查看: 3512|回復(fù): 4
為什么定義了一個(gè)結(jié)構(gòu)體過后1602上面就有一個(gè)亂碼
26.8后面的亂碼和字符都是定義了一個(gè)結(jié)構(gòu)體過后才有的 ,之前都沒有。
#include <reg52.h>
#include<stdlib.h>
#include<intrins.h>
extern bit Start18B20();
extern bit Get18B20Temp(int *temp);
extern void InitLcd1602();
extern void LcdShowStr(unsigned char *str);
extern void LcdSetCursor(unsigned char addr);
extern void LcdWriteDat(unsigned char dat);
extern void LcdWriteCmd(unsigned char del);
extern void  keyscan();
extern unsigned char key,flag1;
unsigned char a[7];
/**************************************************************就是這個(gè)結(jié)構(gòu)體*****/
struct        _pid{
float SV;//用戶設(shè)定溫度
float PV; //測(cè)量溫度
float KP; //比例常數(shù)
float T;  //PID計(jì)算周期--采樣周期
float TI;        //積分常數(shù)
float TD;         //微分常數(shù)
float EK;  //本次偏差
float EK_1;//上次偏差
float SEK; //歷史偏差之和
float IOUT;//積分輸出
float POUT; //比例輸出
float DOUT;//微分輸出
float OUT0; //0值輸出
float OUT;        //pid輸出
unsigned int  C10ms;//判斷是否滿足PID計(jì)算時(shí)間
unsigned int  pwmcycle;//pwm周期
}PID;
  unsigned char i,e=0;
  unsigned char IntToString(unsigned char *str, int dat);
  unsigned char m;
  unsigned char code table[]={'0','1','2','3','4','5','6','7','8','9', '.','-',':',' ','=','.'};
  bit res;
  int temp;        //讀取到的當(dāng)前溫度值
  int intT, decT;  //溫度值的整數(shù)和小數(shù)部分
  unsigned char len;
  unsigned char str[5];
  unsigned char stt[16] = {"T1:"};
  unsigned char sty[16] = {"T2:"};
  EA = 1;            //開總中斷
  Start18B20();      //啟動(dòng)DS18B20
  InitLcd1602();     //初始化液晶
  LcdWriteCmd(0x0C); //關(guān)閉光標(biāo)閃爍
/*實(shí)時(shí)溫度*/
       /*顯示實(shí)時(shí)溫度標(biāo)識(shí)"T1:"*/
    LcdSetCursor(0x00);
    m = 0;
    while(stt[m] != '\0')
       LcdWriteDat(stt[m]);
       m++;
/*顯示設(shè)定溫度標(biāo)識(shí)"T2:"*/
        LcdSetCursor(0x40);
    m = 0;
    while(sty[m] != '\0')
       LcdWriteDat(sty[m]);
       m++;
     res = Get18B20Temp(&temp);  //讀取當(dāng)前溫度
     if (res)                    //讀取成功時(shí),刷新當(dāng)前溫度顯示
        intT = temp >> 4;             //分離出溫度值整數(shù)部分
        decT = temp & 0xF;            //分離出溫度值小數(shù)部分
        len = IntToString(str, intT); //整數(shù)部分轉(zhuǎn)換為字符串
        str[len++] = '.';             //添加小數(shù)點(diǎn)
        decT = (decT*10) / 16;        //二進(jìn)制的小數(shù)部分轉(zhuǎn)換為1位十進(jìn)制位
        str[len++] = decT + '0';      //十進(jìn)制小數(shù)位再轉(zhuǎn)換為ASCII字符
        LcdShowStr(str);        //顯示到液晶屏上
        Start18B20();
/*設(shè)定溫度*/
           keyscan();
           if(flag1==1)
         if(key<11)      //10以下是數(shù)字顯示部分
               LcdSetCursor(0x43+e++) ;
               LcdWriteDat(table[key]);
               a=table[key];
               i++;
             else if(key==11)
               LcdWriteCmd(0x01) ;         //刪除設(shè)定值
                   e=0;
               for(i=0;i<7;i++)
                    a='0';
             flag1=0;        //鍵盤檢測(cè)標(biāo)志置0進(jìn)行下一次檢測(cè)
/* 整型數(shù)轉(zhuǎn)換為字符串,str-字符串指針,dat-待轉(zhuǎn)換數(shù),返回值-字符串長(zhǎng)度 */
  signed char i = 0;
  unsigned char len = 0;
  unsigned char buf[6];
  if (dat < 0)  //如果為負(fù)數(shù),首先取絕對(duì)值,并在指針上添加負(fù)號(hào)
    dat = -dat;
    *str++ = '-';
    len++;
    do
        {          //先轉(zhuǎn)換為低位在前的十進(jìn)制數(shù)組
     buf[i++] = dat % 10;
     dat /= 10;
    } while (dat > 0);
    len += i;     //i最后的值就是有效字符的個(gè)數(shù)
    while (i-- > 0)   //將數(shù)組值轉(zhuǎn)換為ASCII碼反向拷貝到接收指針上
     *str++ = buf + '0';
    *str = '\0';  //添加字符串結(jié)束符
    return len;   //返回字符串長(zhǎng)度
ID:187588 發(fā)表于 2017-4-10 19:09 | 只看該作者
本帖最后由 a512520a 于 2017-4-10 19:13 編輯
ID:187588 發(fā)表于 2017-4-10 19:10 | 只看該作者
就這個(gè)
ID:187588 發(fā)表于 2017-4-10 19:12 | 只看該作者
就這個(gè)
ID:187588 發(fā)表于 2017-4-10 19:13 | 只看該作者
本帖最后由 a512520a 于 2017-4-10 19:15 編輯
主站蜘蛛池模板: 免费视频a | 久久一区精品 | 亚洲欧洲天堂 | 国产一区不卡 | 国产探花视频在线观看 | 日本毛片在线观看 | 深夜福利免费 | 欧美精品在线播放 | 欧美综合激情 | 日韩成人综合 | 久久免费国产视频 | 大香蕉毛片 | 久久国产小视频 | 欧美网站在线观看 | 国产天堂网 | 久久久久久亚洲 | 色婷av| 成人精品在线 | www4h| 二区三区在线观看 | 中文字幕在线免费看 | 超碰在线国产 | 岛国精品在线播放 | 久久只有精品 | 国产精品免费在线播放 | 日韩在线中文字幕 | 国产日韩av在线 | 亚洲国产精品久久久久久久 | 国产又黄又猛 | 一级毛片黄色 | 国产又粗又猛又黄又爽无遮挡 | av在线视 | 欧美成人精品欧美一级乱黄 | 色综合欧美 | 91av在线免费观看 | 一区二区三区四区五区 | 狠狠干2021| 激情综合色 | 日韩av不卡在线观看 | 特级黄色片 | 国产在线黄色 |
