查看: 5160|回復(fù): 3
AVR 單片機初值計算
ID:83710 發(fā)表于 2015-6-24 21:25 | 顯示全部樓層 |閱讀模式
使用芯片 AT Mega16     外部晶振 4.00MHz
定時器1   (16位定時器)寄存器 TCCR1B = 0x04 設(shè)定 256預(yù)分頻
要利用定時器定時1秒
1,4000000 / 256 = 15625    說明定時器每當(dāng) 1/15625 秒 就會觸發(fā)一次中斷
2,65535 - 15625 = 49910    計算出要累加多少次才能在1秒后出發(fā)定時器1的溢出中斷
3,49910 <==> C2 F6           將計算后的值換算成16進(jìn)制
4, TCNT1H = 0xC2 ;             對寄存器賦值
       TCNT1L = 0xF6 ;
例如用16位定時器TIMER1,4MHZ晶振,256分頻,100ms定時,如何求得初值賦給TCNT1?
65536-(4M/256)*0.1=63973.5
其中,4M是晶體頻率,0.1是定時時長單位秒。
對于8位的定時器
T=(2^8-計數(shù)初值)*晶振周期*分頻數(shù)=(2^8-計數(shù)初值)/晶振頻率*分頻數(shù)
計數(shù)初值=2^8-T/晶振周期/分頻數(shù)=2^8-T*晶振頻率/分頻數(shù)
因為AVR一指令 一周期
相關(guān)帖子
ID:690448 發(fā)表于 2020-11-19 18:52 | 顯示全部樓層
ICC-AVR application builder  點幾下鼠標(biāo)就可完成
推薦大家試一試
  1. //ICC-AVR application builder : 2020/11/19 18:50:34
  2. // Target : M16
  3. // Crystal: 4.0000Mhz
  4. #include <iom16v.h>
  5. #include <macros.h>
  6. void port_init(void)
  7. {
  8. PORTA = 0x00;
  9. DDRA  = 0x00;
  10. PORTB = 0x00;
  11. DDRB  = 0x00;
  12. PORTC = 0x00; //m103 output only
  13. DDRC  = 0x00;
  14. PORTD = 0x00;
  15. DDRD  = 0x00;
  16. }
  17. //TIMER1 initialize - prescale:256
  18. // WGM: 0) Normal, TOP=0xFFFF
  19. // desired value: 1Sec
  20. // actual value:  1.000Sec (0.0%)
  21. void timer1_init(void)
  22. {
  23. TCCR1B = 0x00; //stop
  24. TCNT1H = 0xC2; //setup
  25. TCNT1L = 0xF7;
  26. OCR1AH = 0x3D;
  27. OCR1AL = 0x09;
  28. OCR1BH = 0x3D;
  29. OCR1BL = 0x09;
  30. ICR1H  = 0x3D;
  31. ICR1L  = 0x09;
  32. TCCR1A = 0x00;
  33. TCCR1B = 0x04; //start Timer
  34. }
  35. #pragma interrupt_handler timer1_ovf_isr:iv_TIM1_OVF
  36. void timer1_ovf_isr(void)
  37. {
  38. //TIMER1 has overflowed
  39. TCNT1H = 0xC2; //reload counter high value
  40. TCNT1L = 0xF7; //reload counter low value
  41. }
  42. //call this routine to initialize all peripherals
  43. void init_devices(void)
  44. {
  45. //stop errant interrupts until set up
  46. CLI(); //disable all interrupts
  47. port_init();
  48. timer1_init();
  49. MCUCR = 0x00;
  50. GICR  = 0x00;
  51. TIMSK = 0x04; //timer interrupt sources
  52. SEI(); //re-enable interrupts
  53. //all peripherals are now initialized
  54. }
  55. //
  56. void main(void)
  57. {
  58. init_devices();
  59. //insert your functional code here...
  60. }
admin + 50 回帖助人的獎勵!
ID:739227 發(fā)表于 2020-4-27 19:30 | 顯示全部樓層
非常好!不錯!非常感謝樓主
ID:808608 發(fā)表于 2020-10-10 14:23 | 顯示全部樓層
非常好!不錯!非常感謝師傅
主站蜘蛛池模板: 91看片看淫黄大片 | 香蕉视频在线观看网站 | 久久99视频| 一区二区免费看 | 久久免费精品 | 国产一级片在线播放 | 蜜桃av一区 | 精品黄色片 | 成人在线视频免费观看 | 欧美专区在线观看 | 欧美日韩国产中文 | 狠狠网 | 日韩午夜在线观看 | 亚洲精品一区二区三区在线 | 免费看黄网 | 六月婷婷综合 | 91小视频在线观看 | 在线观看黄色网 | 99视频网站| xxxxx国产| 99精品在线 | 97视频国产| 国产黄色精品视频 | 一级黄色片免费看 | 日本免费高清 | 中文字幕在线资源 | 成人aaa| 亚洲欧美日韩在线 | 色吧综合 | 精品一区二区三区免费毛片 | 日本少妇做爰全过程毛片 | 欧美一级视频 | 电家庭影院午夜 | 免费网站观看www在线观 | 久草资源网 | 日韩免费视频一区二区 | 第一福利视频 | 中文字幕久久久久 | 五月婷丁香 | 成人激情综合 | 亚洲欧美日韩另类 |
