#include "delay.h"
#include "sys.h"
#include "usart.h"
#include "hcsr04.h"
int main(void)
float length;
delay_init(); //延時函數初始化
uart_init(115200); //串口初始化為115200
HCSR04_Init();
printf("超聲波初始化成功");//檢測超聲波是否初始化
length=gettime();
printf("距離為:%.3f cm\n",length);//打印總的距離
//以上是主函數模塊
#include "hcsr04.h"
#include "delay.h"
u16 msHcCount =0;
void HCSR04_Init(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //使能PB端口時鐘
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13; //PB.13 端口配置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度為50MHz
GPIO_Init(GPIOB, &GPIO_InitStructure); //根據設定參數初始化GPIOB.13
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14; //PB.14 端口配置
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //下拉輸入
GPIO_Init(GPIOB, &GPIO_InitStructure); //根據設定參數初始化GPIOB.14
//定時器TIM3初始化
TIM_TimeBaseStructure.TIM_Period =10000-1; //設置在下一個更新事件裝入活動的自動重裝載寄存器周期的值
TIM_TimeBaseStructure.TIM_Prescaler =7200-1; //設置用來作為TIMx時鐘頻率除數的預分頻值
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //設置時鐘分割:TDTS = Tck_tim
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上計數模式
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根據指定的參數初始化TIMx的時間基數單位
TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE ); //使能指定的TIM3中斷,允許更新中斷
//中斷優先級NVIC設置
TIM_ClearFlag(TIM3,TIM_FLAG_Update);
TIM_ITConfig(TIM6,TIM_IT_Update,ENABLE);
hcsr04_NVIC();
TIM_Cmd(TIM3,ENABLE);
static void opentimerhc()
TIM_SetCounter(TIM2,0);
msHcCount=0;
TIM_Cmd (TIM2,ENABLE);
static void closeimerhc()
TIM_Cmd(TIM2,DISABLE);
void hcsr04_NVIC(void)
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
// NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; //TIM3中斷
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //先占優先級1級
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //從優先級0級
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
NVIC_Init(&NVIC_InitStructure); //初始化NVIC寄存器
void TIM3_IRQHandler(void) //TIM3中斷
if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) //檢查TIM3更新中斷發生與否
TIM_ClearITPendingBit(TIM3, TIM_IT_Update ); //清除TIMx更新中斷標志
msHcCount++;
u32 gettime(void)//時間獲取函數
u32 t=0;
t=msHcCount*1000;
t+=TIM_GetCounter(TIM2);
TIM2->CNT=0;
delay_ms(50);
float hcgetlength(void)
u32 t=0;
int i=0;
float lengthTemp=0;
float sum=0;
while(i!=5)
GPIO_ResetBits(GPIOB,GPIO_Pin_13); //預拉低trig引腳
delay_ms(20);
GPIO_SetBits(GPIOB,GPIO_Pin_13);
delay_ms(20);
GPIO_ResetBits(GPIOB,GPIO_Pin_13);//發出脈沖
while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_14)==0)//等待信號發出,信號發出,計數器置0,同時變為高電平
opentimerhc();
i=i+1;
while(GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_14)==1)//等待信號接收,信號發出時,引腳一直置1
closeimerhc();
t=gettime();
lengthTemp=((float)t*170/1000);
sum=lengthTemp+sum;
lengthTemp=sum/5.0;
return lengthTemp;
這是超聲波模塊
是程序寫錯了嗎?
如果有人能指出錯誤,請私我
