
  60.
  61. }
  62. void timer1() interrupt 3
  63. {
  64.         if(t1_flag == 0)
  65.         {
  66.                 t1_flag = 1;
  67.                 PWM = 1;
  68.                 TH1 = (tuint - tpwm + 1)/256;
  69.                 TL1 = (tuint - tpwm + 1)%256;
  70.
  71.         }
  72.         else
  73.         {
  74.                 t1_flag = 0;
  75.                 PWM = 0;
  76.                 TH1 = (tuint - 10000 + tpwm + 1)/256;
  77.                 TL1 = (tuint - 10000 + tpwm + 1)%256;
  78.         }
  79. }
  80. void timer0() interrupt 1
  81. {
  82.         TH0 = TL0 = 255;
  83.         t0_flag++;
  84. }
  85. void timer2() interrupt 5
  86. {
  87.         TF2 = 0;
  88.         TH2 = 0x3C;
  89.         TL2 = 0xB0;                //50MS
  90.
  91.         t2_flag++;
  92.
  93.         if(t2_flag == 2)
  94.         {
  95.                 TR0 = 0;
  96.                 TR2 = 0;
  97.                 t2_flag = 0;
  98.                 t2_over = 1;        //表示100ms時間到
  99.         }
  100. }
  101. void GetPulse()
  102. {
  103.         t0_flag = 0;
  104.         t2_flag = 0;
  105.
  106.         TH0 = TL0 = 255;
  107.         TH2 = 0x3C;
  108.         TL2 = 0xB0;                //50MS
  109.
  110.         TR0 = 1;
  111.         TR2 = 1;
  112. }
  113. int PID()        //增量式PID
  114. {
  115.         int change;
  116.         err_now = set - now;
  117.         err_bef = set - bef;
  118.         err_bbef = set - bbef;
  119.
  120.         change = kp*(err_now - err_bef) + ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
  121.
  122. /*
  123.         if(set >= now)
  124.         {
  125.                 if(set - now > 1)
  126.                         change = kp*(err_now - err_bef) + ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
  127.                 else
  128.                         change = 0.2*kp*(err_now - err_bef) + 0.5*ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
  129.         }
  130.         else if(now > set)
  131.         {
  132.                 if(now - set > 1)
  133.                         change = kp*(err_now - err_bef) + ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
  134.                 else
  135.                         change = 0.2*kp*(err_now - err_bef) + 0.5*ki*err_now + kd*(err_now - 2*err_bef + err_bbef);
  136.
  137.         }
  138. */
  139.
  140.         //change = (kp + ki + kd)*(set - now) + (-kp - 2*kd)*(set - bef) + kd*(set - bbef);
  141.         //change = kp*(set - now) + ki*(set - bef) + kd*(set - bbef);
  142.         if(change > 0)
  143.         {
  144.                 printchar(1,10,'+');
  145.                 printuint(1,11,4,change);
  146.
  147.         }
  148.         else if(change < 0)
  149.         {
  150.                 printchar(1,10,'-');
  151.                 printuint(1,11,4,-change);
  152.         }
  153.         else if(change == 0)
  154.         {
  155.                 printchar(1,10,' ');
  156.                 printword(1,11," 0  ");
  157.         }
  158.
  159.         return(change);
  160. }
  161. int PID2()                //位置式PID
  162. {
  163.
  164.         int num = 0;
  165.         static num_bef = 0;
  166.
  167.         err_now = set - now;
  168.         err_bef = set - bef;
  169.
  170.         error_add = error_add + err_now;  //誤差累加。一旦誤差為0則error_add的值不變,PID輸出值不變
  171.         num = kp*err_now + ki*error_add + kd*(err_now - err_bef);
  172.
  173. /*
  174.         if(set - now >= 0)
  175.         {
  176.                 if(set - now > 1)
  177.                         num = kp*err_now + ki*error_add + kd*(err_now - err_bef);
  178.                 else
  179.                         num = 0.1*kp*err_now + ki*error_add + kd*(err_now - err_bef);
  180.         }
  181.         else
  182.         {
  183.                 if(now - set > 1)
  184.                         num = kp*err_now + ki*error_add + kd*(err_now - err_bef);
  185.                 else
  186.                         num = 0.1*kp*err_now + ki*error_add + kd*(err_now - err_bef);
  187.
  188.         }
  189.         */
  190.
  191.         if(num > num_bef)
  192.         {
  193.                 printchar(1,10,'+');
  194.                 printuint(1,11,4,num - num_bef);
  195.         }
  196.         else if(num < num_bef)
  197.         {
  198.                 printchar(1,10,'-');
  199.                 printuint(1,11,4,num_bef - num);
  200.         }
  201.         else
  202.         {
  203.                 printchar(1,10,' ');
  204.                 printuint(1,11,4,0);
  205.         }
  206.
  207.         num_bef = num;
  208.
  209.         return((uint)num);
  210. }
  211. void main()
  212. {
  213.
  214.         lcd_init();
  215.         timer_init();
  216.         TH1 = TL1 = 255;
  217.
  218.         printword(0,0,"P:");                //比例系數
  219.         printword(0,5,"S:");                //設定值
  220.         printword(1,0,"TPWM:");                //當前占空比
  221.         printword(0,10,"PS:");                //當前電機反饋的每秒脈沖數
  222.
  223.         while(1)
  224.         {
  225.                 if(GORB == 1)
  226.                 {        ZZ;                }
  227.                 else
  228.                 {        FZ;                }
  229.
  230.                 if(ADDSPEED == 0)
  231.                         set++;
  232.                 if(SUBSPEED == 0)
  233.                         set--;
  234.
  235.                 if(Just_Get == 1)
  236.                 {
  237.                         Just_Get = 0;
  238.                         GetPulse();
  239.                 }
  240.                 else if(t2_over == 1)
  241.                 {
  242.                         t2_over = 0;
  243.                         Just_Get = 1;
  244.                         pulse = t0_flag;
  245.                         bbef = bef;
  246.                         bef = now;
  247.                         now = t0_flag;
  248.
  249.                         if(set != 0)
  250.                         {
  251.                                 TR1 = 1;
  252.                         }
  253.                         else
  254.                         {
  255.                                 TR1 = 0;
  256.                                 PWM = 0;
  257.                         }
  258.
  259.                 //        tpwm = tpwm + PID();                //增量式PID
  260.                         tpwm = PID2();                                //位置式PID
  261.
  262.                 }
  263.
  264.                 if(UP == 0)
  265.                         kp = kp + 1;
  266.                 if(DOWM == 0)
  267.                         kp = kp - 1;
  268.
  269.                 printuint(0,2,3,kp);
  270.                 printuint(0,7,3,set);
  271.                 printuint(1,5,4,tpwm);
  272.                 printuint(0,13,5,pulse);
  273.         }
  274.
  275. }
  276.
這個是液晶頭文件:
  1. #include <intrins.h>
  3. #define uint unsigned int
  4. //************************************ lcd1602開始 ***********************************
  5. #define LCD_DATA P0                //P0口接LCD數據口
  6. sbit RS                 = P2^2;
  7. sbit RW                 = P2^1;
  8. sbit LCDEN                 = P2^0;
  9. sbit LCD_BUSY        = P0^7;
  10. //********* lcd1602延時函數 ***************
  11. void delayms_lcd(uint ms)//延時?個 ms
  12. {
  13.     uchar a,b,c;
  14.         while(ms--)
  15.         {
  16.           for(c=1;c>0;c--)
  17.         for(b=142;b>0;b--)
  18.             for(a=2;a>0;a--);
  19.         }
  20. }
  21. //**********字符串復制函數**********
  22. void string_copy(uchar *target,uchar *source)//字符串復制 target:目標 source:源
  23. {
  24.         uchar i = 0;
  25.         for(i = 0;source[i] != '\0';i++)//注意target的長度 無保護措施!
  26.         {
  27.                 target[i] = source[i];
  28.         }
  29.         target[i] = '\0';
  30. }
  31. //**********字符串比較函數**********
  32. uchar string_cmp(uchar *target,uchar *source)//字符串比較 target:目標 source:源
  33. {
  34.         uchar revalue;
  35.         uchar i = 0;
  36.         for(i = 0;target[i] != '\0' && source[i] != '\0';i++)  //兩個都不等于'\0'才執行 出現一個等于'\0'就跳出
  37.         {
  38.                 if(target[i] == source[i])
  39.                 {
  40.                         revalue = 1;
  41.                 }
  42.                 else
  43.                 {
  44.                         revalue = 0;
  45.                         break;
  46.                 }
  47.         }
  48.         if(revalue == 1)
  49.         {
  50.                 if(target[i] == '\0' && source[i] == '\0')
  51.                         revalue = 1;
  52.                 else
  53.                         revalue = 0;
  54.         }
  55.         return(revalue);
  56. }
  57. //**************** LCD1602函數 ********************
  58. //LCD基本函數:
  59. void busy_check()  //忙碌檢測
  60. {
  61. /*        RW = 1;         //讀
  62.         RS = 0;        //指令寄存器
  63.         LCD_DATA = 0xFF;//實驗證明讀數時要將I/O口要置1
  64.         LCDEN = 0;
  65.         _nop_();
  66.         _nop_();
  67.         _nop_();
  68.         _nop_();
  69.         LCDEN = 1;// EN高電平讀信息 負跳變執行指令
  70.         _nop_();
  71.         _nop_();
  72.         _nop_();
  73.         _nop_();
  74.         while(1)
  75.         {
  76.                 if(LCD_BUSY == 0)//P07 == 0跳出循環
  77.                         break;
  78.         }  */
  79.         delayms_lcd(2);//仿真時用延時法 下載到真實單片機上時,將這句注釋掉,采用上面的語句。
  80. }
  81. void lcdwrcom(uchar command)//寫指令
  82. {
  83.         busy_check();
  84.         RW = 0;//寫
  85.     RS = 0;//指令寄存器
  86.     LCD_DATA = command;
  87.         LCDEN = 1;//負跳變寫入指令
  88.         _nop_();
  89.         _nop_();
  90.         _nop_();
  91.         _nop_();
  92.         LCDEN = 0;
  93. }
  94. void lcdwrdata(uchar lcd_data)//寫數據        數字、字母、標點符號都是數據
  95. {
  96.         busy_check();
  97.         RW = 0;//寫
  98.     RS = 1;//數據寄存器
  99.     LCD_DATA = lcd_data;
  100.         LCDEN = 1;//負跳變寫入指令
  101.         _nop_();
  102.         _nop_();
  103.         _nop_();
  104.         _nop_();
  105.         LCDEN = 0;
  106. }
  107. void lcd_init()
  108. {
  109.         delayms_lcd(15);//必要 lcd1602上電到電壓穩定需要時間
  110.         RW = 0;//寫
  111.         RS = 0;//指令寄存器
  112.     LCD_DATA = 0x38;// 0x38設置顯示模式為:16X2 顯示,5X7 點陣,8 位數據接口'
  113.         LCDEN = 1;
  114.         _nop_();
  115.         _nop_();
  116.         _nop_();
  117.         _nop_();
  118.         LCDEN = 0;
  119.         delayms_lcd(5);
  120.         lcdwrcom(0x0c);//打開顯示 無光標 不閃爍
  121.         lcdwrcom(0x06);//指令3 光標右移 屏幕所有文字移動無效
  122.         lcdwrcom(0x01);// 清顯示,光標復位到地址00H位置。
  123. }
  124. //LCD擴展函數:
  125. void address(uchar x,uchar y)  //定位下一步要寫數的地址
  126. {
  127.         uchar location;
  128.         if(x == 0)
  129.             location = 0x80|y;
  130.         else
  131.                 location = 0xC0|y;
  132.          lcdwrcom(location);
  133. }
  134. void printchar(uchar x,uchar y,uchar letter)//顯示字母、單個字符
  135. {
  136.         address(x,y);
  137.         lcdwrdata(letter);
  138. }
  139. void printword(uchar x,uchar y,uchar *word) //顯示單詞(字符數組)
  140. {
  141.         uchar i = 0;
  142.         for(i = 0;word[i] != '\0';i++)
  143.         {
  144.                 address(x,y + i);
  145.                 lcdwrdata(word[i]);
  146.         }
  147. }
  148. void printuint(uchar x,uchar y,uchar num_ws_max,uint num)//顯示無符號整形 0~65535 x:行 y:列 num_ws_max 變量的最大位數
  149. {
  150.         uchar i = 0;
  151.         uchar str[5] = {0x20,0x20,0x20,0x20,0x20};
  152.         if(num >= 10000)
  153.         {
  154.                 str[0] = num/10000 + '0';
  155.                 str[1] = num%10000/1000 + '0';
  156.                 str[2] = num%1000/100 + '0';
  157.                 str[3] = num%100/10 + '0';
  158.                 str[4] = num%10 + '0';
  159.         //        str[5] = '\0';         //手動加字符串結束標志
  160.         }
  161.         else if(num >= 1000)
  162.         {
  163.                 str[0] = num/1000 + '0';
  164.                 str[1] = num%1000/100 + '0';
  165.                 str[2] = num%100/10 + '0';
  166.                 str[3] = num%10 + '0';
  167.                 str[4] ='\0';
  168.         }
  169.         else if(num >= 100)
  170.         {
  171.                 str[0] = num/100 + '0';
  172.                 str[1] = num%100/10 + '0';
  173.                 str[2] = num%10 + '0';
  174.                 str[3] = '\0';
  175.         }
  176.         else if(num >=10)
  177.         {
  178.                 str[0] = num/10 + '0';
  179.                 str[1] = num%10 + '0';
  180.                 str[2] = '\0';
  181.         }
  182.         else if(num >= 0)
  183.         {
  184.                 str[0] = num + '0';
  185.                 str[1] = '\0';
  186.         }
  187.
  188.         for(i = 0;i <= 5;i++)        //uint類型 最大值65535 為5位數
  189.         {
  190.                 if(str[i] != '\0' && i < num_ws_max)
  191.                 {
  192.                         address(x,y + i);
  193.                         lcdwrdata(str[i]);
  194.                 }
  195.                 else if(str[i] == '\0' && i < num_ws_max)
  196.                 {
  197.                         address(x,y+i);
  198.                         lcdwrdata(' ');//空格                                                  // 實現功能:在此變量的位數范圍內,把沒數字的位存0x20(空格)
  199.        //例如:最大有3位:999 當變為99時,存為9+'0' 9+'0' 0x20
  200.                 }
  201.         }
  202. }
  203. //******************* lcd1602結尾 *****************************
PID算法控制電機轉速.zip
119.15 KB, 下載次數: 394, 下載積分: 黑幣 -5
參與人數 2黑幣 +10 收起 理由
acenerv + 5 共享資料的黑幣獎勵!
我諾你一世不棄 + 5 很給力!
收藏收藏5 分享淘帖 頂 踩
ID:91715 發表于 2015-10-6 14:29 | 只看該作者
哎,新人一枚,沒有黑幣,朋友能否給分享一份,萬分感謝。郵箱:yuhaitao@hit.edu.cn
ID:91871 發表于 2015-10-8 12:22 來自觸屏版 | 只看該作者
來一水,51黑有你更精彩~~
ID:79544 發表于 2015-11-27 19:43 | 只看該作者
放出源碼多好啊,新手都可以學習學習!
ID:1 發表于 2015-11-27 20:23 | 只看該作者
騰飛的龍 發表于 2015-11-27 19:43
放出源碼多好啊,新手都可以學習學習!
剛編輯了一下,直接把源碼弄出來了。
ID:79544 發表于 2015-11-29 10:37 | 只看該作者
admin 發表于 2015-11-27 20:23
剛編輯了一下,直接把源碼弄出來了。
樓主好人,衷心感謝!其實發帖就是為了大家都可以進一步學習交流,很多初進論壇的新人沒有黑幣又想學習,就下載不了會很失望,這樣放出源碼會聚論壇的人氣!
ID:100387 發表于 2015-12-26 15:54 | 只看該作者
  仿真 軟件 我是 8的   都打不開
ID:116948 發表于 2016-4-27 09:46 | 只看該作者
正在找這樣的資料,下載看看,感謝樓主
ID:118433 發表于 2016-5-4 19:56 | 只看該作者
樓主一個唄
ID:115002 發表于 2016-5-4 21:30 | 只看該作者
樓主,大愛無疆!!!
ID:119368 發表于 2016-5-8 21:36 | 只看該作者
太好了。現在適合的很
ID:20382 發表于 2016-5-13 09:39 | 只看該作者
正學習中,資料正好,感謝樓主
ID:121727 發表于 2016-5-18 15:32 | 只看該作者
缺一枚黑幣不能下載,挺急的,有沒有親給發一份啊454999972@qq.com 好人一生平安
ID:10075 發表于 2016-7-11 10:19 | 只看該作者
ID:138549 發表于 2016-9-6 16:48 | 只看該作者
不錯 謝謝樓主
ID:75390 發表于 2016-10-12 15:08 | 只看該作者
好東西啊,想要可以嗎
ID:61135 發表于 2016-10-27 15:50 | 只看該作者
好資料,學習了
ID:21820 發表于 2016-11-26 20:47 | 只看該作者
非常感謝樓主的無私奉獻!!!!
ID:101533 發表于 2017-3-25 21:17 | 只看該作者
學習學習。謝謝!
ID:101533 發表于 2017-3-25 21:18 | 只看該作者
學習學習。非常感謝!
ID:186087 發表于 2017-4-4 18:50 | 只看該作者
很好,很給力!!!!!!!!!!!!!
ID:185687 發表于 2017-4-11 21:15 | 只看該作者
謝謝這么有用的教程
ID:223448 發表于 2017-7-30 21:31 | 只看該作者
很好啊,謝謝!
ID:130345 發表于 2017-8-5 14:09 | 只看該作者
謝謝哈,正好拿來學學算法
ID:140253 發表于 2018-3-12 17:18 | 只看該作者
謝謝,非常好的資料
ID:294375 發表于 2018-4-29 17:46 | 只看該作者
可以告訴下這個仿真圖怎么設置pid參數么?
ID:457154 發表于 2019-1-2 18:35 | 只看該作者
非常給力!
ID:726402 發表于 2020-4-10 17:06 | 只看該作者
哪位大哥能不能告訴我怎么下載
ID:781688 發表于 2020-6-17 09:34 | 只看該作者
很給力
主站蜘蛛池模板: 亚洲午夜18毛片在线看 | 国产第四页 | 亚洲免费小视频 | 欧美日韩一区二区在线 | 国内精品国产成人国产三级 | 久久性生活视频 | 久久免费高清视频 | 日韩视频免费大全中文字幕 | 欧美一级二级三级 | 99精品久久久久久 | 国产精品一区在线播放 | 免费网站黄 | 亚洲另类视频 | www.黄色片 | 精品欧美一区二区三区久久久 | 日韩视频免费大全中文字幕 | 日日干天天干 | 色99999 | 久久精品一区二区三区四区 | 久久这里都是精品 | 一区二区三区在线观看视频 | 黄色成年人视频 | 日韩精品在线一区 | 亚洲欧美日韩国产精品 | 欧美在线一级 | 黄色高潮视频 | 青青草视频 | 欧美精产国品一二三区 | 国产激情在线视频 | 成人三级小说 | 国产高清在线观看 | 日韩精品在线免费观看 | 欧美资源在线 | 色综合久久88 | 亚洲精品视频一区 | 操操操干干干 | 国产伦精品一区二区三区视频黑人 | 欧美专区在线观看 | 国产黄色大片 | av综合网站 | 在线国产91 |
