查看: 6221|回復: 1
光電編碼盤的直流伺服電機PID閉環調速系統proteus仿真
這個設計的仿真原理圖:
基于單片機的光電編碼盤的直流伺服電機PID閉環調速系統proteus仿真的所有資料下載:
基于光電編碼盤的直流伺服電機PID閉環調速系統.zip (122.5 KB, 下載次數: 119)
  1. ;HC11 PWM Motor Control Example
  2. ;Demonstrates ADC and Timer Output Capture functions
  3. PORTA             equ      $1000
  4. PORTC             equ      $1003
  5. PORTB             equ      $1004
  6. DDRC              equ      $1007
  7. TOC1              equ      $1016
  8. TOC2              equ      $1018
  9. TCTL1             equ      $1020
  10. TCTL2             equ      $1021
  11. TMSK1             equ      $1022
  12. TFLG1             equ      $1023
  13. TMSK2             equ      $1024
  14. PACTL             equ      $1026
  15. ADCTL             equ      $1030
  16. ADR1              equ      $1031
  17. ADR2              equ      $1032
  18.                 org $F000
  19. start:          lds  #$FF
  20.                 ldaa #$FF                        ;Port C is output
  21.                 staa DDRC
  22.                 ldaa #$80                        ;Enable OC1 interrupts.
  23.                 staa TMSK1                        ;
  24.                 ldaa #$2                        ;Set the prescaler (divide by 16)
  25.                 staa TMSK2
  26.                 ldaa #$80                        ;Enable PA7 as output
  27.                 staa PACTL
  28.
  29.
  30.                 ldaa #$10                        ;Start first ADC conversion - multi mode enable
  31.                 staa ADCTL
  32.
  33.                 ldd #$0100                        ;Load the capture register
  34.                 std TOC1
  35.
  36.                 cli                                ;Enable interupts
  37. loop                wai
  38.                 bra loop
  39. ;OC1 interrupt service
  40. oc1f                ldaa #$10                         ;Start another ADC conversion
  41.                 staa ADCTL
  42.                 ldaa ADR1                        ;Read the pot position from ADC channel 1
  43.                 staa PORTB                        ;Display it
  44.
  45.                 suba #127                        ;0x7F is zero reference.
  46.
  47.                 bne oc1f_ne                            ;Jump if values not same
  48. ;Set Both outputs low. Motor is stationary
  49.                 clrb
  50.                 stab PORTA                        ;Both OC1 and OC2 outputs low
  51.                 stab TCTL1                        ;TOC2 mode is disabled
  52.                 bra done
  53.
  54. ;Non-zero drive - decide if +ve or -ve:
  55.
  56. oc1f_ne                bcs oc1f_cs
  57. ;Positive result - motor spins clockwise:
  58.                 ldab #$40                        ;Port A drives this value:
  59.                 stab PORTA
  60.                 clrb                                ;Release TOC2 latch - Port A acquires value, above.
  61.                 stab TCTL1
  62.                 ldab #$40                         ;TOC 2 output toggles on OC2 event; motor drive stops.
  63.                 stab TCTL1
  64.                 bra done
  65. ;Negative result - motor spins anti-clockwise:
  66. oc1f_cs                ldab #$80                        ;Port A drives this value:
  67.                 stab PORTA
  68.                 clrb                            ;Release TOC2 latch - Port A acquires value, above.
  69.                 stab TCTL1
  70.                 ldab #$40                         ;TOC 2 output toggles on OC2 event; motor drive stops.
  71.                 stab TCTL1
  72.                 nega                                ;Invert result -> 0xFF -> 0x01 etc.
  73. ;Now set up TOC2 to trigger at a time forward of TOC1. This means that the motor will
  74. ;be powered for the number of ticks in ACCA * 256.
  75.
  76. done:                tab                             ;TOC 2 is set to trigger after this no of cycles.
  77.                 clra
  78.                 rolb
  79.                 rola
  80.                 rolb
  81.                 rola
  82.                 rolb
  83.                 rola
  84.                 rolb
  85.                 rola
  86.                 rolb
  87.                 rola
  88.                 addd TOC1
  89.                 std TOC2
  90.
  91.                 ldd #$1000
  92.                 addd TOC1
  93.                 std TOC1
  94.
  95.                 ldaa #$80                        ;Clear the TOC 1 interrupt
  96.                 staa TFLG1
  97.                 rti
  98. ;Interrupt Vectors
  99.                 org $FFE8
  100.                 dw oc1f
  101.                 org $FFFE
  102.                 dw start
收藏收藏3 分享淘帖 頂1 踩
ID:194876 發表于 2017-5-16 22:00 | 只看該作者
看看感覺還行
主站蜘蛛池模板: 加勒比一区二区 | 成人av播放| 欧美精品福利 | 国产成人综合在线 | 免费观看黄色片 | 日韩成人精品视频 | 欧美精品二区三区四区免费看视频 | 日韩专区在线 | 超碰av在线 | 久久久久久九九九九 | 在线看黄色片 | av手机在线免费观看 | 丁香婷婷网| 国产欧美在线播放 | 午夜在线视频观看日韩17c | 亚洲 欧美 激情 另类 校园 | 日本高清网站 | 亚洲视频中文字幕 | 亚洲黄色精品 | 国产三级精品视频 | 少妇特黄a一区二区三区 | 久久精品视频免费 | 日日干夜夜骑 | 草逼视频免费看 | 久久av影院 | 欧美精品一区在线 | 久久天天操 | 国产成人精品一区二区三区四区 | 五月婷婷激情综合 | 中文在线免费观看 | 九月丁香婷婷 | 一区二区三区影院 | 欧美视频久久 | 久久免费视频观看 | 久久精品视频网站 | 国产黄色精品 | 看国产毛片 | 婷婷午夜天 | 在线观看成年人视频 | 97精品在线| 日韩在线不卡视频 |
