查看: 802|回復: 8
puya32f030串口驅動Tm1652顯示問題
我想請問為啥我的串口 設置是這樣 驅動不了TM1652 是不是我的哪里程序有問題 有幫忙看看的么
代碼附在下面
tm1652規格書: Tm1652.pdf (366.28 KB, 下載次數: 0)
* INCLUDES
#include "stdlib.h"
#include "py32f0xx_hal.h"
#include "py32f0xx_hal_uart.h"
#include "tm1652.h"
* LOCAL VARIABLES
uint8_t s_7number[10] = {0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F}; // 7段顯示方式0~9
uint8_t Buffer_Tab[11] = {0x77, 0x14, 0x6E, 0x3E, 0x1D, 0x3B, 0x7B, 0x16, 0x7F, 0x3F};
uint8_t seg_no_dot[11] = {0x3f, 0x06, 0x5b, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F, 0x00};
uint8_t seg_with_dot[11] = {0xbf, 0x86, 0xdb, 0xcF, 0xe6, 0xeD, 0xfD, 0x87, 0xfF, 0xeF, 0x80};
UART_HandleTypeDef Uart1_Handle;
* PUBLIC FUNCTIONS
void HAL_UART_MspInit(UART_HandleTypeDef *UartHandle)
    if (UartHandle->Instance == USART1)
        GPIO_InitTypeDef Uart_GPIO_InitConfig;
        /*USART1時鐘使能*/
        TM1652_Tx_GPIO_CLK_ENABLE();
        __HAL_RCC_USART1_CLK_ENABLE();
        Uart_GPIO_InitConfig.Pin = TM1652_Tx_GPIO_PIN;
        Uart_GPIO_InitConfig.Mode = GPIO_MODE_AF_PP;
        Uart_GPIO_InitConfig.Pull = GPIO_PULLUP;
        Uart_GPIO_InitConfig.Speed = GPIO_SPEED_FREQ_HIGH;
        Uart_GPIO_InitConfig.Alternate = GPIO_AF0_USART1;
        HAL_GPIO_Init(TM1652_Tx_GPIO_PORT, &Uart_GPIO_InitConfig);
void address_auto_add1(uint8_t addr,uint8_t dat1,uint8_t dat2,uint8_t dat3)
        uint8_t dat_buf[4] = {0};
        dat_buf[0] = addr;
        dat_buf[1] = seg_no_dot[dat1];
        dat_buf[2] = seg_with_dot[dat2];
        dat_buf[3] = seg_no_dot[dat3];
        HAL_UART_Transmit(&Uart1_Handle,dat_buf,4,0xfff);
        HAL_Delay(5);
        dat_buf[0] = 0x18;
        dat_buf[1] = 0x1D;
        HAL_UART_Transmit(&Uart1_Handle,dat_buf,2,0xfff);
        HAL_Delay(5);
void close_seg(void)
        uint8_t dat_buf[2] = {0};
        dat_buf[0] = 0x18;
        dat_buf[1] = 0x00;
        HAL_Delay(5);
void tm1652_init(void)
    Uart1_Handle.Instance = USART1;
    Uart1_Handle.Init.BaudRate = 19200;
    Uart1_Handle.Init.WordLength = UART_WORDLENGTH_9B;
    Uart1_Handle.Init.StopBits = UART_STOPBITS_1;
    Uart1_Handle.Init.Parity = UART_PARITY_ODD; // 修改為奇校驗
    Uart1_Handle.Init.Mode = UART_MODE_TX;
    Uart1_Handle.Init.HwFlowCtl = UART_HWCONTROL_NONE;
    HAL_UART_Init(&Uart1_Handle);
/****************************************************END OF FILE****************************************************/
#ifndef _TM1652_H_
#define _TM1652_H_
* INCLUDES
* DEFINITIONS
#define TM1652_Tx_GPIO_CLK_ENABLE __HAL_RCC_GPIOB_CLK_ENABLE
#define TM1652_Tx_GPIO_PORT GPIOB
#define TM1652_Tx_GPIO_PIN GPIO_PIN_6
* API FUNCTIONS
extern uint8_t seg_with_dot[11];
extern uint8_t seg_no_dot[11];
extern uint8_t s_7number[10];
extern uint8_t Buffer_Tab[11];
void tm1652_init(void);
void address_auto_add1(uint8_t addr,uint8_t dat1,uint8_t dat2,uint8_t dat3);
void address_auto_add1_low(uint8_t addr,uint8_t dat1,uint8_t dat2,uint8_t dat3);
void close_seg(void);
#endif /* _TM1650_H_ */
int main(void)
  /* Reset of all peripherals, Initializes the Systick. */
  HAL_Init();
  /* Configure the system clock */
  APP_SystemClockConfig();
  tm1652_init();
  while (1)
    address_auto_add1(0x08, Buffer_Tab[0], Buffer_Tab[0], Buffer_Tab[0]);
ID:1066795 發表于 2025-5-6 14:42 | 只看該作者
我參考這個的來著 "基于STM32CUBE的UART串口驅動TM1652程序"
ID:1066795 發表于 2025-5-6 16:44 | 只看該作者
address_auto_add1(0x08, Buffer_Tab[0], Buffer_Tab[0], Buffer_Tab[0]);改成   address_auto_add1(0x08, 1, 2, 1);
ID:69038 發表于 2025-5-7 16:39 | 只看該作者
你可以先用PC的串口助手發數據,來觀察一下1652會不會正常?
ID:1066795 發表于 2025-5-7 17:06 | 只看該作者
zhuls 發表于 2025-5-7 16:39
不太行 沒顯示
ID:1066795 發表于 2025-5-7 17:09 | 只看該作者
沒顯示
ID:1066795 發表于 2025-5-7 17:37 | 只看該作者
ID:1066795 發表于 2025-5-7 17:50 | 只看該作者
可能我的串口有問題 發送下面的HEX TX燈都不閃
08 3F 06 5B 4F FF
18 1D
ID:1066795 發表于 2025-5-8 14:50 | 只看該作者
yslsdas 發表于 2025-5-7 17:50
08 3F 06 5B 4F FF
18 1D
破案了一把直接用到壞芯片啊 可以正常顯示
主站蜘蛛池模板: 午夜精品国产精品大乳美女 | 欧美日韩中文 | 美女网站视频在线观看 | 日韩在线中文字幕 | 久操不卡| 中文字幕网址在线 | 俺去俺来也在线www色官网 | 黄视频免费在线观看 | 欧美久久久久 | 午夜黄色大片 | 精品毛片一区二区三区 | 日韩毛片网 | 国产一区不卡 | 日本免费中文字幕 | 成人午夜小视频 | 九月色婷婷| 伊人影院久久 | 久久久久久久免费视频 | 日韩国产在线播放 | 国产性生活视频 | 国产亚洲一区二区三区 | 午夜国产福利 | 黄色片视频 | 欧美一级片 | 国产精品视频在线观看 | 欧美成人毛片 | av在线免费网站 | 一级黄色av| 国产欧美激情 | 成人免费高清视频 | 成人免费黄色片 | 天堂av影院 | 黄色性视频 | 超碰在线小说 | 国产黄色一区 | 久久亚洲欧美 | 亚洲精品99 | 久久日韩精品 | 黄视频在线播放 | 亚洲一区二区三区免费视频 | 国产精品99久久久久久久久久久久 |
