查看: 3992|回復: 1
基于STM32F103ZET6的超聲波測距程序
ID:274367 發表于 2018-3-4 20:17 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
//這是hc_sr04.h文件
#include "hc_sr04.h"
#include "stm32f10x.h"
#include "delay.h"
#include "usart.h"
//記錄定時器溢出次數
u16 overcount=0;
//設置中斷優先級
void NVIC_Config(void)
        NVIC_InitTypeDef NVIC_InitStructer;
        //NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        NVIC_InitStructer.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructer.NVIC_IRQChannelSubPriority        = 0;
        NVIC_InitStructer.NVIC_IRQChannel                   = TIM2_IRQn;
        NVIC_InitStructer.NVIC_IRQChannelCmd                = ENABLE;
        NVIC_Init(&NVIC_InitStructer);
//初始化模塊的GPIO以及初始化定時器TIM2
void HC_SR04_Init(void)
        //定義結構體
        GPIO_InitTypeDef GPIO_InitStructer;
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructer;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,  ENABLE);
        //TRIG觸發信號 PA.8
        GPIO_InitStructer.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructer.GPIO_Mode  = GPIO_Mode_Out_PP;                        //推挽輸出
        GPIO_InitStructer.GPIO_Pin   = GPIO_Pin_8;
        GPIO_Init(GPIOB, &GPIO_InitStructer);
        GPIO_InitStructer.GPIO_Pin   = GPIO_Pin_6;
        //ECOH回響信號 PA.9
        GPIO_InitStructer.GPIO_Mode  = GPIO_Mode_IN_FLOATING;        //浮空輸入
        GPIO_InitStructer.GPIO_Pin   = GPIO_Pin_9;
        GPIO_Init(GPIOB, & GPIO_InitStructer);
        GPIO_InitStructer.GPIO_Pin   = GPIO_Pin_7;
        //定時器TIM2初始化
        TIM_DeInit(TIM2);
        TIM_TimeBaseInitStructer.TIM_Period        = 1000-1;                                                //定時周期為1000
        TIM_TimeBaseInitStructer.TIM_Prescaler     = 72-1;                                                         //分頻系數72
        TIM_TimeBaseInitStructer.TIM_ClockDivision = TIM_CKD_DIV1;                        //不分頻
        TIM_TimeBaseInitStructer.TIM_CounterMode   = TIM_CounterMode_Up;//向上計數
        TIM_TimeBaseInit(TIM2,&TIM_TimeBaseInitStructer);
        //開啟更新中斷
        TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
        //中斷參數設置
        NVIC_Config();
        //關閉定時器使能
        TIM_Cmd(TIM2,DISABLE);
float Senor_Using(void)
        float length=0,sum=0;
        u16 tim;
        u16 i=0;
        /*測5次數據計算一次平均值*/
        while(i!=5)
                PBout(8) = 1;  //拉高信號,作為觸發信號
                delay_us(20);  //高電平信號超過10us
                PBout(8) = 0;
                //等待回響信號
                while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_9)==RESET);
                TIM_Cmd(TIM2,ENABLE);        //回響信號到來,開啟定時器計數
                i += 1;                                                         //每收到一次回響信號+1,收到5次就計算均值
                //回響信號消失
                while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_9)==SET);
                TIM_Cmd(TIM2,DISABLE);                                                //關閉定時器
                tim = TIM_GetCounter(TIM2);                                //獲取計TIM2數寄存器中的計數值,一邊計算回響信號時間
                length=(tim+overcount*1000)/58.0;        //通過回響信號計算距離
                sum = length+sum;
                TIM2->CNT = 0;          //將TIM2計數寄存器的計數值清零
                overcount = 0;                //中斷溢出次數清零
                delay_ms(10);
        length = sum/5;
        return length;                        //距離作為函數返回值
float Senor_Using0(void)
        u16 tim;
        u16 i=0;
        /*測5次數據計算一次平均值*/
        while(i!=5)
                PBout(6) = 1;  //拉高信號,作為觸發信號
                PBout(6) = 0;
                //等待回響信號
                while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_7)==RESET);
                //回響信號消失
                while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_7)==SET);
                sum = length+sum;
                delay_ms(10);
        length = sum/5;
//中斷,當回響信號很長是,計數值溢出后重復計數,用中斷來保存溢出次數
void TIM2_IRQHandler(void)
        if(TIM_GetITStatus(TIM2,TIM_IT_Update)!=RESET)
                //清除中斷標志
                TIM_ClearITPendingBit(TIM2,TIM_IT_Update);
                overcount++;
我的測試模塊為:US-100帶溫度補償(減少溫度對測量結果的影響)
收藏收藏3 分享淘帖 頂 踩
ID:33998 發表于 2018-8-24 13:57 | 只看該作者
代碼完整一點就更好了
主站蜘蛛池模板: 天天干女人 | 国产理论在线观看 | 日本特黄视频 | 毛片aaa| 91免费观看视频 | 亚洲黄色三级 | 九九精品视频在线观看 | 一级特黄aaaaaa大片 | 涩涩999 | 久久久久免费 | 欧洲av在线 | av狠狠干| 欧美一级片在线 | 青青草91 | 亚洲狠狠| 成人精品在线观看 | 九九色综合 | 日皮视频免费看 | 欧美成人精品一区二区三区 | 一级毛片国产 | 亚洲精品久久久久久久久 | 精品欧美黑人一区二区三区 | 夜夜肉她怀孕h周君彦 | 毛片导航 | 欧美日日夜夜 | 一区二区免费看 | 久久少妇视频 | 欧美久久一区二区 | 亚洲精品xxx | 久久男人的天堂 | 一级黄色免费视频 | 欧美日韩性 | 日韩一级免费视频 | 欧美日韩综合网 | 成人黄色一级片 | 精品一二三| 国产视频一区在线观看 | 欧美一级片在线观看 | 久久国内视频 | 久久久久久爱 | 久久久精品影院 |
