下載附件
2019-4-13 21:04 上傳
- RS BIT P2.0 ;引腳定義,定義液晶顯示端口標號
- RW BIT P2.1
- E BIT P2.2
- L50MS EQU 60H ;工作內(nèi)存定義
- L1MS EQU 61H
- L250MS EQU 62H
- SEC EQU 65H
- MIN EQU 64H
- HOU EQU 63H
- ORG 0000H
- LJMP MAIN
- ORG 000BH ;定時器T0溢出中斷入口地址
- LJMP TT0
- ORG 001BH ; 定時器T1溢出中斷入口地址
- LJMP T1INT
- ORG 1000H
- MAIN: ;液晶初始化
- MOV SP,#70H
- MOV P0,#01H ;清屏
- CALL DISPLAY
- MOV P0,#38H ;8位,2行顯示
- LCALL DISPLAY
- MOV P0,#0FH ;屏顯on,光標on,閃爍on
- LCALL DISPLAY
- MOV P0,#06H ;計數(shù)地址加1,顯示幕on
- LCALL DISPLAY
- LCALL INITIL ;內(nèi)存初始化
- WAIT: LCALL KEY ;鍵盤掃描,是否有鍵按下,否則等待
- LCALL MODD
- LJMP WAIT
- KEY: NOP
- NOP
- LCALL KS
- JNZ K1 ;有按鍵轉(zhuǎn)到K1
- LCALL KAIJI
- LCALL SOP
- XN: LJMP KEY
- K1: LCALL MODD
- LCALL MODD
- LCALL KS
- JNZ K2
- LJMP KEY
- K2: MOV R2,#0FEH ;讀鍵盤
- MOV R4,#00H
- K3: MOV A,R2
- MOV P1,A
- MOV A,P1
- JB ACC.4,L1 ;為1跳轉(zhuǎn),第一行無按鍵
- MOV A,#00H
- LJMP LK
- L1: JB ACC.5,L2
- MOV A,#04H
- LJMP LK
- L2: JB ACC.6,L3
- MOV A,#08H
- LJMP LK
- L3: JB ACC.7,NEXT1
- MOV A,#0CH
- LK: ADD A,R4
- PUSH ACC
- K4: LCALL DELAY1 ;若同時有其他按鍵,則等待
- LCALL KS
- JNZ K4
- MOV R3,#07H
- CLR A
- MOV R0,#30H
- MOV R1,#31H
- MM1: MOV A,@R1
- MOV @R0,A
- INC R0
- INC R1
- DJNZ R3,MM1
- POP ACC
- MOV @R0,A
- RET
- NEXT1: INC R4 ;列掃描
- MOV A,R2
- JNB ACC.3,N2
- LJMP N1
- N2: LJMP KEY
- N1: RL A
- MOV R2,A
- LJMP K3
- KS: MOV A,#0F0H ;判斷P1口
- MOV P1,A
- NOP
- NOP
- MOV A,P1
- CPL A
- ANL A,#0F0H
- RET
- DELAY1:SETB RS0
- DL: MOV R5,#0AH
- DL2: MOV R6,#63
- DL3: NOP
- NOP
- DJNZ R6,DL3
- DJNZ R5,DL2
- CLR RS0
- RET
- INITIL: ;30H-37H初值為零
- MOV R3,#08H
- MOV R0,#30H
- M1: MOV @R0,#00H
- INC R0
- DJNZ R3,M1
- RET
- MODD: ;顯示
- MOV P0,#8EH
- CALL DISPLAY
- MOV A,37H
- MOV DPTR,#TABLE3
- MOVC A,@A+DPTR
- CALL WRITE2
- RET
- KAIJI: MOV A,37H ;開機提示字
- CJNE A,#0FH,DFF
- MOV P0,#80H ;設光標地址
- CALL DISPLAY
- MOV DPTR,#TABLE1;寫數(shù)據(jù)
- CALL WRITE1
- DFF: RET
- ;按鍵值播放歌曲
- SOP: MOV A,37H
- CJNE A,#01H,A11
- LCALL MODD
- MOV 52H,#HIGH TABLE10
- MOV 53H,#LOW TABLE10
- LCALL INITILE2
- LCALL MAIN0
- A11: CJNE A,#02H,A22
- LCALL MODD
- MOV 52H,#HIGH TABLE20
- MOV 53H,#LOW TABLE20
- LCALL INITILE2
- lcall MAIN0
- A22: CJNE A,#03H,A33
- LCALL MODD
- MOV 52H,#HIGH TABLE30
- MOV 53H,#LOW TABLE30
- LCALL INITILE2
- lcall MAIN0
- A33: CJNE A,#04H,A44
- LCALL MODD
- MOV 52H,#HIGH TABLE40
- MOV 53H,#LOW TABLE40
- LCALL INITILE2
- lcall MAIN0
- A44: CJNE A,#05H,A55
- LCALL MODD
- MOV 52H,#HIGH TABLE50
- MOV 53H,#LOW TABLE50
- LCALL INITILE2
- lcall MAIN0
- A55: CJNE A,#06H,A66
- LCALL MODD
- MOV 52H,#HIGH TABLE60
- MOV 53H,#LOW TABLE60
- LCALL INITILE2
- lcall MAIN0
- A66: CJNE A,#07H,A77
- LCALL MODD
- MOV 52H,#HIGH TABLE70
- MOV 53H,#LOW TABLE70
- LCALL INITILE2
- lcall MAIN0
- A77: CJNE A,#08H,A88
- LCALL MODD
- MOV 52H,#HIGH TABLE80
- MOV 53H,#LOW TABLE80
- LCALL INITILE2
- lcall MAIN0
- A88: CJNE A,#09H,A99
- LCALL MODD
- MOV 52H,#HIGH TABLE90
- MOV 53H,#LOW TABLE90
- LCALL INITILE2
- lcall MAIN0
- A99: CJNE A,#0AH,A110
- LCALL MODD
- MOV 52H,#HIGH TABLE100
- MOV 53H,#LOW TABLE100
- LCALL INITILE2
- lcall MAIN0
- A110: CJNE A,#0AH,AAA
- LCALL MODD
- MOV 52H,#HIGH TABLE110
- MOV 53H,#LOW TABLE110
- LCALL INITILE2
- lcall MAIN0
- AAA: RET
- INITILE2:
- MOV L50MS,#20
- MOV L1MS,#00H
- MOV L250MS,#00H
- MOV SEC,#00H
- MOV MIN,#00H
- MOV HOU,#00H
- MOV A,HOU
- MOV B,#10
- DIV AB
- ADD A,#30H ;將BCD嗎轉(zhuǎn)化為ASIIC碼
- MOV P0,#0C8H ;顯示小時十位
- CALL DISPLAY
- CALL WRITE2
- MOV A,B
- ADD A,#30H
- MOV P0,#0C9H ;顯示小時個位
- CALL DISPLAY
- CALL WRITE2
- MOV A,#3AH
- MOV P0,#0DH ;顯示冒號
- CALL DISPLAY
- CALL WRITE2
- MOV A,MIN
- MOV B,#10
- DIV AB
- ADD A,#30H
- MOV P0,#0CBH ;顯示分十位
- CALL DISPLAY
- CALL WRITE2
- MOV A,B
- ADD A,#30H
- MOV P0,#0CCH ;顯示分個位
- CALL DISPLAY
- CALL WRITE2
- MOV A,#3AH
- MOV P0,#0CDH ;顯示冒號
- CALL DISPLAY
- CALL WRITE2
- MOV A,SEC
- MOV B,#10
- DIV AB
- ADD A,#30H
- MOV P0,#0CEH ;顯示秒十位
- CALL DISPLAY
- CALL WRITE2
- MOV A,B
- ADD A,#30H
- MOV P0,#0CFH ;顯示秒個位
- CALL DISPLAY
- CALL WRITE2
- MOV P0,#0C0H ;設光標地址
- CALL DISPLAY
- MOV DPTR,#TABLE2;寫數(shù)據(jù)
- CALL WRITE1
- RET
- DISPLAY: CLR RS ;寫指令
- CLR RW
- CLR E
- LCALL DELAY
- SETB E
- RET
- WRITE1: MOV R1,#00H ;寫數(shù)據(jù)
- A1: MOV A,R1
- MOVC A,@A+DPTR
- CALL WRITE2
- INC R1
- CJNE A,#0FEH,A1 ;未到字符串末尾繼續(xù)
- RET
- WRITE2: MOV P0,A
- SETB RS
- CLR RW
- CLR E
- CALL DELAY
- SETB E
- RET
- DELAY: MOV R4,#05
- D1: MOV R5,#0FFH
- DJNZ R5,$
- DJNZ R4,D1
- RET
- TAB: DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H
- DB 80H,90H,88H,83H,0C6H,0A1H,86H,8EH
- TAB1: DB 89H,86H,0C7H,0C7H,0C0H
- TAB2: DB 0C6H,88H,0C0H
- TABLE1: DB 'WELCOM HERE',0FEH
- TABLE2: DB 'DFF WB ',0FEH
- TABLE4: DB 'CAU',0FEH
- TABLE3: DB 30H,31H,32H,33h
- DB 34H,35H,36H,37H
- DB 38h,39H,41H,42H
- DB 43H,44H,45H,46H
- MAIN0: MOV TMOD,#11H ;播放歌曲程序
- MOV IE,#8aH
- MOV TH1, #3cH
- MOV TL1, #0b0H
- LCALL KS
- JNZ TTM12
- MOV 40H,#00H
- NEXT20: MOV A,40H
- MOV DPH,52H
- MOV DPL,53H
- MOVC A,@A+DPTR
- MOV R2,A
- JZ STOP
- ANL A,#0FH
- MOV R1,A
- MOV A,R2
- SWAP A
- ANL A,#0FH
- JNZ SING
- CLR TR0
- JMP W1
- SING: DEC A
- MOV 22H,A
- RL A
- MOV DPTR,#TABLE00
- MOVC A,@A+DPTR
- MOV TH0,A
- MOV 21H,A
- MOV A,22H
- RL A
- INC A
- MOVC A,@A+DPTR
- MOV TL0,A
- MOV 20H,A
- SETB TR0
- SETB TR1
- W1: LCALL DELAY30
- INC 40H
- LCALL KS ;有鍵跳出
- JNZ STOP
- LJMP NEXT20
- STOP: CLR TR0
- CLR TR1
- LJMP MAIN0
- TTM12: LCALL K2
- MOV A,37H
- CJNE A,#0EH,TTM13
- CLR TR1
- LCALL DELAY1
- TTM120: LCALL KS
- LCALL DELAY1
- JZ TTM120
- LCALL K2
- MOV A,37H
- CJNE A,#0EH,TTM120
- SETB TR1
- LJMP NEXT20
- TTM13: CJNE A,#0CH,TTM14
- MOV A,52H
- INC A
- MOV 52H,A
- MOV A,53H
- INC A
- MOV 53H,A
- MOV A,36H
- INC A
- MOV 37H,A
- LJMP TTM2
- TTM14: CJNE A,#0DH,TTM2
- MOV A,52H
- DEC A
- MOV 52H,A
- MOV A,53H
- DEC A
- MOV 53H,A
- MOV A,36H
- DEC A
- MOV 37H,A
- TTM2: RET
- TT0: PUSH ACC ;定時器中斷子程序0
- PUSH PSW
- MOV TL0,20H
- MOV TH0,21H
- CPL P3.7
- POP PSW
- POP ACC
- RETI
- ;定時器中斷子程序1
- T1INT: MOV TH1, #3CH ;定時器中斷子程序1
- MOV TL1, #0B0H
- DJNZ L50MS,X4
- MOV L50MS,#20
- SECSET: ;每秒種時鐘刷新秒顯示一次
- MOV A,SEC
- MOV B,#10
- DIV AB
- ADD A,#30H
- CALL DISPLAY
- CALL WRITE2
- MOV A,B
- ADD A,#30H
- CALL DISPLAY
- CALL WRITE2
- MOV A,SEC
- INC A
- MOV SEC,A
- XRL A,#60
- X4: JNZ OUT
- MINSET: MOV SEC,#00H ; *每分鐘刷新分顯示一次
- MOV A,MIN
- INC A
- MOV MIN,A
- MOV B,#10
- DIV AB
- ADD A,#30H
- CALL DISPLAY
- CALL WRITE2
- MOV A,B
- ADD A,#30H
- CALL DISPLAY
- CALL WRITE2
- MOV A,MIN
- MOV B,#3
- MUL AB
- MOV B,#100
- DIV AB
- MOV R2,A
- MOV A,#10
- XCH A,B
- DIV AB
- MOV A,MIN
- XRL A,#60
- JNZ OUT
- HOUSET:
- MOV MIN,#00H ;每小時刷新小時顯示一次
- MOV A,HOU
- MOV B,#10
- DIV AB
- CALL DISPLAY
- CALL WRITE2
- MOV A,B
- ADD A,#30H
- CALL DISPLAY
- CALL WRITE2
- MOV A,HOU
- INC A
- MOV HOU,A
- XRL A,#10
- JNZ OUT
- SJMP OVERFLOW
- OUT: RETI;溢出處理
- OVERFLOW:
- MOV L50MS,#20
- MOV L1MS,#00H
- MOV L250MS,#00H
- MOV SEC,#00H
- MOV MIN,#00H
- MOV HOU,#00H
- RETI
- DELAY30:
- MOV R7,#2
- W2: MOV R4,#125
- W3: MOV R3,#248
- DJNZ R3,$
- DJNZ R4,W3
- DJNZ R7,W2
- DJNZ R1,DELAY30
- RET
- TABLE00:
- DW 64580,64684,64777,64820
- DW 64898,64968,65030,64260
- DW 64400,64524,65058,63835,64021
- TABLE10: ;第一首《精忠報國》
- DB 66H,52H,36H,22H,12H,12H,22H,32H,98H,84H,82H,92H,14H,12H,22H
- DB 32H,52H,22H,42H,38H,66H,52H,36H,22H,12H,22H,22H,32H,98H
- DB 24H,22H,32H,54H,52H,32H,92H,12H,92H,82H,98H,66H,52H,36H,22H
- DB 12H,12H,22H,32H,98H,84H,82H,92H,14H,12H,22H,32H,52H,22H,42H,38H
- DB 66H,52H,36H,22H,12H,22H,22H,32H,98H,24H,22H,32H,54H,52H,32H
- DB 22H,12H,92H,82H,98H,14H,24H,34H,44H,64H,0B4H,64H,32H,52H
- DB 62H,0B2H,62H,52H,38H,24H,22H,32H,54H,52H,62H,52H,32H,32H,22H,38H
- DB 64H,0B4H,64H,32H,52H,62H,0B2H,62H,52H,38H,22H,22H,22H,32H,52H,52H
- DB 52H,62H,7FH,74H,04H,58H,6FH
- DB 00
- TABLE20: ;第二首《月亮代表我的心》
- DB 02H,82H
- DB 16H,32H,54H,02H,52H
- DB 0A6H,32H,54H,02H,52H
- DB 64H,74H,0B6H,64H
- DB 52H,5CH,32H,22H
- DB 16H,12H,14H,32H,22H
- DB 16H,12H,14H,22H,32H
- DB 26H,12H,94H,22H,32H
- DB 2CH
- DB 32H,52H
- DB 36H,22H,14H,54H
- DB 0ACH,92H,0A2H
- DB 96H,0A2H,96H,82H
- DB 3CH,54H
- DB 0ACH,92H,0A2H
- DB 2CH,02H,82H
- DB 16H,32H,56H,12H
- DB 0A6H,32H,56H,52H
- DB 66H,72H,0B6H,62H
- DB 62H,52H,58H,32H,22H
- DB 26H,92H,0A4H,12H,22H
- DB 1CH
- DB 00
- TABLE30: ;第三首《看我七十二變》
- DB 0d4H,84H,94H,82H,92H
- DB 12H,22H,82H,92H,02H,92H,82H,0d2H
- DB 82H,92H,14H,84H,02H,0d1H,0d1H
- DB 0c2H,0d2H,84H,0d2H,0d2H,82H,82H
- DB 84H,82H,82H,94H,82H,0d2H
- DB 82H,82H,82H,92H,02H,82H,82H,0d2H
- DB 0c4H,84H,0d4H,92H,0d2H
- DB 82H,0d2H,82H,92H,98H
- DB 04H,94H,88H
- DB 04H,94H,88H
- DB 04H,94H,88H
- DB 04H,94H,88H,04H
- DB 32H,32H,22H,12H,02H,92H,12H,92H
- DB 32H,32H,22H,12H,02H,92H,12H,22H
- DB 54H,44H,34H,12H,22H
- DB 34H,22H,12H,02H,92H,12H,92H
- DB 54H,44H,32H,22H,12H,92H
- DB 00
- TABLE40: ;第四首《同一首歌》
- DB 88h,14h,24h,36H,42H,34H,14H,28H,14H,94H
- DB 1fH,88H,14H,24H,34H,32H,42H,54H,14H
- DB 46H,32H,54H,22H,32H,32H,22H,2CH,38H,54H,74H
- DB 76H,62H,68H,54H,52H,62H,74H,62H,52H,3fH
- DB 46H,42H,54H,64H,54H,42H,32H,28H,0a4H,0a2H
- DB 92H,84H,94H,1fH,0b8H,68H,46H,52H,68H
- DB 74H,72H,72H,74H,62H,52H,3fH,0b8H,68H
- DB 46H,52H,68H,64H,62H,62H,64H,42H,32H,2fH
- DB 58H,14H,24H,36H,42H,34H,12H,12H,26H,22H,24H,22H,12H
- DB 94H,9cH,0a8H,0a6H,92H,84H,64H,54H,22H,22H,46H,42H,44H,32H,22H,5fH
- DB 00
- TABLE50: ;第五首《大!
- DB 82H,92H,12H,14H,12H,14H,92H,82H,12H,14H,22H,14H,92H,12H,22H,24H
- DB 22H,24H,12H,92H,22H,24H,32H,24H,32H,52H,62H,54H,52H,64H,52H,32H
- DB 22H,32H,22H,12H,94H,82H,92H,12H,14H,12H,14H,94H,1cH
- DB 22H,32H,22H,12H,94H,82H,92H,12H,14H,12H,14H,22H,12H,1cH,32H,52H
- DB 62H,64H,62H,64H,0b2H,62H,52H,54H,62H,54H,32H,22H
- DB 12H,14H,12H,14H,24H,3cH,32H,22H,12H,14H,12H,14H,0b2H,62H,52H,54H,62H,54H,32H,52H
- DB 66H,0b2H,0b4H,62H,52H,5cH,32H,52H,62H,64H,62H,64H,0b2H,62H,52H,54H
- DB 62H,54H,32H,22H,12H,14H,12H,14H,54H,3cH,32H,22H,12H,14H,12H,14H,22H,32H
- DB 52H,54H,32H,54H,32H,52H,6fH,04H,02H,92H,32H,24H,12H,1fH
- DB 00
- TABLE60: ;第六首《兩只蝴蝶》
- DB 32H,22H,38H,02H,22H,32H,22H,18H,04H,92H,12H,24H,22H,32H,22H,12H,92H,92H,88H,04H,32H,22H
- DB 38H,02H,22H,32H,22H,18H,04H,92H,12H,24H,22H,32H,22H,21H,92H,12H,28H,04H,32H,22H
- DB 38H,02H,22H,32H,22H,18H,04H,92H,12H,24H,22H,32H,22H,12H,92H,91H,11H,88H
- DB 04H,32H,52H,58H,02H,52H,62H,52H,38H,04H,22H,22H,24H,22H,32H,22H,12H,92H,92H
- DB 12H,12H,1cH,08H,02H,52H,52H,62H,0b2H,72H,72H,62H,32H,22H,22H,22H
- DB 38H,02H,32H,32H,52H,64H,64H,02H,92H,32H,22H,28H,04H,32H,52H,52H,32H,54H,02H,0b4H,72H
- DB 62H,72H,34H,02H,62H,62H,72H,62H,52H,32H,22H,02H,32H,22H,32H
- DB 58H,02H,52H,52H,62H,0b2H,72H,72H,62H,32H,22H,22H,22H
- DB 38H,02H,32H,32H,52H,64H,64H,02H,92H,32H,22H,28H,04H,32H,52H,52H,32H,54H,02H,0B4H,72H
- DB 62H,72H,34H,02H,62H,62H,72H,62H,52H,32H,22H,02H,84H,92H,1cH
- DB 00
- TABLE70: ;第七首<<世上只有媽媽好>>
- DB 66H,52H,34H,54H,0B4H,62H,52H,68H,34H,52H,62H,54H,34H,12H,92H,52H,32H,28H
- DB 26H,32H,54H,52H,62H,34H,24H,18H,56H,32H,22H,12H,92H,12H,8FH
- DB 00
- TABLE80: ;第八首歌《彩云追月》
- DB 86H,92H,12H,22H,32H,52H,68H,63H,52H,34H,62H,0B2H,0B2H,62H,51H,61H,51H,31H,54H
- DB 62H,0B2H,0B2H,62H,52H,32H,52H,52H,51H,61H,51H,31H,34H,52H,62H,74H,32H,52H,52H,32H,21H,31H,21H,11H,24H
- DB 32H,52H,52H,32H,22H,12H,24H,32H,52H,52H,32H,62H,52H,61H,51H,31H,21H,21H,31H,21H,11H,1CH
- DB 21H,31H,22H,23H,31H,21H,18H,02H,0B2H,0BCH,0B4H,72H,61H,51H,72H,61H,71H,61H,51H,61H,71H,61H,6FH
- DB 86H,94H,12H,22H,32H,52H,64H,62H,51H,31H,52H,21H,31H,21H,33H,62H,0B2H,0B2H,62H,51H,61H,51H,31H,54H
- DB 62H,0B2H,72H,61H,51H,51H,61H,51H,31H,54H,61H,0B2H,72H,61H,51H,51H,61H,51H,31H,32H,21H,11H,32H,51H,61H,54H
- DB 02H,32H,24H,32H,52H,52H,32H,22H,31H,21H,11H,24H,32H,52H,62H,0B2H,72H,61H,51H,61H,51H,31H,32H,52H,52H,32H,62H
- DB 51H,31H,31H,21H,11H,91H,23H,31H,21H,1CH,12H,24H,32H,62H,51H,31H,34H,0B4H,72H,61H,51H,63H,71H,64H
- DB 0B2H,54H,72H,62H,71H,61H,54H,61H,51H,31H,21H,34H,73H,61H,54H,22H,32H,52H,22H,36H,52H,62H,61H,31H,32H,21H,11H,21H,11H,91H,81H
- DB 94H,52H,62H,52H,42H,32H,22H,32H,52H,0B4H,74H,64H,52H,61H,51H,41H,5CH,02H,52H,0B4H,74H,63H,51H,61H,51H,31H,21H
- DB 00
- TABLE90: ;第九首<<十年>>
- DB 02H,11H,21H,32H,32H,22H,32H,21H,11H,0A1H,91H,92H,0D1H,91H,83H,91H,0A2H,91H,81H,94H,11H,0A1H,91H,0A1H,98H,03H,81H,0A1H,0A1H,91H,0A1H
- DB 98H,04H,02H,11H,21H,32H,32H,22H,32H,21H,31H,51H,11H,13H,31H,22H,22H,21H,11H,0A1H,11H,13H,11H,11H,0A1H,91H,0A1H
- DB 11H,93H,94H,03H,81H,11H,0A1H,91H,81H,92H,0A1H,91H,94H,08H,03H,81H,32H,21H,11H,22H,31H,21H,21H,83H
- DB 01H,11H,91H,0A1H,11H,61H,51H,11H,34H,01H,31H,21H,31H,48H,23H,31H,32H,42H,38H,03H,11H,21H,52H,31H
- DB 33H,31H,31H,41H,51H,61H,23H,21H,21H,41H,31H,21H,13H,0D1H,0D1H,21H,11H,0A1H,11H,91H,92H,91H,11H,0A1H,91H
- DB 0A1H,31H,31H,22H,0A1H,11H,14H,01H,11H,21H,31H,63H,31H,42H,51H,31H,31H,22H,11H,21H,52H,31H,33H,31H,31H,41H
- DB 51H,61H,23H,21H,21H,41H,31H,21H,13H,0D1H,0D1H,21H,11H,0A1H,11H,91H,92H,91H,11H,0A1H,91H
- DB 0A2H,41H,31H,22H,31H,21H,12H,12H,11H,11H,21H,31H,63H,51H,32H,11H,21H,26H,11H,0A1H,18H
- DB 00
- TABLE110: ;第十首<<你的愛給了誰>>
- DB 02H,91H,0A1H,16H,21H,11H,0A6H,81H,0A1H,9CH,02H,91H,0A1H,16H,21H,31H,24H,21H,0A1H,11H,0A1H
- DB 9CH,02H,11H,21H,36H,32H,24H,21H,0A1H,11H,0A1H,9CH,02H,91H,0A1H,14H,11H,11H,21H,11H,0A4H,04H,04H,02H,0A1H,11H,0A1H,93H,92H
- DB 02H,61H,71H,0B4H,0B2H,0B1H,0B1H,76H,0B1H,71H,6CH,02H,61H,71H,0B6H,0B1H,0B1H,76H,0B1H,71H,6CH,02H,51H,61H,56H,61H,51H,54H,51H,0B1H,71H,0B1H
- DB 72H,62H,68H,02H,61H,51H,66H,62H,58H,0CH,02H,51H,41H,5FH
- DB 66H,62H,54H,0B2H,71H,61H,6CH
- DB 00
- TABLE100:
- DB 17H,02H, 17H,03H, 18H,03H, 19H,02H, 15H,03H
- DB 16H,03H, 17H,03H, 17H,03H, 17H,03H, 18H,03H
- DB 19H,02H, 16H,03H, 17H,03H, 18H,02H, 18H,03H
- DB 17H,03H, 15H,02H, 18H,03H, 17H,03H, 18H,02H
- DB 10H,03H, 15H,03H, 16H,02H, 15H,03H, 16H,03H
- DB 17H,02H, 17H,03H, 18H,03H, 19H,02H, 1AH,03H
- DB 1BH,03H, 1FH,03H, 1FH,03H, 17H,03H, 18H,03H
- DB 19H,02H, 16H,03H, 17H,03H, 18H,03H, 17H,03H
- DB 18H,03H, 1FH,03H, 1FH,02H, 16H,03H, 17H,03H
- DB 18H,03H, 17H,03H, 18H,03H, 20H,03H, 20H,02H
- DB 1FH,03H, 1BH,03H, 1FH,66H, 20H,03H, 21H,03H
- DB 20H,03H, 1FH,03H, 1BH,03H, 1FH,66H, 1FH,03H
- DB 1BH,03H, 19H,03H, 19H,03H, 15H,03H, 1AH,66H
- DB 1AH,03H, 19H,03H, 15H,03H, 15H,03H, 17H,03H
- DB 16H,66H, 17H,04H, 18H,04H, 18H,03H, 19H,03H
- DB 1AH,03H, 19H,03H, 19H,03H, 1FH,03H, 1BH,03H
- DB 1FH,00H, 1AH,03H, 1AH,03H, 1AH,03H, 1BH,03H
- DB 1BH,03H, 1AH,03H, 19H,03H, 19H,02H, 17H,03H
- DB 15H,17H, 15H,03H, 16H,03H, 17H,03H, 18H,03H
- DB 17H,04H, 18H,0EH, 18H,03H, 17H,04H, 18H,0EH
- DB 18H,66H, 17H,03H, 18H,03H, 17H,03H, 18H,03H
- DB 20H,03H, 20H,02H, 1FH,03H, 1BH,03H, 1FH,66H
- DB 20H,03H, 21H,03H, 20H,03H, 1FH,03H, 1BH,03H
- DB 1FH,66H, 1FH,04H, 1BH,0EH, 1BH,03H, 19H,03H
- DB 19H,03H, 15H,03H, 1AH,66H, 1AH,03H, 19H,03H
- DB 15H,03H, 15H,03H, 17H,03H, 16H,66H, 17H,04H
- DB 18H,04H, 18H,03H, 19H,03H, 1FH,03H, 1BH,03H
- DB 1FH,66H, 20H,03H, 21H,03H, 20H,03H, 1FH,03H
- DB 1BH,03H, 1FH,66H, 1FH,03H, 1BH,03H, 19H,03H
- DB 19H,03H, 1FH,03H, 1BH,03H, 1FH,00H, 18H,02H
- DB 18H,03H, 1AH,03H, 19H,0DH, 15H,03H, 15H,02H
- DB 18H,66H, 16H,02H, 17H,02H, 15H,00H, 00H,00H
- END
數(shù)字音樂盒的設計.zip
(77.13 KB, 下載次數(shù): 96)
2019-4-13 21:04 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
