查看: 2519|回復: 5
關于STM32單片機ADC模塊的時鐘配置
ID:1095470 發表于 2023-10-9 11:03 | 顯示全部樓層 |閱讀模式
大佬們,幫忙看看:STM32f070的芯片,ADC換了專用的14MHz時鐘源后,它的寄存器在配置時就寫不了了,這是什么原因呀?
程序如下:
#include "main.h"
uint32_t Buffer_adc[3];
uint32_t ISENA;
uint32_t ISENB;
uint32_t DC_ADC;
int main(void)
        GPIO_InitTypeDef GPIO_InitStructure ;
        ADC_InitTypeDef ADC_InitStructure ;
        DMA_InitTypeDef DMA_InitStructure ;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);
        ADC_ClockModeConfig(ADC1,ADC_ClockMode_AsynClk);                                        //ADC專用14MHz時鐘
//        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
        RCC_HSI14Cmd(ENABLE);
        RCC_HSI14ADCRequestCmd(ENABLE);
//        RCC_ADCCLKConfig(RCC_ADCCLK_HSI14);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN ;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_3|GPIO_Pin_5 ;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
        GPIO_Init(GPIOA,&GPIO_InitStructure);
        NVIC_InitStructure.NVIC_IRQChannel = ADC1_IRQn ;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE ;
        NVIC_InitStructure.NVIC_IRQChannelPriority = 0 ;
        NVIC_Init(&NVIC_InitStructure);
        ADC_DeInit(ADC1);
        ADC_StructInit(&ADC_InitStructure);
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE ;
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right ;
        ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None  ;
        ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b ;
        ADC_InitStructure.ADC_ScanDirection = ADC_ScanDirection_Upward ;
        ADC_Init(ADC1,&ADC_InitStructure);
        ADC1->CFGR1 |= (1<<13);
//        ADC_ClockModeConfig(ADC1,ADC_ClockMode_SynClkDiv4);
        ADC_ChannelConfig(ADC1,ADC_Channel_1|ADC_Channel_3|ADC_Channel_5,ADC_SampleTime_55_5Cycles);//選擇ADC通道和采樣時間
        ADC_GetCalibrationFactor(ADC1);//開始校準
//        ADC_ClockModeConfig(ADC1,ADC_ClockMode_AsynClk);                                        //ADC專用14MHz時鐘
        ADC_AutoPowerOffCmd(ADC1,DISABLE);        //失能低功耗自關斷模式
        DMA_DeInit(DMA1_Channel1);
        DMA_InitStructure.DMA_BufferSize = 3 ;
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC ;
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable ;
        DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)Buffer_adc ;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word ;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable ;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular ;
        DMA_InitStructure.DMA_PeripheralBaseAddr = 0x40012440 ;
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word ;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable ;
        DMA_InitStructure.DMA_Priority = DMA_Priority_High ;
        DMA_Init(DMA1_Channel1,&DMA_InitStructure) ;
//        ADC_ITConfig(ADC1,ADC_IT_ADRDY,ENABLE);
//        ADC_ITConfig(ADC1,ADC_IT_EOSMP,ENABLE);
//        ADC_ITConfig(ADC1,ADC_IT_EOC,ENABLE);
        ADC_DMARequestModeConfig(ADC1, ADC_DMAMode_Circular);//循環轉換模式
        ADC_DMACmd(ADC1,ENABLE);//使能ADC的DMA請求
        ADC_Cmd(ADC1,ENABLE);//打開ADC
        while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_ADRDY)); //ADC轉換準備完成
        ADC_StartOfConversion(ADC1);//軟件控制ADC開始轉換
        DMA_Cmd(DMA1_Channel1, ENABLE);//打開DMA通道
                while((DMA_GetFlagStatus(DMA1_FLAG_TC1)) == RESET ); //當產生傳輸完成的事件時
                ISENA = Buffer_adc[0]*3300/0xfff ;
                ISENB = Buffer_adc[1]*3300/0xfff ;
                DC_ADC = Buffer_adc[2]*3300/0xfff ;
                DMA_ClearFlag(DMA1_FLAG_TC1);        //清除DMA通道1傳輸完成標志TCIFx,由硬件設置,軟件清零
時鐘樹
時鐘樹
ADC寄存器
ADC寄存器
RCC寄存器
RCC寄存器
時鐘控制寄存器RCC_CR2
時鐘控制寄存器RCC_CR2
ID:1095470 發表于 2023-10-9 11:38 | 顯示全部樓層
本來用的是HSE外部高速時鐘源,程序可以實現AD功能,換成HSI14時鐘源后就這樣了。
修改的部分程序如下:
屏蔽了 RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);//使能APB2時鐘
          上面這一句。
添加了ADC_ClockModeConfig(ADC1,ADC_ClockMode_AsynClk); //選擇ADC的時鐘來源于HSI14
         RCC_HSI14Cmd(ENABLE);//使能HSI14時鐘源
         RCC_HSI14ADCRequestCmd(ENABLE);//使能來自于ADC的HSI14時鐘源請求
         ADC_AutoPowerOffCmd(ADC1,DISABLE);//失能低功耗自關斷模式
         以上這四句。
ID:1095470 發表于 2023-10-9 11:22 | 顯示全部樓層
大佬們快來幫忙解答一下小白的小小問題
ID:891041 發表于 2023-10-9 14:56 | 顯示全部樓層
txx111 發表于 2023-10-9 11:38
修改的部分程序如下:
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE); 這句不能屏蔽 屏蔽就無法配置寄存器了。
這一句是開ADC時鐘  和設置ADC時鐘源是不是異步無關。想配置ADC寄存器必須要開的。
ID:1095470 發表于 2023-10-9 18:13 | 顯示全部樓層
abob 發表于 2023-10-9 14:56
這一句 ...
原來是這樣,終于解決了,太感謝你了,大佬!
ID:1093723 發表于 2023-10-11 20:34 | 顯示全部樓層
TM32的ADC模塊應用與配置方法詳解 “ADC時鐘配置: ADC模塊需要一個時鐘源來進行工作。通過RCC寄存器配置,選擇適當的時鐘源,并設置ADC的預分頻系數,以確保ADC工作在適當的時鐘頻率下。
主站蜘蛛池模板: 四虎影视最新网址 | a级片在线 | 婷婷在线视频 | 在线免费毛片 | 四虎在线免费观看视频 | av女优天堂 | 国产成人综合网 | 欧美日韩亚洲一区二区三区 | 久久久免费观看 | 亚洲区视频 | 日本午夜视频 | 亚洲精品网站在线观看 | 99视频网站 | 午夜精品在线观看 | 国产精品久久网 | 欧美日韩精品久久 | 青青在线 | 精品视频免费 | 日韩在线一区二区三区 | 久久激情视频 | 国产精品久久久久久久成人午夜 | 91欧美激情一区二区三区成人 | 深夜福利网 | 亚洲黄色录像 | 天天做天天爱 | 日韩精品久久久久久 | 日本黄a三级三级三级 | 中文字幕日本 | 黄视频免费观看 | 一区二区国产精品 | av网站在线看 | 97人人插| 一区二区网站 | 国产成人影视 | 成人免费视屏 | 三级av网站 | 国产精品毛片va一区二区三区 | 三a毛片| 狠狠干天天 | 日本国产欧美 | 亚洲第一伊人 |
