查看: 3751|回復: 1
[原創]開源采用vb上位機串口對時的單片機16*64LED條屏仿真程序
ID:405708 發表于 2018-10-10 20:48 | 顯示全部樓層 |閱讀模式
附件內有上位機VB源碼和上位機安裝程序,圖片左上角的小界面是上位機程序,可獲取電腦的時間和日期發送到16*64LED上顯示(需要安裝虛擬串口)。
單片機16*64LED條屏仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
  1. #include "reg51.h"                                                         //包含51單片機的端口和內部寄存器定義的頭文件
  2. typedef unsigned char uint8;                                                               //定義字符型
  3. typedef unsigned int  uint16;                                                              //定義整型
  4. typedef unsigned long uint32;                                                              //定義長整型
  5. uint32  dx,dxx;        //字符顯示偏移量
  6. uint8  brk,flag;
  7. uint8 BUFFER[22];
  8. sbit RTC_RST     =                P3^5;
  9. sbit RTC_SCLK         =                 P3^6;
  10. sbit RTC_IO                 =                P3^7;
  11. uint8 bdata AA;        //brk延時用
  12. uint8 const code dat_bit_up[]={0xF7,0xFB,0xFD,0xFE,0x7F,0xBF,0xDF,0xEF};   //列高位掃描數據
  13. uint8 const code dat_bit_down[]={0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F}; //列低位掃描數據
  14. sbit AA7 = AA^7;
  15. #define READ_SECOND     0x81
  16. #define WRITE_SECOND    0x80
  17. #define READ_MINE       0x83
  18. #define WRITE_MINE      0x82
  19. #define READ_HOUR       0x85
  20. #define WRITE_HOUR                 0x84
  21. #define READ_DAY                0x87
  22. #define WRITE_DAY                0x86
  23. #define READ_MONTH                0x89
  24. #define WRITE_MONTH                0x88
  25. #define READ_WEEK                0x8b
  26. #define WRITE_WEEK                0x8a
  27. #define READ_YEAR       0x8d
  28. #define WRITE_YEAR                0x8c
  29. uint8 const code NUM[][16]=
  30. {
  31. {0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18,0x00,0x00,0x00},/*"0",0*/
  32. …………
  33. …………
  34. …………限于本文篇幅 余下代碼請從51黑下載附件…………
  35. {0x00,0x00,0x10,0x81,0x28,0xC2,0x21,0x44,0x21,0x24,0x22,0x00,0x3E,0xFF,0x22,0x44,0x22,0x44,0x22,0x7C,0x3E,0x44,0x22,0x7C,0x22,0x44,0x22,0xFE,0x3E,0x44,0x00,0x44},/*"期",4*/
  36. {0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x00,0x00},/*":",0*/
  37. };
  38. /*****************************************************************************************************************************
  39. /     端口定義
  40. ******************************************************************************************************************************/
  41. #define LED_PORTH P0          //列高位
  42. #define LED_PORTL P2          //列低位
  43. sbit SER_CP=P3^4;             //串行時鐘線
  44. sbit SER_SDA=P3^3;            //串行數據線
  45. sbit SER_EN=P3^2;             //74595數據有效線
  46. /*****************************************************************************************************************************
  47. /   函數名稱:Delay
  48. /   作用: 延時子程序主要用于LED的消隱
  49. ******************************************************************************************************************************/
  50. void Delay()                  //延時子程序
  51. {
  52.     uint16  i,j;
  53.     for(i=0;i<0x14;i++)
  54.     for(j=0;j<0x05;j++);
  55. }
  56. /*****************************************************************************************************************************
  57. /   函數名稱:LED_Ser
  58. /   作用: 發送串行數據到74LS595
  59. /   入口參數:dat 為要發送的數據8位
  60. ******************************************************************************************************************************/
  61. void LED_Ser(uint16 dat)
  62. {
  63.     uint8 i;
  64.     for(i=0;i<16;i++)          //共8BYTE
  65.     {
  66.         SER_SDA=dat&0x01;     //把數據的最后一位放在數據線上
  67.         dat>>=1;              //向右移位共8下這樣可以發送8位數據
  68.         SER_CP=0;                     //
  69.         SER_CP=1;             //產生上升沿發送數據1BYTE
  70.     }
  71. }
  72. void LED_Ser_8(uint8 dat)
  73. {
  74.     uint8 i;
  75.     for(i=0;i<8;i++)          //共8BYTE
  76.     {
  77.         SER_SDA=dat&0x01;     //把數據的最后一位放在數據線上
  78.         dat>>=1;              //向右移位共8下這樣可以發送8位數據
  79.         SER_CP=0;                     //
  80.         SER_CP=1;             //產生上升沿發送數據1BYTE
  81.     }
  82. }
  83. /*****************************************************************************************************************************
  84. /   函數名稱:LED_Ser_EN
  85. /   作用: 用于在SER_EN口線上產生上長沿使74595發送的數據有效
  86. ******************************************************************************************************************************/
  87. void LED_Ser_EN()
  88. {
  89.     SER_EN=0;                         //
  90.     SER_EN=1;                 //產生上升沿脈沖用于使74595發的數據有效
  91. }
  92. /*****************************************************************************************************************************
  93. /   函數名稱:LED_Disp
  94. /   作用: 在LED上顯示字符或BMP
  95. /   入口參數:*dat 為要顯示的字符或BMP的數據的首地址指針
  96. ******************************************************************************************************************************/
  97. void  LED_Disp(uint16 *dat)
  98. {
  99.     uint16  tmp;
  100.         uint8  a,j,i;
  101.     for(j=0;j<16;)
  102.     {
  103.         for(i=0;i<16;i++)
  104.             {
  105.             for(a=0;a<4;a++)   //共四個字
  106.                 {
  107.                 if(dx>15){dxx+=16;dx=0;}  //dx,dxx為顯示偏移量
  108.                 tmp=((dat[i+dxx+a*16]>>dx)|(dat[i+dxx+(a+1)*16]<<(16-dx)));//移動一位最大可移動八位左
  109.                                 if(dat[i+(a+1)*16+dxx]==0x55aa){dxx=0;tmp=0;flag=1;}
  110.                 LED_Ser(~tmp);        //發送右
  111.                 }
  112.             LED_Ser_EN();      //使發送的數據顯示
  113.             if(j<8){LED_PORTH=dat_bit_up[j];LED_PORTL=0XFF;}   //上半列掃描
  114.             else{LED_PORTL=dat_bit_down[j-8];LED_PORTH=0XFF;}  //下半列掃描
  115.             Delay();        //延時
  116.             LED_PORTL=0XFF;        //消隱
  117.             LED_PORTH=0XFF;        //消隱
  118.                         j++;
  119.             }
  120.     }
  121. }
  122. void RTC_Write(uint8 dat)
  123. {
  124.         uint8 i;
  125.         for(i=0;i<8;i++)
  126.         {
  127.                 RTC_IO=(bit)(dat&0x01);
  128.                 RTC_SCLK=1;
  129.                 RTC_SCLK=0;
  130.                 dat>>=1;
  131.         }
  132. }
  133. uint8 RTC_Read()
  134. {
  135.     uint8 i;
  136.     for(i=0; i<8; i++)
  137.     {
  138.         AA >>=1;                                 //相當于匯編中的 RRC
  139.         AA7 = RTC_IO;
  140.         RTC_SCLK = 1;
  141.         RTC_SCLK = 0;
  142.     }
  143.     return AA;
  144. }
  145. void RTC_Write_Byte(uint8 addr,uint8 dat)
  146. {
  147.         RTC_RST=0;
  148.         RTC_SCLK=0;
  149.         RTC_RST=1;
  150.         RTC_Write(addr);
  151.         RTC_Write(dat);
  152.         RTC_SCLK=1;
  153.         RTC_RST=0;
  154. }
  155. uint8 RTC_Read_Byte(uint8 addr)
  156. {
  157.         uint8 dat;
  158.         RTC_RST=0;
  159.         RTC_SCLK=0;
  160.         RTC_RST=1;
  161.         RTC_Write(addr|0x01);
  162.         dat=RTC_Read();
  163.         RTC_SCLK=1;
  164.         RTC_RST=0;
  165.         return dat;
  166. }
  167. typedef struct __SYSTEMTIME__
  168. {
  169.         uint8  Second;
  170.         uint8  Mine;
  171.         uint8  Hour;
  172.         uint8  Day;
  173.         uint8  Month;
  174.         uint8  Week;
  175.         uint8  Year;
  176. }SYSTEMTIME;
  177. SYSTEMTIME TIMETYPE;
  178. void CurrentTime(SYSTEMTIME *dat)
  179. {
  180.         uint8 TimeValue;
  181.         TimeValue=RTC_Read_Byte(READ_SECOND);
  182.         dat->Second=(((TimeValue&0x70)>>4)*10)+(TimeValue&0x0f);
  183.         TimeValue=RTC_Read_Byte(READ_MINE);
  184.         dat->Mine=  (((TimeValue&0x70)>>4)*10)+(TimeValue&0x0f);
  185.         TimeValue=RTC_Read_Byte(READ_HOUR);
  186.         dat->Hour=  (((TimeValue&0x70)>>4)*10)+(TimeValue&0x0f);
  187.         TimeValue=RTC_Read_Byte(READ_DAY);
  188.         dat->Day=        (((TimeValue&0x70)>>4)*10)+(TimeValue&0x0f);
  189.         TimeValue=RTC_Read_Byte(READ_MONTH);
  190.         dat->Month= (((TimeValue&0x70)>>4)*10)+(TimeValue&0x0f);
  191.         TimeValue=RTC_Read_Byte(READ_WEEK);
  192.         dat->Week=        (TimeValue&0x0f);
  193.         TimeValue=RTC_Read_Byte(READ_YEAR);
  194.         dat->Year=        (((TimeValue&0x70)>>4)*10)+(TimeValue&0x0f);
  195. }
  196. void  LED_Disp_Time_Year(SYSTEMTIME *dat)
  197. {
  198.         uint8  j,i;
  199.     for(j=0;j<16;)
  200.     {
  201.         for(i=0;i<16;i++)
  202.             {
  203.                                 LED_Ser_8(~HZ[0][i]);        //發送右
  204.                                 LED_Ser_8(~NUM[2][i]);        //發送右
  205.                                 LED_Ser_8(~NUM[0][i]);        //發送右
  206.                                 LED_Ser_8(~NUM[(dat->Year)/10][i]);        //發送右
  207.                                 LED_Ser_8(~NUM[(dat->Year)%10][i]);        //發送右
  208.                                 LED_Ser_8(~Date[0][i*2+1]);
  209.                                 LED_Ser_8(~Date[0][i*2]);
  210.                                 LED_Ser_8(~HZ[0][i]);        //發送右
  211.
  212.             LED_Ser_EN();      //使發送的數據顯示
  213.             if(j<8){LED_PORTH=dat_bit_up[j];LED_PORTL=0XFF;}   //上半列掃描
  214.             else{LED_PORTL=dat_bit_down[j-8];LED_PORTH=0XFF;}  //下半列掃描
  215.             Delay();        //延時
  216.             LED_PORTL=0XFF;        //消隱
  217.             LED_PORTH=0XFF;        //消隱
  218.                         j++;
  219.             }
  220.     }
  221. }
  222. void  LED_Disp_Time_Month(SYSTEMTIME *dat)
  223. {
  224.         uint8  j,i;
  225.     for(j=0;j<16;)
  226.     {
  227.         for(i=0;i<16;i++)
  228.             {
  229.                                 LED_Ser_8(~NUM[dat->Month/10][i]);        //發送右
  230.                                 LED_Ser_8(~NUM[dat->Month%10][i]);        //發送右
  231.                                 LED_Ser_8(~Date[1][i*2+1]);        //發送右
  232.                                 LED_Ser_8(~Date[1][i*2]);        //發送右
  233.                                 LED_Ser_8(~NUM[dat->Day/10][i]);        //發送右
  234.                                 LED_Ser_8(~NUM[dat->Day%10][i]);
  235.                                 LED_Ser_8(~Date[2][i*2+1]);
  236.                                 LED_Ser_8(~Date[2][i*2]);        //發送右
  237.
  238.             LED_Ser_EN();      //使發送的數據顯示
  239.             if(j<8){LED_PORTH=dat_bit_up[j];LED_PORTL=0XFF;}   //上半列掃描
  240.             else{LED_PORTL=dat_bit_down[j-8];LED_PORTH=0XFF;}  //下半列掃描
  241.             Delay();        //延時
  242.             LED_PORTL=0XFF;        //消隱
  243.             LED_PORTH=0XFF;        //消隱
  244.                         j++;
  245.             }
  246.     }
  247. }
  248. void  LED_Disp_Time_Week(SYSTEMTIME *dat)
  249. {
  250.         uint8  j,i;
  251.     for(j=0;j<16;)
  252.     {
  253.         for(i=0;i<16;i++)
  254.             {
  255.                                 LED_Ser_8(~HZ[0][i]);        //發送右
  256.                                 LED_Ser_8(~Date[3][i*2+1]);        //發送右
  257.                                 LED_Ser_8(~Date[3][i*2]);        //發送右
  258.                                 LED_Ser_8(~Date[4][i*2+1]);        //發送右
  259.                                 LED_Ser_8(~Date[4][i*2]);        //發送右
  260.                                 LED_Ser_8(~WEEK[dat->Week-1][i*2+1]);
  261.                                 LED_Ser_8(~WEEK[dat->Week-1][i*2]);
  262.                                 LED_Ser_8(~HZ[0][i]);        //發送右
  263.
  264.             LED_Ser_EN();      //使發送的數據顯示
  265.             if(j<8){LED_PORTH=dat_bit_up[j];LED_PORTL=0XFF;}   //上半列掃描
  266.             else{LED_PORTL=dat_bit_down[j-8];LED_PORTH=0XFF;}  //下半列掃描
  267.             Delay();        //延時
  268.             LED_PORTL=0XFF;        //消隱
  269.             LED_PORTH=0XFF;        //消隱
  270.                         j++;
  271.             }
  272.     }
  273. }
  274. void  LED_Disp_Time_Time(SYSTEMTIME *dat)
  275. {
  276.         uint8  j,i;
  277.     for(j=0;j<16;)
  278.     {
  279.         for(i=0;i<16;i++)
  280.             {
  281.                                 LED_Ser_8(~NUM[dat->Hour/10][i]);        //發送右
  282.                                 LED_Ser_8(~NUM[dat->Hour%10][i]);        //發送右
  283.                                 LED_Ser_8(~Date[5][i]);        //發送右
  284.                                 LED_Ser_8(~NUM[dat->Mine/10][i]);        //發送右
  285.                                 LED_Ser_8(~NUM[dat->Mine%10][i]);        //發送右
  286.                                 LED_Ser_8(~Date[5][i]);
  287.                                 LED_Ser_8(~NUM[dat->Second/10][i]);
  288.                                 LED_Ser_8(~NUM[dat->Second%10][i]);        //發送右
  289.
  290.             LED_Ser_EN();      //使發送的數據顯示
  291.             if(j<8){LED_PORTH=dat_bit_up[j];LED_PORTL=0XFF;}   //上半列掃描
  292.             else{LED_PORTL=dat_bit_down[j-8];LED_PORTH=0XFF;}  //下半列掃描
  293.             Delay();        //延時
  294.             LED_PORTL=0XFF;        //消隱
  295.             LED_PORTH=0XFF;        //消隱
  296.                         j++;
  297.             }
  298.     }
  299. }
  300. /*****************************************************************************************************************************
  301. /   函數名稱:ET0_INT
  302. /   作用: 定時器T0的中斷服務程序用于延自加字符顯示偏移量以產生字符滾動顯示的效果
  303. ******************************************************************************************************************************/
  304. void ET0_INT() interrupt 1 using 0    //中斷服務程序
  305. {
  306.     TH0=0x03;
  307.     TL0=0x04;
  308.     brk++;
  309.     if(brk==10)
  310.     {
  311.         brk=0;       //brk延時用
  312.         dx++;       //字符顯示偏移量
  313.     }
  314. }
  315. void Char_to_time(uint8 *dat)
  316. {
  317.         uint8 year,month,day,week,hour,mine;
  318.     year=((dat[0]-'0')*16+(dat[1]-'0'));
  319.         month=((dat[3]-'0')*16+(dat[4]-'0'));
  320.         day=((dat[6]-'0')*16+(dat[7]-'0'));
  321.         hour=((dat[9]-'0')*16+(dat[10]-'0'));
  322.         mine=((dat[12]-'0')*16+(dat[13]-'0'));
  323.         week=(dat[15]-'0');
  324.         RTC_Write_Byte(0x8e,0x00); //寫入允許
  325.     RTC_Write_Byte(0x80,WRITE_SECOND|0x80);
  326.         RTC_Write_Byte(0x8e,0x80); //禁止寫入
  327.         RTC_Write_Byte(0x8e,0x00); //寫入允許
  328.         RTC_Write_Byte(WRITE_YEAR,year); //寫入新的秒數
  329.         RTC_Write_Byte(WRITE_MONTH,month); //寫入新的秒數
  330.         RTC_Write_Byte(WRITE_DAY,day); //寫入新的秒數
  331.         RTC_Write_Byte(WRITE_HOUR,hour); //寫入新的秒數
  332.         RTC_Write_Byte(WRITE_MINE,mine&0x7f); //寫入新的秒數
  333.         RTC_Write_Byte(WRITE_WEEK,week); //寫入新的秒數
  334.         RTC_Write_Byte(0x8e,0x00); //寫入允許
  335.         RTC_Write_Byte(0x80,WRITE_SECOND&0x7f);
  336.         RTC_Write_Byte(0x8E,0x80);
  337. }
  338.
  339. void Serial_int() interrupt 4 using 0
  340. {
  341.         uint8 i;
  342.         for(i=0;i<17;i++)
  343.         {
  344.         //        RI=0;
  345.                 while(RI==0);
  346.                 RI=0;
  347.                 BUFFER[i]=SBUF;
  348.         }
  349.         Char_to_time(BUFFER);
  350. }
  351. /*****************************************************************************************************************************
  352. /   函數名稱:main
  353. /   作用: 主程序
  354. ******************************************************************************************************************************/
  355. void main()
  356. {
  357. //   TMOD=0x01;      //定時器方式1
  358.     TH0=0x03;
  359.     TL0=0x04;
  360.
  361.         TMOD=0x20;
  362.         TH1=0xfd;
  363.         TL1=0xfd;
  364.         SCON=0x50;
  365.         PCON&=0xef;
  366.         EA=1;           //開總中斷
  367.     ET0=1;          //開定時器中斷
  368.     TR0=1;          //開始定時
  369.         ES=1;
  370.         TR1=1;
  371.         RI=0;
  372.         while(1)
  373.         {
  374.
  375.             while(!flag)
  376.                 {
  377.                         LED_Disp(HZ);
  378.                 }
  379.                 while(dx!=0x14)
  380.                 {
  381.                         CurrentTime(&TIMETYPE);
  382.                         LED_Disp_Time_Year(&TIMETYPE); //顯示主程序
  383.                 }
  384.                 dx=0;
  385.                 while(dx!=0x14)
  386.                 {
  387.                         CurrentTime(&TIMETYPE);
  388.                         LED_Disp_Time_Month(&TIMETYPE);
  389.                 }
  390.                 dx=0;
  391.                 while(dx!=0x14)
  392.                 {
  393.                         CurrentTime(&TIMETYPE);
  394.                         LED_Disp_Time_Week(&TIMETYPE);
  395.                 }
  396.                 dx=0;
  397.                 while(dx!=0x6f)
  398.                 {
  399.                         CurrentTime(&TIMETYPE);
  400.                         LED_Disp_Time_Time(&TIMETYPE);
  401.                 }
  402.                 dx=0;
  403.                 flag=0;
  404.                 while(!flag)
  405.                 {
  406.                         LED_Disp(HZ1);
  407.                 }
  408.                 flag=0;
  409.         }
  410.
  411. }
HBLED.rar (3.53 MB, 下載次數: 47)
相關帖子
ID:61840 發表于 2018-11-12 14:29 | 顯示全部樓層
謝謝分享!收藏了!
主站蜘蛛池模板: 日韩欧美精品一区二区 | 91成人免费版 | 国产精品毛片va一区二区三区 | 亚洲免费久久 | 99久久综合| 亚洲精品911 | 日韩三级一区二区 | 最新av在线播放 | 免费99精品国产自在在线 | 黄av在线 | 午夜黄视频 | 日日夜夜精品免费 | 欧美精品在线看 | 日韩精品一 | 精品国产一区二区三区久久久蜜月 | 日日夜夜精品免费 | 国产又粗又猛又黄又爽无遮挡 | 欧美69视频| 色综合天天综合网天天狠天天 | 免费色视频 | 日韩视频在线观看 | 老司机深夜福利视频 | 黄色片中文字幕 | 午夜性福利| 一级免费毛片 | 亚洲免费精品视频 | 亚洲免费看片 | 午夜影院在线观看视频 | 日韩免费高清视频 | 一区二区三区高清 | 欧美香蕉视频 | 亚洲免费视频观看 | 草草视频在线 | 国产福利91| 精品国产三级 | 午夜色婷婷 | 激情五月婷婷综合 | a级黄色片 | 亚洲久草| 一区二区在线看 | 欧美日韩一二三区 |
