查看: 2114|回復: 0
MY-IMX6-EK200 Linux-4.1.15 測試手冊(1)
ID:295355 發表于 2019-4-24 14:02 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 明遠智睿 于 2019-4-24 14:04 編輯
明遠智睿MY-IMX6-EK200 Linux-4.1.15 測試手冊
1  測試環境
開發板型號:MY-IMX6-EK200-6Q-2G-16G
內核版本:Linux-4.1.15
文件系統:L4115-fsl-image-qt5-myimx6a9.tar.bz2
2  網口測試
2.1  ETH0
關閉 ETH1
# ifconfig eth1 down
配置 ETH0
# ifconfig eth0 192.168.137.81
使用 ping 進行測試
# ping 192.168.137.99 -c 2 -w 4
PING 192.168.137.99 (192.168.137.99) 56(84) bytes of data.
64 bytes from 192.168.137.99: icmp_seq=1 ttl=128 time=0.811 ms
64 bytes from 192.168.137.99: icmp_seq=2 ttl=128 time=0.324 ms
--- 192.168.137.99 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 999ms
rtt min/avg/max/mdev = 0.324/0.567/0.811/0.244 ms
2.2  ETH1 測試
關閉 ETH0
# ifconfig eth0 down
配置 ETH0
# ifconfig eth1 192.168.137.82
使用 ping 進行測試
64 bytes from 192.168.137.99: icmp_seq=1 ttl=128 time=1.54 ms
64 bytes from 192.168.137.99: icmp_seq=2 ttl=128 time=4.03 ms
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 1.546/2.792/4.039/1.247 ms
3  USB 測試
插入U盤
usb 1-1.2: new high-speed USB device number 5 using ci_hdrc
usb-storage 1-1.2:1.0: USB Mass Storage device detected
scsi host1: usb-storage 1-1.2:1.0
scsi 1:0:0:0: Direct-Access     TOSHIBA  TransMemory      1.00 PQ: 0 ANSI: 4
sd 1:0:0:0: [sda] 15148608 512-byte logical blocks: (7.75 GB/7.22 GiB)
sd 1:0:0:0: [sda] Write Protect is off
sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
sda: sda4
sd 1:0:0:0: [sda] Attached SCSI removable disk
拔出U盤
usb 1-1.2: USB disconnect, device number 5
4  SD卡測試
插入SD卡
mmcblk2: mmc2:1234 SA02G 1.83 GiB
mmcblk2:
彈出SD卡
mmc2: card 1234 removed
5  標準 GPIO 測試
EIM_A25__GPIO5_IO02 J7:4
EIM_D23__GPIO3_IO23 J1:12
EIM_D28__GPIO3_IO28 J1:8
EIM_D29__GPIO3_IO29 J1:10
EIM_D30__GPIO3_IO30 J21:12
SD1_CLK__GPIO1_IO20 J4:8
SD1_DAT0__GPIO1_IO16 J14:18
SD2_CMD__GPIO1_IO11 J4:13
SD2_CLK__GPIO1_IO10 J4:7
SD2_DAT0__GPIO1_IO15 J4:3
SD2_DAT1__GPIO1_IO14 J4:5
SD2_DAT2__GPIO1_IO13 J4:9
SD2_DAT3__GPIO1_IO12 J4:11
SD3_DAT5__GPIO7_IO00 J21:11
GPIO_19__GPIO4_IO05 J7:3
# OUT_IO_NUMBER=85
# echo ${OUT_IO_NUMBER} > /sys/class/gpio/export
# echo out > /sys/class/gpio/gpio${OUT_IO_NUMBER}/direction
# echo 0 > /sys/class/gpio/gpio${OUT_IO_NUMBER}/value
# echo 1 > /sys/class/gpio/gpio${OUT_IO_NUMBER}/value
6  GPIO-LED 測試
led-heartbeat
說明:led-heartbeat 連接到 D8,系統啟動后可以看到 D8 在有規律的閃爍。
led-timer
說明:led-timer 連接到 D9,系統啟動后可以看到 D9 在有規律的閃爍。
更改 led-timer (D9) 滅的時間
# echo 1000 > /sys/class/leds/led-timer/delay_off
更改 led-timer (D9) 亮的時間
# echo 2000 > /sys/class/leds/led-timer/delay_on
led-default
使 led-default (D7) 滅
echo 0 > /sys/class/leds/default/brightness
使 led-default (D7) 常亮
echo 1 > /sys/class/leds/default/brightness
led-gpio
使 led-gpio (D10) 滅
echo 0 > /sys/class/leds/gpio/brightness
使 led-gpio (D10) 常亮
echo 1 > /sys/class/leds/gpio/brightness
7  GPIO-KEY 測試
運行 evtest 準備測試
# evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0:  WM8962 Beep Generator
/dev/input/event1:  gpio-keys
Select the device event number [0-1]:
選擇 gpio-keys 所對應的序號
Select the device event number [0-1]: 1
Input driver version is 1.0.1
Input device ID: bus 0x19 vendor 0x1 product 0x1 version 0x100
Input device name: "gpio-keys"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 114 (KEY_VOLUMEDOWN)
Event code 115 (KEY_VOLUMEUP)
Event code 116 (KEY_POWER)
Properties:
Testing ... (interrupt to exit)
按動開發板上的按鍵
Event: time 1537921332.815219, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 1
Event: time 1537921332.815219, -------------- SYN_REPORT ------------
Event: time 1537921332.985211, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 0
Event: time 1537921332.985211, -------------- SYN_REPORT ------------
Event: time 1537921335.355204, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 1
Event: time 1537921335.355204, -------------- SYN_REPORT ------------
Event: time 1537921335.535203, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 0
Event: time 1537921335.535203, -------------- SYN_REPORT ------------
Event: time 1537921337.375207, type 1 (EV_KEY), code 116 (KEY_POWER), value 1
Event: time 1537921337.375207, -------------- SYN_REPORT ------------
Event: time 1537921337.535204, type 1 (EV_KEY), code 116 (KEY_POWER), value 0
Event: time 1537921337.535204, -------------- SYN_REPORT ------------
【下章節MY-IMX6-EK200 Linux-4.1.15 測試手冊(2)】
主站蜘蛛池模板: 亚洲成人黄色 | 国内自拍偷拍 | 亚洲天堂男人天堂 | 一区二区三区在线观看视频 | 91成人国产 | 国产一级黄色大片 | 91性高潮久久久久久久久 | 黄色片免费观看 | 欧美色综合天天久久综合精品 | 精品毛片一区二区三区 | 欧美a级黄色片 | 亚洲天堂v | 爱情岛论坛av | 亚洲另类视频 | 在线看成人片 | 美女免费视频网站 | av青青草原| 视频一区二区在线播放 | 欧美日韩福利 | 中文字幕丰满人伦在线 | 中文字幕一区二区三区视频 | 国产日韩欧美一区 | 日韩在线一区二区 | 激情视频一区 | 伊人2222 | 欧美日韩成人在线观看 | 午夜在线观看免费视频 | 国产伦精品一区二区免费 | 日韩一区在线视频 | 91精品国产成人www | 天天躁日日躁狠狠躁av麻豆男男 | 黄色网页免费 | 婷婷av在线| 久久精品久久精品 | 日韩国产在线 | 欧美成人a | 亚洲精品成a人在线观看 | 国产伦精品一区二区三区视频网站 | 亚洲一级在线 | 99热最新 | av日韩精品 |
