查看: 14001|回復: 18
單片機電子密碼鎖仿真 可修改密碼
ID:204443 發表于 2017-5-29 10:00 | 顯示全部樓層 |閱讀模式
電子密碼鎖 可修改密碼等,下面是proteus仿真原理圖:
  1. #include <reg52.h>
  2. #include "delay_ms.h"
  3. #include  "矩陣鍵盤.h"
  4. #include "i2c.h"
  5. #include "1602.h"
  6. #include "delay_ms.h"
  7. #include "mima.h"
  8. #define uchar unsigned char
  9. #define uint unsigned int
  10. #define A 0x0a //輸入密碼
  11. #define B 0x0b  //修改密碼
  12. #define D 0x0d //關鎖
  13. #define enter 0x0c //確認
  14. #define backspace 0x0f //退格鍵
  15. sbit baojing = P3^7; //蜂鳴器接口
  16. sbit lock = P3^3;//鎖信號
  17. sbit set = P3^2;
  18. uchar idata mima_5[6] = {1,2,3,4,5,6}; //初始密碼
  19. uchar flag_change;
  20. uchar aa;//存放密碼錯誤的次數,夠三次報警
  21. uchar bb;
  22. uchar flag_t0;
  23. void baoj1()//報警函數
  24. {
  25.         int i;
  26.         for(i = 0;i < 5; i++)
  27.         {
  28.                 baojing = 1;
  29.                 delay_ms(5);
  30.                 baojing = 0;
  31.                 delay_ms(5);
  32.         }
  33. }
  34. void baoj()
  35. {
  36.         uchar i;
  37.         for(i = 0; i < 10; i++)
  38.                 baoj1();
  39. }
  40. /*密碼處理函數*/
  41. void mimachuli()
  42. {
  43.         uchar key,i;
  44.         uchar idata mima_1[6]={' ',' ',' ',' ',' ',' '};//存放密碼緩沖區
  45.         uchar idata mima_2[6]={' ',' ',' ',' ',' ',' '};
  46.         uchar idata mima_3[6]={' ',' ',' ',' ',' ',' '};
  47.         key = step_choose();
  48.         if(key == A)//A被按下,接收輸入密碼,處理
  49.         {
  50.                 read_n_add(mima_1,0x00,6);
  51.                 write_com(0x06);//寫一個字符后地址指針加 1
  52.                 write_com(0x01);//顯示清零,數據指針清零
  53.                 write_com(0x0f);//顯示光標
  54.                 lcd_pos(0,0);
  55.                 write_n_char(" press password ");
  56.
  57.                 if(input_mima(mima_2)) //處理輸入密碼
  58.                 {
  59.                         if(mimaduibi(mima_2,mima_1)) //密碼正確
  60.                         {
  61.                                 lcd_pos(0,0);
  62.                                 write_com(0x0c);
  63.                         write_com(0x06);//寫一個字符后地址指針加 1
  64.                          write_com(0x01);//顯示清零,數據指針清零
  65.                                 write_n_char(" password right ");
  66.                                 aa = 0; //清除密碼錯誤次數
  67.                                 lock = 0; //開鎖
  68.                                 baojing = 1; //響一下
  69.                                 delay_ms(1000);
  70.                                 baojing = 0;
  71.                                 TR0 = 1;
  72.                                 flag_t0 = 1;
  73.                                 while(key != D && flag_t0) //D沒按下一直開
  74.                                 {
  75.                                         key = keyscan();
  76.                                 }
  77.                                 TR0 = 0;
  78.                                 lock = 1;//D按下了關鎖
  79.                         }
  80.                         else //密碼 不正確
  81.                         {
  82.                                 lcd_pos(0,0);
  83.                                 write_com(0x0c); //關光標
  84.                                 write_com(0x06);//寫一個字符后地址指針加 1
  85.                                 write_com(0x01);//顯示清零,數據指針清零
  86.                                 write_n_char(" password wrong");
  87.                                 delay_ms(1000);
  88.                                 aa++;
  89.                                 if(aa == 4)
  90.                                 {
  91.                                         aa = 0;
  92.                                     i = 20; //密碼不正確報警
  93.                                         while(i--)
  94.                                          baoj();
  95.                                 }
  96.                         }
  97.                 }
  98.                 else //密碼沒有輸入正確或完成
  99.                 {
  100.                         lcd_pos(0,0);
  101.                         write_com(0x0c); //關光標
  102.                    write_com(0x06);//寫一個字符后地址指針加 1
  103.                    write_com(0x01);//顯示清零,數據指針清零
  104.                         write_n_char(" password wrong");
  105.                         delay_ms(1000);
  106.                         aa++;
  107.                         if(aa == 4)
  108.                         {
  109.                                 aa = 0;
  110.                             i = 20; //密碼不正確報警
  111.                                 while(i--)
  112.                                  baoj();
  113.                         }
  114.                 }
  115.         }
  116.         if(key == B)//B被按下,修改密碼
  117.         {
  118.                 read_n_add(mima_1,0x00,6);
  119.                 write_com(0x06);//寫一個字符后地址指針加 1
  120.                 write_com(0x01);//顯示清零,數據指針清零
  121.                 write_com(0x0f);//顯示光標
  122.                 lcd_pos(0,0);
  123.                 write_n_char(" input password");
  124.                 write_com(0x0f);//顯示光標
  125.                 if(input_mima(mima_2)) //處理輸入密碼
  126.                 {
  127.                         if(mimaduibi(mima_2,mima_1)) //密碼正確
  128.                         {
  129.                                 lcd_pos(0,0);
  130.                                 write_com(0x0c);
  131.                       write_com(0x06);//寫一個字符后地址指針加 1
  132.                       write_com(0x01);//顯示清零,數據指針清零
  133.                                 write_n_char("password right ");
  134.                                 aa = 0; //清除密碼錯誤次數
  135.                                 delay_ms(1500);
  136.                                 flag_change = 1;
  137.                                 while(flag_change) //下面開始修改密碼
  138.                                 {
  139.                                         write_com(0x06);//寫一個字符后地址指針加 1
  140.                                         write_com(0x01);//顯示清零,數據指針清零
  141.                                         write_com(0x0f);//顯示光標
  142.                                         lcd_pos(0,0);
  143.                                         write_n_char("In new password");
  144.                                         delay_ms(1500);
  145.                                         if(input_mima(mima_2)) //處理輸入密碼
  146.                                         {
  147.                                                 lcd_pos(0,0);
  148.                                                 write_com(0x0c);
  149.                                  write_com(0x06);//寫一個字符后地址指針加 1
  150.                                  write_com(0x01);//顯示清零,數據指針清零
  151.                                                 write_n_char("Input new pass"); //確定新密碼
  152.                                                 lcd_pos(1,0);
  153.                                                 write_n_char("word again");
  154.                                                 delay_ms(2000);
  155.                                                 lcd_pos(0,0);
  156.                                                 write_com(0x0f);//顯示光標
  157.                                  write_com(0x06);//寫一個字符后地址指針加 1
  158.                                  write_com(0x01);//顯示清零,數據指針清零
  159.                                                 write_n_char("In new password");
  160.                                                         if(input_mima(mima_3)) //處理輸入密碼
  161.                                                         {
  162.        if(mimaduibi(mima_2,mima_3)) //密碼正確
  163.        {
  164.        lcd_pos(0,0);
  165.        write_com(0x0c);
  166.                                                               write_com(0x06);//寫一個字符后地址指針加 1
  167.                                                               write_com(0x01);//顯示清零,數據指針清零
  168.        write_n_char("password has");
  169.        lcd_pos(1,0);
  170.        write_n_char("change already");
  171.        write_n_add(mima_3,0x00,6); //把修改的密碼存進24C02
  172.        delay_ms(2000);
  173.        flag_change = 0;
  174.        }
  175.        else //密碼 不正確
  176.        {
  177.        lcd_pos(0,0);
  178.        write_com(0x0c); //關光標
  179.        write_com(0x06);//寫一個字符后地址指針加 1
  180.        write_com(0x01);//顯示清零,數據指針清零
  181.        write_n_char("password wrong");
  182.        delay_ms(1000);
  183.        aa++;
  184.        if(aa == 4)
  185.        {
  186.        aa = 0;
  187.        i = 20; //3次輸入密碼不正確報警
  188.        while(i--)
  189.        baoj();
  190.        }
  191.        flag_change = 0;
  192.        }
  193.                                                         }
  194.                                                         else //密碼沒有輸入正確或完成
  195.                                                         {
  196.        lcd_pos(0,0);
  197.        write_com(0x0c); //關光標
  198.                                                            write_com(0x06);//寫一個字符后地址指針加 1
  199.                                                            write_com(0x01);//顯示清零,數據指針清零
  200.        write_n_char(" password wrong");
  201.        delay_ms(1000);
  202.        aa++;
  203.        if(aa == 4)
  204.        {
  205.        aa = 0;
  206.        i = 20; //3次輸入密碼不正確報警
  207.        while(i--)
  208.        baoj();
  209.        }
  210.                                                         }
  211.
  212.                                         }
  213.                                         else //密碼沒有輸入正確或完成
  214.                                         {
  215.                                                 lcd_pos(0,0);
  216.                                                 write_com(0x0c); //關光標
  217.                                            write_com(0x06);//寫一個字符后地址指針加 1
  218.                                            write_com(0x01);//顯示清零,數據指針清零
  219.                                                 write_n_char("password wrong");
  220.                                                 delay_ms(1000);
  221.                                                 flag_change = 0;
  222.                                                 aa++;
  223.                                                 if(aa == 4)
  224.                                                 {
  225.                                                         aa = 0;
  226.                                                     i = 20; //3次輸入密碼不正確報警
  227.                                                         while(i--)
  228.                                                          baoj();
  229.                                                 }
  230.                                         }
  231.
  232.                                 }
  233.                         }
  234.                         else //密碼 不正確
  235.                         {
  236.                                 lcd_pos(0,0);
  237.                                 write_com(0x0c); //關光標
  238.                                 write_com(0x06);//寫一個字符后地址指針加 1
  239.                                 write_com(0x01);//顯示清零,數據指針清零
  240.                                 write_n_char("password wrong");
  241.                                 delay_ms(1000);
  242.                                 aa++;
  243.                                 if(aa == 4)
  244.                                 {
  245.                                         aa = 0;
  246.                                     i = 20; //3次輸入密碼不正確報警
  247.                                         while(i--)
  248.                                          baoj();
  249.                                 }
  250.                         }
  251.                 }
  252.                 else //密碼沒有輸入正確或完成
  253.                 {
  254.                         lcd_pos(0,0);
  255.                         write_com(0x0c); //關光標
  256.                    write_com(0x06);//寫一個字符后地址指針加 1
  257.                    write_com(0x01);//顯示清零,數據指針清零
  258.                         write_n_char("password wrong");
  259.                         delay_ms(1000);
  260.                         aa++;
  261.                         if(aa == 4)
  262.                         {
  263.                                 aa = 0;
  264.                             i = 20; //3次輸入密碼不正確報警
  265.                                 while(i--)
  266.                                  baoj();
  267.                         }
  268.                 }
  269.         }
  270. }
  271. /*外部中斷函數,恢復出廠設置,長按set鍵恢復*/
  272. void int0() interrupt 0
  273. {
  274.         delay_ms(2000);
  275.         if(!set)
  276.         {
  277.                 lcd_pos(0,0);
  278.                 write_com(0x0c); //關光標
  279.            write_com(0x06);//寫一個字符后地址指針加 1
  280.                 write_com(0x01);//顯示清零,數據指針清零
  281.                 i2cinit();//24C02總線初始化
  282.                 write_n_add(mima_5,0x00,6);
  283.                 write_n_char("password renew");
  284.                 lcd_pos(1,0);
  285.                 write_n_char("already");
  286.                 delay_ms(1000);
  287.                 lcd_pos(0,0);
  288.                 write_com(0x0c); //關光標
  289.            write_com(0x06);//寫一個字符后地址指針加 1
  290.                 write_com(0x01);//顯示清零,數據指針清零
  291.                 write_n_char("Input password");
  292.                 lcd_pos(1,0);
  293.                 write_n_char("Press key A");
  294.         }// 引起了三個警告
  295. }
  296. ……………………
  297. …………限于本文篇幅 余下代碼請從51黑下載附件…………
電子密碼鎖仿真有代碼.zip (3.92 MB, 下載次數: 487)
參與人數 2黑幣 +55 收起 理由
老大4012 + 5 很給力!
ID:248401 發表于 2017-11-11 16:35 | 顯示全部樓層
支持支持
ID:248401 發表于 2017-11-11 17:49 | 顯示全部樓層
支持了
ID:298628 發表于 2018-3-28 23:05 | 顯示全部樓層
謝謝樓主的程序
ID:333064 發表于 2018-5-18 15:57 | 顯示全部樓層
樓主真棒
ID:363386 發表于 2018-7-5 13:46 | 顯示全部樓層
真心在這里面有好多大佬謝謝分享
ID:365622 發表于 2018-7-5 15:03 | 顯示全部樓層
大佬,都是大佬
ID:28942 發表于 2018-7-5 22:44 | 顯示全部樓層
謝謝樓主的分享
ID:398918 發表于 2018-9-17 11:10 | 顯示全部樓層
謝謝,樓主的分享
ID:403340 發表于 2018-9-27 20:05 來自觸屏版 | 顯示全部樓層
z348818516 發表于 2018-9-17 11:10
謝謝,樓主的分享
大佬是否可以分享一下
ID:358464 發表于 2019-4-8 10:05 | 顯示全部樓層
謝謝分享!參考一下
ID:585326 發表于 2019-8-9 19:53 | 顯示全部樓層
不能修改密碼
ID:654359 發表于 2019-12-2 15:56 | 顯示全部樓層
感謝分享!學習一下。
ID:659524 發表于 2019-12-11 11:35 來自觸屏版 | 顯示全部樓層
大佬求資料分享
ID:776035 發表于 2020-6-11 11:38 | 顯示全部樓層
感謝分享!學習一下。
ID:780428 發表于 2020-6-15 21:32 | 顯示全部樓層
支持支持
ID:780128 發表于 2020-6-17 22:41 | 顯示全部樓層
支持支持幫大忙了
ID:783929 發表于 2020-6-19 10:58 | 顯示全部樓層
太厲害了
ID:1076624 發表于 2023-5-11 10:47 來自觸屏版 | 顯示全部樓層
1044689557 發表于 2019-8-9 19:53
不能修改密碼
能改嗎
主站蜘蛛池模板: 国产精品久久久一区二区 | 成人午夜av | 久久久成人免费视频 | 伊人网在线观看 | av在线免费播放 | 国产激情视频在线 | a天堂在线视频 | 国产欧美一区二区三区视频在线观看 | 黄色片免费 | 在线一级片 | 日韩一区二区三区av | 天天干少妇| 久久久国产视频 | 亚洲国产精品va在线看黑人 | 亚洲成人国产 | 欧美资源在线 | 日本免费在线视频 | www.男人的天堂 | 欧美一级艳片视频免费观看 | 日日骚av | 午夜天堂在线 | 成人深夜 | 懂色av一区二区三区 | 国产精品一区二区在线播放 | 中文字幕一区二 | 一区二区三区网站 | 嫩草视频在线观看 | 国产精品99久久久久久久久 | 亚洲黄色在线视频 | 精品视频99 | 中文字幕丰满人伦在线 | 精久久久 | 欧美一级免费 | 性视频在线 | 天天爽 | 97久久久 | 亚洲福利一区二区 | 天天爽天天爽 | 日韩精品福利 | 欧美激情免费 | 亚洲成人免费 |
