查看: 6131|回復: 3
單片機電子琴設計中怎么存音樂
ID:185632 發表于 2017-6-5 15:57 | 顯示全部樓層 |閱讀模式
五一單片機中電子琴的中音樂的那種音律怎么用代碼啊什么表示
ID:164602 發表于 2017-6-5 18:12 | 顯示全部樓層
這個問題有點復雜。一個個地說吧。
首先是音樂的知識:
第一:音樂與頻率的關系——標準A = 440 Hz,8度音的頻率為原來音頻率的2倍。我們不是搞音樂的,這個就不多說。
第二:音階與頻率的具體關系:
音階      Octave0 Octave1  Octave2  Octave3
Do  C      262      523     1047     2093
    Db      277      554    1109     2217
Re  D       294      587     1175     2349
    Eb      311       622     1245     2489
Mi  E       330       659     1329     2637
Fa   F      349      698     1397     2794
    Gb      370      740     1480     2960
Sol  G      392       784     1568    3136
    Ab      415       831    1661     3322
La  A       440       880     1760     3520
    Bb      466       923    1865      3729
Si   B       494       988      1976     3951
有了這些知識,就可以用單片機控制頻率,讓蜂鳴器發出音樂了。
怎么編程呢?
給你一個程序:
本實例利用無源蜂鳴器發出音樂聲音。
還用到了定時計數器0
#include <reg51.h>
#define uint unsigned int
#define uchar unsigned char
sbit voice=P1^5;//蜂鳴器I/O口
uchar code sound[]={0xff,
軟件使用規則:
下面已經定義好了簡譜對應的頻率數據
節拍數據為:
四分之一拍:0x10
四分之二拍:0x20
四分之三拍:0x30
      一拍:0x40
一又四分之一拍:0x60
      兩拍:0x80
      三拍:0xc0
音樂數據是這樣的:兩個十六進制數據,表達一個音符,它包含信息有:第一個數據為音階,第二數據為節拍,一定是成對放置。
//此后為音樂樂譜,全部為3拍
0x60,0xc0,//低音階1,2,3,4,5,6,7
0x55,0xc0,
0x4c,0xc0,
0x48,0xc0,
0x40,0xc0,
0x39,0xc0,
0x33,0xc0,
0x30,0xc0,//中音階1,2,3,4,5,6,7
0x2b,0xc0,
0x26,0xc0,
0x24,0xc0,
0x20,0xc0,
0x1c,0xc0,
0x19,0xc0,
0x18,0xc0,//高音階1,2,3,4,5,6,7
0x15,0xc0,
0x13,0xc0,
0x12,0xc0,
0x10,0xc0,
0x0e,0xc0,
0x0d,0xc0,
0x26,0x20,0x2b,0x20,0x26,0x80,0xff,0x20,0x2b,0x20,0x26,0x20,0x26,0x10,//兩只蝴蝶
0x2b,0x10,0x30,0x80,0xff,0x40,0x39,0x20,0x30,0x20,0x2b,0x40,0x2b,0x20,
0x26,0x20,0x2b,0x20,0x30,0x20,0x39,0x20,0x39,0x10,0x30,0x10,0x40,0x80,
0x40,0x80,0x26,0x20,0x2b,0x20,0x26,0x80,0xff,0x20,0x2b,0x20,0x26,0x20,
0x26,0x10,0x2b,0x10,0x30,0x80,0xff,0x40,0x39,0x20,0x30,0x20,0x2b,0x40,
0x2b,0x20,0x26,0x20,0x2b,0x20,0x30,0x20,0x39,0x20,0x30,0x20,0x2b,0xc0,
0x2b,0x10,0x30,0xc0,0x39,0x20,0x30,0x20,0x2b,0x40,0x2b,0x20,0x26,0x20,
0x2b,0x20,0x30,0x20,0x39,0x20,0x39,0x10,0x30,0x10,0x40,0xc0,0x26,0x20,
0x20,0x20,0x20,0x80,0xff,0x20,0x20,0x20,0x1c,0x20,0x20,0x20,0x26,0xc0,
0x2b,0x20,0x2b,0x20,0x2b,0x60,0x2b,0x20,0x26,0x20,0x2b,0x20,0x30,0x20,
0x39,0x20,0x39,0x20,0x30,0x20,0x30,0x20,0x30,0xc0,0xff,0x40,0xff,0x40,
0xff,0x20,0x20,0x20,0x20,0x20,0x1c,0x20,0x18,0x20,0x19,0x20,0x19,0x20,
0x1c,0x20,0x26,0x20,0x2b,0x20,0x2b,0x20,0x26,0x20,0x26,0x80,0xff,0x20,
0x26,0x20,0x26,0x20,0x20,0x20,0x1c,0x40,0x1c,0x40,0xff,0x20,0x39,0x20,
0x26,0x20,0x2b,0x20,0x2b,0xc0,0x26,0x20,0x20,0x20,0x20,0x20,0x26,0x20,
0x20,0x40,0xff,0x20,0x18,0x40,0x19,0x20,0x1c,0x20,0x1c,0x10,0x19,0x10,
0x26,0x40,0xff,0x20,0x1c,0x20,0x1c,0x20,0x19,0x20,0x1c,0x20,0x20,0x20,
0x26,0x20,0x2b,0x20,0xff,0x20,0x26,0x20,0x2b,0x20,0x26,0x20,0x20,0x80,
0x26,0x20,0x2b,0x20,0xff,0x20,0x40,0x40,0x39,0x20,0x30,0xc0,0xff,0xc0,
0xff,0xc0,//休止符
,0x00};
uchar zdjs=0, jp;//jp為節拍變量,
void del(yj);//yj為音階變量,延時為了樂音高低
void main(void)
        uint dpjs=0;//讀數據的指針
        uchar yj;
        TMOD=0x01;//定時器0,工作方式1:16位定時器(0~65535),定時器模式,由運行控制位TR0開啟
        IE=0x82;//中斷允許寄存器設置,等于以下分別的設置:EA=1總中斷允許,ET0=1定時器中斷0允許;
        TH0=0xd8;//給定時器賦初值,即定時時間的長短:12MHz下10ms
        TL0=0xf0;
        TR0=1;//啟動定時器0
                zdjs=0;//節拍長短的計數器計數變量
                dpjs++; yj=sound[dpjs];
                dpjs++; jp=sound[dpjs];
                while(zdjs!=jp)
                        if(yj!=0xff)
                                if(yj!=0)
                                        voice=!voice;
                                        del(yj);
                                        dpjs=0;
                                        break;
                                voice=1;
                                del(jp);
void time0() interrupt 1
        TH0=0xd8;//定時10ms,12M
        TL0=0xf0;
        zdjs++;
void del(yj)
        uchar yj2=2;
        while(yj!=0)
                while(yj2!=0)
                        yj2--;
                        yj2=2;
                        yj--;
好了,電子音樂已經可以通過51單片機進行演奏了。
還可以有其它的演奏辦法:
第一:上述程序不是唯一的,只要能控制好蜂鳴器發聲音的頻率,就可以發出音樂。
第二:還可以通過電子電路的設計,通過雙穩態電路(模擬電路)或其它芯片,可以得到發音樂的結果。小孩玩的電子琴,就是這樣來的。網上很多資料,這里不多說了。
ID:77589 發表于 2023-5-15 11:11 | 顯示全部樓層
當然用數組存放啊!如果數據太多,外掛Flash啊!
ID:1034262 發表于 2023-5-15 16:27 | 顯示全部樓層
可以參考MIDI。
或者自己定義,節拍速率,音符、時值。
主站蜘蛛池模板: 亚洲一区精品视频 | 日韩一级二级三级 | 天天爽 | 免费av一区二区 | 少妇综合 | 国产成人精品毛片 | 国产剧情在线 | 国产成人午夜精品 | 日韩亚洲欧美在线观看 | 手机在线看片1024 | 亚洲综合精品 | 欧美美女一区二区 | 亚洲天堂偷拍 | 久久久精品在线 | 国产三级黄色 | 午夜小视频在线观看 | 国产欧美综合一区二区三区 | 午夜免费福利 | 天堂av片 | 欧美精品黄色 | av网在线观看 | 99热1| 亚洲免费在线播放 | 中文字幕国产在线 | 国产伦精品一区二区三区视频我 | 久久久精品在线 | 亚洲一区二区av | 久久黄视频 | 亚洲高清视频在线 | 免费毛片在线播放 | 亚洲久久在线 | 日韩城人网站 | 男人的天堂在线 | 亚洲精品一区二区三区蜜桃久 | 欧美一区二区在线播放 | av观看网站 | 免费性爱视频 | 亚洲a级片 | 91插插插插 | av在线成人| 蜜桃视频成人 |
