查看: 4239|回復(fù): 1
4x4鍵盤(pán)、數(shù)碼管顯示、數(shù)組應(yīng)用等練習(xí)
ID:75246 發(fā)表于 2015-3-28 15:38 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
//程序名稱:簡(jiǎn)單加法
//用于練習(xí)4x4鍵盤(pán)、數(shù)碼管顯示、數(shù)組應(yīng)用等
//4x4軟鍵盤(pán)布局
//        1 2 3 A
//        4 5 6 B
//        7 8 9 C
//        * 0 # D
//  程序中A加號(hào),#回車(chē),*ESC清零
//  數(shù)碼管接P0、P2^4-P2^7
//  鍵盤(pán)接P1
//改編自 http://m.zg4o1577.cn/bbs/dpj-20218-1.html
//              1.3.6 包含綜合應(yīng)用的實(shí)用程序
#include <reg52.h>
sbit KEY_IN_1  = P1^4;  //矩陣按鍵的掃描輸入引腳1
sbit KEY_IN_2  = P1^5;  //矩陣按鍵的掃描輸入引腳2
sbit KEY_IN_3  = P1^6;  //矩陣按鍵的掃描輸入引腳3
sbit KEY_IN_4  = P1^7;  //矩陣按鍵的掃描輸入引腳4
sbit KEY_OUT_1 = P1^3;  //矩陣按鍵的掃描輸出引腳1
sbit KEY_OUT_2 = P1^2;  //矩陣按鍵的掃描輸出引腳2
sbit KEY_OUT_3 = P1^1;  //矩陣按鍵的掃描輸出引腳3
sbit KEY_OUT_4 = P1^0;  //矩陣按鍵的掃描輸出引腳4
sbit  ADDR0 = P2^4;
sbit  ADDR1 = P2^5;
sbit  ADDR2 = P2^6;
sbit  ADDR3 = P2^7;
sbit  ENLED = P0;
unsigned char code LedChar[] = {
    0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,
    0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8e
};   //數(shù)碼管真值表
const unsigned char code KeyCodeMap[4][4] = { //矩陣按鍵編號(hào)到PC標(biāo)準(zhǔn)鍵盤(pán)鍵碼的映射表
    { 0x1B, '0', 0x0D, 0x27 },  //數(shù)字鍵0、ESC鍵、  回車(chē)鍵、 向右鍵
    { '7',  '8',  '9', 0x28 },  //數(shù)字鍵7、數(shù)字鍵8、數(shù)字鍵9、向下鍵
    { '4',  '5',  '6', 0x25 },  //數(shù)字鍵4、數(shù)字鍵5、數(shù)字鍵6、向左鍵
        { '1',  '2',  '3', 0x26 }   //數(shù)字鍵1、數(shù)字鍵2、數(shù)字鍵3、向上鍵
unsigned char KeySta[4][4] = {  //全部矩陣按鍵的當(dāng)前狀態(tài)
    {1, 1, 1, 1},
    {1, 1, 1, 1},
    {1, 1, 1, 1},
    {1, 1, 1, 1}
};           //由于數(shù)組不能定義成bit型,這里定義成unsigned char型
unsigned char LedBuf[6] = {    //數(shù)碼管動(dòng)態(tài)掃描顯示緩沖區(qū)
    0xC0, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
void DisplayNum(unsigned long num);
void KeyAction(unsigned char keycode);
void main(void)
    unsigned char i, j;
    unsigned char backup[4][4] = {  //按鍵值備份,保存前一次的值
        {1, 1, 1, 1},
        {1, 1, 1, 1},
        {1, 1, 1, 1},
        {1, 1, 1, 1}
    //選擇數(shù)碼管進(jìn)行顯示
    P0 = 0xFF;
    ADDR3 = 1;
    ENLED = 0;
    //配置T0工作在模式1,定時(shí)1ms
    TMOD = 0x01;
    TH0 = 0xFC;
    TL0 = 0x67;
    TR0 = 1;
    ET0 = 1;
    EA = 1;
        //檢索按鍵狀態(tài)的變化
        for (i=0; i<4; i++)
            for (j=0; j<4; j++)
                if (backup[j] != KeySta[j])
                    if (backup[j] == 0)  //按鍵彈起時(shí)執(zhí)行動(dòng)作
                        KeyAction(KeyCodeMap[j]);
                    backup[j] = KeySta[j];
    static unsigned long result = 0;  //用于保存運(yùn)算結(jié)果
    static unsigned long addend = 0;  //用于保存輸入的加數(shù)
    if ((keycode>='0') && (keycode<='9'))  //輸入0-9的數(shù)字
        addend = (addend*10) + (keycode-'0'); //原數(shù)據(jù)擴(kuò)大10倍,由新輸入的數(shù)字填充其個(gè)位
        DisplayNum(addend);    //運(yùn)算結(jié)果顯示到數(shù)碼管
    else if (keycode == 0x26)  //向上鍵A用作加號(hào),執(zhí)行加法或連加運(yùn)算
        result += addend;      //進(jìn)行加法運(yùn)算
        addend = 0;
        DisplayNum(result);    //運(yùn)算結(jié)果顯示到數(shù)碼管
    else if (keycode == 0x0D)  //回車(chē)鍵#,執(zhí)行加法運(yùn)算(實(shí)際效果與加號(hào)并無(wú)區(qū)別)
        addend = 0;
    else if (keycode == 0x1B)  //Esc鍵*,清零結(jié)果
        addend = 0;
        result = 0;
        DisplayNum(addend);    //清零后的加數(shù)顯示到數(shù)碼管
    signed char i;
    unsigned char buf[4];
    for (i=0; i<4; i++)   //把長(zhǎng)整型數(shù)轉(zhuǎn)換為4位十進(jìn)制的數(shù)組
        buf = num % 10;
        num /= 10;
    for (i=3; i>=1; i--)  //從最高位起,遇到0即轉(zhuǎn)換為空格,遇到非0即退出
        if (buf == 0)
            LedBuf = 0xFF;
            break;
    for ( ; i>=0; i--)    //剩余低位都如實(shí)轉(zhuǎn)換為數(shù)字
        LedBuf = LedChar[buf];
void InterruptTimer0() interrupt 1
    unsigned char i;
    static unsigned char ledcnt = 0;  //數(shù)碼管掃描計(jì)數(shù)器
    static unsigned char keyout = 0;  //矩陣按鍵掃描輸出計(jì)數(shù)器
    static unsigned char keybuf[4][4] = {  //按鍵掃描緩沖區(qū),保存一段時(shí)間內(nèi)的掃描值
        {0xFF, 0xFF, 0xFF, 0xFF},
    TH0 = 0xFC;  //溢出后進(jìn)入中斷重新賦值
    TL0 = 0x67;
    //將一行的4個(gè)按鍵值移入緩沖區(qū)
    keybuf[keyout][0] = (keybuf[keyout][0] << 1) | KEY_IN_1;
    keybuf[keyout][1] = (keybuf[keyout][1] << 1) | KEY_IN_2;
    keybuf[keyout][2] = (keybuf[keyout][2] << 1) | KEY_IN_3;
    keybuf[keyout][3] = (keybuf[keyout][3] << 1) | KEY_IN_4;
    //消抖后更新按鍵狀態(tài)
    for (i=0; i<4; i++)  //每行4個(gè)按鍵,所以循環(huán)4次
        if ((keybuf[keyout] & 0x0F) == 0x00)
        {   //連續(xù)4次掃描值為0,即16ms(4*4ms)內(nèi)都只檢測(cè)到按下?tīng)顟B(tài)時(shí),可認(rèn)為按鍵已按下
            KeySta[keyout] = 0;
        else if ((keybuf[keyout] & 0x0F) == 0x0F)
        {   //連續(xù)4次掃描值為1,即16ms(4*4ms)內(nèi)都只檢測(cè)到彈起狀態(tài)時(shí),可認(rèn)為按鍵已彈起
            KeySta[keyout] = 1;
    //執(zhí)行下一次的掃描輸出
    keyout++;
    keyout &= 0x03;
    switch (keyout)
        case 0:
            KEY_OUT_4 = 1;
            KEY_OUT_1 = 0;
            break;
        case 1:
            KEY_OUT_1 = 1;
            KEY_OUT_2 = 0;
            break;
        case 2:
            KEY_OUT_2 = 1;
            KEY_OUT_3 = 0;
            break;
        case 3:
            KEY_OUT_3 = 1;
            KEY_OUT_4 = 0;
            break;
        default:
            break;
    //執(zhí)行數(shù)碼管動(dòng)態(tài)掃描顯示
    P0 = 0xFF;
    switch (ledcnt)
                case 0: ADDR0=0; ADDR1=1; ADDR2=1; ADDR3=1; break;
                case 1: ADDR0=1; ADDR1=0; ADDR2=1; ADDR3=1; break;
                case 2: ADDR0=1; ADDR1=1; ADDR2=0; ADDR3=1; break;
                case 3: ADDR0=1; ADDR1=1; ADDR2=1; ADDR3=0; break;
                case 4: ADDR0=1; ADDR1=1; ADDR2=1; ADDR3=1; break;
        default: break;
    P0 = LedBuf[ledcnt];
    ledcnt++;
    if (ledcnt >= 5)
        ledcnt = 0;
相關(guān)帖子
ID:82493 發(fā)表于 2015-6-15 19:14 | 只看該作者
不錯(cuò),值得借鑒一下
主站蜘蛛池模板: 精品久久久久久久久久久久久久久久 | 国产中文一区 | 精品国产乱码久久久久久影片 | 91蜜桃在线观看 | 中文字幕一区二区三区在线观看 | 91av视频| 亚洲一区二区在线视频 | 国产精品视频专区 | 黑人精品xxx一区一二区 | 成人在线免费视频 | 久久av一区二区三区亚洲 | 久热99 | 欧美精品一二三区 | 亚洲免费成人 | 日韩国产在线播放 | 六月丁香激情 | 亚洲黄色在线 | 秋霞一区二区三区 | 国产欧美视频在线观看 | 狠狠干在线视频 | 日韩av免费播放 | 国产欧美日韩在线观看 | 黄色在线免费观看视频 | 成人在线精品 | 精品一区二区在线播放 | 深夜福利网站 | 在线不卡视频 | av三级在线观看 | 久久天堂网 | 亚洲高清在线观看 | 日韩中文字幕在线播放 | 青青草国产精品 | www.天天操| 男人影院在线观看 | 毛片网站视频 | 男人操女人视频网站 | 国产欧美日韩一区二区三区 | 久久久精品在线观看 | 一级黄片毛片 | 日韩视频在线观看 | 国产精品二区一区二区aⅴ污介绍 |
