該設(shè)計方案由硬件和軟件兩部分組成。噪聲測量儀的硬件電路系統(tǒng),包括噪聲信號的轉(zhuǎn)換、放大、交直流轉(zhuǎn)換與電壓、頻率轉(zhuǎn)換電路以及單片機系統(tǒng)的硬件電路、LED顯示電路等。軟件部分主要是用單片機語言編程,實現(xiàn)對信號的采集、轉(zhuǎn)換及顯示。對于不同型號的單片機只需要相應(yīng)的改變一下地址即可。
仿真原理圖如下,只是一個簡單的模擬而已(proteus仿真工程文件可到本帖附件中下載)
電路原理圖如下:
- <font face="宋體">#include <reg52.h>
- #include "LCD1602.h"
- unsigned char welcome[]={"welcome!"};
- unsigned char Show0[6]={"Noise:"};
- unsigned char Show1[5]={"dB"};
- /*unsigned int code Countnum[60]={ 11, 13, 15, 17, 19, 22, 24, 27, 31, 34, //T0計數(shù)值
- 39, 44, 49, 55, 62, 69, 78, 87, 98, 110,
- 123, 138, 155, 174, 195, 219, 246, 276, 309, 347,
- 390, 438, 491, 550, 618, 693, 778, 873, 979, 1099,
- 1233,1383,1552,1742,1954,2193,2460,2760,3097,3475,
- 3899,4375,4909,5508,6180,6934,7780,8729,9794,10989,};*/
- unsigned long code Countnum[100]={10,11,12,13,15,17,19,22,25,28,
- 31,35,39,43,48,54,60,67,75,84,
- 94,105,117,131,146,163,182,204,228,255,
- 286,320,359,402,451,506,567,636,713,799,
- 896,1005,1127,1264,1418,1590,1783,2000,2244,2517,
- 2824,3168,3556,3989,4475,5020,5632,6319,7089,7953,
- 8923,10011,11232,12602,14139,15863,17798,19969,22405,25138,
- 28204,31644,35504,39835,44694,50146,56263,63127,70828,79469,
- 89164,100042,112247,125941,141305,158544,177886,199588,223937,251257,
- 281910,316303,354891,398187,446765,501270,562424,631039,708025,794404,};
- unsigned char code dB[100][3]={"031","032","033","034","035","036","037","038","039","040", //T0計數(shù)值對應(yīng) dB
- "041","042","043","044","045","046","047","048","049","050",
- "051","052","053","054","055","056","057","058","059","060",
- "061","062","063","064","065","066","067","068","069","070",
- "071","072","073","074","075","076","077","078","079","080",
- "081","082","083","084","085","086","087","088","089","090",
- "091","092","093","094","095","096","097","098","099","100",
- "101","102","103","104","105","106","107","108","109","110",
- "111","112","113","114","115","116","117","118","119","120",
- "121","122","123","124","125","126","127","128","129","130",
- sbit beep=P2^2;
- sbit key_1=P2^1;
- sbit key_2=P2^0;
- //////////////////////////////////////////////////////全局變量/////////////////////////////////////////////////////
- unsigned long count,c;
- uchar t,z;
- uchar shu,ys;
- //////////////////////////////////////////////////////函數(shù)聲明////////////////////////////////////////////////////
- 延時子程序
- 延時時間(xms*1)ms
- void delayms(uint xms) //延時xms
- uint x,y;
- for(x=xms;x>0;x--)
- for(y=90;y>0;y--);
- void key()
- if (key_1==0)
- delayms(10);
- if (key_1==0)
- while(key_1==0);
- if (shu<99) shu++;
- if (key_2==0)
- delayms(10);
- if (key_2==0)
- while(key_2==0);
- if (shu>0) shu--;
- void alarm()
- ys++;
- if (ys>20)
- ys=0;
- beep=!beep;
- //////////////////////////////////////////主函數(shù)///////////////////////////////////////////////////////////
- void main(void)
- uint m,n;
- uint i;
- delayms(1000);
- TMOD=0X15; //T0外部計數(shù) 工作方式1 T1定時方式1
- EA=0; //開總中斷
- ET1=0; //關(guān)閉T1
- TH0=0;
- TL0=0;
- TH1=(65536-50000)/256; //裝初值
- TL1=(65536-50000)%256; //裝初值
- init_1602();
- WRITE_LCD1602_COM(0x80+3); // 顯示地址
- for(i=0; i<6; i++)
- WRITE_LCD1602_DAT(Show0[i]);
- delayms(5);
- WRITE_LCD1602_COM(0x80+12); // 顯示地址
- for(i=0;i<2;i++)
- WRITE_LCD1602_DAT(Show1[i]);
- delayms(5);
- WRITE_LCD1602_COM(0xc0+3); // 顯示地址
- WRITE_LCD1602_byte("Limit:");
- WRITE_LCD1602_COM(0xc0+12); // 顯示地址
- for(i=0;i<2;i++)
- delayms(5);
- EA=1;
- ET1=1; //開T1
- TR1=1; //T1開始定時
- TR0=1; //T0開始計數(shù)
- while(1)
- key();
- WRITE_LCD1602_COM(0xc0+9);
- WRITE_LCD1602_DAT(0x30+(shu+31)/100%10);
- WRITE_LCD1602_DAT(0x30+(shu+31)/10%10);
- WRITE_LCD1602_DAT(0x30+(shu+31)%10);
- i=0;
- if(count==0)
- continue;
- while(count>Countnum[i])
- i++;
- m=i;
- i=0;
- WRITE_LCD1602_COM(0x80+9);
- for(n=0; n<3; n++)
- WRITE_LCD1602_DAT(dB[m][n]);
- delayms(5);
- if(m>=shu)
- alarm();
- }else
- beep=1;
- void Timer0() interrupt 1
- z++;
- void Timer1() interrupt 3
- TR1=0; //關(guān)閉T1定時
- t++;
- if(t==20) //定時1s時間到
- t=0;
- TR0=0; //T0停止計數(shù)
- c=z*65535+(TH0*256+TL0); // 將計數(shù)值讀取
- TH0=0; //清空計數(shù)值
- TL0=0; //清空計數(shù)值
- count=c;
- c=0;
- z=0;
- TR1=1; //T1開始定時
- </font>
復(fù)制代碼 全部資料51hei下載地址:
10仿真.rar
(98.4 KB, 下載次數(shù): 50)
2021-3-31 14:39 上傳
點擊文件名下載附件
噪聲計原理圖.pdf
(87.99 KB, 下載次數(shù): 38)
2021-3-31 14:39 上傳
點擊文件名下載附件
1程序.rar
(30.97 KB, 下載次數(shù): 31)
2021-3-31 14:39 上傳
點擊文件名下載附件
