查看: 2804|回復: 0
智能小車—借助串口通信發送密碼程序
ID:76556 發表于 2015-4-10 01:46 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
借助密碼鎖模塊向小車發送正確密碼(這里小車用電腦模擬)帶小車確認密碼正確后進入主程序
本程序共分為三個程序,為:main.c主程序    PWM呼吸燈.c程序    lcd12864.c程序    串口通信.c程序
/******************main.c主程序*******************/
#include <reg51.h>
sbit KEY_IN1 = P2^4;
sbit KEY_IN2 = P2^5;
sbit KEY_IN3 = P2^6;
sbit KEY_IN4 = P2^7;
sbit KEY_OUT1 = P2^3;
sbit KEY_OUT2 = P2^2;
sbit KEY_OUT3 = P2^1;
sbit KEY_OUT4 = P2^0;
unsigned char Key_Buff[4][4]={{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}};
void Delays_Lcd(unsigned int x); //延時子函數
void T0_Init();
void Write_Instruction(unsigned char Parameter); //寫指令(Write/Instruction)。。形參(Parameter)
void Write_Date(unsigned char Parameter); //寫數據(Write/Date)。。形參(Parameter)
void init_Lcd();      //液晶初始化(init/lcd)
void Position_Lcd(unsigned char x,unsigned char y); //進入點設定,,液晶顯示位置(Lcd/Position)
void Staret();
void PWM_Delays(unsigned int x);
void PWM_LED();
void Init_information();
void Open_Uart();
void AT_Start();
void The_boot_password();    //void The_boot_password(啟動密碼)
unsigned char Key_Loosen[4][4]={{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}};
Open_Uart();
Staret();
P2=0xff;
T0_Init();
static unsigned char Num_Password2=0;
unsigned char Num2,Num4;
static unsigned char Num_Password1=0;
static bit Num_Bit1=0;
static bit Num_Bit2=0;
unsigned char Num1;
static unsigned char Num_Pa1=0;
static unsigned char Num_Pa2=0;
static unsigned char Num_Pa3=0;
static unsigned char Num_Pa4=0;
static unsigned char Num_Pa5=0;
static unsigned char Num_Pa6=0;
static unsigned char Num_Pa7=0;
static unsigned char Num_Pa8=0;
static unsigned char Num_Pa9=0;
static unsigned char Num_Pa0=0;
if(Num_Bit2==1)
  switch(Num_Password2)
   case 1:if(Num_Password1==1){Num_Pa1++;}break;
   case 2:if(Num_Password1==3){Num_Pa3++;}break;
   case 3:if(Num_Password1==1){Num_Pa1++;}break;
   case 4:if(Num_Password1==4){Num_Pa4++;}break;
   case 5:if(Num_Password1==5){Num_Pa5++;}break;
   case 6:if(Num_Password1==2){Num_Pa2++;}break;
   case 7:if(Num_Password1==0){Num_Pa0++;}break;
   default : break;
  Num_Bit2=0;
  while(Num_Pa1==2&Num_Pa2==1&Num_Pa3==1&Num_Pa4==1&Num_Pa5==1&Num_Pa0==1)
  unsigned char TV2[]={"    歡迎使用"};
  init_Lcd();
   Num1=0;
   Position_Lcd(2,0);
      while(TV2[Num1]!='\0')  //教材P176頁講述了TV1[Num1]!='\0'的意思特別是'\0'的意思("空"在儲存器中的存儲形式是"\0")
    Write_Date(TV2[Num1]);
    Num1++;
PWM_LED();
  if(Num_Password2==7)
   unsigned char TV1[]={"              "};
   unsigned char TV2[]={"密碼錯誤 ^-^ "};
   unsigned long ss;
   Num1=0;
   Position_Lcd(2,1);
    Num1++;
  Write_Instruction(0x0c);
  for(ss=50000;ss>0;ss--);
   Num1=0;
   Position_Lcd(2,1);
      while(TV1[Num1]!='\0')  //教材P176頁講述了TV1[Num1]!='\0'的意思特別是'\0'的意思("空"在儲存器中的存儲形式是"\0")
    Write_Date(TV1[Num1]);
    Num1++;
   Num_Pa1=0;
   Num_Pa2=0;
   Num_Pa3=0;
   Num_Pa4=0;
   Num_Pa5=0;
   Num_Pa6=0;
   Num_Pa7=0;
   Num_Pa8=0;
   Num_Pa9=0;
   Num_Pa0=0;
   Num_Bit1=0;
   Num_Password2=0;
if(Num_Bit1==1)
  unsigned char TV1[]={"*"};
  Write_Instruction(0x0f);
  Num1=0;
  Position_Lcd(2,Num_Password2);
    Num1++;
for(Num4=0;Num4<4;Num4++)
  for(Num2=0;Num2<4;Num2++)
   if(Key_Loosen[Num4][Num2]!=Key_Buff[Num4][Num2])
     if(Key_Loosen[Num4][Num2]==0)
     unsigned char Fg;
     Fg=Num4*4+Num2;
     switch(Fg)
      case 0:P0 = Num_Password1=14;break;       //*
      case 1:P0 = Num_Password1=0;break;     //0
      case 2:P0 = Num_Password1=15;break;      //#
      case 3:P0 = Num_Password1=13;break;      //D
      case 4:P0 = Num_Password1=7;break;
      case 5:P0 = Num_Password1=8;break;
      case 6:P0 = Num_Password1=9;break;
      case 7:P0 = Num_Password1=12;break;      //C
      case 8:P0 = Num_Password1=4;break;
      case 9:P0 = Num_Password1=5;break;
      case 10:P0 = Num_Password1=6;break;      //6
      case 11:P0 = Num_Password1=11;break;      //B
      case 12:P0 = Num_Password1=1;break;
      case 13:P0 = Num_Password1=2;break;
      case 14:P0 = Num_Password1=3;break;
      case 15:P0 = Num_Password1=10;break;      //A
      Num_Password2++;
      Num_Bit1=1;
      Num_Bit2=1;
    Key_Loosen[Num4][Num2]=Key_Buff[Num4][Num2];
void InterruptTimer0() interrupt 1
unsigned char Num1;
static unsigned char Keys=0;
TH0 = 0xFC;
TL0 = 0x67;
Key_Buff[Keys][0]=(Key_Buff[Keys][0]<<1)|KEY_IN1;
Key_Buff[Keys][1]=(Key_Buff[Keys][1]<<1)|KEY_IN2;
Key_Buff[Keys][2]=(Key_Buff[Keys][2]<<1)|KEY_IN3;
Key_Buff[Keys][3]=(Key_Buff[Keys][3]<<1)|KEY_IN4;
for(Num1=0;Num1<4;Num1++)
   if((Key_Buff[Keys][Num1]&0x0f)==0x00)
    Key_Buff[Keys][Num1]=0;
Keys++;
Keys=Keys&0x03;
switch(Keys)
case 0:KEY_OUT4=1;KEY_OUT1=0;break;
case 1:KEY_OUT1=1;KEY_OUT2=0;break;
case 2:KEY_OUT2=1;KEY_OUT3=0;break;
case 3:KEY_OUT3=1;KEY_OUT4=0;break;
/******************PWM呼吸燈.c程序*******************/
#include <reg52.h>
sbit PWMOUT = P1^3;
unsigned int q;
for(q=x;q>0;q--);
void PWM_LED()
static unsigned int Num1=0;
static unsigned int Num2=600;
static bit bit1=0;
PWMOUT=1;
  if(bit1==1)
  if(Num1==0)
   PWMOUT=0;
   bit1=0;
  Num1--;
  Num2++;
PWM_Delays(Num1);
PWMOUT=0;
PWM_Delays(Num2);
if(bit1==0)
  if(Num1==600)
   unsigned int q,h;
   PWMOUT=1;
   for(h=60000;h>0;h--);
   for(q=60000;q>0;q--);
   bit1=1;
  Num1++;
  Num2--;
/******************lcd12864.c程序*******************/
#include<reg51.h>
sbit RS = P1^0;
sbit RW = P1^1;
sbit E = P1^2;
#define  Date P0   //定義Date口為數據口P0
void Delays_Lcd(unsigned int x)  //延時子函數
{  unsigned int i,j;
   for(i=45;i>0;i--)
      for(j=x;j>0;j--);
void T0_Init()
EA = 1;
TMOD=TMOD&0XF0;
TMOD = TMOD|0x01;
TH0 = 0xFC;
TL0 = 0x67;
ET0 = 1;
TR0 = 1;
void Write_Instruction(unsigned char Parameter) //寫指令(Write/Instruction)。。形參(Parameter)
RS=0;
RW=0;
E=0;
Date=Parameter;
E=1;
Delays_Lcd(0);
E=0;
void Write_Date(unsigned char Parameter) //寫數據(Write/Date)。。形參(Parameter)
RS=1;
RW=0;
E=0;
Date=Parameter;
E=1;
Delays_Lcd(0);
E=0;
void init_Lcd()      //液晶初始化(init/lcd)
Write_Instruction(0x01);
Write_Instruction(0x30);
void Position_Lcd(unsigned char x,unsigned char y) //進入點設定,,液晶顯示位置(Lcd/Position)
unsigned char  Position;
if(x==1)
{x=0x80;}
else if(x==2)
{x=0x90;}
else if(x==3)
{x=0x88;}
else if(x==4)
{x=0x98;}
Position=x+y;
Write_Instruction(Position);     //顯示地址
void Staret()
unsigned char code TV1[]={"輸入密碼"};
unsigned char code TV2[]={":"};
unsigned char Num1;
RS=0;
RW=0;
E=0;
init_Lcd();
Position_Lcd(1,2);
Num1=0;
  Num1++;
Position_Lcd(2,0);
Num1=0;
  Num1++;
Position_Lcd(2,1);
/******************串口通信.c程序*******************/
#include<reg51.h>
unsigned char Serial_data; //串口數據(Serial_data)用這個來保存。
static unsigned char Into=0;
static bit AT_one1=0;
static bit start_now=0;
void Init_Serialport1()  //初始化串口1(Serial port)
TMOD=TMOD&0x0F;
TMOD=TMOD|0x20;
TH1=0xFD;
TL1=0xFD;
TR1=1;
SCON=SCON&0x0F;
SCON=0x50;
EA=1;
ES=1;
void AT_Start()
while(AT_one1==0)
        ES=0;
        SBUF='X';
        while(TI==0);
        TI=0;
        if(Serial_data=='X')
                SBUF='&';
                while(TI==0);
                TI=0;
                ES=1;
                AT_one1=1;
        ES=1;
void The_boot_password()   //void The_boot_password(啟動密碼)
static unsigned char password_Num=0;;
ES=0;
ET0 = 0;
while(start_now==0)
        unsigned char code password[]="THE password Is Correct !@#$%^&*()+";
        SBUF=password[password_Num];
        while(TI==0);
        TI=0;
        password_Num++;
        if(password_Num==36)
                password_Num=0;
                ES=1;
                if(Serial_data=='R')
                         start_now=1;
                ES=0;
ET0 = 1;
void Open_Uart()
Init_Serialport1();
AT_Start();
void Serial_port1() interrupt 4
RI=0;
Serial_data=SBUF;
Into=1;
主站蜘蛛池模板: 欧美999| 伊人久久中文字幕 | 中文字幕日韩高清 | 99视频在线观看免费 | 精品久久一区二区 | 国产人成一区二区三区影院 | 一级黄色片网站 | 激情五月激情综合网 | 欧美一道本 | 免费在线看a| 午夜性福利 | 国产在线视频一区二区 | 日韩一级视频 | 亚洲一区二区三区在线播放 | 美女一级片| 在线观看a视频 | 一区二区三区视频 | 免费av片 | 91午夜理伦私人影院 | 中文字幕+乱码+中文乱码91 | 国产中文一区 | 成人在线一区二区 | 久艹在线观看 | 福利视频网站 | 欧美日韩在线观看视频 | 亚洲黄色在线视频 | 亚洲欧美日韩一区二区三区四区 | 人人干人人草 | 神马久久影院 | 精品一区二区三区免费看 | 色婷婷成人 | 亚洲特级毛片 | 日本精品网站 | 久久久少妇| 黄色1级视频 | 午夜视频一区二区 | 国产麻豆一区二区三区 | 日本亚洲欧美 | 国产香蕉在线观看 | 三年中文在线观看免费大全中国 | 欧美综合在线视频 |
