查看: 3889|回復(fù): 0
[BIOS編程]在DOS下如何通過程式實(shí)現(xiàn)對(duì)CPU的超頻...
ID:71922 發(fā)表于 2015-1-11 00:14 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
...(轉(zhuǎn)自英布之劍的博客)
#include<stdio.h>
#include<conio.h>
#include<stdlib.h>
#include<dos.h>
#define DEBUG
typedef unsigned char BYTE;
typedef unsigned int WORD;
typedef unsigned long DWORD;
#define READ_CLOCK_GEN   0x01
#define WRITE_CLOCK_GEN 0x00
WORD SMB_Base=0;
//Get SMBus Base address
WORD getSMBase()
     DWORD pciaddr;
    // bus:0 dev:31 fun:3, register:20h
     pciaddr = (1L << 31) + (0L << 16)+(31L << 11)+(3 << 8)+ (0x20 & 0xfc);
    asm{
         mov eax,pciaddr
         mov dx,0CF8h
         out dx,eax
        mov dx,0CFCh
         in eax, dx        //read SMB Base
        and ax, 0FFE0h
    return _AX;
//Get SMBus Status
BYTE GetSMBusStatus()
     return inportb(SMB_Base+0x00);
//Check SMBus Ready or not
WORD SMBusReady()
      unsigned int m,n,s=0, check,i;
     for(i=0;i<0x80;i++)
        //m=inportb(SMB_Base);     //read status
        m=GetSMBusStatus();
        delay(10);
       outportb(SMB_Base, m);
        delay(1);
       n=m;    //save
       m=m&0x02;                //BIT1:INTR is 1, ready
        if(m!=0)
        goto ret;
       m=n;    //restore
       m=m&0xbf;                //Bit6:INUSE_STS is 0, ready
        if(m==0)
        goto ret;
       m=n;    ///restore
       m=m&0x04;                //Bit2:DEV_ERR not 0, error
        if(m)
        break;
      s=1;
ret:
    return(s);
// Check Byte Done Status
WORD CheckByteDone()
unsigned   int ss=0,st,i;
for(i=0;i<32;i++)
     st=inportb(SMB_Base);
     delay(1);
    st=st&0x80;        //Byte trans done...
     if(st)
       goto back;
    ss=1;
back:
return(ss);
//Enable 32-Byte buffer
void Enable32ByteBuffer()
     outportb(SMB_Base+0x0d, inportb(SMB_Base+0x0d)|0x02);
//Clear SMBus Status
void ClearSMBusStatus()
     outportb(SMB_Base+0x00, 0xFE);
//Set Slave Address
void SetSlaveAddress(BYTE flag)
     outportb(SMB_Base+0x04, 0xD2|flag);
//set command(index)
void SetCommand(BYTE index)
#ifdef DEBUG
     printf("Command:%02x\n", index);
#endif
     outportb(SMB_Base+0x03, index);
//reset index point of 32 Bytes buffer
void ResetIndexPoint()
     inportb(SMB_Base+0x02);
//init block read
void InitBlockReadWrite()
     outportb(SMB_Base+0x02, 0x54);
//write byte count
void SetWriteByteCount(BYTE Count)
     outportb(SMB_Base+0x05, Count);
//set data
void SetData(BYTE data)
     outportb(SMB_Base+0x07, data);
//get byte count
BYTE GetByteCount()
     return inportb(SMB_Base+0x05);
//get data
BYTE GetData()
     return inportb(SMB_Base+0x07);
//read SM Bus
int ReadSMBus(BYTE index)
int sts, j;
int count;
//set slave address
SetSlaveAddress(READ_CLOCK_GEN);
delay(1);
//set command
SetCommand(index);
delay(2);
//reset index point
ResetIndexPoint();
delay(1);
//init block read
InitBlockReadWrite();
delay(1);
sts=SMBusReady();
if(sts!=0)
     return (-1);
count=GetByteCount();
printf("Count=%d\n", count);
for(j=0;j<count;j++)
     printf("%02x ", GetData());
     CheckByteDone();
printf("\n\n");
return 0;
//Write SM Bus
int WriteSMBus(BYTE index, BYTE count)
int sts;
//set slave address
SetSlaveAddress(WRITE_CLOCK_GEN);
delay(1);
//set command
SetCommand(index);
delay(2);
//set write byte count
SetWriteByteCount(count);
delay(1);
//reset index point
ResetIndexPoint();
delay(1);
//init block read
delay(1);
sts=SMBusReady();
if(sts!=0)
     return (-1);
return 0;
// Main Program
int sts=0;
//get SMB Base
SMB_Base =getSMBase();
printf("SMB_Base:%04X\n", SMB_Base);
//enable 32 byte buffer
Enable32ByteBuffer();
delay(3);
sts=SMBusReady();
if(sts!=0)
     printf("SMBus not Ready0!\n");
     exit(0);
//Enable M/N mode (1.read first)
if (ReadSMBus(0x1f)==-1)
printf("SMBus not Ready1!\n");
exit(1);
//---------------- 2. Enable M/N -------------
ResetIndexPoint();
delay(1);
SetData(0x61);      //Bit0 set 1 enable
delay(1);
sts=SMBusReady();
if(sts!=0)
     printf("SMBus not Ready2!\n");
     exit(2);
// write change value
if (WriteSMBus(0x1f, 1)==-1)
printf("SMBus not Ready3!\n");
exit(3);
//---------------- 3. read again --------------
printf("SMBus not Ready4!\n");
exit(4);
//Change clock    (1. read frist)
if (ReadSMBus(0x11)==-1)
printf("SMBus not Ready5!\n");
exit(5);
//---------------- 2. Change it --------------
//reset index point
ResetIndexPoint();
delay(1);
GetData();        //11h
CheckByteDone();
GetData();        //12h
CheckByteDone();
SetData(0xa0);    //13h (80*10+0)/6=133.33 -> (80*10+10)/6=135
delay(1);
sts=SMBusReady();
if(sts!=0)
     printf("SMBus not Ready6!\n");
     exit(1);
//write change value
if (WriteSMBus(0x11, 3)==-1)
printf("SMBus not Ready7!\n\n");
exit(7);
//-------------- 3. Read again ---------------
printf("SMBus not Ready8!\n");
exit(5);
// double check Enable M/N mode (1.read first)
printf("SMBus not Ready9!\n");
exit(1);
ResetIndexPoint();
delay(1);
SetData(0x61);
delay(1);
sts=SMBusReady();
if(sts!=0)
     printf("SMBus not Ready10!\n");
     exit(2);
printf("SMBus not Ready11!\n");
exit(3);
printf("SMBus not Ready12!\n");
exit(4);
相關(guān)帖子
主站蜘蛛池模板: 一级黄色片免费观看 | 国产精品伦子伦免费视频 | 日本欧美视频 | 亚洲国产精品久久久 | 亚洲视频在线观看免费 | 免费观看a级片 | 五月天婷婷网站 | 在线免费看毛片 | 天天天天操 | 秋霞福利视频 | 黄色高清网站 | 97精品在线视频 | 欧美在线观看视频 | 日日日操操操 | 国产精品久久久久久久久久久久午夜片 | 成人午夜激情视频 | 欧美日在线 | 国产精品成人免费精品自在线观看 | 国产精品免费看 | 一区二区三区在线免费 | 日韩精品久久久久久久酒店 | 国产精品成人在线 | 中文字幕日韩高清 | 日韩福利片 | 亚洲精品乱码久久久久久动漫 | 亚洲天堂男人天堂 | 国产超碰在线 | 久久久一区二区三区 | 亚洲精品一区二三区 | 四虎永久在线视频 | 精品福利在线 | 在线看的av| 国产做爰视频免费播放 | 青青综合 | 国产精品日日摸天天碰 | 精品久久久久久久久久 | 国产成人精品一区二区三区在线观看 | 超碰免费在线观看 | 国产日韩综合 | 一级片免费在线观看 | 超碰av在线|
