查看: 3025|回復: 0
CPLD設計PID控制器
ID:682837 發表于 2021-5-27 10:17 | 顯示全部樓層 |閱讀模式
使用Verilog語言,編譯成功
  1. `timescale 1ns/100ps//時間尺度
  2. module pidctrl3 (
  3. isetpoint,  // desire quater period    期望四分之一周期
  4. ifeedback,  // quater period measured  四分之一周期測量
  5. iupdate,
  6. iclk,
  7. irst,
  8. ikp,
  9. iki,
  10. ikd,
  11. isynvalue,
  12. iscale,
  13. ilimit,
  14. ierrlimit,
  15. oreferr,
  16. oresult,    // oresultput flux/strength溢出/強度
  17. ordy
  18. );
  19. input [15:0] isetpoint;
  20. input [15:0] ifeedback;
  21. input iupdate;
  22. input iclk;
  23. input irst;
  24. input [15:0] ikp;
  25. input [15:0] iki;
  26. input [15:0] ikd;
  27. input [15:0] isynvalue;
  28. input [11:0] iscale;
  29. input [15:0] ilimit;
  30. input [15:0] ierrlimit;
  31. output [15:0] oreferr;
  32. output [15:0] oresult;
  33. output ordy;
  34. reg [15:0] mula;
  35. reg [15:0] mulb;
  36. wire [30:0] mulc;
  37. reg [30:0] mulcq;
  38. reg [38:0] accq;
  39. wire [39:0] acc;
  40. reg [27:0] integralq;
  41. reg ordy;
  42. reg [7:0] statq;
  43. reg [15:0] errq;
  44. wire [16:0] tmperr;
  45. wire [16:0] tmperrabs;
  46. reg [15:0] derivq;
  47. wire chklimit;
  48. reg [45:0] delta;
  49. reg [45:0] deltaq;
  50. reg [47:0] deltasumq;
  51. wire [38:0] satdeltasum;
  52. wire [15:0] saterr;
  53. reg [15:0] saterrq;
  54. wire [15:0] effectiveerr;
  55. reg [38:0] satacc;
  56. reg [3:0] selscale;
  57. wire [15:0] fixresult;
  58. wire [15:0] absresult;
  59. reg [15:0] oresult;
  60. wire oversat;
  61. assign tmperr = {isetpoint[15],isetpoint} - {ifeedback[15],ifeedback};
  62. assign tmperrabs = tmperr[16] ? ~tmperr : tmperr;
  63. assign oversat = tmperrabs > {ierrlimit[15],ierrlimit};
  64. assign saterr = tmperr[16] ? (oversat ? ~ierrlimit : tmperr[15:0]) :
  65.                              (oversat ?  ierrlimit : tmperr[15:0]);
  66. // always @(*)
  67. //   case (err[16:15])
  68. //     2'b01 : saterr = 16'h7fff;
  69. //     2'b10 : saterr = 16'h8001;
  70. //     default : saterr = err[15:0];
  71. //   endcase
  72. always @(posedge iclk)
  73.   if (irst) saterrq <= 'h0;
  74.   else saterrq <= iupdate ? saterr : saterrq;
  75. //##################################################################
  76. always @(posedge iclk)
  77.   if (irst) begin
  78.     errq <= 'h0;                        // it records errors between feedbacks and targets
  79.     derivq <= 'h0;                        // it records the changes of errq
  80.   end else begin
  81.     errq <= statq[0] ? saterrq : errq;
  82.     derivq <= statq[0] ? saterrq - errq : derivq;
  83.   end
  84. //##################################################################
  85. always @(*)                                        // To save the number mulipliers, one single multiplier is time-multiplexed
  86.    case (statq[3:1])
  87.      3'b001 : begin mula = errq; mulb = ikp; end                                // perform PID, proportional calculation
  88.      3'b010 : begin mula = integralq[27:12]; mulb = iki; end        // perform PID, integral calculation
  89.      3'b100 : begin mula = derivq; mulb = ikd; end                                // perform PID, derivative calculation
  90.     default : begin mula = 'h0; mulb = 'h0; end
  91.    endcase
  92. assign mulc = {{15{mula[15]}},mula} * {{15{mulb[15]}},mulb};
  93. always @(posedge iclk)
  94.   if (irst) integralq <= 'h0;                // it records the sum of recent errq
  95.   else integralq <= statq[1] ? integralq + {{12{errq[15]}},errq} - {{12{integralq[27]}},integralq[27:12]} : integralq;
  96. // ##################################################
  97. always @(*)
  98.   case (statq[4:2])
  99.     3'b010 : selscale = iscale[7:4];
  100.     3'b100 : selscale = iscale[3:0];
  101.     default : selscale = iscale[11:8];
  102.   endcase
  103. always @(*)
  104.   case (selscale)        // A scaler that enlarge PID gains
  105.     4'h8 : delta = {{15{mulcq[30]}} ,mulcq};
  106.     4'h9 : delta = {{14{mulcq[30]}} ,mulcq, 1'h0};
  107.     4'ha : delta = {{13{mulcq[30]}} ,mulcq, 2'h0};
  108.     4'hb : delta = {{12{mulcq[30]}} ,mulcq, 3'h0};
  109.     4'hc : delta = {{11{mulcq[30]}} ,mulcq, 4'h0};
  110.     4'hd : delta = {{10{mulcq[30]}} ,mulcq, 5'h0};
  111.     4'he : delta = {{9{mulcq[30]}} ,mulcq, 6'h0};
  112.     4'hf : delta = {{8{mulcq[30]}} ,mulcq, 7'h0};
  113.     4'h1 : delta = {{6{mulcq[30]}} ,mulcq, 9'h0};
  114.     4'h2 : delta = {{5{mulcq[30]}} ,mulcq, 10'h0};
  115.     4'h3 : delta = {{4{mulcq[30]}} ,mulcq, 11'h0};
  116.     4'h4 : delta = {{3{mulcq[30]}} ,mulcq, 12'h0};
  117.     4'h5 : delta = {{2{mulcq[30]}} ,mulcq, 13'h0};
  118.     4'h6 : delta = {{1{mulcq[30]}} ,mulcq, 14'h0};
  119.     4'h7 : delta = {mulcq, 15'h0};
  120.    default : delta = {{7{mulcq[30]}} ,mulcq, 8'h0};
  121.   endcase
  122. always @(posedge iclk)
  123.   if (irst) deltaq <= 'h0;
  124.   else deltaq <= delta;
  125. //##################################
  126. always @(posedge iclk)
  127.   if (irst) deltasumq <= 'h0;
  128.   else if (statq[0]) deltasumq <= 'h0;
  129.   else if (|statq[5:3]) deltasumq <= deltasumq + {deltaq[45],deltaq[45],deltaq};
  130.   else deltasumq <= deltasumq;
  131. //##################################
  132. assign satdeltasum = deltasumq[47] ? (&deltasumq[47:38] ? deltasumq[38:0] : 39'h40_0000_0001)
  133.                                    : (|deltasumq[47:38] ? 39'h3f_ffff_ffff : deltasumq[38:0]);
  134. assign acc = {accq[38],accq} + {satdeltasum[38],satdeltasum};
  135. always @(*)
  136.   case (acc[39:38])
  137.     2'b10 : satacc = 39'h40_0000_0001;
  138.     2'b01 : satacc = 39'h3f_ffff_ffff;
  139.     default : satacc  = acc[38:0];
  140.   endcase
  141. always @(posedge iclk)
  142.   if (irst) begin
  143.     ordy <= 'h0;
  144.     accq <= {isynvalue,23'h0};        // It is the last output result
  145.     oresult <= isynvalue;
  146.   end else begin
  147.     ordy <= statq[7];
  148.     accq <= statq[7] ? {fixresult,accq[22:0]} : (statq[6] ? satacc : accq);
  149.     oresult <= statq[7] ? fixresult : oresult;
  150.   end
  151. //##########################################
  152. always @(posedge iclk)
  153.   if (irst) begin
  154.     statq <= 'h0;                        // used to record calculation status, it take 6 cycles to do 1 PID iteration
  155.     mulcq <= 'h0;                        // A flip-flop to stored result from multiplier
  156.   end else begin
  157.     statq <= {statq[6:0],iupdate};
  158.     mulcq <= mulc;
  159.   end
  160. assign absresult = accq[38] ? ~accq[38:23] : accq[38:23];
  161. assign chklimit = absresult > ilimit;
  162. assign fixresult = chklimit ? (accq[38] ? ~ilimit : ilimit) : accq[38:23];
  163. assign oreferr = errq;
  164. endmodule
  165. `ifdef USETESTBENCH
  166. module tb_pidctrl3();
  167. reg clk;
  168. reg rst;
  169. reg [15:0] setpoint;
  170. wire [15:0] feedbackx;
  171. wire [15:0] feedbacky;
  172. reg [4:0] noise;
  173. wire [15:0] resultx;
  174. wire [15:0] resulty;
  175. reg update;
  176. initial begin
  177.   clk = 0;
  178.   forever clk = #5 ~clk;
  179. end
  180. initial begin
  181.   rst = 1;
  182.   setpoint = 0;
  183.   #1000;
  184.   rst = 0;
  185.   setpoint = 16'h100;
  186.   #100000;
  187.   setpoint = 16'h200;
  188.   #100000;
  189.   setpoint = 16'hfe00;
  190.   #100000;
  191.   setpoint = 16'hfd00;
  192.   #100000;
  193.   setpoint = 16'h400;
  194.   #100000;
  195.   setpoint = 16'h7ff;
  196.   #100000;
  197.   setpoint = 16'hf800;
  198.   #100000;
  199.   setpoint = 16'h100;
  200.   #100000;
  201.   setpoint = 16'hf000;
  202.   #100000;
  203.   setpoint = 16'h5000;
  204.   #100000;
  205. end
  206. initial begin
  207.   noise = 0;
  208.   update = 0;
  209.   forever begin
  210.     noise = $random();
  211.     update = 1;
  212.     #10;
  213.     update = 0;
  214.     #100;
  215.   end
  216. end
  217. assign feedbackx = { {5{resultx[15]}},resultx[15:5]} + {{11{noise[4]}},noise};
  218. assign feedbacky = { {5{resulty[15]}},resulty[15:5]} + {{11{noise[4]}},noise};
  219. pidctrl3 pidctrl3 (
  220. .isetpoint(setpoint),  // desire quater period
  221. .ifeedback(feedbackx),  // quater period measured
  222. .iupdate(update),
  223. .iclk(clk),
  224. .irst(rst),
  225. .ikp(16'h4000),
  226. .iki(16'h3000),
  227. .ikd(16'h2000),
  228. .isynvalue(16'h0),
  229. .iscale(12'heee),
  230. .ilimit(16'h2000),
  231. .ierrlimit(16'hffff),
  232. .oreferr(),
  233. .oresult(resultx),    // oresultput flux/strength
  234. .ordy()
  235. );
  236. pidctrl pidctrl (
  237. .isetpoint(setpoint),  // desire quater period
  238. .ifeedback(feedbacky),  // quater period measured
  239. .iupdate(update),
  240. .iclk(clk),
  241. .irst(rst),
  242. .ikp(16'h4000),
  243. .iki(16'h3000),
  244. .ikd(16'h2000),
  245. .isynvalue(16'h0),
  246. .ilimiter(16'h7fff),
  247. .iscaler(4'he),
  248. .oreferr(),
  249. .oresult(resulty),    // oresultput flux/strength
  250. .ordy()
  251. );
  252. endmodule
  253. `endif
TBPID.zip
1.36 MB, 下載次數: 15, 下載積分: 黑幣 -5
主站蜘蛛池模板: 国产在线h| 国产精品一区二区在线 | 日韩精品在线一区 | 亚洲精品一二三区 | 黄色网页免费 | 国产欧美久久久 | 九色视频丨porny丨丝袜 | 在线成人免费视频 | 欧美一级黄| 三级黄网站 | 好吊视频一区二区三区四区 | 成人国产精品一区二区 | 国产成人在线视频 | 激情五月婷婷 | 欧美特黄一级 | 欧美性生活网站 | 欧美日韩国产一区二区 | 日韩一级片 | 国产精品二区一区二区aⅴ污介绍 | 日韩一区二区三区av | 中文字幕不卡在线观看 | 午夜影院福利 | 在线观看日韩视频 | 一区二区在线看 | 日韩欧美自拍 | 我要看一级黄色片 | 天天拍天天射 | 欧美日韩免费 | 久草成人 | 精品视频一区二区三区 | 亚洲欧美视频在线观看 | 五月天婷婷网站| 国产一级免费观看 | 午夜视频在线看 | 不卡免费视频 | 91插插插插插 | 欧美一级在线播放 | 亚洲精品xxx | 一级毛片在线免费观看 | 日韩av网站在线观看 | 亚洲精品www久久久久久广东 |
