查看: 4206|回復: 8
51單片機交通燈,為什么我的黃燈一直亮著,代碼看不出是哪里的問題,怎么解決。
回帖獎勵 5 黑幣 回復本帖可獲得 5 黑幣獎勵! 每人限 5 次
ID:848926 發表于 2020-12-12 23:34 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include"reg51.h"
//unsigned char code duan[]={0xb7,0x05,0x73,0x67,0xC5,0xE6,0xF6,0x07,0xF7,0xE7};//共陰段碼
unsigned char code duan[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//共陰段碼
sbit DUAL = P3^0;
sbit LED3_yellow = P1^2;
sbit LED2_green = P1^1;
sbit LED1_red = P1^0;
sbit LED6_yellow = P1^5;
sbit LED4_red = P1^3;
sbit LED5_green = P1^4;
sbit WEI1 = P2^0;
sbit WEI2 = P2^1;
sbit WEI3 = P2^2;
sbit WEI4 = P2^3;
unsigned char count = 0;
unsigned char i = 0;
unsigned char key_num = 0;
unsigned char mode = 0;
void delay(unsigned char ms)
        while(ms--);
void display(unsigned char grva,unsigned char kwgrva)
        DUAL = 1;
        P0=0x00;
        P0 = duan[grva/10];
        DUAL = 0;
        WEI1=0;
        WEI2=1;
        WEI3=1;
        WEI4=1;
        delay(10);
        DUAL = 1;
        P0=0x00;
        P0 = duan[grva%10];
        DUAL = 0;
        WEI1=1;
        WEI2=0;
        WEI3=1;
        WEI4=1;
        delay(10);
        DUAL = 1;
        P0=0x00;
        P0 = duan[kwgrva/10];
        DUAL = 0;
        WEI1=1;
        WEI2=1;
        WEI3=0;
        WEI4=1;
        delay(10);
        DUAL = 1;
        P0=0x00;
        P0 = duan[kwgrva%10];
        DUAL = 0;
        WEI1=1;
        WEI2=1;
        WEI3=1;
        WEI4=0;
        delay(10);
        if(kwgrva == 0 || grva == 0)
                mode++;
                count = 0;
                if(mode==4)
                        mode=0;
void partten_1(void)  //南北通行
        TR0 = 0;
        LED1_red = 0;
        LED2_green = 1;
        LED3_yellow = 0;
        LED4_red = 1;
        LED5_green= 0;
        LED6_yellow = 0;
        display(0,0);
void partten_2(void) //東西通行
        TR0 = 0;
        LED1_red = 1;
        LED2_green = 0;
        LED3_yellow = 0;
        LED4_red = 0;
        LED5_green= 1;
        LED6_yellow = 0;
        display(0,0);
void partten_3(void)
        TR0 = 1;
        if(mode == 0)
                LED1_red = 0;
                LED2_green = 1;
                LED3_yellow = 0;
                LED4_red = 1;
                LED5_green= 0;
                LED6_yellow = 0;
                display(25-count,30-count);
        else if(mode == 1)
                LED1_red = 0;
                LED2_green = 0;
                LED3_yellow = 0;
                LED4_red = 1;
                LED5_green= 0;
                LED6_yellow = 0;
                display(5-count,5-count);
        else if(mode == 2)
                LED1_red = 1;
                LED2_green = 0;
                LED3_yellow = 0;
                LED4_red = 0;
                LED5_green= 1;
                LED6_yellow = 0;
                display(30-count,25-count);
        else if(mode == 3)
                LED1_red = 0;
                LED2_green = 0;
                LED3_yellow = 0;
                LED4_red = 1;
                LED5_green= 0;
                LED6_yellow = 0;
        TMOD |= 0x01;
        TH0 = (65536-10000)/256;   //10MS
        TL0 = (65536-10000)%256;
        ET0 = 1;
        EX0 = 1;
        IT0 = 1;
        EA = 1;
        TR0 = 1;
                if(key_num == 0)partten_3();
                 if(key_num == 1)partten_1();
                 if (key_num == 2)partten_2();
void INT_0() interrupt 0
        key_num++;
        if(key_num == 3)
                key_num = 0;
                count = 0;
                mode = 3;
void TIMER0() interrupt 1
        i++;
        if(i == 100) //1ms
                i = 0;
                count++;
仿真圖
仿真圖
ID:160500 發表于 2020-12-13 09:01 | 只看該作者
1、延時程序參數不對;2、黃燈沒有關閉的代碼,肯定一直亮。
ID:799567 發表于 2020-12-13 09:07 | 只看該作者
判斷標志位,到時間后取反黃燈輸出
ID:396971 發表于 2020-12-17 16:45 | 只看該作者
Io電平給反了吧,看電路圖6個LED燈是共陽接法,負極才是接的IO口,你黃燈一直給的低電平,當然會一直亮
ID:862566 發表于 2020-12-18 08:49 | 只看該作者
你的黃燈都是0呀,也沒給1
ID:854384 發表于 2020-12-18 19:30 | 只看該作者
有些是默認0為亮燈,1為熄燈,你可以在主函數里面添加代碼讓燈初始化全滅
ID:303207 發表于 2020-12-20 15:20 | 只看該作者
你的黃燈沒有給關閉的函數定義,沒有低電平
ID:514901 發表于 2020-12-20 15:58 | 只看該作者
在點亮下一個燈時,先把上一個燈滅了
ID:212797 發表于 2020-12-20 16:54 | 只看該作者
測試的三個partten里面,LED3_yellow和LED6_yellow控制引腳始終給的都是低電平信號,肯定是亮的了
主站蜘蛛池模板: 亚洲黄色免费 | 人人草在线视频 | 欧美又大粗又爽又黄大片视频 | 伊人久久综合 | 黄色成人在线 | 91在线精品李宗瑞 | 天天综合网站 | 久久精品小视频 | 在线播放a | 黄色免费网站 | 国产激情一区 | 日韩视频在线观看免费 | 日本一本草久p | 精品一二三区 | 久久久久久久九九九九 | 四虎影视在线 | 欧美一级在线观看 | 亚洲小视频在线观看 | 天天澡天天狠天天天做 | 亚洲激情在线 | 欧美日韩久久久 | 精品国产乱码久久久久 | 黄色激情视频网站 | 中文字幕不卡视频 | 在线不欧美| 一色桃子av | 免费一级黄色 | 精品日韩av | 黄色大片在线 | 999久久久国产精品 亚洲黄色三级 | 亚洲视频国产 | 日本成人精品 | 国产精品天美传媒入口 | 欧美色图一区二区三区 | 中文字幕在线观看一区 | 在线视频a | 欧日韩av | 中文字幕一二区 | 欧美性猛交xxxx黑人交 | 国产成人精品一区二区三区在线观看 | 天天色天天色 |
