查看: 2275|回復: 0
Proteus步進電機控制模塊不能控制,求大神指教
ID:299677 發表于 2021-3-19 10:13 | 顯示全部樓層 |閱讀模式
這個是源碼,源碼和仿真都在附件
#include"reg51.h"
#include"intrins.h"
#include"absacc.h"
#define busy 0x80
#define uchar unsigned char
#define uint unsigned int
sbit RS=P2^6;
sbit RW=P2^5;
sbit E=P2^7;
sbit KEY1=P3^1;
sbit KEY2=P3^0;
sbit KEY3=P3^2;
uchar code tab[8]={0x02,0x06,0x04,0x0c,0x08,0x09,0x01,0x03};
uchar temp;
void delay(uchar k)
uint i,j;
for(i=0;i<k;i++)
  for(j=0;j<60;j++)
void test_1602busy()
   P0=0xFF;
      E=1;
      RS=0;
      RW=1;
   _nop_();
   _nop_();
   while(P0&busy)
     { E=0;
       _nop_();
       E=1;
       _nop_();
       E=0;
    void write_1602Command(uchar co)
     test_1602busy();
     RS=0;
     RW=0;
     E=0;
_nop_();
     P0=co;
_nop_();
     E=1;
_nop_();
     E=0;
    void write_1602Data(uchar Data)
     test_1602busy();
     P0=Data;
     RS=1;
     RW=0;
     E=1;
_nop_();
     E=0;
    void init_1602(void)
     write_1602Command(0x38);
     delay(5);
     write_1602Command(0x01);
     delay(5);
     write_1602Command(0x06);
     delay(5);
     write_1602Command(0x0F);
     delay(5);
    write_1602Command(0x0C);
    void DisplayOneChar(uchar X,uchar Y,uchar DData)
    Y&=1;
    X&=15;
    if(Y)X|=0x40;
    X|=0x80;
    write_1602Command(X);
    write_1602Data(DData);
    void display_1602(uchar *DData,X,Y)
    uchar ListLength=0;
    Y&=0x01;
    X&=0x0F;
    while(X<16)
    DisplayOneChar(X,Y,DData[ListLength]);
    ListLength ++;
    X++;
    uchar i=0;
    uchar delay_v=100;
    uchar flag=0;
    P1=0xFF;
    P2=0xFF;
    init_1602();
    display_1602("STA: SPD:",0,0);
       display_1602("RUN:     ",0,1);
    if(KEY2==1)DisplayOneChar(4,0,'Z');
    else DisplayOneChar(4,0,'F');
    if(KEY3==0)
    i++;
    i=i%3;
    while(KEY3==0)
    switch(i)
    case 0:delay_v=100;DisplayOneChar(13,0,'1');break;
    case 1:delay_v=75;DisplayOneChar(13,0,'2');break;
       case 2:delay_v=50;DisplayOneChar(13,0,'3');break;
    if(KEY1==0)
    display_1602("  RUN:on  ",0,1);
    if(flag==0)
    if(KEY2==1)
    {temp=0;
    P1=tab[temp];
    flag=1;
    delay(delay_v);
    if(KEY2==0)
    temp=6;
    P1=tab[temp];
    flag=1;
    delay(delay_v);
    if(KEY2==1)
    {temp++;
    if(temp==8)
    {temp=0;}
    P1=tab[temp];
    delay(delay_v );
    if(KEY2==0)
    {temp--;
    if(temp==0xFF)
    {temp=7;}
    P1=tab[temp];
    delay(delay_v);
    else display_1602("  RUN:off  ",0,1);
步進電機.rar
89.93 KB, 下載次數: 3
主站蜘蛛池模板: 午夜88| 91精品国产99久久久久久红楼 | 亚洲精选在线观看 | 永久黄网站色视频免费观看w | 国产一区二区影院 | 国产激情综合 | 免费毛片网 | 中文字幕在线观看网址 | 欧美激情在线播放 | 美日韩一区二区三区 | 亚洲av毛片成人精品 | 日韩精品一区二区视频 | 色哟哟av | 日韩黄色影院 | 国产天堂av | 91片黄在线观看 | aaa国产精品 | 国产一级视频在线观看 | 亚洲少妇一区 | 97精品在线视频 | 日本韩国欧美中文字幕 | 欧美在线视频一区二区 | 国产中文在线观看 | 精品亚洲一区二区三区 | 国产无精乱码一区二区三区 | 欧美一级日韩一级 | 51调教丨国产调教视频 | a天堂在线观看 | 成人欧美激情 | 日韩精品综合 | 欧美一级做性受免费大片免费 | 亚洲第一视频网站 | 青草av在线 | 亚洲国产片 | 国产一级黄色大片 | 麻豆影音 | 日本在线视频一区二区 | 午夜黄色大片 | 8x8ⅹ国产精品一区二区 | 国产精品久久久久久久久久久久久 | 99久久婷婷国产综合精品草原 |
