查看: 6284|回復: 8
全智能密碼鎖程序
ID:76127 發表于 2015-4-5 00:46 | 顯示全部樓層 |閱讀模式
  1. //-----------------------------------------------
  2. //-----------------密碼鎖程序--------------------
  3. //-----------------芯片STC89C52RC--晶振11.0592M--
  4. //***********************************************
  5. #include <reg52.h>
  6. #include "AT24C01.C"
  7. #include "LCD1602.C"
  8. //---------------------------
  9. #define uchar unsigned char
  10. #define uint  unsigned int
  11. static uchar c=0;
  12. //---------------------------
  13. sbit K0=P0^0;//0
  14. sbit K1=P0^1;//1
  15. sbit K2=P0^2;//2
  16. sbit K3=P0^3;//確認密碼
  17. sbit K4=P0^4;//修改密碼
  18. //---------------------------
  19. sbit LE_LED=P3^4;
  20. sbit LED_LDEOKK=P1^3;
  21. sbit LED_LEDOK=P1^4;
  22. sbit LED_OPEN=P1^5;
  23. sbit beep=P3^3;
  24. //---------------------------
  25. uchar tablee [3];  //鍵值存儲器
  26. uchar tablee2[4];  //常規密碼存儲器
  27. //------------------------------
  28. void delayx(uint i)
  29. {
  30. uint w;
  31. for(w=0;w<i;w++);
  32. }
  33. //------------------------------
  34. void beepo()
  35. {
  36. beep=0;
  37. delayx(5000);
  38. beep=1;
  39. }
  40. //------------------------------數據鍵盤掃描并返回鍵值
  41. shuju_jianpan()
  42. {
  43. uchar a=15;
  44. uchar KEY; //
  45. if(!K0) //0
  46. {
  47. delayx(500);
  48. while(K0==0);
  49. beepo();
  50. a=0;
  51. }
  52. //----------------------
  53. if(!K1) //1
  54. {
  55. delayx(500);
  56. while(K1==0);
  57. beepo();
  58. a=1;
  59. }
  60. //----------------------
  61. if(!K2) //2
  62. {
  63. delayx(500);
  64. while(K2==0);
  65. beepo();
  66. a=2;
  67. }
  68. switch (a)
  69. {
  70.   case 0: KEY=0; break;
  71.   case 1: KEY=1; break;
  72.   case 2: KEY=2; break;
  73.   case 15:KEY=15;break;
  74. }
  75. return (KEY);
  76. }
  77. //***********************************************************//
  78. //***********************************************************//
  79. void main()
  80. {
  81. uchar b;
  82. uchar u=0;
  83. uchar e=30;
  84. uchar f=31;
  85. uchar y=32;
  86. uchar nem0=0,nem1=0,nem2=0;
  87. uchar nem3=0,nem4=0,nem5=0;
  88. uchar r=0;
  89. uchar j;
  90. uchar q=0;
  91. uchar h=0;
  92. LE_LED=0;
  93. LCD1602_0(15,0);       //顯示PleasePassword
  94. //---------------------------------------------------------
  95. //-----------------------------------------置入初始出廠密碼
  96. if(q==0)
  97. {
  98. init(); //24c01初始化
  99. W_AT24C01(e,2); //寫入初始密碼“111”數據到AT24C01存儲器中保存
  100. delayx(500);
  101. //------------------
  102. init();
  103. W_AT24C01(f,2);
  104. delayx(500);
  105. //------------------
  106. init();
  107. W_AT24C01(y,2);
  108. delayx(500);
  109. q=1;
  110. }
  111. //--------------------------------------------------------------------
  112. tablee2[3]=0;
  113. //--------------------------------------------------------------------
  114. while(1)
  115. {
  116. b=shuju_jianpan(); //數據鍵盤掃描
  117. if(b!=15)    //如果b不等于15說明有鍵按下
  118. {
  119. tablee2[c++]=b; //密碼存儲器
  120. LCD1602_0(15,c);
  121. if(c==4)c=0;
  122. b=15;
  123. } //通過計算一下將密碼確認復雜化,這樣可以解決密碼重復按下后確認為錯誤碼密碼,
  124. //如當設置密碼為222時,當按下2222或更多22222的密碼后,可以保證這些是錯誤密碼。
  125.    h=((tablee2[2]*5)+(tablee2[1]*3)+tablee2[0]+tablee2[3]);
  126. //========================================
  127. if(!K3)       //確認輸入鍵 P0.3
  128. {
  129. c=0;   //消除密碼累加的現象
  130. delayx(500);
  131. while(K3==0);
  132. beepo();
  133. //----------------開始密碼比較------------
  134. init();//AT24C01初始化
  135. nem0=R_AT24C01(e);
  136. init();
  137. nem1=R_AT24C01(f);
  138. init();
  139. nem2=R_AT24C01(y);
  140. delayx(500);  //延遲一下
  141. //----------------------------------------
  142. if(nem0==tablee2[0]&&nem1==tablee2[1]&&nem2==tablee2[2]&&h==((tablee2[2]*5)+(tablee2[1]*3)+tablee2[0]+0))
  143. {
  144. LED_OPEN=0; //開鎖
  145. beep=0;
  146. delayx(20000);
  147. beep=1; //長嗚一聲音表示確認密碼正確并開鎖
  148. tablee2[0]=0;
  149. tablee2[1]=0;
  150. tablee2[2]=0; //將密碼重置一下
  151. LED_OPEN=1; //關鎖
  152.    delayx(600);
  153. LCD1602_2(); //welcomeBack
  154. delayx(60000);
  155. delayx(60000);
  156. delayx(60000);
  157. LCD1602_1(15);       //顯示PleasePassword
  158. }
  159. else
  160. {
  161. beepo();
  162. delayx(5000);
  163. beepo();
  164. delayx(5000);
  165. beepo();
  166. delayx(5000);    //短響3聲音表示密碼錯誤
  167. r++;
  168. tablee2[3]=0;    //清除一下該存儲器中的錯誤數據避免下次持續報錯
  169. LCD1602_1(0);       //顯示PleasePassword
  170.    }
  171. if(r==4)   //如果錯誤3次密碼則報警2分鐘
  172. {
  173. for(j=0;j<30;j++)
  174. {
  175. beepo();
  176. delayx(5000);
  177.     }
  178. r=0;
  179. }
  180. }
  181. //====================================================================
  182. if(!K4)   //修改密碼鍵 P0.4
  183. {
  184. delayx(500);
  185. while(K4==0);
  186. beepo();
  187. //------------------------
  188.     while(u<3)
  189. {
  190.    b=shuju_jianpan();//數據鍵盤掃描 --先輸入舊密碼確認主人身份
  191.    if(b!=15)   //如果b不等于15說明有鍵按下
  192.    {
  193.    u++;
  194. tablee2[c++]=b;   //常規密碼存儲器
  195. LCD1602_0(15,c);
  196. if(c==4)c=0;
  197. b=15;
  198.    }
  199. }
  200.    u=0;
  201.    h=((tablee2[2]*5)+(tablee2[1]*3)+tablee2[0]+tablee2[3]);
  202. //----------------開始密碼比較----------------------------
  203. init();//AT24C01初始化
  204. nem3=R_AT24C01(e);
  205. init();
  206. nem4=R_AT24C01(f);
  207. init();
  208. nem5=R_AT24C01(y);
  209. delayx(500);  //延遲一下
  210. //---------------------------------------------------------
  211. if(nem0==tablee2[0]&&nem1==tablee2[1]&&nem2==tablee2[2]&&h==((tablee2[2]*5)+(tablee2[1]*3)+tablee2[0]+0))
  212. {
  213. c=0;
  214. beep=0;
  215. delayx(20000);
  216. beep=1;   //長嗚一聲音表示開始修改密碼
  217. LED_LEDOK=0;   //燈亮表示密碼正確
  218. delayx(20000);
  219. LED_LEDOK=1;   //燈亮表示密碼正確
  220. LCD1602_1(0);     //顯示PleasePassword
  221.     //---------------------------------------------------------
  222. while(c<3)   //密碼長度必須為3位
  223. {
  224. b=shuju_jianpan(); //數據鍵盤掃描
  225. if(b!=15)
  226. {
  227. tablee2[c++]=b;
  228. LCD1602_0(15,c);
  229. b=15;
  230. }
  231. }
  232. c=0;
  233.     //---------------------------------------------------------
  234.             while(K3==1);
  235. LCD1602_2(); //welcomeBack
  236. delayx(500);
  237. while(K3==0);
  238. delayx(500);
  239. while(K3==0);
  240. init();             //24c01初始化
  241. W_AT24C01(e,tablee2[0]); //寫入數據到AT24C01存儲器中保存
  242. delayx(500);
  243. //------------------
  244. init();
  245. W_AT24C01(f,tablee2[1]);
  246. delayx(500);
  247. //------------------
  248. init();
  249. W_AT24C01(y,tablee2[2]);
  250. delayx(500);
  251. //------------------
  252. LED_LDEOKK=0; //燈亮表示密碼正確
  253. beep=0;
  254. delayx(10000);
  255. beep=1;             //長嗚一聲音表示確認已輸入數據
  256. LED_LDEOKK=1;
  257. u=0;
  258. delayx(50000);
  259. beep=0;
  260.     delayx(50000);
  261.     beep=1;   //長嗚一聲音表修改密碼OK
  262. LCD1602_0(15,0);       //顯示PleasePassword
  263. }
  264. }  //修改密碼的if語句
  265. } //總的while(1)語句
  266. }
  267. //======================================================
  268. //---IIC AT24C01存儲器讀寫操作程序-----------
  269. #include <reg52.h>
  270. #define uchar unsigned char
  271. sbit SDA=P3^6;
  272. sbit SCL=P3^7;
  273. ///------------------------------------------
  274. void delay()
  275. { ; ; }
  276. ///////////////////////
  277. void start()//起始信號
  278. {
  279. SDA=1;
  280. delay();
  281. SCL=1;
  282. delay();
  283. SDA=0;
  284. delay();
  285. }
  286. ///////////////////////
  287. void stop()//終止信號
  288. {
  289. SDA=0;
  290. delay();
  291. SCL=1;
  292. delay();
  293. SDA=1;
  294. delay();
  295. }
  296. //////////////////////////////////////////////////
  297. //////////////////////////////////////////////////
  298. void respons()//應答信號,等待或者發送一個應答信號
  299. {
  300. uchar i;
  301. SCL=1;
  302. delay();
  303. while((SDA==1)&&(i<250))i++;
  304. SCL=0;
  305. delay();
  306. }
  307. /*************************************************/
  308. void init()//初始化
  309. {
  310. SDA=1;
  311. SCL=1;
  312. }
  313. //////////////////////////////////////////////////
  314. void write_byte(uchar date)//寫一字節
  315. {
  316. uchar i;
  317. SCL=0;
  318. for(i=0;i<8;i++)
  319. {
  320. date=date<<1;
  321. SDA=CY;
  322. SCL=1;
  323. delay();
  324. SCL=0;
  325. delay();
  326. }
  327. }
  328. //------------------------------------------------
  329. uchar read_byte()//讀數據(也就是接收從器件傳來的數據)
  330. {
  331. uchar i,k;
  332. for(i=0;i<8;i++)
  333. {
  334. SCL=1;
  335. delay();
  336. k=(k<<1)|SDA;
  337. SCL=0;
  338. delay();
  339. }
  340. return k;
  341. }
  342. //////////////////////////////////////////////////
  343. //=============AT24C01寫操作=====================//
  344. void W_AT24C01(uchar address,uchar date)//寫數據
  345. {
  346. start();
  347. write_byte(0xa0);  //器件地址
  348. respons();
  349. write_byte(address);//器件內存地址 address
  350.     respons();
  351. write_byte(date);//數據    date
  352. respons();
  353. stop();
  354. }
  355. //////////////////////////////////////////////////
  356. //==============AT24C01讀操作====================//
  357. uchar R_AT24C01(uchar address)
  358. {
  359. uchar date;
  360. start();
  361. write_byte(0xa0);//寫器件地址和寫指令0XA0=10100000B最后一個零表示寫,低電平有效
  362. respons();
  363. write_byte(address);////器件內存地址address
  364. respons();
  365. start();
  366. write_byte(0xa1);//寫器件地址和讀指令0XA1=10100001B,最后一個1表示讀,高電平有效
  367. respons();
  368. date=read_byte();
  369. stop();
  370. return date;
  371. }
  372. //======================================================
  373. //------------------LCD1602顯示程序(模塊)--------------------
  374. #include <reg52.h>
  375. #define uchar unsigned char
  376. ///////////////LCD1602/////////////
  377. sbit RS=P0^5;
  378. sbit RW=P0^6;
  379. sbit YE=P0^7;
  380. /////////////////////////////////////////////////////////////
  381. uchar code table1[] ={" Welcome   Back"};
  382. uchar code table2[] ={" PleasePassword"};
  383. uchar code table3[] ={"****"};
  384. uchar code table4[] ={"                "};
  385. /////////////////////////////////////////////////////////////
  386. void delayy(unsigned int us)
  387. {
  388. while(us--);
  389. }
  390. /////////////////////////////////////////////////////////////
  391. void delay2()
  392. {
  393. RS=0;
  394. RW=0;
  395. YE=0;
  396. delayy(5);
  397. YE=1;
  398. }
  399. //------------------------------------------
  400. void LCD1602_START()
  401. {
  402. //////////////////////////////////////LCD屏初始化
  403. P2=0x01; //清屏
  404. delay2();
  405. P2=0x38; //顯示設定兩行
  406. delay2();
  407. P2=0x0f;  //打開顯示和光標
  408. delay2();
  409. P2=0x06;  //光標右移
  410. delay2();
  411. P2=0x80;  //光標回到第一行的開頭
  412. delay2();
  413. }
  414. /******************************LCD1602液晶顯示****************************/
  415. void LCD1602_0(uchar dd0,uchar jj0)//dd是整數
  416. {
  417.    uchar i,nem;
  418.       LCD1602_START();
  419. /////////////////////////////////////////////////////////////
  420.        for(nem=0;nem<dd0;nem++)//溫度英文字PleasePassword顯示
  421.          {
  422. P2=table2[nem];
  423. RS=1;
  424. RW=0;
  425. YE=0;
  426.    delay2();
  427.      }
  428. ////////////////////////////////////////////////////////////
  429. delay2();
  430.     P2=0xc0; //換行顯示***0xc0指令是光標回到第二行的開頭
  431. for(i=0;i<jj0;i++)
  432.      {
  433. delay2();
  434. P2=table3[i];
  435. RS=1;
  436. RW=0;
  437. YE=0;
  438. }
  439. }
  440. //==========================================================================
  441. void LCD1602_1(uchar dd1)//dd是整數
  442. {
  443.    uchar i,nem;
  444.       LCD1602_START();
  445.        for(nem=0;nem<dd1;nem++)//溫度英文字PleasePassword顯示
  446.          {
  447. P2=table2[nem];
  448. RS=1;
  449. RW=0;
  450. YE=0;
  451.    delay2();
  452.      }
  453. /////////////////////////////////////////////////
  454. delay2();
  455.     P2=0xc0; //換行顯示***0xc0指令是光標回到第二行的開頭
  456. for(i=0;i<16;i++)
  457.      {
  458. delay2();
  459. P2=table4[i];
  460. RS=1;
  461. RW=0;
  462. YE=0;
  463. }
  464. }
  465. //==========================================================================
  466. void LCD1602_2()//dd是整數
  467. {
  468.    uchar i,nem;
  469.       LCD1602_START();
  470.        for(nem=0;nem<15;nem++)//溫度英文字welcomeback顯示
  471.          {
  472. P2=table1[nem];
  473. RS=1;
  474. RW=0;
  475. YE=0;
  476.    delay2();
  477.      }
  478. /////////////////////////////////////////////////
  479. delay2();
  480.     P2=0xc0; //換行顯示***0xc0指令是光標回到第二行的開頭
  481. for(i=0;i<16;i++)
  482.      {
  483. delay2();
  484. P2=table4[i];
  485. RS=1;
  486. RW=0;
  487. YE=0;
  488. }
  489. }
ID:613605 發表于 2019-11-12 14:22 | 顯示全部樓層
高手!!!!!
ID:94791 發表于 2016-3-19 21:46 | 顯示全部樓層
                          高手
ID:92732 發表于 2015-10-17 16:22 | 顯示全部樓層
這個看著就覺額6
ID:44267 發表于 2015-9-5 14:07 | 顯示全部樓層
太強了,太強了,太強了,太強了,
ID:44267 發表于 2015-9-5 14:05 | 顯示全部樓層
太強了,太強了,太強了,太強了,
ID:52756 發表于 2015-7-10 12:21 | 顯示全部樓層
原理圖呢
ID:80284 發表于 2015-6-8 16:19 | 顯示全部樓層
全智能的?挺厲害的呀。
ID:54731 發表于 2015-5-15 10:14 | 顯示全部樓層
下載來試試可以用嗎?謝謝!
主站蜘蛛池模板: 国产寡妇亲子伦一区二区三区四区 | 亚洲精品乱码久久久久久蜜桃91 | 在线观看不卡av | 日韩av在线免费观看 | 死神来了4无删减版在线观看 | 日韩性视频 | 91久久精品日日躁夜夜躁欧美 | 欧美日在线| 国产精品久久久久久久成人午夜 | 国产午夜影院 | 日韩aaaa| 欧美三级在线视频 | 天天操夜夜操狠狠操 | 日日夜夜干 | 国产精品一区在线观看 | 中文字幕日韩一区 | 国产一区亚洲 | 亚洲另类色综合网站 | 69精品人人人人 | 日本一级大片 | 九九久久精品视频 | 国产精品成人免费精品自在线观看 | 免费观看a级片 | 国产精品黄色 | 免费看片黄色 | 成人国产精品久久久网站 | 日韩av手机在线 | 久视频在线 | 福利视频网址导航 | 亚洲精品aaa | 亚洲黄视频 | 成人a视频 | 免费网站观看www在线观 | 久久精品视 | 狠狠干狠狠干 | 久久精品一区二区三区四区五区 | 国产一区二区三区视频 | 日本一级大片 | 在线观看亚洲精品 | 欧美精品第一页 | 日韩黄色免费视频 |
