查看: 2255|回復: 0
msp430g2553
ID:110821 發表于 2016-3-26 00:28 | 顯示全部樓層 |閱讀模式
#include "msp430g2553.h"
#define LATCH_OUT       P1DIR |= BIT5
#define LATCH_OUT_H     P1OUT |= BIT5
#define LATCH_OUT_L     P1OUT &=~ BIT5
#define SCK_OUT         P1DIR |= BIT4
#define SCK_OUT_H       P1OUT |= BIT4
#define SCK_OUT_L       P1OUT &=~ BIT4
#define OE_OUT          P1DIR |= BIT2
#define OE_OUT_H        P1OUT |= BIT2
#define OE_OUT_L        P1OUT &=~ BIT2
#define R1_OUT          P1DIR |= BIT1
#define R1_OUT_H        P1OUT |= BIT1
#define R1_OUT_L        P1OUT &=~ BIT1
#define G1_OUT          P1DIR |= BIT3
#define G1_OUT_H        P1OUT |= BIT3
#define G1_OUT_L        P1OUT &=~ BIT3
#define A_OUT           P2DIR |= BIT0
#define A_OUT_H         P2OUT |= BIT0
#define A_OUT_L         P2OUT &=~ BIT0
#define B_OUT           P2DIR |= BIT1
#define B_OUT_H         P2OUT |= BIT1
#define B_OUT_L         P2OUT &=~ BIT1
#define C_OUT           P2DIR |= BIT2
#define C_OUT_H         P2OUT |= BIT2
#define C_OUT_L         P2OUT &=~ BIT2
#define D_OUT           P2DIR |= BIT3
#define D_OUT_H         P2OUT |= BIT3
#define D_OUT_L         P2OUT &=~ BIT3
#include "move.h"
// Stop watchdog timer to prevent time out reset ?
WDTCTL = WDTPW + WDTHOLD;
//主系統時鐘切換為外部高速晶振
  if (CALBC1_8MHZ == 0xFF || CALDCO_8MHZ == 0xFF)
while(1);// If calibration constants erased, trap CPU!!
    // Configure Basic Clock
     BCSCTL1 = CALBC1_8MHZ;// Set range
     DCOCTL = CALDCO_8MHZ;// Set DCO step + modulation*/ ? ?? ??? ? ?? ??
     BCSCTL3 |= LFXT1S_2; // Set LFXT1為vol時鐘即12kHZ ? ?? ??? ? ?? ??
     CCTL0|= CCIE;//設置捕獲/比較控制寄存器,CCIE=0x0010,使能捕獲比較中斷
     CCR0 =6;//設置捕獲/比較寄存器,初始值為12000,對于ACLK時鐘頻率為12khz的頻率,相當于1s  ? ?? ???TA0CTL = TASSEL_1 +TACLR+MC_1; // 設置定時器A控制寄存器,  ? ?
// TASSEL_1選擇輔助時鐘ACLK,TASSEL_2選擇子系統時鐘SMCLK,與dco有關;
// TACLR=0x0004,清除定時器A計數器  ? ??
//TACTL |= MC0; //設置定時器A控制寄存器,MC0=0x0010,使計數模式為增計數 P1DIR=0XFF;
      P1OUT=0xF0;
      P2SEL=0;
      _EINT();//使能中斷,這是一個C編譯器支持的內部過程。
      LCK_OUT;
          LCK_L;
      for(a=0;a<32;a++)//黑屏,用于開機狀態時刷屏,即關閉所有燈,沒有他的話開機會全屏點亮 ? ?? ?? ?? ?? ?dispram[a]=Bmp[0][a];? ?? ?? ? ?
     delay(100);
     for(zi=0;zi<13;zi++)//顯示效果:向右滾屏? ?? ?? ?? ? ? ?
    rightdisplay();
     for(zi=13;zi<25;zi++)//向右移動 ? ?? ?? ??
    updisplay();
    for(zi=24;zi<33;zi++)//顯示效果:向左滾屏? ?? ?? ?? ? ? ?? ?? ??
    leftdisplay();
   for(zi=32;zi<NUM;zi++)//向右移動 ? ?? ?? ?? ?
   downdisplay();
   delay(100);//所有字顯示完了的等待時間
   #pragma vector=TIMER0_A0_VECTOR
  __interrupt void Timer_A (void) //定時器A的CC0中斷處理程序
   row=P1OUT; //讀取當前顯示的行號 ? ?
   row++;
   row&=0x0f;//行號加1,屏蔽高4位 ? ?  ?
if(zi<13)
   toright(CHENG);
  else if(zi<25&&zi>=12)
toupdown(GREEN);
else if(zi<33&&zi>=24)
toleft(RED);
toupdown(GREEN);
P1OUT&=0xf0;//行號端口清零 ?
LCK_H;//上升沿將數據送到輸出鎖存器 ? ?
P1OUT|=row; //寫入行號 ?
LCK_L;//鎖存顯示數據 }
unsigned char tab[8];
unsigned char DIS[]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};//行數據
             16x16漢字取模數據
unsigned char hztest[32]=    //二維數組,目的是減少運算,可以用最基本的一維數組,每個漢字有32個字節數據
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
             向595寫入一個字節 單紅色
void InputByte( unsigned char DataR1) //寫一個字節
  unsigned  char i;
  for(i=0; i<8; i++)
    if((DataR1&0x01) == 1)
      R1_OUT_L;
      R1_OUT_H;
    SCK_OUT_L;
    SCK_OUT_H;
    DataR1 = DataR1 >> 1;
            初始化定時器,做為動態掃描
void Init_TimerA0(void)
  CCTL0 = CCIE;                             // CCR0 interrupt enabled
  CCR0 = 300;
  TACTL = TASSEL_2 + MC_1;                  // SMCLK, contmode
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P1DIR |= BIT0;                            // P1.0 output
  LATCH_OUT;
  SCK_OUT;
  OE_OUT;
  R1_OUT;
  G1_OUT;
  A_OUT;
  B_OUT;
  C_OUT;
  D_OUT;
  Init_TimerA0();
  _BIS_SR(LPM0_bits + GIE);                 // Enter LPM0 w/ interrupt
  while(1);
// Timer A0 interrupt service routine
  static unsigned char count,j,i;
//  unsigned char i;
  LATCH_OUT_L; //鎖存釋放
  for(j=0;j<1;j++) //取每個漢字的前2個字節,數據傳輸完成后鎖存輸出即可 j表示漢字個數,如果是3個漢字屏就可以修改成3
    InputByte(hztest[j*32+i]);
    InputByte(hztest[j*32+i+1]);
  OE_OUT_H;//暫時關閉屏幕,防止出現鬼影,如果沒有使用該引腳控制則會出現拖影現象。
  LATCH_OUT_H; //鎖存有效,此時一行的數據顯示到屏上
  P2OUT = DIS[15-count] & 0x0f;//用P2口的前4位控制16行,屏內部通過4-16譯碼器工作,循環掃描其他15行
  OE_OUT_L;//使能
  count++;
  i+=2;              //累加調用下一行數據
  if(count==16)
    count=0;
  if(i==32)
    i=0;
主站蜘蛛池模板: 欧美在线视频一区二区 | 在线观看www| 日韩欧美在线一区 | 超碰在线国产 | 欧美性生交xxxxx久久久 | 黄色大片av | 免费观看一区二区 | 中文字幕在线观看一区二区三区 | 拍床戏真做h文黄肉1v1 | 欧美在线免费观看 | 偷拍福利视频 | 91黄色大片 | 亚洲美女毛片 | 天天爱夜夜操 | 日韩精品视频在线 | 亚洲欧美另类在线观看 | 欧美日韩精品在线观看 | 久久精品视频国产 | 一区二区视频在线播放 | 欧美成人专区 | 国产乱国产乱300精品 | 乱色av| 第一福利视频导航 | 色婷婷丁香 | 四虎影视在线播放 | 在线视频日韩 | 欧美精品一级片 | 精品网站999www | 国产午夜视频在线观看 | a视频在线观看 | 日韩av在线一区二区 | 成人一区二区视频 | 五月天.com| 日本黄色一级视频 | 三级a做爰全过程 | 18视频在线观看 | 黄色1级视频 | 国产成人+综合亚洲+天堂 | 午夜视频在线免费观看 | 日韩在线精品 | 欧美日韩性 |
