查看: 3786|回復: 0
PCB設計中專業英譯術語之形狀與尺寸
ID:156167 發表于 2018-5-11 17:53 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
  1.開料:CutLamination/Material cutting
  2.鉆孔:Drilling
  3.內鉆:Inner LayerDrilling
  4一次孔:Outer Layer Drilling
  5.二次孔:2nd Drilling
  6.雷射鉆孔:Laser Drilling /Laser Ablation
  7.()孔鉆孔:Blind & Buried Hole Drilling
  8.干膜制程:PhotoProcess(D/F)/Dry Film
  9.前處理 (Pretreatment)
  10.壓膜:Dry Film Lamination
  11.曝光:Exposure
  12.顯影:Developing
  13.去膜:Stripping
  14.壓合:Lamination
  15:黑化:Black OxideTreatment
  16.微蝕:Microetching
  17.鉚釘組合:eyelet
  18.迭板:Lay up
  19.壓合:Lamination
  20.后處理:Post Treatment
  21.黑氧化:Black Oxide Removal
  22.銑靶:spot face
  23.去溢膠:resin flush removal
  24.減銅:Copper Reduction
  25.水平電鍍:HorizontalElectrolytic Plating
  26.電鍍:Panel plating
  27.錫鉛電鍍:Tin-Lead Plating /Pattern Plating
  28.低于 1 mil: Less than 1 mil Thickness
  29.高于 1 mil:More than 1 mil Thickness
  30.砂帶研磨:Belt Sanding
  31:剝錫鉛:Tin-Lead Stripping
  32.微切片: Microsection
  33.蝕銅:Etching
  34.初檢:Touch-up
  35.塞孔:Plug Hole
  36.防焊(綠漆/綠油)SolderMask
  37.C面印刷:Printing Top Side
  38.S面印刷:Printing Bottom Side
  39.靜電噴涂:Spray Coating
  40.前處理:Pretreatment
  41.預烤:Precure
  42.后烘烤:Postcure
  43.印刷:Ink Print
  44.表面刷磨:Scrub
  45.后烘烤:Postcure
  46.UV烘烤:UV Cure
  47.文字印刷:Printing of Legend
  48.噴砂:Pumice/Wet Blasting
  49.印可剝離防焊/藍膠:Peelable Solder Mask)
  50.化學前處理,化學研磨:Chemical Milling
  51.選擇性浸金壓膜:Selective Gold Dry Film Lamination
  52.鍍金:Gold plating
  53.噴錫:Hot Air SolderLeveling
  54.成型:Profile/Form
  55.開短路測試:Electrical Testing
  56.終檢:Final VisualInspection
  57.金手指鍍鎳金:Gold Finger
  58.電鍍軟金:Soft Ni/Au Plating
  59.浸鎳金:Immersion Ni/Au / Electroless Ni/Au
  60.噴錫:Hot Air Solder Leveling
  61.水平噴錫:HorizontalHot Air Solder Leveling
  62.垂直噴錫: Vertical Hot Air Solder Leveling
  63.超級焊錫:Super Solder
  64.印焊錫突點:Solder Bump
  65.數控銑/鑼板:N/C Routing/Milling
  66.模具沖/啤板:Punch
  67.板面清洗烘烤:Cleaning & Backing
  68.V型槽/V-CUTV-Cut/V-Scoring
  69.金手指斜邊:Beveling of G/F
  70.短斷路測試Electrical Testing/Continuity & Insulation Testing
  71.AOI 光學檢查:AOI Inspection
  72VRS 目檢:Verified & Repaired
  73.泛用型治具測試:Universal Tester
  74.專用治具測試:Dedicated Tester
  75.飛針測試:Flying Probe
  76.終檢:Final Visual Inspection
  77.壓板翹:Warpage Remove
  78.X-OUT 印刷:X-Out Marking
  79.包裝及出貨:Packing& shipping
  80.清洗及烘烤: Final Clean & Baking
  81.銅面保護劑:ENTEK Cu-106A/OSP
  82.離子殘余量測試:Ionic Contamination Test/ Cleanliness Test
  83.冷熱沖擊試驗:Thermal cycling Testing
  84.焊錫性試驗:Solderability Testing
  85.雷射鉆孔:Laser Ablation
  86.雷射鉆Tooling:Laser ablationTooling Hole
  87.雷射曝光對位孔:Laser Ablation Registration Hole
  88.雷射Mask制作:Laser Mask
  89.雷射鉆孔:Laser Ablation
  90.AOI檢查及VRS:AOI Inspection & Verified & Repaired
  91.除膠渣:Desmear
  92.專用治具測試:Dedicated Tester
  93.飛針測試:Flying Probe
  94.壓板翹: Warpage Remove
  95.底片:Ablation
  96.燒溶:laser)
  97./磨:abrade
  98.粗化:abrasion
  99.耐磨性:absorption resistance
  100.允收:ACC /accept
  101.加速腐蝕:accelerated corrosion test
  102加速試驗:accelerated test
  103.速化反應:acceleration
  104.加速劑:accelerator
  105.允許:acceptable
  106.活化液:activator
  107.實際在制品:active work in process
  108.附著力:adhesion
  109.黏著法:adhesive method
  110.氣泡:air inclusion
  111.風刀:air knife
  112.不定形的改變:amorphous change
  113.總量:amount
  114.硝基戊烷:amylnitrite
  115.分析儀:analyzer
  116環狀墊圈;孔環annular ring
  117.陽極泥:anodeslime (sludge)
  118.陽極清洗:anodizing
  119.自動光學檢測:AOI/automatic optical inspection
  120.引用之文件:applicable documents
  121.允收水平抽樣:AQL sampling
  122.液態光阻:aqueous photoresist
  123.縱橫比(厚寬比)aspect ratioAs received
  124.背光:back lighting
  125.墊板:back-up
  126.預留在制品:banked work in process
  127.基材:base material
  128.基準績效:baseline performance
  129.批:batch
  130.貝他射線照射法:beta backscattering
  131.切斜邊;斜邊:beveling
  132.二方向之變形:biaxial deformation
  133.黑化:black-oxide
  134.空板:blank panel
  135.挖空:blanking
  136.彈開:blip
  137.氣泡:blister blistering
  138.吹孔:blow hole
  139.板厚錯誤:board-thickness error
  140.黏結層:bonding plies
  141.板彎:bow ; bowing
  142.破空:break out
  143.搭橋;橋接:bridging
  144.接單生產:BTO (Build To Order)
  145,.燒焦:burning
  146.毛邊(毛頭)burr
  147.碳化物:carbide
  148.定位梢:carlson pin
  149.載運劑:carrier
  150.催化:catalyzing
  151.陰極濺射法:catholicsputtering
  152.隔板;鋼板:caul plate
  153.校驗系統之各種要求:calibration system requirements
  154.中心光束法:center beam method
  155.集中式投射線:central projection
  156.認證:certification
  157.倒角 (金手指)chamfer chamfer
  158.切斜邊;倒角:chamfering
  159.特性阻抗:characteristic impedance
  160.電量傳遞過電壓:charge transfer overpotential
  161.網框:chase
  162.棋盤:checkboard
  163.蟹和劑:chelator
  164.化學鍵:chemical bond
  165.化學蒸著鍍:chemical vapor deposition
  166.圓周性之孔破:circumferential void
  167.包夾金屬:clad metal
  168.無塵室:clean room
  169.間隙:clearance
170.表面處理:Coating/Surface Finish
主站蜘蛛池模板: 麻豆一区二区三区 | 天堂一区二区三区 | 日韩欧美精品一区二区 | 一级大片免费看 | 一区二区高清视频 | av免费看网站 | 国产日本在线观看 | 亚洲人在线观看 | 久久精品欧美一区二区三区不卡 | 国产亚洲欧美在线 | 中国黄色1级片 | 精品国产视频 | 久久久久久黄色 | 欧美精品一区二区在线观看 | 亚洲综合五月天婷婷丁香 | 伊人亚洲综合 | 国产免费久久 | 日本a在线观看 | 欧美国产日韩一区二区 | 黄色小视频免费观看 | 欧美国产日韩一区二区 | 黄在线观看| 亚洲欧美高清 | 青青在线视频 | 91黄色片 | 综合色婷婷一区二区亚洲欧美国产 | 日韩精品中文字幕在线观看 | 免费三级黄色片 | av一二三区 | 免费av网站在线观看 | 超碰精品在线 | 午夜成人影片 | 日韩精品国产精品 | 免费色片 | 国产高清视频在线播放 | 国产精品一区三区 | 亚洲亚洲人成综合网络 | 日韩视频在线播放 | 久久精品黄色 | 色福利网 | 成人aa|
