- #include <reg51.h>
- #include <intrins.h>
- #include <stdlib.h>
- #define uchar unsigned char
- #define uint unsigned int
- #include<intrins.h>
- uchar shijian[6]={0x1,0x1,0x0,0x2,0x5,0x8};
- uchar zi[]={"時分秒"};
- uchar j,key;
- char z,z1;
- uchar m,mark=0,bz=0;
- uint k=4000;
- uchar i;
- /* 端口定義*/
- sbit LCD_RS = P2^7; //寄存器選擇輸入
- sbit LCD_RW = P2^6; //液晶讀/寫控制
- sbit LCD_EN = P2^5; //液晶使能控制
- sbit LCD_PSB = P2^4; //串/并方式控制
- void delay_1ms(uint x)
- uint i,j;
- for(j=0;j<x;j++)
- for(i=0;i<110;i++);
- /*寫指令數據到LCD */
- /*RS=L,RW=L,E=高脈沖,D0-D7=指令碼。 */
- void jud()
- {char n=0,m=0,temp;
- if(P1!=0xf0)
- {delay_1ms(15);
- if(P1!=0xf0)
- bz=1;
- if(bz==1)
- uchar scan[4]={0xfe,0xfd,0xfb,0xf7};
- uchar table[4][4]={0x7e,0xbe,0xde,0xee,0x7d,0xbd,0xdd,0xed,0x7b,0xbb,0xdb,0xeb,0x77,0xb7,0xd7,0xe7};
- uchar num[4][4]={0,4,8,12,1,5,9,13,2,6,10,14,3,7,11,15};
- while(n<4)
- {P1=scan[n];temp=P1;m=0;
- while(m<4)
- {if(temp==table[n][m])
- goto next;
- else
- m++;
- n++;
- next: key=num[n][m];
- bz=1;
- if(key==10)
- mark=1;
- P1=0XF0;
- while(P1!=0xf0);
- delay_1ms(15);
- P1=0XF0;
- void write_cmd(uchar cmd)
- LCD_RS = 0;
- LCD_RW = 0;
- LCD_EN = 0;
- P0 = cmd;
- delay_1ms(5);
- LCD_EN = 1;
- delay_1ms(5);
- LCD_EN = 0;
- /*寫顯示數據到LCD */
- /*RS=H,RW=L,E=高脈沖,D0-D7=數據。 */
- void write_dat(uchar dat)
- LCD_RS = 1;
- LCD_RW = 0;
- LCD_EN = 0;
- P0 = dat;
- delay_1ms(5);
- LCD_EN = 1;
- delay_1ms(5);
- LCD_EN = 0;
- /* 設定顯示位置 */
- void lcd_pos(uchar X,uchar Y)
- uchar pos;
- if (X==0)
- {X=0x80;}
- else if (X==1)
- {X=0x90;}
- else if (X==2)
- {X=0x88;}
- else if (X==3)
- {X=0x98;}
- pos = X+Y ;
- write_cmd(pos); //顯示地址
- /* LCD初始化設定 */
- void lcd_init()
- LCD_PSB = 1; //并口方式
- write_cmd(0x30); //基本指令操作
- delay_1ms(5);
- write_cmd(0x0C); //顯示開,關光標
- delay_1ms(5);
- write_cmd(0x01); //清除LCD的顯示內容
- delay_1ms(5);
- /* 主程序 */
- main()
- { uchar x;
- EA=1;
- P1=0XF0;
- TMOD=0X2;
- TH0=0X6;
- TL0=0X6;
- EA=1;ET0=1;TR0=1;
- i=0;
- delay_1ms(10); //延時
- lcd_init();
- lcd_pos(0,1);
- write_dat(zi[0]);
- write_dat(zi[1]);
- lcd_pos(0,3);
- write_dat(zi[2]);
- write_dat(zi[3]);
- lcd_pos(0,5);
- write_dat(zi[4]);
- write_dat(zi[5]);
- while(1)
- z=1;
- z1=0;
- P1=0XF0;
- lcd_pos(0,0);
- i = 0;
- while(i<2)
- write_dat(shijian[i]+0x30);
- i++;
- lcd_pos(0,2);
- while(i<4)
- i++;
- lcd_pos(0,4);
- while(i<6)
- i++;
- jud();
- if(key==10)
- {TR0=0;
- lcd_pos(0,0);delay_1ms(5);
- write_cmd(0x0f);
- delay_1ms(5);
- bz=0;
- while(!bz)
- {jud();}
- while(mark)
- {jud();
- if(key==12)
- {z--;write_cmd(0x10);delay_1ms(5);write_cmd(0x10);delay_1ms(5);bz=0;if((2*(z-1)+(z1-1))==-3){for(x=0;x<6;x++){write_cmd(0x14);delay_1ms(5);}z=3;z1=0;}}
- else if(key==13)
- {z++;write_cmd(0x14);delay_1ms(5);write_cmd(0x14);delay_1ms(5);bz=0;if((2*(z-1)+(z1-1))>=5){for(x=0;x<6;x++){write_cmd(0x10);delay_1ms(5);}z=1;z1=0;}}
- else if(key<=9)
- {z1++;write_dat(key+48);delay_1ms(5);shijian[2*(z-1)+(z1-1)]=key;if((2*(z-1)+(z1-1)<5)&&(z1%2==0)){write_cmd(0x14);delay_1ms(5);}else if(2*(z-1)+(z1-1)>=5){for(x=0;x<5;x++){write_cmd(0x10);delay_1ms(5);}z=1;z1=0;}bz=0;}
- else if(key==11)
- {write_cmd(0x0c);delay_1ms(5);mark=0;}
- while(!bz)
- { jud();}
- bz=0;
- TR0=1;
- count0 (void) interrupt 1
- k--;
- if(k==0x0)
- {++shijian[5];k=4000;
- if (shijian[5]==0x0a)
- {shijian[5]=0x0;
- ++shijian[4];
- if(shijian[4]==0x6)
- {shijian[4]=0x0;
- ++shijian[3];
- if (shijian[3]==0x0a)
- {shijian[3]=0x0;
- ++shijian[2];
- if(shijian[2]==0x6)
- {shijian[2]=0x0;
- ++shijian[1];
- if((shijian[0]==0x0)&&(shijian[1]==0x0a))
- {shijian[1]=0x0;
- ++shijian[0];
- else if((shijian[0]==0x1)&&(shijian[1]==0x2))
- {shijian[1]=0x0;
- shijian[0]=0x0;
