51單片機(jī)做的溫控風(fēng)扇實(shí)物圖:
下載附件
溫控風(fēng)扇
2017-4-6 02:42 上傳
智能溫控風(fēng)扇原理圖:
下載附件
2017-4-6 02:45 上傳
單片機(jī)源程序如下:
- #include <reg52.h> //調(diào)用單片機(jī)頭文件
- #define uchar unsigned char //無符號(hào)字符型 宏定義 變量范圍0~255
- #define uint unsigned int //無符號(hào)整型 宏定義 變量范圍0~65535
- #include <intrins.h>
- #define RdCommand 0x01 //定義ISP的操作命令
- #define PrgCommand 0x02
- #define EraseCommand 0x03
- #define Error 1
- #define Ok 0
- #define WaitTime 0x01 //定義CPU的等待時(shí)間
- sfr ISP_DATA=0xe2; //Flash數(shù)據(jù)寄存器地址(E2h)
- sfr ISP_ADDRH=0xe3; //Flash高字節(jié)寄存器地址(E3h)
- sfr ISP_ADDRL=0xe4; //Flash低字節(jié)寄存器地址(E4h)
- sfr ISP_CMD=0xe5; //Flash命令模式寄存器地址(E5h)
- sfr ISP_TRIG=0xe6; //Flash命令觸發(fā)寄存器地址(E6h)
- sfr ISP_CONTR=0xe7; //ISP/IAP控制寄存器地址(E2h)
- sbit dula=P2^6;//U1鎖存器的鎖存端 000001111111 顯示函數(shù) 11111100000
- sbit wela=P2^7;//申明U2鎖存器的鎖存
- uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,
- 0x39,0x5e,0x79,0x71};
- uchar num;//定時(shí)器要用到
- void ISP_IAP_enable(void); /* ================ 打開 ISP,IAP 功能 ================= */
- void ISP_IAP_disable(void); /* =============== 關(guān)閉 ISP,IAP 功能 ================== */
- void ISPgoon(void); /* ================ 公用的觸發(fā)代碼 ==================== */
- uchar byte_read(unsigned int byte_addr); /* ========= 字節(jié)讀 ============= */
- void SectorErase(unsigned int sector_addr); /* =========== 扇區(qū)擦除 ============ */
- void byte_write(unsigned int byte_addr, unsigned char original_data); /* ==== 字節(jié)寫 ==== */
- void display(); //000033333 顯示函數(shù) 3333300000//
- //數(shù)碼管段選定義 0 1 2 3 4 5 6 7 8 9
- uchar code smg_du[]={0x28,0xee,0x32,0xa2,0xe4,0xa1,0x21,0xea,0x20,0xa0,
- 0x60,0x25,0x39,0x26,0x31,0x71,0xff}; //斷碼
- //數(shù)碼管位選定義
- uchar code smg_we[]={0xef,0xdf,0xbf,0x7f};
- uchar dis_smg[8] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8};
- uchar smg_i = 3; //顯示數(shù)碼管的個(gè)位數(shù)
- sbit dq = P2^4; //18b20 IO口的定義
- sbit pwm = P2^3; //蜂鳴器IO口定義
- bit flag_lj_en; //按鍵連加使能
- bit flag_lj_3_en; //按鍵連3次連加后使能 加的數(shù)就越大了
- uchar key_time,key_value; //用做連加的中間變量
- bit key_500ms ;
- uchar f_pwm_l ; //越小越暗
- uint temperature ; //
- bit flag_300ms ;
- uchar menu_1,a_a ; //菜單設(shè)計(jì)的變量
- uint t_high ,t_low; //溫度上下限報(bào)警值
- /***********************1ms延時(shí)函數(shù)*****************************/
- void delay_1ms(uint q)
- uint i,j;
- for(i=0;i<q;i++)
- for(j=0;j<120;j++);
- /***********************小延時(shí)函數(shù)*****************************/
- void delay_uint(uint q)
- while(q--);
- /***********************數(shù)碼顯示函數(shù)*****************************/
- void display()
- static uchar i;
- i++;
- if(i >= smg_i)
- i = 0;
- P1 = 0xff; //消隱
- P3 = smg_we[i]; //位選
- P1 = dis_smg[i]; //段選
- /***********************18b20初始化函數(shù)*****************************/
- void init_18b20()
- bit q;
- dq = 1; //把總線拿高
- delay_uint(1); //15us
- dq = 0; //給復(fù)位脈沖
- delay_uint(80); //750us
- dq = 1; //把總線拿高 等待
- delay_uint(10); //110us
- q = dq; //讀取18b20初始化信號(hào)
- delay_uint(20); //200us
- dq = 1; //把總線拿高 釋放總線
- /*************寫18b20內(nèi)的數(shù)據(jù)***************/
- void write_18b20(uchar dat)
- uchar i;
- for(i=0;i<8;i++)
- { //寫數(shù)據(jù)是低位開始
- dq = 0; //把總線拿低寫時(shí)間隙開始
- dq = dat & 0x01; //向18b20總線寫數(shù)據(jù)了
- delay_uint(5); // 60us
- dq = 1; //釋放總線
- dat >>= 1;
- /*************讀取18b20內(nèi)的數(shù)據(jù)***************/
- uchar read_18b20()
- uchar i,value;
- for(i=0;i<8;i++)
- dq = 0; //把總線拿低讀時(shí)間隙開始
- value >>= 1; //讀數(shù)據(jù)是低位開始
- dq = 1; //釋放總線
- if(dq == 1) //開始讀寫數(shù)據(jù)
- value |= 0x80;
- delay_uint(5); //60us 讀一個(gè)時(shí)間隙最少要保持60us的時(shí)間
- return value; //返回?cái)?shù)據(jù)
- /*************讀取溫度的值 讀出來的是小數(shù)***************/
- uint read_temp()
- uint value;
- uchar low; //在讀取溫度的時(shí)候如果中斷的太頻繁了,就應(yīng)該把中斷給關(guān)了,否則會(huì)影響到18b20的時(shí)序
- TR1=0; //關(guān)掉中斷
- init_18b20(); //初始化18b20
- write_18b20(0xcc); //跳過64位ROM
- write_18b20(0x44); //啟動(dòng)一次溫度轉(zhuǎn)換命令
- delay_uint(50); //500us
- write_18b20(0xbe); //發(fā)出讀取暫存器命令
- EA = 0;
- low = read_18b20(); //讀溫度低字節(jié)
- value = read_18b20(); //讀溫度高字節(jié)
- EA = 1;
- value <<= 8; //把溫度的高位左移8位
- value |= low; //把讀出的溫度低位放到value的低八位中
- value *= 0.625; //轉(zhuǎn)換到溫度值 小數(shù)
- return value; //返回讀出的溫度 帶小數(shù)
- /*************定時(shí)器0初始化程序***************/
- void time_init()
- EA = 1; //開總中斷
- TMOD = 0X01; //定時(shí)器0、定時(shí)器1工作方式1
- ET0 = 1; //開定時(shí)器0中斷
- TR0 = 1; //允許定時(shí)器0定時(shí)
- menu_1 = 0 ;
- ET1 = 1; //開定時(shí)器0中斷
- TR1 = 1; //允許定時(shí)器0定時(shí)
- /********************獨(dú)立按鍵程序*****************/
- uchar key_can; //按鍵值
- void key() //獨(dú)立按鍵程序
- static uchar key_new;
- key_can = 20; //按鍵值還原
- P2 |= 0x07;
- if((P2 & 0x07) != 0x07) //按鍵按下
- if(key_500ms == 1) //連加
- key_500ms = 0;
- key_new = 1;
- delay_1ms(1); //按鍵消抖動(dòng)
- if(((P2 & 0x07) != 0x07) && (key_new == 1))
- { //確認(rèn)是按鍵按下
- key_new = 0;
- switch(P2 & 0x07)
- case 0x06: key_can = 3; break; //得到k2鍵值
- case 0x05: key_can = 2; break; //得到k3鍵值
- case 0x03: key_can = 1; break; //得到k4鍵值
- flag_lj_en = 1; //連加使能
- else
- if(key_new == 0)
- key_new = 1;
- SectorErase(0x2e00);//擦除扇區(qū)命令 擦2
- byte_write(0x2e00,t_high%256);//重新寫入數(shù)據(jù)命令 把t_high(溫度上限)寫入扇區(qū)
- byte_write(0x2e01,t_high/256);
- byte_write(0x2e20,t_low%256); // 把t_low(溫度下限)寫入扇區(qū)
- byte_write(0x2e21,t_low/256);
- byte_write(0x2e55,a_a); // 把a(bǔ)-a的值寫入扇區(qū)
- flag_lj_en = 0; //關(guān)閉連加使能
- flag_lj_3_en = 0; //關(guān)閉3秒后使能
- key_value = 0; //清零
- key_time = 0;
- key_500ms = 0;
- /****************按鍵處理數(shù)碼管顯示函數(shù)***************/
- void key_with()
- if(key_can == 1) //設(shè)置鍵
- menu_1 ++;
- if(menu_1 >= 3)
- menu_1 = 0;
- smg_i = 3; //數(shù)碼管顯示3位
- if(menu_1 == 1) //設(shè)置高溫標(biāo)志位
- smg_i = 4; //數(shù)碼管顯示4位
- if(key_can == 2)
- if(flag_lj_3_en == 0)
- t_high ++ ; //按鍵按下未松開自動(dòng)加三次
- else
- t_high += 10; //按鍵按下未松開自動(dòng)加三次之后每次自動(dòng)加10
- if(t_high > 990)
- t_high = 990;
- if(key_can == 3)
- t_high -- ; //按鍵按下未松開自動(dòng)減三次
- else
- t_high -= 10; //按鍵按下未松開自動(dòng)減三次之后每次自動(dòng)減10
- if(t_high <= t_low)
- t_high = t_low + 1;
- dis_smg[0] = smg_du[t_high % 10]; //取小數(shù)顯示
- dis_smg[1] = smg_du[t_high/ 10 % 10] & 0xdf; //取個(gè)位顯示
- dis_smg[2] = smg_du[t_high / 100 % 10] ; //取十位顯示
- dis_smg[3] = 0x64; //H
- if(menu_1 == 2) //設(shè)置低溫標(biāo)志位
- if(key_can == 2)
- t_low ++ ; //按鍵按下未松開自動(dòng)加三次
- else
- t_low += 10; //按鍵按下未松開自動(dòng)加三次之后每次自動(dòng)加10
- if(t_low >= t_high)
- t_low = t_high - 1;
- if(key_can == 3)
- t_low -- ; //按鍵按下未松開自動(dòng)減三次
- else
- t_low -= 10; //按鍵按下未松開自動(dòng)加三次之后每次自動(dòng)加10
- if(t_low <= 10)
- t_low = 10;
- dis_smg[0] = smg_du[t_low% 10]; //取小數(shù)顯示
- dis_smg[1] = smg_du[t_low/ 10 % 10] & 0xdf; //取個(gè)位顯示
- dis_smg[2] = smg_du[t_low/ 100 % 10] ; //取十位顯示
- dis_smg[3] = 0x3D; //L
- //****************風(fēng)扇控制函數(shù)***************/
- void fengshan_kz()
- if(temperature >= t_high) //風(fēng)扇全開
- TR1 = 0;
- pwm = 0;
- else if((temperature < t_high) && (temperature >= t_low)) //風(fēng)扇緩慢
- f_pwm_l = 60;
- TR1 = 1;
- else if(temperature < t_low) //關(guān)閉風(fēng)扇
- TR1 = 0;
- pwm = 1;
- /****************主函數(shù)***************/
- void main()
- t_high=byte_read(0x2e01);//程序開始時(shí)讀取EEPROM中的數(shù)據(jù)(讀取上限)
- t_high <<= 8;
- t_high |= byte_read(0x2e00);
- t_low=byte_read(0x2e21);// 程序開始時(shí)讀取EEPROM中的數(shù)據(jù)(讀取下限)
- t_low <<= 8;
- t_low |= byte_read(0x2e20);
- a_a=byte_read(0x2e55);// 程序開始時(shí)讀取EEPROM中的數(shù)據(jù)(讀取下限)
- if(a_a!=22) //防止首次上電時(shí)讀取出錯(cuò)
- t_high=150; //第一次上電溫度上限為15.C
- t_low=120; ////第一次上電溫度下限為12.C
- a_a=22;
- delay_1ms(150);
- P0 = P1 = P2 = P3 = 0xff;
- temperature = read_temp(); //先讀出溫度的值
- delay_1ms(650);
- dis_smg[0] = smg_du[temperature % 10]; //取溫度的小數(shù)顯示
- dis_smg[1] = smg_du[temperature / 10 % 10] & 0xdf; //取溫度的個(gè)位顯示
- dis_smg[2] = smg_du[temperature / 100 % 10] ; //取溫度的十位顯示
- time_init(); //初始化定時(shí)器
- while(1)
- key(); //按鍵程序
- if(key_can < 10)
- key_with(); //設(shè)置溫度上下限
- if(flag_300ms == 1) //300ms 處理一次溫度程序
- flag_300ms = 0;
- if(menu_1 == 0)
- smg_i = 3;
- fengshan_kz(); //風(fēng)扇控制函數(shù)
- void ISP_IAP_enable(void) /* ================ 打開 ISP,IAP 功能 ================= */
- EA = 0; /* 關(guān)中斷 */
- ISP_CONTR = ISP_CONTR & 0x18; /* (0001,1000) **ISP/IAP 控制寄存器復(fù)位*/
- ISP_CONTR = ISP_CONTR | WaitTime; /* 寫入硬件延時(shí) */
- ISP_CONTR = ISP_CONTR | 0x80; /*(10000000) ISPEN=1 在ISPEN(ISP_CONTR.7) =1時(shí),
- (解釋當(dāng)ISPCONTR的最高位=1時(shí)有效,)
- 對(duì)ISP_TRIG (命令觸發(fā)寄存器)先寫入46h,再寫入B9h,ISP/IAP命令才會(huì)生效。 */
- void ISP_IAP_disable(void) /* =============== 關(guān)閉 ISP,IAP 功能 ================== */
- ISP_CONTR = ISP_CONTR & 0x7f; /* ISPEN = 0 */
- ISP_TRIG = 0x00;
- EA = 1; /* 開中斷 */
- void ISPgoon(void) /* ================ 公用的觸發(fā)代碼 ==================== */
- ISP_IAP_enable(); /* 打開 ISP,IAP 功能 第47行有定義*/
- ISP_TRIG = 0x46; /* 觸發(fā)ISP_IAP命令字節(jié)1 (解釋)在ISPEN(ISP_CONTR.7) =1時(shí),
- 再寫入B9h,ISP/IAP命令才會(huì)生效。 */
- ISP_TRIG = 0xb9; /* 觸發(fā)ISP_IAP命令字節(jié)2 */
- _nop_();
- unsigned char byte_read(unsigned int byte_addr) /* ========= 字節(jié)讀 ============= */
- ISP_ADDRH = (unsigned char)(byte_addr >> 8);/* 讀出byte_addr的高八位;
- 如果byte_addr是16位的,就是把byte_addr的高八位
- 賦值給一個(gè)unsigned char類型的變量:ISP_ADDRH*/
- ISP_ADDRL = (unsigned char)(byte_addr & 0x00ff); /* 讀出byte_addr的低八位;*/
- ISP_CMD = ISP_CMD & 0xf8; /* (11111000)清除低3位 */
- ISP_CMD = ISP_CMD | RdCommand; /* 寫入讀命令 */
- ISPgoon(); /* 觸發(fā)執(zhí)行 */
- ISP_IAP_disable(); /* 關(guān)閉ISP,IAP功能 */
- return (ISP_DATA); /* 返回讀到的數(shù)據(jù) */
- void SectorErase(unsigned int sector_addr) /* =========== 扇區(qū)擦除 ============ */
- unsigned int iSectorAddr;
- iSectorAddr = (sector_addr & 0xfe00); /* 取扇區(qū)地址 */
- ISP_ADDRH = (unsigned char)(iSectorAddr >> 8);
- ISP_ADDRL = 0x00;
- ISP_CMD = ISP_CMD & 0xf8; /* 清空低3位 (注釋)清楚后待機(jī)模式,無ISP操作 */
- ISP_CMD = ISP_CMD | EraseCommand; /* 擦除命令3 前面定義過#define EraseCommand 0x03
- (00000011)對(duì)用戶的應(yīng)用程序flash區(qū)及數(shù)據(jù)flash
- 區(qū)扇區(qū)擦除*/
- void byte_write(unsigned int byte_addr, unsigned char original_data) /* ==== 字節(jié)寫 ==== */
- ISP_ADDRH = (unsigned char)(byte_addr >> 8); /* 取出高八位 */
- ISP_ADDRL = (unsigned char)(byte_addr & 0x00ff); /*取出低八位*/
- ISP_CMD = ISP_CMD & 0xf8; /* 清低3位 意思就是將第三位全部清0再在下邊的prgcommand(00000010)
- 進(jìn)行或運(yùn)算得(*****010)*/
- ISP_CMD = ISP_CMD | PrgCommand; /* 寫命令2 (注釋)(*****010)對(duì)用戶的應(yīng)用程序flash
- 區(qū)及數(shù)據(jù)flash區(qū)字節(jié)編程*/
- ISP_DATA = original_data; /* 寫入數(shù)據(jù)準(zhǔn)備 注釋:DATA為數(shù)據(jù)寄存器*/
- ISP_IAP_disable(); /* 關(guān)閉IAP功能 */
- /*************定時(shí)器0中斷服務(wù)程序***************/
- void time0_int() interrupt 1
- static uchar value; //定時(shí)2ms中斷一次
- TH0 = 0xf8;
- TL0 = 0x30; //2ms
- display(); //數(shù)碼管顯示函數(shù)
- value++;
- if(value >= 150)
- value = 0;
- flag_300ms = 1;
- if(flag_lj_en == 1) //按下按鍵使能
- key_time ++;
- if(key_time >= 250) //500ms
- key_time = 0;
- key_500ms = 1; //500ms
- key_value ++;
- if(key_value > 3)
- key_value = 10;
- flag_lj_3_en = 1; //3次后1.5秒連加大些
- /*******************定時(shí)器1用做單片機(jī)模擬PWM 調(diào)節(jié)***********************/
- void Timer1() interrupt 3 //調(diào)用定時(shí)器1
- static uchar value_l;
- TH1=0xff; // 定時(shí)中斷一次
- TL1=0xec; //
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
溫控風(fēng)扇的全部源碼下載:
風(fēng)扇.rar
(4.78 KB, 下載次數(shù): 785)
2017-4-6 02:44 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
