查看: 2868|回復(fù): 0
51 定時器1做時鐘
ID:73477 發(fā)表于 2015-2-10 01:26 | 顯示全部樓層 |閱讀模式
本帖最后由 hutians 于 2015-2-10 01:28 編輯
#include<reg52.h>
#define uchar unsigned char
#define uint unsigned int
sbit dula=P2^6;
sbit wela=P2^7;
sbit lcden=P3^4;
sbit lcdrs=P3^5;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
sbit rd=P3^7;
const uchar table[]=" 2015-02-02 MON";           //15
const uchar table1[]=" 00:00:00";           //9
uchar t0,s1num;
char nian,yue,ri,week,shi,fen,miao;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void write_comm(uchar comm)
        lcdrs=0;
        lcden=0;
        P0=comm;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(uchar date)
        lcdrs=1;
        lcden=0;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void init()
        uchar num;
        dula=0;
        wela=0;
        lcden=0;
        write_comm(0x38);
        write_comm(0x0c);
        write_comm(0x06);
        write_comm(0x01);
        write_comm(0x80);
        for(num=0;num<15;num++)
                write_date(table[num]);
                delay(5);
        write_comm(0x80+0x40+2);
        for(num=0;num<9;num++)
                write_date(table1[num]);
                delay(5);
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
void write_sfm(uchar address,uchar date)   //時分秒
        uchar shi,ge;
        shi=date/10;
        ge=date%10;
        write_comm(0x80+0x40+address);
        write_date(0x30+shi);
        write_date(0x30+ge);
void write_nyr(uchar address,uchar date)  //年月日
        char shi,ge;
        shi=date/10;
        ge=date%10;
        write_comm(0x80+address);
void write_week(char week)
        write_comm(0x80+12);
        switch(week)
                case 1: write_date('M'); delay(5);
                                write_date('O'); delay(5);
                                write_date('N');
                                break;
                case 2: write_date('T'); delay(5);
                                write_date('U'); delay(5);
                                write_date('E');
                                break;
                case 3: write_date('W'); delay(5);
                                write_date('E'); delay(5);
                                write_date('D');
                                break;
                case 4: write_date('T'); delay(5);
                                write_date('H'); delay(5);
                                write_date('U');
                                break;
                case 5: write_date('F'); delay(5);
                                write_date('R'); delay(5);
                                write_date('T');
                                break;
                case 6: write_date('S'); delay(5);
                                write_date('A'); delay(5);
                                write_date('T');
                                break;
                case 7: write_date('S'); delay(5);
                                write_date('N');
                                break;
void keyscan()
        rd=0;
        s1=1;
        if(s1==0)
                delay(5);
                if(s1==0)
                        while(!s1);
                        s1num++;
                        if(s1num==1)
                                TR0=0;
                                write_comm(0x0f);
                                write_comm(0x80+0x40+9);
                        if(s1num==2)
                                write_comm(0x80+0x40+6);
                        if(s1num==3)
                                write_comm(0x80+0x40+3);
                        if(s1num==4)
                        if(s1num==5)
                                write_comm(0x80+9);
                        if(s1num==6)
                                write_comm(0x80+6);
                        if(s1num==7)
                                write_comm(0x80+3);
                        if(s1num==8)
                                s1num=0;
                                write_comm(0x0c);
                                TR0=1;
        if(!s1num==0)
                if(s2==0)
                        delay(5);
                        if(s2==0)
                                if(s1num==1)  //判斷地址指針位置
                                        miao++;
                                        if(miao==60)
                                        miao=0;
                                        write_sfm(9,miao);
                                if(s1num==2)
                                        fen++;
                                        if(fen==60)
                                        fen=0;
                                        write_sfm(6,fen);
                                if(s1num==3)
                                        shi++;
                                        if(shi==24)
                                        shi=0;
                                        write_sfm(3,shi);
                                if(s1num==4)
                                        week++;
                                        if(week==8)
                                        week=1;
                                        write_week(week);
                                if(s1num==5)
                                        ri++;
                                        if(ri==32)
                                                ri=1;
                                        write_nyr(9,ri);
                                        write_comm(0x80+9);
                                if(s1num==6)
                                        yue++;
                                        if(yue==13)
                                        yue=1;
                                        write_nyr(6,yue);
                                        write_comm(0x80+6);
                                if(s1num==7)
                                        nian++;
                                        if(nian==100)
                                        nian=1;
                                        write_nyr(3,nian);
                                        write_comm(0x80+3);
                                while(!s2);        }
                if(s3==0)
                        delay(5);
                        if(s3==0)
                                if(s1num==1)
                                        miao--;
                                        if(miao==-1)
                                        miao=59;
                                        write_sfm(9,miao);
                                if(s1num==2)
                                        fen--;
                                        if(fen==-1)
                                        fen=59;
                                        write_sfm(6,fen);
                                if(s1num==3)
                                        shi--;
                                        if(shi==-1)
                                        shi=23;
                                        write_sfm(3,shi);
                                if(s1num==4)
                                        week--;
                                        if(week==0)
                                        week=7;
                                        write_week(week);
                                if(s1num==5)
                                        ri--;
                                        if(ri==0)
                                        ri=31;
                                        write_nyr(9,ri);
                                        write_comm(0x80+9);
                                if(s1num==6)
                                        yue--;
                                        if(yue==0)
                                        yue=12;
                                        write_nyr(6,yue);
                                        write_comm(0x80+6);
                                if(s1num==7)
                                        nian--;
                                        if(nian==0)
                                        nian=100;
                                        write_nyr(3,nian);
                                        write_comm(0x80+3);
                                while(!s3);
        init();
                keyscan();
void timer0() interrupt 1
        t0++;
                if(t0==18)
                        t0=0;
                        miao++;
                        if(miao==60)
                                miao=0;
                                fen++;
                                if(fen==60)
                                        fen=0;
                                        shi++;
                                        if(shi==24)
                                                shi=0;
                                                ri++;
                                                if(ri==32)
                                                        ri=1;
                                                        yue++;
                                                        if(yue==13)
        yue=1;
        nian++;
        if(nian==100)
        nian=1;
        write_nyr(3,nian);
                                                        write_nyr(6,yue);
                                                write_nyr(9,ri);
                                                week++;
                                                if(week==8)
                                                        week=1;
                                        write_sfm(3,shi);
                                write_sfm(6,fen);
                        write_sfm(9,miao);
相關(guān)帖子
主站蜘蛛池模板: 9l视频自拍九色9l视频成人 | 日本黄色三级视频 | 欧美日韩精品一区二区 | 国产免费无遮挡 | 黄色免费视频网站 | www四虎影院 | 欧美三级韩国三级日本三斤在线观看 | 免费网站黄色 | 中文一区二区 | 国产黄色免费网站 | 一区二区三区在线免费观看 | 97国产精品人人爽人人做 | 一区二区三区四区在线播放 | 国产精品欧美在线 | 欧美色偷偷 | 欧美亚洲在线观看 | 三级视频在线 | 中文字幕麻豆 | 免费一级黄色片 | 国产精品一级 | 国产精品911 | 黄色一级片视频 | 亚洲高清在线播放 | 国产日韩欧美视频 | 一区二区免费在线观看 | 午夜免费看片 | 日韩中文字幕一区二区 | 日本免费毛片 | 伊人2222 | 青青青草视频 | 深夜福利影院 | 中文字幕二区 | 色av吧| 五月婷婷在线视频 | 色综合久久88 | 在线观看国产免费视频 | 一区二区三区四区av | 日本精品视频在线观看 | 国产精品一 | 91爱爱网站| 亚洲成人免费在线 |
