查看: 4189|回復: 0
再來個鍵盤掃描程序
ID:1 發表于 2013-5-29 01:36 | 顯示全部樓層 |閱讀模式
#include<iom16v.h>
#include<macros.h>
#define uchar unsigned char
#define uint unsigned int
uchar num;
const uchar  table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void fm();
void delay(uint z);
void init();
void key();
void display();
void fm();
      init();
              key();
            display();
void delay(uint z)//延時函數
      uint x,y;
     for(x=z;x>0;x--)
         for(y=110;y>0;y--);
void init()//初始化函數
      DDRA=0X5C;
     DDRB=0XFF;
     PORTA&=0XFB;
     PORTB=0XFF;
     PORTA|=0X04;
     PORTA&=0XFB;
     PORTA&=0XEF;
    // PORTB=0XFF;
     PORTB=0XFE;
     PORTA|=0X10;
     PORTA&=0XEF;
void key()
      uchar temp;
     DDRD=0XFF;
     PORTD=0XFF;
     PORTD&=0XFE;
     DDRD&=0X0F;
    // PORTD&=0XFE;
     temp=PIND;//讀數據,判斷是否有鍵按下
     temp=temp&0XF0;
     if(temp!=0XF0)
            delay(10);
           PORTD&=0XFE;
           temp=PIND;
           temp=temp&0XF0;
          if(temp!=0XF0)
                   temp=PIND;
                switch(temp)
                      case 0xeE:
                     num=0;
                     break;
                     case 0xdE:
                     num=1;
                     break;
                     case 0xbE:
                     num=2;
                     break;
                     case 0x7E:
                     num=3;
                     break;
          while(temp!=0XF0)
                PORTD&=0XFE;
                   temp=PIND;
                temp=temp&0XF0;
                fm();//蜂鳴器函數,由于是有緣蜂鳴器,所以需要一定的頻率來驅動才能發聲
      DDRD=0XFF;
     PORTD=0XFF;
     PORTD&=0XFD;
     DDRD&=0X0F;
     temp=PIND;
     temp=temp&0XF0;
     if(temp!=0XF0)
            delay(10);
           PORTD&=0XFD;
           temp=PIND;
           temp=temp&0XF0;
          if(temp!=0XF0)
                   temp=PIND;
                switch(temp)
                      case 0xeD:
                     num=4;
                     break;
                     case 0xdD:
                     num=5;
                     break;
                     case 0xbD:
                     num=6;
                     break;
                     case 0x7D:
                     num=7;
                     break;
          while(temp!=0XF0)
                PORTD&=0XFD;
                   temp=PIND;
                temp=temp&0XF0;
                fm();
      DDRD=0XFF;
     PORTD=0XFF;
     PORTD&=0XFB;
     DDRD&=0X0F;
     temp=PIND;
     temp=temp&0XF0;
     if(temp!=0XF0)
            delay(10);
           PORTD&=0XFB;
           temp=PIND;
           temp=temp&0XF0;
          if(temp!=0XF0)
                   temp=PIND;
                switch(temp)
                      case 0xeB:
                     num=8;
                     break;
                     case 0xdB:
                     num=9;
                     break;
                     case 0xbB:
                     num=10;
                     break;
                     case 0x7B:
                     num=11;
                     break;
          while(temp!=0XF0)
                PORTD&=0XFB;
                   temp=PIND;
                temp=temp&0XF0;
                fm();
      DDRD=0XFF;
     PORTD=0XFF;
     PORTD&=0XF7;
     DDRD&=0X0F;
     temp=PIND;
     temp=temp&0XF0;
     if(temp!=0XF0)
            delay(10);
           PORTD&=0XF7;
           temp=PIND;
           temp=temp&0XF0;
          if(temp!=0XF0)
                   temp=PIND;
                switch(temp)
                      case 0xe7:
                     num=12;
                     break;
                     case 0xd7:
                     num=13;
                     break;
                     case 0xb7:
                     num=14;
                     break;
                     case 0x77:
                     num=15;
                     break;
          while(temp!=0XF0)
                PORTD&=0XF7;
                   temp=PIND;
                temp=temp&0XF0;
                fm();
void display()//顯示函數
     PORTA&=0XF7;
    PORTB=table[num];
    PORTA|=0X08;
    PORTA&=0XF7;
void fm()
      PORTA&=0XBF;
     delay(3);
     PORTA|=0X40;
     delay(1);
主站蜘蛛池模板: 欧美一级淫片免费视频黄 | 一区二区三区韩国 | 蜜臀久久99精品久久久久野外 | 毛片a| 欧美区在线 | 国产一级免费在线观看 | 久久蜜桃av | 久久国产精品久久久久久久久久 | 91精品国模一区二区三区 | 国产精品无码久久久久 | 亚洲人成在线观看 | 91av视频在线免费观看 | 午夜在线免费观看视频 | 欧美一级免费黄色片 | 中文字幕精品一区久久久久 | 成人免费一区二区三区视频网站 | 精品视频一区二区 | 91精品久久久久久久久中文字幕 | 九九av | 日韩中文字幕一区 | 国产一区二区三区免费观看在线 | 国产a一区二区 | 99re热精品视频国产免费 | 亚洲国产成人精品女人久久久 | 人人人艹 | www免费视频 | 欧美日韩不卡 | 亚洲一区二区三 | 综合久久亚洲 | 99国产精品久久久久久久 | 91网在线播放 | 久草色播 | 中文字幕一区二区三区在线观看 | 欧美日韩视频在线第一区 | 91视频大全 | 天天操夜夜操 | 国产乱码精品一区二区三区忘忧草 | 久久精品国产久精国产 | 亚洲国产精品99久久久久久久久 | 成人三区 | 韩日一区二区三区 |
