查看: 1886|回復: 5
STM32單片機TIM觸發ADC采樣
ID:1095470 發表于 2023-10-20 11:43 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本人最近在學習使用TIM來觸發ADC采樣,使用的是TIM1_CC4事件來觸發ADC1通道4的采樣,TIM_CH4通道對應的是PA11引腳,ADC1_CH4對應的是PA4引腳,由變量DC_ADC來存儲ADC1通道4的采樣值。使用ST-Link進行仿真,由示波器測量得到TIM1_CH4的輸出波形是50%占空比的方波,符合預期,說明TIM1的輸出信號(即ADC1的觸發信號)是沒有問題的。但是ADC1_DR寄存器存放的值一直是校準完成后校準因子的值,且程序一直運行在主函數的等待EOC轉換完成標志循環內,說明ADC1并沒有被觸發,求高人指點這是哪里出了問題,萬分感謝!
程序如下:
#include "main.h"
uint32_t DC_ADC = 0;
void MyGPIO_Init(void)
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE);  //開啟GPIO時鐘
        GPIO_InitTypeDef GPIO_InitStruct1;
        GPIO_InitTypeDef GPIO_InitStruct2;
        GPIO_InitStruct1.GPIO_Mode = GPIO_Mode_AN;                        //設置PA4為模擬輸入
        GPIO_InitStruct1.GPIO_Pin = GPIO_Pin_4;
        GPIO_InitStruct1.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOA,&GPIO_InitStruct1);
        GPIO_InitStruct2.GPIO_Mode = GPIO_Mode_AF;                        //設置PA11為復用功能
        GPIO_InitStruct2.GPIO_Pin = GPIO_Pin_11;
        GPIO_InitStruct2.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStruct2.GPIO_OType = GPIO_OType_PP;                       //設置輸出為推挽輸出
        GPIO_InitStruct2.GPIO_PuPd = GPIO_PuPd_UP;                       //上拉
        GPIO_Init(GPIOA,&GPIO_InitStruct2);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource11,GPIO_AF_2);    //PC6設置為復用功能AF2(TIM1)
void MyADC1_Init(void)
        /*==================1.開啟ADC1時鐘===============*/
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
        /*==================2.復位ADC1===============*/
        ADC_DeInit(ADC1)
        /*==================3.ADC1初始化===============*/
        ADC_InitTypeDef ADC_InitStruct;
        ADC_InitStruct.ADC_Resolution = ADC_Resolution_12b ;                                           //分辨率12位
        ADC_InitStruct.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC4;                    //外部觸發源為TIM1_CC4
        ADC_InitStruct.ADC_ContinuousConvMode = DISABLE;                                             //不開啟連續轉換模式
        ADC_InitStruct.ADC_ScanDirection = ADC_ScanDirection_Upward;                             //向前掃描
        ADC_InitStruct.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_Rising;        //外部觸發為上升沿
        ADC_InitStruct.ADC_DataAlign = ADC_DataAlign_Right;                                            //數據對齊模式:右對齊
        ADC_Init(ADC1,&ADC_InitStruct);
        ADC_ChannelConfig(ADC1,ADC_Channel_4,ADC_SampleTime_239_5Cycles);               //設置通道4和采樣周期
        /*==================4.校準并使能ADC1===============*/
        ADC_GetCalibrationFactor(ADC1);                                                  //ADC打開校準并等待完成
        ADC_Cmd(ADC1, ENABLE);                                                               //開啟ADC
        while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_ADRDY));                           //等待ADC準備完成
void MyTIM1_Init(uint16_t arr,uint16_t psc)
        /*==============1.打開TIM1時鐘=============*/
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);
        /*==============2.初始化TIM1=============*/
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruct;
        TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV1;
        TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Up;    //向上計數
        TIM_TimeBaseInitStruct.TIM_Period = arr - 1;
        TIM_TimeBaseInitStruct.TIM_Prescaler = psc -1 ;
        TIM_TimeBaseInit(TIM1,&TIM_TimeBaseInitStruct);
        /*==============3.配置TIM1 PWM1模式=============*/
        TIM_OCInitTypeDef TIM_OCInitStruct;
        TIM_OCInitStruct.TIM_OCMode = TIM_OCMode_PWM1;                        //設置輸出模式:PWM1模式
        TIM_OCInitStruct.TIM_OutputState = TIM_OutputState_Enable;                //設置比較輸出使能:
        TIM_OCInitStruct.TIM_OCPolarity = TIM_OCPolarity_High;                        //設置ref為有效電平時 輸出高電平
        TIM_OCInitStruct.TIM_Pulse = arr/2;                                                        //輸出占空比:50%的PWM波
        TIM_OC4Init(TIM1,&TIM_OCInitStruct);                                                //通道4輸出
        TIM_CtrlPWMOutputs(TIM1,ENABLE);                   //PWM輸出使能
        TIM_Cmd(TIM1,ENABLE);                              //使能定時器 輸出上升沿時觸發ADC采樣
int main()
        MyGPIO_Init();
        MyADC1_Init();
        MyTIM1_Init(10000,8);
                while(ADC_GetFlagStatus(ADC1,ADC_FLAG_EOC)==RESET) ;     //等待轉換完成標志
                DC_ADC = ADC_GetConversionValue(ADC1)*3300/0xfff ;            //由ADC采樣轉換值計算出真實電壓
收藏收藏2 分享淘帖 頂 踩
ID:891041 發表于 2023-10-20 22:07 | 只看該作者
EXTTRIG 寄存器沒配置這一位
ID:526543 發表于 2023-10-22 16:51 | 只看該作者
ADC配置問題 ADC校準問題 TIM1配置問題 GPIO配置問題 時鐘配置 錯誤檢查這些好好查查
ID:1095470 發表于 2023-10-23 11:23 | 只看該作者
abob 發表于 2023-10-20 22:07
EXTTRIG 寄存器沒配置這一位
謝謝你的解答!我查了一下你說的EXTTRIG,F103的板子開啟外部觸發確實是需要將CR2寄存器的EXTTRIG置1。但是我使用的是F070的板子,找遍了ADC的寄存器也沒有發現外部觸發的開關控制,CFGR寄存器有個EXTEN可以選擇四種設置:關閉硬件觸發檢測(可由軟件啟動轉換),以及在上升沿、下降沿和上升下降沿進行硬件觸發檢測。類似于F103和F070的這種區別還有ADC通道的掃描,F103的ADC是可以選擇通道掃描開啟和關閉的,而F070的只能選擇掃描方向,默認就是開啟的。
ID:1095470 發表于 2023-10-23 11:43 | 只看該作者
123456ZXC1 發表于 2023-10-22 16:51
都查過了,TIM可以輸出預期的波形,TIM配置應該沒有問題,通過逐步調試感覺應該是ADC觸發的問題,大佬幫忙看看我的觸發配置對不對
ID:1095470 發表于 2023-10-25 09:20 | 只看該作者
已解決。
個人理解:ADC的外部觸發(包括TIM的Update和CCx事件)也是需要操作ADC_CR寄存器的開始轉換命令ADSTART位來實現的,是通過軟件層面進行開始轉換的控制,而不是在硬件層面直接通過內部邏輯電路觸發。
解決方法:
在main函數的 while(ADC_GetFlagStatus(ADC1,ADC_FLAG_EOC)==RESET) ;     //等待轉換完成標志
這一行前面加上ADC_StartOfConversion(ADC1);     //開啟ADC_CR寄存器的ADSTART位,即開始轉換命令
主站蜘蛛池模板: 欧美在线播放视频 | 国产欧美日韩一区二区三区 | 一区二区三区视频在线 | 黄色片一级 | av黄色在线 | 日韩精品视频网站 | 亚洲成人精品在线观看 | 亚洲午夜av | 一极黄色片 | 亚洲精品在线看 | 亚洲色网址 | 久久久久性 | 国产精品一区在线播放 | 88av视频| 成人在线免费视频 | 手机看黄色片 | 欧美精品乱码99久久蜜桃 | 毛片网站在线播放 | 亚洲视频免费看 | 久久久网 | 一级黄视频| 日韩视频一区二区 | 五月天婷婷综合网 | 日韩二三区 | 免费一区二区 | 国产一区精品视频 | 精品成人在线 | 岛国av在线免费观看 | 国产精品一区在线播放 | 神马午夜嘿嘿 | 国产一区二区在线观看视频 | 三上悠亚一区二区 | 欧美日本在线观看 | 中文字幕黄色片 | 日韩欧美黄色 | 免费一级黄色录像 | 亚洲小视频在线观看 | 一区二区三区四区精品 | 日本一级淫片色费放 | 激情久久五月天 | 黄色一级视频免费看 |
