查看: 5002|回復: 0
智能小車源程序及制作資料
全部資料下載:
單片機智能小車.rar (411.11 KB, 下載次數: 8)
部分代碼預覽:
  1. #include "s480.h"
  2. #include "bsrsd.h"
  3. #define        P_IOA_Data                         (volatile unsigned int *)0x7000
  4. #define P_IOA_Dir                         (volatile unsigned int *)0x7002
  5. #define P_IOA_Attrib                 (volatile unsigned int *)0x7003
  6. #define P_IOB_Data                        (volatile unsigned int *)0x7005
  7. #define P_IOB_Dir                        (volatile unsigned int *)0x7007
  8. #define P_IOB_Attrib                (volatile unsigned int *)0x7008
  9. #define P_TimerA_Data                (volatile unsigned int *)0x700A
  10. #define P_TimerA_Ctrl                (volatile unsigned int *)0x700B
  11. #define P_TimerB_Data                (volatile unsigned int *)0x700C
  12. #define P_TimerB_Ctrl                (volatile unsigned int *)0x700D
  13. #define P_Watchdog_Clear        (volatile unsigned int *)0x7012
  14. #define P_INT_Mask                        (volatile unsigned int *)0x702D
  15. #define P_INT_Clear                        (volatile unsigned int *)0x7011
  16. #define NAME_ID                         0x100
  17. #define COMMAND_GO_ID                 0x101
  18. #define COMMAND_BACK_ID         0x102
  19. #define COMMAND_LEFT_ID         0x103
  20. #define COMMAND_RIGHT_ID         0x104
  21. #define S_NAME                                0                                                        //給我取個名字吧
  22. #define S_ACT1                                1                                                        //前進
  23. #define S_ACT2                                2                                                        //倒車,請注意
  24. #define S_ACT3                                3                                                        //左拐
  25. #define S_ACT4                                4                                                        //右拐
  26. #define S_RDY                                5                                                        //Yeah
  27. #define S_AGAIN                                6                                                        //請再說一遍
  28. #define S_NOVOICE                        7                                                        //沒有聽到任何聲音
  29. #define S_CMDDIFF                        8                                                        //說什么暗語呀
  30. #define S_NOISY                                8                                                        //說什么暗語呀
  31. #define S_START                                9                                                        //準備就緒,開始辨識
  32. #define S_GJG                                10                                                        //拐就拐
  33. #define S_DCZY                                11                                                        //倒車,請注意
  34. extern  unsigned int BSR_SDModel[100];                                        //外部變量BSR_SDModel[100],辨識器自帶
  35. extern void F_FlashWrite1Word(unsigned int addr,unsigned int Value);
  36. extern void F_FlashErase(unsigned int sector);
  37. unsigned int uiTimeset = 3;        //運行時間定時,調整該參數控制運行時間
  38. unsigned int uiTimecont;        //運行時間計時
  39. //=============================================================
  40. // 語法格式:        void Delay();
  41. // 實現功能:        延時
  42. // 參數:                無
  43. // 返回值:                無
  44. //=============================================================
  45. void Delay()
  46. {
  47.         unsigned int i;
  48.         for(i=0;i<0x3Fff;i++)
  49.         {
  50.                 *P_Watchdog_Clear=0x0001;
  51.         }
  52. }
  53. //=============================================================
  54. // 語法格式:        void PlaySnd(unsigned SndIndex,unsigned DAC_Channel);
  55. // 實現功能:        語音播放函數
  56. // 參數:                SndIndex-播放語音資源索引號
  57. //                                DAC_Channel-播放聲道選擇
  58. // 返回值:                無
  59. //=============================================================
  60. void PlaySnd(unsigned SndIndex,unsigned DAC_Channel)
  61. {
  62.         BSR_StopRecognizer();        //停止識別器
  63.         SACM_S480_Initial(1);        //初始化為自動播放
  64.         SACM_S480_Play(SndIndex, DAC_Channel, 3);                        //開始播放一段語音
  65.         while((SACM_S480_Status()&0x0001)!= 0)                                //是否播放完畢?
  66.         {
  67.                 SACM_S480_ServiceLoop();                                                //解碼并填充隊列
  68.                 *P_Watchdog_Clear=0x0001;                                                //清看門狗
  69.         }
  70.         SACM_S480_Stop();        //停止播放
  71.         BSR_InitRecognizer(BSR_MIC);                                                //初始化識別器
  72. }
  73. //=============================================================
  74. // 語法格式:        int TrainWord(int WordID,int SndID);
  75. // 實現功能:        訓練一條指令
  76. // 參數:                WordID-指令編碼
  77. //                                SndID-指令提示音索引號
  78. // 返回值:                無
  79. //=============================================================
  80. int TrainWord(unsigned int WordID,unsigned int SndID)
  81. {
  82.         int Result;
  83.         PlaySnd(SndID,3);        //引導訓練,播放指令對應動作
  84.         while(1)
  85.         {
  86.                 Result = BSR_Train(WordID,BSR_TRAIN_TWICE);                //訓練兩次,獲得訓練結果
  87.
  88.                 if(Result==0)break;
  89.                 switch(Result)
  90.                 {
  91.                 case -1:        //沒有檢測出聲音
  92.                         PlaySnd(S_NOVOICE,3);
  93.                         return -1;
  94.                 case -2:        //需要訓練第二次
  95.                         PlaySnd(S_AGAIN,3);
  96.                         break;
  97.                 case -3:        //環境太吵
  98.                         PlaySnd(S_NOISY,3);
  99.                         return -3;
  100.                 case -4:        //數據庫滿
  101.                          return -4;
  102.                 case -5:        //檢測出聲音不同
  103.                         PlaySnd(S_CMDDIFF,3);
  104.                         return -5;
  105.                 case -6:        //序號錯誤
  106.                         return -6;
  107.                 default:
  108.                         break;
  109.                 }
  110.         }
  111.         return 0;
  112. }
  113. //=============================================================
  114. // 語法格式:        void TrainSD();
  115. // 實現功能:        訓練函數
  116. // 參數:                無
  117. // 返回值:                無
  118. //=============================================================
  119. void TrainSD()
  120. {
  121.         while(TrainWord(NAME_ID,S_NAME) != 0) ;                          //訓練名稱
  122.         while(TrainWord(COMMAND_GO_ID,S_ACT1) != 0) ;                  //訓練第1個動作
  123.         while(TrainWord(COMMAND_BACK_ID,S_ACT2) != 0) ;          //訓練第2個動作
  124.         while(TrainWord(COMMAND_LEFT_ID,S_ACT3) != 0) ;          //訓練第3個動作
  125.         while(TrainWord(COMMAND_RIGHT_ID,S_ACT4) != 0) ;        //訓練第4個動作
  126. }
  127. //=============================================================
  128. // 語法格式:        void StoreSD();
  129. // 實現功能:        存儲語音模型函數
  130. // 參數:                無
  131. // 返回值:                無
  132. //=============================================================
  133. void StoreSD()
  134. {        unsigned int ulAddr,i,commandID,g_Ret;
  135.         F_FlashWrite1Word(0xef00,0xaaaa);
  136.          F_FlashErase(0xe000);
  137.            F_FlashErase(0xe100);
  138.            F_FlashErase(0xe200);
  139.            ulAddr=0xe000;//********
  140.         for(commandID=0x100;commandID<0x105;commandID++)
  141.         {
  142.                 g_Ret=BSR_ExportSDWord(commandID);
  143.                 while(g_Ret!=0)        //模型導出成功?
  144.                 g_Ret=BSR_ExportSDWord(commandID);
  145.                 for(i=0;i<100;i++)        //保存語音模型SD1(0xe000---0xe063)
  146.                 {
  147.                     F_FlashWrite1Word(ulAddr,BSR_SDModel[i]);
  148.                         ulAddr+=1;
  149.                 }
  150.         }
  151. }
  152. //=============================================================
  153. // 語法格式:        void StoreSD();
  154. // 實現功能:        裝載語音模型函數
  155. // 參數:                無
  156. // 返回值:                無
  157. //=============================================================
  158. void LoadSD()
  159. {        unsigned int *p,k,jk,Ret,g_Ret;
  160.         p=(int *)0xe000;
  161.         for(jk=0;jk<5;jk++)
  162.         {
  163.                 for(k=0;k<100;k++)
  164.                 {
  165.                         Ret=*p;
  166.                         BSR_SDModel[k]=Ret;                                        //裝載語音模型
  167.                         p+=1;
  168.                 }
  169.                 g_Ret=BSR_ImportSDWord();
  170.                 while(g_Ret!=0)                                                        //模型裝載成功?
  171.                 g_Ret=BSR_ImportSDWord();
  172.         }
  173. }
  174. //=============================================================
  175. // 語法格式:        void GoAhead();
  176. // 實現功能:        前進子函數
  177. // 參數:                無
  178. // 返回值:                無
  179. //=============================================================
  180. void GoAhead()                                                     //前進
  181. {
  182.         PlaySnd(S_ACT1,3);                                                        //提示
  183.         *P_IOB_Data=0x1400;                                                        //前進
  184.         *P_INT_Mask |= 0x0004;                                                //以下為中斷定時操作
  185.         __asm("int fiq,irq");
  186.         uiTimecont = 0;
  187. }
  188. //=============================================================
  189. // 語法格式:        void BackUp();
  190. // 實現功能:        后退子函數
  191. // 參數:                無
  192. // 返回值:                無
  193. //=============================================================
  194. void BackUp()                                                //倒退
  195. {
  196.         PlaySnd(S_DCZY,3);                                                        //提示
  197.         *P_IOB_Data=0x2800;                                                        //倒退
  198.         *P_INT_Mask |= 0x0004;                                                //以下為中斷定時操作
  199.         __asm("int fiq,irq");
  200.         uiTimecont = 0;
  201. }
  202. //=============================================================
  203. // 語法格式:        void TurnLeft();
  204. // 實現功能:        左轉子函數
  205. // 參數:                無
  206. // 返回值:                無
  207. //=============================================================
  208. void TurnRight()                                           //右轉
  209. {
  210.         PlaySnd(S_GJG,3);
  211.         *P_IOB_Data=0x1800;                                                        //右轉
  212.         Delay();        //延時
  213.         *P_IOB_Data=0x2400;                                                        //左轉
  214.         *P_INT_Mask |= 0x0004;                                                //以下為中斷定時操作
  215.         __asm("int fiq,irq");
  216.         uiTimecont = 0;
  217. }
  218. //=============================================================
  219. // 語法格式:        void TurnRight();
  220. // 實現功能:        右轉子函數
  221. // 參數:                無
  222. // 返回值:                無
  223. //=============================================================
  224. void TurnLeft()                                               //左轉
  225. {
  226.         PlaySnd(S_GJG,3);                                                        //語音提示
  227.     *P_IOB_Data=0x2400;                                                        //左轉
  228.         Delay();        //延時
  229.         *P_IOB_Data=0x1800;                                                        //右轉
  230.         *P_INT_Mask |= 0x0004;                                                //以下為中斷定時操作
  231.         __asm("int fiq,irq");
  232.         uiTimecont = 0;
  233. }
  234. //=============================================================
  235. // 語法格式:        void Stop();
  236. // 實現功能:        停車子函數
  237. // 參數:                無
  238. // 返回值:                無
  239. //=============================================================
  240. void Stop()                                                   //停車
  241. {
  242.         *P_IOB_Data=0x0000;                                                        //停車
  243.         PlaySnd(S_RDY,3);                                                        //語音提示
  244. }
  245. //=============================================================
  246. // 語法格式:        void BSR(void);
  247. // 實現功能:        辨識子函數
  248. // 參數:                無
  249. // 返回值:                無
  250. //=============================================================
  251. void BSR(void)
  252. {
  253.         int Result;        //辨識結果寄存
  254.         Result = BSR_GetResult();                                        //獲得識別結果
  255.         if(Result>0)        //有語音觸發?
  256.         {
  257.                 *P_IOB_Data=0x0000;                                                //臨時停車
  258.                 switch(Result)
  259.                 {
  260.                 case NAME_ID:                                                        //識別出名稱命令
  261.                         Stop();        //停車待命
  262.                         break;
  263.                 case COMMAND_GO_ID:                                                //識別出第一條命令
  264.                         GoAhead();                                                        //執行動作一:直走
  265.                         break;
  266.                 case COMMAND_BACK_ID:                                        //識別出第二條命令
  267.                         BackUp();                                                        //執行動作二:倒車
  268.                         break;
  269.                 case COMMAND_LEFT_ID:                                        //識別出第三條命令
  270.                         TurnLeft();                                                        //執行動作三:左轉
  271.                         break;
  272.                 case COMMAND_RIGHT_ID:                                        //識別出第四條命令
  273.                         TurnRight();                                                //執行動作四:右轉
  274.                         break;
  275.                 default:
  276.                         break;
  277.                 }
  278.         }
  279. }
  280. //=============================================================
  281. // 語法格式:        void IRQ5(void);
  282. // 實現功能:        中斷服務子函數
  283. // 參數:                無
  284. // 返回值:                無
  285. //=============================================================
  286. void IRQ5(void)__attribute__((ISR));                        //運動定時控制
  287. void IRQ5(void)
  288. {
  289.         if(uiTimecont++ == uiTimeset)
  290.         {
  291.                 *P_IOB_Data = 0x0000;
  292.         }
  293.         *P_INT_Clear = 0x0004;
  294. }
  295. //=============================================================
  296. // 語法格式:        int main(void);
  297. // 實現功能:        主函數
  298. // 參數:                無
  299. // 返回值:                無
  300. //=============================================================
  301. int main(void)
  302. {        unsigned int BS_Flag;                                                //Train標志位
  303.
  304.         *P_IOA_Dir=0xff00;                                                        //初始化IOA,IOA0~7下拉輸入
  305.         *P_IOA_Attrib=0xff00;
  306.         *P_IOA_Data=0x0000;
  307.
  308.         *P_IOB_Dir=0x0f00;                                                        //初始化IOB,IOB8~11同向輸出
  309.         *P_IOB_Attrib=0x0f00;
  310.         *P_IOB_Data=0x0000;
  311.
  312.         BSR_DeleteSDGroup(0);                                                //初始化存儲器RAM
  313.         BS_Flag=*(unsigned int *)0xe000;                        //讀存儲單元0xe000
  314.         if(BS_Flag==0xffff)                                                        //沒有經過訓練(0xe000內容為0xffff)
  315.         {
  316.                 TrainSD();        //訓練
  317.                 StoreSD();        //存儲訓練結果(語音模型)
  318.         }
  319.         else        //經過訓練(0xe000內容為0x0055)
  320.         {
  321.                 LoadSD();        //語音模型載入識別器
  322.         }
  323.
  324.         PlaySnd(S_START,3);                                                        //開始識別提示
  325.         BSR_InitRecognizer(BSR_MIC);                                //初始化識別器
  326.
  327.         while(1)
  328.         {
  329.                 BSR();
  330.                 if((*P_IOA_Data)&0x0004)                                //是否重新訓練
  331.                 {
  332.                         F_FlashErase(0xe000);
  333.                         while(1);
  334.                 }
  335.         }
  336. }
主站蜘蛛池模板: 国产精品视频专区 | 亚洲免费在线观看视频 | 天堂中文在线视频 | 亚洲视频精品 | 性欧美8khd高清极品 | 四虎欧美 | 日韩黄色大片 | 四虎成人av | 中文字幕在线观看日韩 | 亚洲日本中文字幕 | 亚洲激情第一页 | 国产精品成人一区 | av一区二区在线观看 | 91性高潮久久久久久久久 | 久操国产| 少妇高潮久久久久久潘金莲 | 精品一区在线播放 | 国产精品乱码一区二区三区 | 久久免费视频网站 | 亚洲国产成人精品女人久久久 | 日韩中文字幕在线 | 91麻豆精品国产91久久久久久久久 | 特级丰满少妇一级aaaa爱毛片 | 在线视频黄 | 男人天堂网在线 | 在线观看二区 | 黄色一级片免费 | 国产成人精品一区二区三区视频 | 成人国产网站 | 亚洲精品视频在线播放 | 一区二区不卡视频 | 成人在线免费视频观看 | 二区三区视频 | 欧美在线不卡 | 国产一区在线播放 | 一区二区自拍 | av免费网 | 亚洲精品无 | 黄色免费大片 | 在线观看三级 | 日韩欧美一级片 |
