查看: 3710|回復: 2
基于89C51單片機的可調(diào)倒計時程序
ID:952422 發(fā)表于 2021-7-13 19:52 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
使用 獨立按鍵 數(shù)碼管 定時器 ;
源代碼如下:
#include "reg52.h"
sbit k1=P3^1;
sbit k2=P3^0;
sbit k3=P3^2;
sbit k4=P3^3;
sbit LSA=P2^2;
sbit LSB=P2^3;
sbit LSC=P2^4;
#define plusvalue 30 //每次按鍵增加多少秒,可調(diào)
#define delays 6200
unsigned int times=0;
int seconds=0,seconds_1=0;
unsigned int sec=0;
unsigned int flag=0;
unsigned int wei[8]={0};
unsigned int i;
unsigned char code smgduan[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40,0x00};
/*0x3f  , 0x06 , 0x5b , 0x4f , 0x66 , 0x6d
   0              1              2           3        4     5
0x7d , 0x07 , 0x7f  , 0x6f , 0x77 , 0x7c
   6           7             8             9      A     B
0x39 , 0x5e , 0x79 , 0x71 , 0x00
   C    D        E      F             NULL
void Timer0Init(void)                //10毫秒@11.0592MHz
        TMOD &= 0xF0;                //設(shè)置定時器模式
        TMOD |= 0x01;                //設(shè)置定時器模式
        TL0 = 0x00;                //設(shè)置定時初值
        TH0 = 0xDC;                //設(shè)置定時初值
        TF0 = 0;                //清除TF0標志
        TR0 = 0;                //定時器0開始計時
        ET0=1;
        EA=0;
void delay()                //@11.0592MHz
        unsigned char i, j;
        i = 18;
        j = 235;
        do
                while (--j);
        } while (--i);
void delay1( int a)
while(a--);
void display()
                         LSA=0;LSB=0;LSC=0;P0=smgduan[wei[0]];delay1(10);P0=0x00;
                         LSA=1;LSB=0;LSC=0;P0=smgduan[wei[1]];delay1(10);P0=0x00;
                         LSA=0;LSB=1;LSC=0;P0=smgduan[wei[2]];delay1(10);P0=0x00;
                         LSA=1;LSB=1;LSC=0;P0=smgduan[wei[3]];delay1(10);P0=0x00;
                         LSA=0;LSB=0;LSC=1;P0=smgduan[wei[4]];delay1(10);P0=0x00;
                         LSA=1;LSB=0;LSC=1;P0=smgduan[wei[5]];delay1(10);P0=0x00;
                         LSA=0;LSB=1;LSC=1;P0=smgduan[wei[6]];delay1(10);P0=0x00;
                         LSA=1;LSB=1;LSC=1;P0=smgduan[wei[7]];delay1(10);P0=0x00;
                wei[7]=seconds_1/60/10;
                wei[6]=seconds_1/60%10;
                wei[5]=16;
                wei[4]=seconds_1%60/10;
                wei[3]=seconds_1%60%10;
                wei[2]=17;
                wei[1]=17;
                wei[0]=17;
void caculate()
        seconds=plusvalue*times;
                seconds_1=seconds;
void start()
        if(seconds!=0)
                        TR0=1;
                        EA=1;
                        TR0=0;
                        EA=0;
void stop()
        TR0=0;
        EA=0;
        flag++;
        if(flag%2==0)
                TR0=1;
                EA=1;
                flag=0;
void plus()
        times=times+1;
void cut()
        times=times-1;
void keyscan()
        if(k1==0)
                delay1(delays);
                if(k1==0)
                        start();
                caculate();
        else if(k2==0)
                delay1(delays);
                if(k2==0)
                stop();
        else if(k3==0)
                delay1(delays);
                if(k3==0)
                plus();
                caculate();
        else if(k4==0)
                delay1(delays);
                if(k4==0)
                cut();
                caculate();
        Timer0Init();
                        keyscan();
                        display();
                        if(seconds_1<0)
                        EA=0;
                        for(i=0;i<8;i++)
                                wei[ i]=17;
void Timer0_Routine() interrupt 1 //10ms溢出一次
        unsigned int T0Count;
        TH0 = 0xDC;
        T0Count++;
        if(T0Count==100)
                T0Count=0;
                seconds_1--;
ID:328014 發(fā)表于 2021-7-14 00:09 | 只看該作者
樓主能分享一下原理圖或者介紹下電路連接嗎?
ID:952422 發(fā)表于 2021-7-14 10:41 | 只看該作者
電路的連接如圖
主站蜘蛛池模板: 国产人成一区二区三区影院 | 欧美成人高清 | 国产乡下妇女做爰视频 | 成人毛片在线播放 | 成人免费在线视频观看 | 日韩欧美一级 | 午夜黄视频 | av片在线观看 | www.国产在线 | 97香蕉视频 | 精品毛片一区二区三区 | 成人免费看片39 | av网站免费在线观看 | 欧美日韩国产在线播放 | 亚洲欧美日韩在线 | 欧美国产精品一区二区 | 黄视频网站在线观看 | 欧美性猛交xxxx免费看久久久 | 欧美日韩精品久久久免费观看 | 欧美一级全黄 | 欧美激情视频一区二区三区 | 亚洲视频三区 | 国产福利小视频 | 欧美国产日韩视频 | 综合色在线| 免费的黄色网址 | 免费视频一区二区 | 九色视频丨porny丨丝袜 | 可以免费看的毛片 | 国产h视频 | 日韩欧美在线观看 | 亚洲精品一区二三区 | 日本少妇做爰全过程毛片 | 午夜视频福利 | 亚洲成人毛片 | 日韩激情网站 | 日韩av在线一区二区 | 中文字幕www| 黄视频免费观看 | 99热伊人| 午夜在线观看视频 |
