PADS Logic常用快捷鍵-
F2 ------- add connection 連接線-
M ------- popmenu 彈出右鍵菜單-
Ctrl+A ------- select All 全選-
Ctrl+B ------- sheet 切換到整線sheet可以的視圖狀態(tài)-
Ctrl+C ------- copy 復(fù)制選定對(duì)象(可以是多選或選一范圍): 也可以在按住Ctrl同時(shí)拖動(dòng)選定對(duì)象進(jìn)行該操作-
Ctrl+D ------- redraw 刷新-
Ctrl+E ------- move 移動(dòng)選定對(duì)象(可以是多選或選一范圍): 也可以直接拖動(dòng)-
Ctrl+F ------- X mirror X軸鏡向操作(對(duì)象需處于拖動(dòng)狀態(tài))-
Ctrl+N ------- new 新建設(shè)計(jì)-
Ctrl+O ------- open打開設(shè)計(jì)-
Ctrl+P ------- print 打印-
Ctrl+Q ------- query/modify 查詢選定(單個(gè))對(duì)象的屬性(part, net等): 也可以通過雙擊對(duì)象進(jìn)行 該操作-
Ctrl+R ------- rotate 90 對(duì)單個(gè)對(duì)象進(jìn)行旋轉(zhuǎn)90度操作(對(duì)象需處于拖動(dòng)狀態(tài))-
Ctrl+S ------- save 保存-
Ctrl+V ------- paste 粘貼-
Ctrl+W ------- zoom 切換到放大鏡操作狀態(tài):?jiǎn)螕糇箧I放大視圖,單擊右鍵縮小-
Ctrl+X ------- cut 剪切-
Ctrl+Alt+C ------- display color 展出顏色設(shè)置窗口-
Ctrl+Shift+F ------- Y mirror Y軸鏡向操作(對(duì)象需處于拖動(dòng)狀態(tài))-
Ctrl+Alt+G ------- preference 設(shè)置窗口-
Ctrl+Alt+S ------- 調(diào)出狀態(tài)窗口-
Ctrl+Alt+F ------- 過濾器窗口-
Ctrl+Shift+O ------- 打開pads layout link窗口-
無模式命令:-
s -------- search 查找對(duì)像或坐標(biāo)-
q -------- measure 測(cè)量長(zhǎng)度-
un -------- undo 撤消上一次操作-
re -------- redo 恢復(fù)上一次撤消-
